Old 10-14-2012, 08:46 PM   #70081
Ren20
Finding Touge
Oddometer: 111
I have a rm250 1990s Donor bike. Almost complete bike without the cylinder head and seat. Everything else is there. USD forks, bigger rear wheels(19" ??) etc.
I am wondering what kind of parts I could fit onto the dr650. Is it even worth it?
Is it a rm250 by the way? :)
Ren20 screwed with this post 10-14-2012 at 09:52 PM
Ren20 is offline   Reply With Quote
Old 10-14-2012, 08:53 PM   #70082
sagebrushocean
Harris's hawker
sagebrushocean's Avatar
Oddometer: 180
780 for sale in Seattle area
No affiliation, but I might give this one a test ride.
http://seattle.craigslist.org/skc/mcy/3303257537.html
2008 DR650SE supermoto
2009 CRF230M
sagebrushocean is offline   Reply With Quote
Old 10-14-2012, 09:20 PM   #70083
TrophyHunter
Oddometer: 2,192
Originally Posted by AJxr View Post
this is what i am after! i have a fresh set of mt21s mounted with heavy duty tubes. do you have any gps tracks or maps/guides. looking to make the most of my time out there
http://www.dualsportmaps.com/
Ck dsm for tracks. Strega and Crawdaddy on ADV have some tracks up there. We did the X-Plane ride http://dualsport-sd.com/forums/index...__1#entry35945 a few years ago and a lot of our local group spends time up there.
I missed the Utah trip a week or so ago. http://dualsport-sd.com/forums/index...-of-utah-1012/
Enjoy!
Ren20 - that thing looks like it did all 7700 miles in a climate controled garage! Nice.
2005 DR650 '07 WR450
2013 HD Road King '73 Hodaka Wombat
"It's a small amount of gas, but it represents a long walk" My Dad...
TrophyHunter is offline   Reply With Quote
Old 10-14-2012, 09:36 PM   #70084
neo1piv014
ADV in training
Oddometer: 619
I've always wanted to try out the DR with the big bore kit and a TM40 carb just to see what kind of a difference it makes. You'll have to tell us how the test drive goes
_________________________
Ride videos
'01 DR650
"The impossible often has a kind of integrity which the merely improbable lacks."
neo1piv014 is offline   Reply With Quote
Old 10-14-2012, 09:52 PM   #70085
BergDonk
BergDonk's Avatar
Oddometer: 3,467
Presumably the front end is bolt on. Probably pass on the 19" rear. Front brake may be a challenge. Go for it.
shed time IS quality time
BergDonk's DR650 BergDonk's XT1200Z
BergDonk is offline   Reply With Quote
Old 10-14-2012, 10:12 PM   #70086
doug s.
Oddometer: 1,317
yes, the usd front end should be a bolt-on. i bolted an rm125 usd front end on to mine. i upgraded the springs to race tech... mine was from a mid-2000's bike, but the front end looks like yours...
doug s.
doug s. is online now   Reply With Quote
Old 10-14-2012, 10:17 PM   #70087
Ren20
Finding Touge
Oddometer: 111
ah. Thanks for the info.
Now, that the RM is older model. I am wondering if the front suspension is better than a newer model DR650.
Dual sport is all new to me. And I have been reading everything about dr650. I rode around 90 miles on Saturday. The Suspension felt fine. tho it was all freeway. I am a lite rider at 155 lbs.
I think the brake definite have rooms for improvement. The front rotor on the RM is significantly smaller. I could imagine the brake would be worse after the swap.
Ren20 screwed with this post 10-14-2012 at 10:45 PM
Old 10-14-2012, 10:23 PM   #70088
doug s.
Oddometer: 1,317
I think the brake definite how rooms for improvement. The front rotor on the RM is significantly smaller. I could imagine the brake would be worse after the swap.
i'd think that, w/a proper spring for your weight, the front end of your mr will still be a lot better than the stock dr front end. i agree, the brakes will need an upgrade. i am planning on doing a 320mm conwersion; they're awailable for the rm's, and include the offset bracket needed. caliper needs no changing; my dr caliper works w/the stock rm front end/brakes...
oh, sst brake line is also a good upgrade, even if you keep the stock dr front end/brake rotor......
doug s.
doug s. screwed with this post 10-14-2012 at 10:25 PM Reason: sst brake line mention
Old 10-14-2012, 10:24 PM   #70089
sagebrushocean
Harris's hawker
Oddometer: 180
A braided stainless front brake line will make a world of difference if all the other stock bits (pads, rotor, caliper, master cylinder) are in good shape.
2009 CRF230M
Old 10-15-2012, 06:28 AM   #70090
disconnected
anti click
disconnected's Avatar
Oddometer: 7,123
Howdy again folks, I have a quick question. I received my Acerbis Tank and went to put it on. On the stock tank there where two hoses, one connected to the bottom left of the carb and the other connected to the top right-ish section.
The Acerbis only has one outlet, was the second hose on the stock tank a breather hose?
Thanks,
Greg
IBA # 47004
disconnected is online now   Reply With Quote
Old 10-15-2012, 06:43 AM   #70091
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,593
Thanks,
Greg
The hose to the top of the carb is a vacuum which triggers the automatic fuel tap to flow fuel. If you're using a gravity feed with only one hose, plug the vacuum fitting on top of the carb.
Old 10-15-2012, 06:50 AM   #70092
disconnected
anti click
Oddometer: 7,123
ahh okay.. any hints on what to plug it with?
Thanks,
Greg
IBA # 47004
Old 10-15-2012, 06:59 AM   #70093
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,593
Thanks,
Greg
There's usually a little rubber plug which comes with the tank/tap. I figure most people put that over the vacuum fitting but I left the hose on the carb fitting and stuffed the rubber plug into the free end of the hose, effectively plugging it. This way if I ever need a piece of tube, there's a handy one right there.
Old 10-15-2012, 07:03 AM   #70094
disconnected
anti click
Oddometer: 7,123
Okay, great. Thanks for the help. The 5.3 Natural tone Acerbis changes the look of the bike to.... SWEET!....
Greg
IBA # 47004
Old 10-15-2012, 07:07 AM   #70095
Eggsontoast
Eggsontoast's Avatar
Oddometer: 66
Wicked
Just a thought, has anyone tried to fit the XTZ660's front fairing and tank assembly on to a DR? Pat
La Moto, c' est une aventure qui mene jusqu' au bout du monde...
Eggsontoast is offline   Reply With Quote
Times are GMT -7.   It's 08:59 AM.
