Old 10-09-2012, 10:50 AM   #70066
Ren20
Finding Touge
Oddometer: 96
thanks for the tip. I already bought it. My uncle picked it up. uncle said the bike looks excellent. The seller was very nice as well. I won't be able to see it until the weekend.
Here's the picture.
Originally Posted by Adv Grifter View Post
Could be a good deal if that mileage is true. So easy to disconnect ODO.
Sadly, many fudge ODO readings.
Try to find a good mechanic to come with you to check bike out. Have a close listen and nice test ride. Sound can tell you a lot on a DR650. Listen for changes from Cold to Hot. Look at oil, shift through gear box.
Check underside for off road damage (linkage, case, bash plate, underside of swing arm, fork ends ... all can show damage from off road use/abuse)
chances are good its a great deal. Best!
Ren20 is offline   Reply With Quote
Old 10-09-2012, 10:58 AM   #70067
mud390
mud390's Avatar
Oddometer: 161
Wanting to get everyone's thoughts on a DR650 I'm looking at buying. The bike is a 2006, single owner, with just over 8000 miles. Has a full FMF setup, TM40 carb, brand new set of 17 supermoto wheels with brand new tires, new Trail Tech vapor, new 520 chain and sprockets (stock gearing), extra fork, dirt wheels (rear hub is trashed), 320mm front rotor, stainless brake lines, and all the stock parts. Bike is real clean and well taken care of. The guys is asking $3000 for it. Thoughts?
mud390 is offline   Reply With Quote
Old 10-09-2012, 11:01 AM   #70068
neo1piv014
ADV in training
Oddometer: 610
Jump all over it. Assuming you want the supermoto setup (which is awesome), that's every awesome mod you'd want to do besides the big bore kit.
_________________________
Ride videos
'01 DR650
"The impossible often has a kind of integrity which the merely improbable lacks."
neo1piv014 is offline   Reply With Quote
Old 10-09-2012, 11:18 AM   #70069
isaac004
isaac004's Avatar
Oddometer: 402
Originally Posted by Feelers View Post
Hey Isaac!
I love how my intiminators work, so I'm hoping to help you fix yours and experience the goodness!
Because I am a nerd, I did a bunch of research on your intiminator fork clunking. I am pretty positive I know what's causing that clunk, and probably the lack of rebound. Essentially, the intiminator is floating off its seat on top of the damper rod due to pressure overwhelming the spring during the compression stroke and when the downward movement of the fork tube stops, the intiminator gets pushed down by the spring against the damping force until it contacts its seat. Hopefully, that makes sense.
So, how can you correct it?
There are 3 possibilities:
First, and most lame is defective valving inside the intiminator. We'll skip that for now because a replacement is the only solution. I think this is also unlikely.
Second is spring rate. I'm not sure which springs you are using - whether stock or aftermarket, but since the spring rate is sort of being overpowered by the damping rate, it's possible that using stiffer springs might help. Adding more preload to your springs also might help. However, the intiminators are designed to be used with the stock springs I'm pretty sure, so the spring rate should not be the issue. I wouldn't swap springs just as an experiment...
Now for the most likely culprit. I've heard that these intiminators are pretty sensitive to oil viscosity, and they are designed and tuned at the factory using Amsoil 5WT fork fluid. When I installed my intiminators, I was very careful to find the best alternative to the amsoil. WT has almost nothing to do with viscosity.
Oil........................Viscosity @ 40degC................Viscosity @ 100degC............Viscosity Index
Amsoil #5..................5.7........................... ................4.4............................... ..............210
Maxima 5wt..............15.9............................. ............3.5................................... ..........150
Your fork oil will typically be nearer to the 40degC mark, so that is the main number to look at. Your viscosity (resistance to flow) is triple the design viscosity and likely the reason the intiminators are having problems flowing the oil fast enough. Amsoil has an unusually low viscosity somehow.
You can select a better oil from the chart at the bottom of this page:
http://www.peterverdone.com/archive/lowspeed.htm
FWIW, I used Torco RFF 5 with a 40degC viscosity of 10.75 which works well. I bought it because of price/availability, but the damping at high speed is a bit harsh. It's still much better than stock, but the Amsoil #5 would almost certainly be the best.
