Old 10-16-2012, 04:08 AM   #70126
blackcap
blackcap's Avatar
Oddometer: 538
i had a problem with the small copper spring inside the starter switch. it managed to overheat with too much current somehow, lost its spring and no longer made contact with the other little copper pieces in there. took a while to work that one out on the boggy hole track
"One must die sometime and to die with ones boots on is very noble" - Carl Stearns Clancy, first RTW motorcycle, 1912-13
Australia to Iceland on a DR650 http://oztoice.wordpress.com
and facebook https://www.facebook.com/oztoice
blackcap is offline   Reply With Quote
Old 10-16-2012, 04:57 AM   #70127
greer
Oddometer: 3,805
Mine begins exactly as yours does, with a total of 17 digits.
Sarah
Originally Posted by mud390 View Post
Info followed by a quick question. I'm looking at a 2006 DR650. The VIN starts out JS1SP46A followed by 9 additional numbers for a total of 17 digits. I called my insurance company and they were having issues with the "JS1" part of the VIN. I just wanted to verify that this isn't an overseas model and is a US Spec model. Does everyone else have VIN's that start with JS1?
'08 DR650
greer is offline   Reply With Quote
Old 10-16-2012, 05:50 AM   #70128
TDY
TDY's Avatar
Oddometer: 194
My VIN also starts with the same 8 characters as yours. My bike is a 2001 bought in Canada.
'15 FZ-07 (new road toy)
01 DR650 (work horse)
'08 CRF230F (fun in the trails)
'08 CRF100F (no trail too tight)
TDY is offline   Reply With Quote
Old 10-16-2012, 06:29 AM   #70129
Feyala
Oddometer: 358
Originally Posted by Adv Grifter View Post
Good work! I suspected it would be one of the several cut outs mentioned. (clutch switch, kick stand or kill button).
WD40 works wonders on these issues. Many times just a good flush with WD will chase out water and allow current to flow.
The other thing that can happen if you let the bike sit in rain too long is the starter can flood out, rust up and get nasty.
Over time if it gets wet a lot it will corrode inside. Pull it apart and scour it well, re-grease and put back together. May need new brushes but should be OK.
Sounds like a nice Bike Cover should be on your X mas list.
Especially as the starter wasn't getting power and we'd recently molested the kickstand switch, that was my first thought too.
Wd40 may have worked, will try that next time.
I also thought the starter may have died... it has recently been making that squealing "crowing" noise when cold out, but I read that this is due to low grease on one part and not terribly abnormal. It is somewhat reassuring that if it does get corroded and nasty it is something I can probably fix.
Would like a bike cover, but they all seem way too bulky to carry with me, I have too much crap as it is! . My solution is to go south for the winter, where there's less rain...
All of the contacts (including that spring) were very tarnished on mine, and one of the solder points looked shoddy. A time out in a shot glass of vinegar fixed the tarnish.
Feyala is offline   Reply With Quote
Old 10-16-2012, 06:42 AM   #70130
oktulsa17
Oddometer: 208
Originally Posted by motolab View Post
How many miles are there on the carb? What monkeying has been done?
Regards,
Derek
Not sure what has been done previously, this is just an uneducated guess on my part. I think I'm the 3rd owner on this bike. I could take it to a shop, but I'd like to do this work myself. I'll just do some searches and see what I can learn.
But in general what adjustments should be made when going to altitude? Move a clip up or down on the needle Or ????
... I was born on the prairie where the wind blew free and there was nothing to break the light of the sun. I was born where there were no inclosures and where everything drew a free breath. I want to die there and not within walls
Chief Ten Bears 1867
oktulsa17 is offline   Reply With Quote
Old 10-16-2012, 07:16 AM   #70131
holckster
dougholck
Oddometer: 836
Originally Posted by oktulsa17 View Post
This may have been covered somewhere but I'm too lazy to look. Took my '06 to New Mexico recently and it had real problems trying to get to speed as the altitude rose Crossed the Continental divide and on I-40 just had real problems staying out of everybodies way. Just cutting out and spuddering alot. I bought it used and I think the carb has been monkeyed with. It was doing this to some extent in OK at closer to 600 ft, but was real noticeable in NM.
It's back to 'normal' but I'd like to get it running better and maybe know what to do to max performance when I get to altitude.
My 08 acted in a similar manner, no power, sputtering, spewed black smoke when reved (semed like choke was on, but it wasn't)
Problem was lack of air to carb due to a strap that I passed under the seat to hang storage bags in front of the Wolfman bags collapsing the rubber snorkel.
Removed rubber snorkel and repositioned strap, cleaned air filter (was not excessivly dirty) ,and 100% perfect.
BTW, stock carb with no mods.
Maybe get a stock carb from someone who has switched and start over.
