Old 10-12-2012, 10:15 AM   #70141
Rusty Rocket
Life behind "Bars"
Rusty Rocket's Avatar
Oddometer: 6,242
Originally Posted by FatChance View Post
The 7 year old yellow IMS tank on my DR650 is still yellow...
It was white when you bought it. Right?
1996 DR 650 (a big girl that likes it dirty)
1973 Penton Six-Days (mint)
1971 Suzuki TS185 (needs restoration)
2005 KTM 400exc w/ BajaDesigns D/S light kit
Rusty Rocket is offline   Reply With Quote
Old 10-12-2012, 10:26 AM   #70142
motolab
motolab's Avatar
Oddometer: 1,108
Originally Posted by neo1piv014 View Post
For instance, the pictures there showed some kind of white chicklet ring in the main needle spring, whereas mine was just a spring. I'm not 100% sure what it does, but I guess that I've been running without it for all this time so it couldn't hurt.
The DR650 also uses a lower spring seat. Suzuki calls it a "ring" and its part number is 13331-12D00. Without it, the needle will rattle and the slide spring preload will be reduced.
Did you inspect the float needle, slide guide, emulsion tube, jet needle, and slide for wear?
With the needle having been allowed to rattle around like that, I would be most concerned about emulsion tube, jet needle, and slide needle hole wear.
How many miles are there on the carburetor?
Regards,
Derek
motolab screwed with this post 10-12-2012 at 10:55 AM
motolab is offline   Reply With Quote
Old 10-12-2012, 10:35 AM   #70143
ER70S-2
ER70S-2's Avatar
Oddometer: 2,538
Stock '04 DR650.
2004 DR650: 46,358 miles of
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is offline   Reply With Quote
Old 10-12-2012, 11:13 AM   #70144
Rusty Rocket
Life behind "Bars"
Oddometer: 6,242
Was out playing Tag-O-Rama last Friday. Last pic of this bike in "street attire" Turned 20,000 miles that afternoon.
Now she goes back to knobbies a smaller mirror and a 14 tooth sprocket. The tankbag will stay for the first dirt ride for evaluation purposes. Any problems and it comes off
Old 10-12-2012, 11:20 AM   #70145
neo1piv014
ADV in training
Oddometer: 610
Regards,
Derek
The bike has 10600 miles on it, but I don't know how many of those were without that ring. The PO said he pit a DJ kit in there so it might have happened then. I didn't see any kind of noticeable wear on my Carb parts that made me concerned. What exactly should I be looking for? I'll try to find that ring online somewhere.
Sent from my LG-P999 using Tapatalk 2
_________________________
Ride videos
'01 DR650
"The impossible often has a kind of integrity which the merely improbable lacks."
neo1piv014 is offline   Reply With Quote
Old 10-12-2012, 12:31 PM   #70146
motolab
motolab's Avatar
Oddometer: 1,108
If the jet needle does not have more than one clip groove, it's not a DJ needle. Is the white needle spacer installed under the clip? If so, is it round, without a notch or being d-shaped?
The rubber tip of the float needle should be inspected under magnification. It should perfectly conical, with no witness line evident where it was contacting the seat. If any evidence is visible, or if there is a gap between the bottom edge of the rubber tip and the aluminum portion of the needle, if the plunger is stuck, or if the plunger return spring is sacked out, the needle should be replaced. Not doing so means that the float valve is leaking, or will begin leaking soon.
Emulsion tube wear generally sets in rapidly when the slide guide has worn .010" or more. The way to tell is to measure the depth of the depressions that are located in the bottom corners, concentric to the bore. If they are .010" deep or less, the slide guide should be replaced. '96 and up DR650 emulsion tubes are nickel plated, and so a bit more wear resistant than those found on previous models or KTMs. I don't know how thick the plating is, but if the nickel has worn away to expose the brass, it's definitely time to replace. Replace the slide if the lift hole area has been increased over stock, if there is vertical grooving on the downstream side, or if the needle hole is enlarged and/or ovaled.