Thanks for all of the tips!
I am using stock springs with some preload...I have not measured it, but I do have to compress the spring about 1 inch to get the fork caps to start engaging the threads.
You make a very good point about the oil, although Amsoil's webpage says the following (http://www.amsoil.com/storefront/stl.aspx):
Kinematic Viscosity @ 100°C, cSt (ASTM D-445)
4.4
Kinematic Viscosity @ 40°C, cSt (ASTM D-445)
15.7
So to correct your chart, it would read as follows:
Amsoil #5..................15.7.......................... .................4.4.............................. ...............210
When I called the Ricor guys up in Nevada, they said that if Amsoil is not available, Maxima would be a very good alternative. The kinematic viscosities are very similar. Your #3 theory does make sense, although I still think there is some physical binding since the fork does not want to return to normal ride height at all. If the oil was too thick, it should rebound back to normal ride height, just very slowly.
I think the Ricor unit still might be defective. Though I still may also buy some Amsoil #5 fork oil if I can track some down.
Thank you for the insight though, I enjoy the discussion going on here.
A Father and Son Trip Down the Great Divide: http://www.advrider.com/forums/showthread.php?t=606301
A Father and Son Trip Through Death Valley: http://www.advrider.com/forums/showthread.php?t=869090
BMW F800GS, Yamaha WR250R, Suzuki DR650
isaac004 is offline   Reply With Quote
Old 10-09-2012, 12:01 PM   #70070
Escaped
Escaped's Avatar
Oddometer: 265
He already bought the bike and it looks great in the photos.
Hey for a story I read somewhere -
This guy bought a used motorcycle with very low miles and after buying he said to himself "I really took advantage of that seller, what an astute buyer I am!"
Well he had the bike a few years and really racked up the miles. It was time to sell the bike and he told himself "There are too many miles on this bike to get a good price, I will just turn back the OD so I can get a better deal, what an astute seller I am going to be!"
Well he took apart the speedometer to get at the OD and found a note. The note said "Oh No Not Again".
DR650 - Living the Dream!
Escaped is offline   Reply With Quote
Old 10-09-2012, 12:25 PM   #70071
DockingPilot
Hooked Up and Hard Over
DockingPilot's Avatar
Oddometer: 7,461
Acerbis tank and available fuel to the engine
Wow, I have the Acerbis 5.3 gal tank. Well I just had it trucked home from California using Allied after my 2,600 mile offroad trip out there. Last Friday the truck arrive with all the bikes. I start mine using the ON position of the petcock. She stumbles on idle, I swithc to reserve, she lights up.
I think to myself, I know I had a few gallons in there when I dropped the bike off in Reno wtf ?
I baby it to the Shell 4 miles from my house. She drinks 5.2..something gals !
So Im making 2 points.
1. For the 1st time Allied has drained the gas tanks or the driver was simply stealing it, as they have never done that before and I have used them many times.
2. You can get just about all the usable fuel out of that tank before you'll push.
Frank Reinbold
"Every bike I ever had, was the best bike I ever had, when I had it"
*2010 FOREVER WEST*
NEW ENGLAND AND CANADA OFFROAD F800GS
14 DAY IDAHO ADVENTURE KTM 950
TRANS AM TRAIL WEST
TRANS AM TRAIL VID CLIP
THE DEAN OF WESTERN ADVENTURE ROUTES
DockingPilot is offline   Reply With Quote
Old 10-09-2012, 12:37 PM   #70072
Feelers
Oddometer: 181
Hahahaha.....The amsoil publication that I got 5.7 from must have erroneously left off a 1. Nuts! So much for that theory! 15.7 does make a heck of a lot more sense.... Your video does sound exactly like the intiminator is floating above it's seat though.... I guess you should try to poke around at the intiminator and see if any of the passages are blocked or the valves are sticky. Maybe clean it up? Maybe take it apart? Maybe the rebound circuit is blocked or something....
Feelers is offline   Reply With Quote
Old 10-09-2012, 12:38 PM   #70073
procycle
procycle's Avatar
Oddometer: 1,607
Check to see that all that gas isn't in the crankcase with the oil.
