10-07-2012, 10:11 AM
#70021 |
Oddometer: 290
Fun With Carbon Fiber
Good morning everyone!!
A month or so back I decided that I wanted to recreate all the body parts of my DR650 with carbon fiber parts. I started a thread to share my progress learning how to do composite work and making the pieces for my DR. The last part that I will make will be a Dakar style fairing with a dash to hold all the goodies that we need on our bikes. Lots of people have posted greats tips and tricks on the thread and I've included a great resource page to help others get started. Follow along and if you're interested in making carbon fiber parts for your DR, do it! It's really easy. Fun With Carbon Fiber Teaser Pic. You can find many more in the thread...
10-07-2012, 10:21 AM
#70022 | ||
Oddometer: 2,542
http://www.advrider.com/forums/showthread.php?t=634749 Quote:
2004 DR650: 46,358 miles of ![]() ER70S-2 screwed with this post 10-07-2012 at 10:27 AM |
10-07-2012, 02:33 PM
#70023 | |
Oddometer: 25
Now What?
So, will this enzyme additive work its way out after a couple tanks or do I need to drain the fuel? I added it to one tank. I've refueled only once so far but did not add any more startron. It is still not running well in first gear or on start up. Thanks again. |
10-07-2012, 04:05 PM
#70024 | |
Dual Sport Addict
Oddometer: 987
I just got a Seat Concepts Tall foam kit and it is awesome! It made room for my knees and is very comfortable. There customer service is excellent. I called and talked to one of the owners who basically told me I could have any cover option I could dream up for $160 with free shipping for mentioning ADV. I got a carbon top with gripper sides on a tall foam. The install was a breeze and if you don't like how it turns out you can always pull the staples and do it over.
2011 DirtRoad650 http://i838.photobucket.com/albums/z...mping12182.jpg '98 DR 350 http://i838.photobucket.com/albums/z...t/Photo280.jpg '99 DR 650. Sold. |
10-07-2012, 04:12 PM
#70025 | ||
Oddometer: 1,110
Start the engine and warm it up. Set the idle CO to 3-4%. Set the idle speed to 1500 rpm. If you don't have a way to measure CO%, lower the idle speed below the factory spec. Starting from a setting that is known to be lean (1-1/2 turns is likely but not guaranteed to be), adjust the fuel screw to obtain the highest idle speed. Adjust to 1/8 - 1/4 turn richer than that. Then, adjust the idle speed back to 1500 rpm. Quote:
Put some tape on the throttle housing and the edge of the grip. Mark zero throttle with a sharpie. This is best done with the engine idling, so you can tell when the slack in the cable has just been taken up. Turn off the engine and mark wide open. Now take a tape measure (metric works best in my opinion) and measure the length of the arc. Put a mark at the mid point. Duplicate this procedure to mark the mid-point between here and zero throttle opening to get 1/4 open. Repeat for 1/8 and 1/16 openings. With the help of the marks, determine precisely during what throttle opening(s) it misbehaves. Don't have an accident trying to look at the marks while riding. If you do, I'm not responsible! Regards, Derek |
10-07-2012, 05:20 PM
#70026 |
Asperger
Oddometer: 2,043
To what is the front axle supposed to be torqued? I just r/r my front tire and don't have my manual to let me know the torque of the axle or the four axle nuts. I think the rear was around 70 - 75...but I can't remember the front. Thanks.
http://breakingbooks.wordpress.com http://www.kenmarshallmetalworks.com/ 2011 DR650, Fly Aero tapered bars, Race Tech front springs/emulators, RT rear spring/shock shaft assy, BarkBusters, MT21s, 14/43T, etc I may not be Rainman, but I'm not stupid eighter. Like Bartek on a taco. |
10-07-2012, 05:25 PM
#70027 | |
ultra runner
Oddometer: 5,857
sounds good, I will look this up too. :()) Im 6'2" so I would like a tall seat.
greg Quote:
10-07-2012, 06:11 PM
#70028 | |
Oddometer: 1,597
Clarke's second law of Egodynamics: "For every expert, there is an equal and opposite expert." - Jasper Fforde www.procycle.us - Everything for your DR650 and lots of other great stuff! DR900 Big Bore Stroker buildup |
10-07-2012, 06:18 PM
#70029 |
human
Oddometer: 1,144
Since I tend to ride to far out of the way places that are devoid of fuel stops, I REALLY do need every last drop of gas in my Safari tank. So my question for those of you that have done this mod to the carb, is it REALLY as easy as the video shows? Is there a special "trick" to not breaking off that elbow that the video doesn't show? I don't own a bench vice and because of my lack of mechanical skill, would rather not remove the carb.
Thanks, Canoli
Latest Ride Reports: Dumb & Dangerous Down Under: Rd to Santa Teresa They Don't All End Well..Do They? Dumb & Dangerous Down Under Dumb & Dangerous (Asia Series Finale) |
10-07-2012, 07:41 PM
#70030 | |
Oddometer: 1,640
Others have had no problems. Good luck. |
10-07-2012, 07:48 PM
#70031 | |
Oddometer: 269
"To me the trail is calling! The old trail - the trail that is always new." Matthew Alexander Henson "It's not the destination. It's the journey." Me |
10-07-2012, 07:50 PM
#70032 | |
Oddometer: 269
#70033 |
Procrastinators
Oddometer: 5,779
My experience as well. I gave up and lived with it the way it is.
Want to know more about the Garmin Montana? See the Wisdom and FAQ Thread. "Don't play a lute to a cow" (Old Chinese Idiom) "The motorcycle, being poorly designed for both flight and marine operation, sustained significant external and internal damage," police noted. |
10-07-2012, 08:19 PM
#70034 |
Oddometer: 1,110
10-07-2012, 09:50 PM
#70035 | |
Oddometer: 214
Currently riding DR650 (2011) Mods: Manrack, ebay 48 litre top box, grind header pipe; B&B bash plate; bigger/better tool compartment (pvc pipe) - Screens For Bikes Windscreen, TM40 Pumper Carb, Safari Tank, Seat Concepts, Oxford Heater Grips, Highway Pegs, Wolfman Expidition bags and racks