Good Luck
Doug Holck
Lodi, CA
3 Continents - 7 Countries - 50 States
04 BMW 1150GS Adventure
08 DR650
02 BMW K1200LTe
05 Yamaha TW200
BMW MOA 109760
AMA Charter Life Member 518333
International Fellowship of Motorcycling Rotarians
HDDC POSSE
holckster is offline   Reply With Quote
Old 10-16-2012, 07:57 AM   #70132
Ren20
Finding Touge
Oddometer: 111
This is kind of embarrassing, I didn't know my bike has a choke. I hope I didn't leave the choke on for my first 90miles ride.
Ren20 is offline   Reply With Quote
Old 10-16-2012, 08:05 AM   #70133
Krusty ...
What? Me hurry?
Krusty ...'s Avatar
Oddometer: 7,598
Generally speaking, I doubt if an hour and a half would hurt anything other than fuel mileage. Are you sure it was ever on? In warm weather, you hardly need to choke to get them started.
SUZUKI DR650SE INFORMATION INDEX
"...choosing a DR indicates an affinity for peace, harmony and enlightenment. Serenity lies in accepting it as it is, changing what you want, and the wisdom of knowing it ain't orange." -psmcd
Krusty ... is offline   Reply With Quote
Old 10-16-2012, 08:22 AM   #70134
Fire Escape
Fire Escape's Avatar
Oddometer: 1,582
serial number
My 2006 serial number Begins
JS1SP............ 17 digits you should be fine.
Bruce
No one calls the Fire Department because they did something smart!
06 DR 650, Moose RS Holder, Handguards and Skidplate, ProTaper bars, Garmin 60CSx, Motech racks w/ 20mm Ammo cans, Renazco 08 Scrambler, Conti Trail Attacks and BlackTiger Fork mod, 05 FSE 450, 03 KLR 250, 02 FXDX, 72 WR 250 (again), 72 SL 350 K2 (again), 72 TR6R, 06 XT 225
Fire Escape is offline   Reply With Quote
Old 10-16-2012, 08:24 AM   #70135
Ren20
Finding Touge
Oddometer: 111
The bike started up fine. It was around 55 to 60 degrees. My last bike was EFI so I am kind of spoiled.
Old 10-16-2012, 09:46 AM   #70136
ER70S-2
ER70S-2's Avatar
Oddometer: 6,462
Jet kits are designed to work with an open airbox, if your snorkle is still in place (rubber tube on top of airbox), that's likely to be the problem.
Some aftermarket jet kits have been known to run rich at the suggested jet sizes. Since it's worse at higher altitudes, it's too rich. You can start by raising the needle clip one notch (dropping the needle). If this helps, try raising it another notch and test ride. You're going leaner so when rideability suffers you need to move the clip back down one (raising needle) to richen the mixture.
Me too.
2004 DR650: 62,605 miles
2013 WR250R
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is offline   Reply With Quote
Old 10-16-2012, 10:38 AM   #70137
motolab
motolab's Avatar
Oddometer: 2,623
Technically, BST40 carbs use a cold start enrichment circuit instead of a choke. A choke is closed when an engine is cold and opened when it is warm, whereas a fuel enrichment circuit is opened when the engine is cold and closed when it is warm. A choke works by restricting the air flow, whereas an enrichment circuit works by adding extra fuel. A choke requires a fast idle cam or something akin to it (or you have to hold the throttle open manually), whereas an enrichment circuit adds a little extra air simultaneously with the extra fuel, so the fast idle is already built in.
Regards,
Derek
motolab is offline   Reply With Quote
Old 10-16-2012, 10:46 AM   #70138
motolab
motolab's Avatar
Oddometer: 2,623
See http://www.advrider.com/forums/showp...ostcount=56570.
Regards,
Derek
Old 10-16-2012, 12:04 PM   #70139
motolab
motolab's Avatar
Oddometer: 2,623
In the case of the DJ kit, I think using the term "designed" is being overly kind. In the case of the FP kit, it will work just fine with the snorkel in place (obviously it would need to be jetted properly and the correct clip position selected, just like in any other instance).
Regards,
Derek
Old 10-16-2012, 01:28 PM   #70140
malokam
malokam's Avatar
Oddometer: 457
Im shamelessly advertising. My bike is for sale. Anyone interested let me know.
http://advrider.com/forums/showthread.php?t=834559
WITH GREAT HORSE POWER....... COMES SHITTY GAS MILEAGE .. AND HIGHER INSURANCE PREMIUM....
2007 DR650 SuperMoto with almost all the goodies..(it never ends ya know!)
Take a look at my cool sticker-bombing project
malokam is offline   Reply With Quote
Times are GMT -7.   It's 01:11 AM.