See (scroll down for description and links. Click image for high-res view):
Slide guide, used
Slide guide, new
Emulsion tubes, new and used
Slide, used
Slide, new
Regards,
Derek
Old 10-12-2012, 02:13 PM   #70147
neo1piv014
ADV in training
Oddometer: 610
Well, it looks like I'm going to be pulling the carb apart again this evening to check this all out. The needle does have a white spacer on it, and I think it was pretty much perfectly round. At least, nothing stuck out in my memory of it. Is the "float needle" that large needle in the slide?
Actually,. I might be better off waiting until I get home to ask questions since I can't check out the pictures at work. Thanks for the info dump, though. It's much appreciated.
If the jet needle does not have more than one clip groove, it's not a DJ needle. Is the white needle spacer installed under the clip? If so, is it round, without a notch or being d-shaped?The rubber tip of the float needle should be inspected under magnification. It should perfectly conical, with no witness line evident where it was contacting the seat. If any evidence is visible, or if there is a gap between the bottom edge of the rubber tip and the aluminum portion of the needle, if the plunger is stuck, or if the plunger return spring is sacked out, the needle should be replaced. Not doing so means that the float valve is leaking, or will begin leaking soon.
Slide guide, used
Slide guide, new
Slide, used
Slide, new
Regards,
Derek
Ride videos
'01 DR650
Old 10-12-2012, 02:32 PM   #70148
JTB488
Oddometer: 40
The float needle is a small brass needle with a rubber cone shaped tip on the pivoting end of the float.
JTB488 is offline   Reply With Quote
Old 10-12-2012, 02:50 PM   #70149
neo1piv014
ADV in training
Oddometer: 610
Umm...I didn't see anything like that when I pulled my carb. Does it go into something? Like would it have maybe stayed inside of one of the many holes in the carb? I know the bike ran great after I put everything together, so I'm kind of curious what else I may have missed.
Ride videos
'01 DR650
Old 10-12-2012, 03:03 PM   #70150
jessepitt
Dual Sport Addict
jessepitt's Avatar
Oddometer: 987
I hate a tank bag off pave. Any time you need to get forward while standing it impedes your movement and can cause some bad hill climb out comes.
jessepitt is offline   Reply With Quote
Old 10-12-2012, 03:06 PM   #70151
motolab
motolab's Avatar
Oddometer: 1,108
To remove the float needle, you have to separate the float from the cage. When you put it back together, using a float height too, set the float height to 14.7mm.
Regards,
Derek
Old 10-12-2012, 03:23 PM   #70152
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 4,809
Wolfman Endure tankbag. I can straddle the bag no problem.
Guess what doofus, nobody reads your lame blog.
Albie is offline   Reply With Quote
Old 10-12-2012, 04:01 PM   #70153
wayno
wayno's Avatar
Oddometer: 4,806
Mines still blue after 5/6 years...wish it would turn clear so I could mark gallons
RIDE SAFE
wayno is offline   Reply With Quote
Old 10-12-2012, 04:04 PM   #70154
neo1piv014
ADV in training
Oddometer: 610
Regards,
Derek
Okay. I think that might be where it is then. When I removed the float, I pulled that tall column thing that was on one side, and then I pull the other side out where it was all flat down one edge. It all came up at the same time, and nothing fell off it, so I just assumed it was all one piece. If I get some time this weekend, I'm going to take it back off the bike and see about doing a more thorough examination.
Oh, and I went ahead and looked up that missing part from the spring on Bike Bandit. It's only $7.00, so I might as well go ahead and grab that.
Ride videos
'01 DR650
neo1piv014 screwed with this post 10-12-2012 at 04:05 PM Reason: Added info
Old 10-12-2012, 05:03 PM   #70155
JTB488
Oddometer: 40
Look in the BST-40 bible thread, shows the needle and float together in one pic,looks to be aluminum in ours, but still the little rubber tip.
Times are GMT -7.   It's 02:00 AM.