Clarke's second law of Egodynamics: "For every expert, there is an equal and opposite expert." - Jasper Fforde
www.procycle.us - Everything for your DR650 and lots of other great stuff!
DR900 Big Bore Stroker buildup
procycle is offline   Reply With Quote
Old 10-09-2012, 12:46 PM   #70074
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 6,782
OK, another update here.
I was trying to avoid just straight up removing them, but I figured it was worth a shot. So today I had a free hour and decided to pull out the Intiminators to see how the fork action is. I did not bother to add more oil (as the oil height dropped), add preload (to keep the same preload I should add around 3/4" extra in PVC pipe, or bump the oil viscosity up (with the Intiminators removed I should go back up to around 10 wt, as Ricor recommended a lower 5 wt). I will do these things later.
The fork action has pretty much returned to normal, in regards to no more excessive binding, easier to compress, and it rebounds back to normal ride height without me having to "pull" it up.
I'm using 5mm of preload and no problems with stiction or returning to full height.
What spacers were you running?
Ricor recommend running the stock spacers, uncut.
Easier to compress without the Intiminators? It should be, the anti-dive is one of the selling points.
NordieBoy is offline   Reply With Quote
Old 10-09-2012, 12:54 PM   #70075
DockingPilot
Oddometer: 7,461
No, I had the petcock off of course. I also am certifiable when it come to oil. I check the level constantly and changed it immediately after getting back from the Shell station and warming it up. It was right on the money level wise before I pulled the drain plug.
Magnetic of course.......
My buddies Super Enduro was also drained dry.
Frank Reinbold
*2010 FOREVER WEST*
TRANS AM TRAIL WEST
Old 10-09-2012, 12:59 PM   #70076
isaac004
isaac004's Avatar
Oddometer: 402
Yes, I will probably take it apart and try and clean it/inspect it.
I'm running some home made PVC pipe spacers, about 1" tall (or roughly the same height as the fork caps) if I recall correctly from memory.
Easier to compress and rebound now. When I compressed with Intiminators, it clunked and felt stuck at the bottom, requiring some assistance to pull the fork up through its rebound stroke.
I'm thinking it's also possible the finish on the inside of my fork legs is not as precise or the exact diameter as most of the forks out there, which is causing some binding. I read one story about someone purchasing Intiminators for a bike that was not too common, and due to too much variation in the fork tube ID, Ricor said they could not make any off the shelf as they could not get a lock on the dimensions. They would instead require an actual ID measurement to make them.
Old 10-09-2012, 01:01 PM   #70077
isaac004
isaac004's Avatar
Oddometer: 402
There is a rule that the tank must be less then half full, so maybe they did drain it some...but then just decided to go all the way.
Old 10-09-2012, 01:10 PM   #70078
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 5,400
That is really good to know. My next tank will be the Acerbis!
I wonder if the Acerbis will expand like the IMS does? My so called 4.9 IMS now takes 5.4 gallons once emptied of every drop of fuel ... BUT it can only really use about 4.5 gallons before running out when on reserve. You can tip her over and get a bit more, but that's a last ditch effort, maybe worth 10 to 15 miles further.
Adv Grifter is online now   Reply With Quote
Old 10-09-2012, 03:01 PM   #70079
GaThumper
Road Less Traveled
GaThumper's Avatar
Location: Thumpin' in North GA - headin' for the Smokys
Oddometer: 457
Here's the picture.
Nice!
Dirtly: 2009 Suzuki DR650SE Road Sofa: 2001 Yamaha (ad)Venture 1300
Dirtlier: 1999 Suzuki DR350SE Old Sport: 1979 Suzuki GS1000E
1996 Suzuki Intruder 1400 (for sale) 1987 Yamaha TT600 (for sale)
GaThumper is offline   Reply With Quote
Old 10-09-2012, 03:52 PM   #70080
ADVwanaB
ADVwanaB's Avatar
Oddometer: 463
Here's the picture.
Is that a spare stock tank on the right? it looks larger than what is on the bike in the background,, must be a figment of my imagination.
2009 KLX351s (RED)
2003 DR650 (BLUE)
ADVwanaB is online now   Reply With Quote
Times are GMT -7.   It's 08:02 PM.
