Old 10-15-2012, 07:07 AM   #70096
Eggsontoast
Eggsontoast's Avatar
Oddometer: 66
Wicked
Just a thought, has anyone tried to fit the XTZ660's front fairing and tank assembly on to a DR? Pat
La Moto, c' est une aventure qui mene jusqu' au bout du monde...
Eggsontoast is offline   Reply With Quote
Old 10-15-2012, 07:15 AM   #70097
BlueLghtning
Riding is my passion
BlueLghtning's Avatar
Oddometer: 4,981
Originally Posted by greer View Post
Westley's Bleache White (tire/whitewall cleaner from Walmart) worked very well on a white tank I had. I soaked paper towels in the Westley's and left them draped on the tank overnight. Soak them again the next morning if you need to.
Sarah
Originally Posted by Sierra Thumper View Post
Thanks for the info Sarah I almost bought some of that Bleache White when I was in Walmart the other day, but after reading the label it made me a little nervous that it might damage or streak the tank, and damage the paint and other stuff on my bike if I wasn't super careful.
Maybe I ought to pull the tank off so I can really soak it good...
Soft Scrub with bleach also works very well on white tanks. I had a white Safari Tank on my Husky and it easily took off the GA Red clay that had stained the tank.
BlueLghtning - Follow me on my SPOT Messenger
Mine: 09 DL650, 08 WR250R,
Hers: 07 Ninja 650R, 13 CRF250L,
Smugmug Pics - Save $5 <-- Click Here
BlueLghtning is offline   Reply With Quote
Old 10-15-2012, 07:47 AM   #70098
neo1piv014
ADV in training
Oddometer: 619
That'd be cool looking. It'd probably be more expensive trying to fab that up than just buying a custom fairing kit designed for it though.
_________________________
Ride videos
'01 DR650
"The impossible often has a kind of integrity which the merely improbable lacks."
neo1piv014 is offline   Reply With Quote
Old 10-15-2012, 10:35 AM   #70099
motolab
motolab's Avatar
Oddometer: 2,520
Originally Posted by disconnected View Post
ahh okay.. any hints on what to plug it with?
Use 13508-17C00 CAP in conjunction with 13671-05A40 CLIP, or install 13502-12D00 COVER, DIAPHRAGM in place of your existing one.
Regards,
Derek
motolab is offline   Reply With Quote
Old 10-15-2012, 12:50 PM   #70100
disconnected
ultra runner
disconnected's Avatar
Oddometer: 6,924
Regards,
Derek
IBA # 47004
disconnected is online now   Reply With Quote
Old 10-15-2012, 01:06 PM   #70101
Lil' Steve
PussyWagon™ Chauffer
Lil' Steve's Avatar
Oddometer: 3,947
Suzuki part #'s for a rubber vacuum cap and small spring clamp that will fit over where the vaccum hose is now. Or the cover which has no vacuum port. Your local auto parts store should have an assortment of vacuum caps/plugs for a couple of bucks.
Steve
13 PCX150, 07 KLX250S w/300 kit, 05 DR650SE, 01 FZ-1
99 VFR800 w/870 kit, 96 GPz1100, 87 CH250
Lil' Steve is offline   Reply With Quote
Old 10-15-2012, 01:09 PM   #70102
disconnected
ultra runner
Oddometer: 6,924
I just thought the other guy was picking on me..
IBA # 47004
Old 10-15-2012, 01:12 PM   #70103
Lil' Steve
Lil' Steve's Avatar
Oddometer: 3,947
Carbs have been a regular discussion lately so that might explain the lack of explanation.
Steve
Old 10-15-2012, 02:27 PM   #70104
mud390
mud390's Avatar
Oddometer: 161
I was looking for options for short, adjustable levers for the DR650 and came up with very few choices. I was really looking for unbreakable (type that pivots up if it hits something) but found nothing. I thought about swapping perches with a SV650 but dislike the way the front master cylinder is mounted. A little parts book scouring led me to discover that the DL650 (Vstrom) and SV650 naked use the same levers for clutch and brake. Since they levers are the same part number, their sizing should be the same, meaning that the world of fancy, shiny levers just exponentially expanded. The perches look identical for clutch, but the brake on the DL650 has the front master cylinder like a DR, except the line output is facing the fork, not forward. It appears that there is enough clearance to rotate the line for proper routing. My questions are as follows:
1. Do you know if the DR and DL front master cylinder have the same bore, stroke, and brake line hardware size? If the DL is larger in bore and stroke, I'm good with that.
2. Will the DL perches fit a stock DR bar?
3. Do you think the difference in brake line output locations will affect routing/operation?
mud390 is offline   Reply With Quote
Old 10-15-2012, 03:00 PM   #70105
TinMan207
Most often a lurker...
TinMan207's Avatar
Oddometer: 1,502
I don't know about the other questions that you asked, but the previous owner of My DR installed an ASV "unbreakable" clutch on it. works well for me, but I have no idea how to tell which lever it is.
Hoping this helps.
When I was young I hoped to be Rich and good looking. At this point, I think that having great stories of many adventures is a much better plan
06 Suzuki DL650 (2 at the moment!) - 00 DR650
TinMan207 is offline   Reply With Quote
Old 10-15-2012, 03:07 PM   #70106
neo1piv014
ADV in training
Oddometer: 619
My bad.
Ride videos
'01 DR650
Old 10-15-2012, 03:29 PM   #70107
deathu
deathu's Avatar
Oddometer: 77
Just a quick note, DO use the clip on the vacuum cap. I did not know about this, and although it was a tight fit mine just fell off during a ride, maybe some 300 miles after installing the tank. The crazy exhaust popping at idle immediately got me thinking of a vacuum leak. Anyway, not a nice thing to fix on the side of the road.
deathu is offline   Reply With Quote
Old 10-15-2012, 03:33 PM   #70108
procycle
procycle's Avatar
Oddometer: 2,249
Check here --> http://www.procycle.us/bikepages/dr650.html#shortlevers
Clarke's second law of Egodynamics: "For every expert, there is an equal and opposite expert." - Jasper Fforde
www.procycle.us - Everything for your DR650 and lots of other great stuff!
DR900 Big Bore Stroker buildup
TurboDiesel Corvette - go to the end to start at the beginning
procycle is offline   Reply With Quote
Old 10-15-2012, 03:39 PM   #70109
TinMan207
TinMan207's Avatar
Oddometer: 1,502
Originally Posted by procycle View Post
ohhhh man! people have to stop linking to your site! My list of "gotta haves"
get's bigger every darned time.
Old 10-15-2012, 03:59 PM   #70110
Mongle
Knuckle dragger
Mongle's Avatar
Oddometer: 2,691
I see a lot of rubber products that are swelling up just from the gas fumes. Don't know if it is the ethanol or something else they are putting in there. The boat world is pulling their hair out due to these problems. They still run a lot of flexible fuel lines (unlike cars) and have vapor tanks with rubber like diaphrams.
I carry of couple of spares with me now. Use a small zip tie to hold it on. They have been lasting about 9 months before falling apart completely.
Mongle is offline   Reply With Quote
Times are GMT -7.   It's 03:53 AM.
