Old 10-17-2012, 11:33 PM   #70171
motolab
motolab's Avatar
Oddometer: 2,621
Originally Posted by badweatherbiker View Post
I have to pull the carb this weekend to check it out but it surges from the time I take off all the way through the gears and at highway speed. If it was right it wouldn't be a big deal but I don't have the time to tinker. the jet kit was installed by the p/o around 200 miles ago in August.
Does the problem get worse or better as the engine warms up?
Regards,
Derek
motolab is offline   Reply With Quote
Old 10-18-2012, 05:33 AM   #70172
planemanx15
planemanx15's Avatar
Oddometer: 1,009
Now that the weather is getting cooler, I have a question about the oil cooler. My commute to work is short, about 10 mins). Today it was around 45*F and the oil temp barely got to 110*F as per my vapor. That includes a 2 minute warm up prior to riding.
Should I cover my oil cooler for these short rides so that the oil can get to a better operating temp?
2000 Suzuki DR650-790 - 790cc Big bore build thread
1985 Yamaha CA50 - The little scooter that Could
2009 Piaggio BV-250 - Escusi, Babba be bo-bee
planemanx15 is offline   Reply With Quote
Old 10-18-2012, 05:45 AM   #70173
Zapp22
ZAPP - Tejas
Zapp22's Avatar
Oddometer: 13,729
Question Transmission Rebuilders: a question
If one were to pro-actively rebuild the Transmission, and wanted to make sure its as bulletproof as possible, would you use aftermarket parts or not?
I realize our friends at Procycle [and maybe others?] have a super high-quality 3rd gear kit, but I'm wondering if the collective really KNOW FOR SURE what causes the 3rd gear to detonate the trans??? Its just really hard for me to fathom that Suzi would manufacture all the parts for the trans, and keep on manufacturing just one defective component... it does not pass sniff test.
So if rebuilding with Race-proven Baja-capable parts is the ticket - is there any science on how many of them blowup for one reason or other? how many units have been tested, in-service, for long periods of time as have the Suzuki parts? its a rhetorical question....
you who have done the job, what did you use?
Zapp
"I will not let the White City fall... nor our people fail. - Aragorn
K4 WEESTROM Stealthfighter Black -SOLD - Invisible to Radar, '02 DR650SE SOLD ,'Ole 97' DR650SE My Fave K5 WEESTROM ADVbomber
Zapp22 is offline   Reply With Quote
Old 10-18-2012, 05:59 AM   #70174
Zapp22
ZAPP - Tejas
Zapp22's Avatar
Oddometer: 13,729
i think you're on the right path. TTalk has a lot more discussion of carb/rebuild/etc for DR and my own personal opinion after reading obsessively on the topic is that its not easy to actually IMPROVE overall perf... there are far more fails than successes.... way, way, way more. those who are really good wrenches can succeed beautifully and have a bike that goes 5mph faster and gets there a good deal quicker, if that's important to you.....
Zapp
Old 10-18-2012, 06:04 AM   #70175
neo1piv014
ADV in training
Oddometer: 619
This is why Derek is a life saver.
_________________________
Ride videos
'01 DR650
"The impossible often has a kind of integrity which the merely improbable lacks."
neo1piv014 is offline   Reply With Quote
Old 10-18-2012, 06:05 AM   #70176
P-P
P-P's Avatar
Oddometer: 97
Originally Posted by barko1 View Post
Mine crapped out and no amount of WD40, contact cleaner, etc seemed to help so I picked up a newer one off Ebay. WD is probably good preventive maintenance, thanks for reminding me. Heading to Monticello Canyon in NM Friday, somewhere around 30-40+ water crossings
I use Silicone Spray - more dielectric and lasts quite well.
Just say NO! to CaliFornication!
P-P is offline   Reply With Quote
Old 10-18-2012, 06:58 AM   #70177
GaThumper
Road Less Traveled
GaThumper's Avatar
Location: Thumpin' in North GA - headin' for the Smokys
Oddometer: 514
Originally Posted by Pike Bishop View Post
Thanks fellas. After perusing your links and doing a Google search of advrider (way better than the in-house search functionality BTW) I decided that if I need a battery (I'm hoping this one might just need some water and a charge) the 10.5 Ah AGM Motobatt MBTX9U for ~ $67 is the way to go.
I appreciate your help.
Here's some info I've posted in the past. Has anyone used the YTZ14S? 230 cca sounds interesting. If your supplier only references batteries by bike, tell them it's a 2003 Honda ST1300. When my Deka wears out in a few years, I'll probably try one myself.
Edit: I just noticed that the link in my original post is now broken. I've saved a copy of the PDF so I have a copy the whole report if needed. It can also be accessed in the archives.
http://web.archive.org/web/201106011...ki-battery.pdf
Originally Posted by GaThumper View Post
There are some more powerful batteries that will fit our battery box. I haven't tried one yet, but when my Deka battery needs replacing again (in a few years!) I might try one of the "bigger" batterys. Here's some info I picked up when I was looking at replacing the battery on my '09.
I'm using a Deka battery made by East Penn Mfg. Their replacement for the standard Yuasa YTX9-BS is the ETX9.
I haven't tried it myself but I have found out that there are three Yuasa Batteries that are almost exactly the same physical size, but more Amp Hours/Cold Cranking Amps. I was really tempted to try one in my '09 when I replaced the battery this spring, but ended up going with the Deka.
The stock YTX9-BS-BS is 150x87x105 mm and 8AH/120CCA
The YTX-12A-BS is an AGM battery with the same dimensions and 9.5AH/175CCA
The YTZ 12S is an AGM battery that is 150x87x110 (5mm taller) and 11AH/210CCA
The YTZ 14S is an AGM battery that is also 150x87x110 and packs 11.2AH and 230CCA
I went to pick up 2 of the YTZ14S for me and my riding buddy and when tested one of the only two in stock had a bad cell. That made me uneasy, so I had him bring out a Deka ETX9 and test it and it exceeded the CCA of the YTZ14S so I bought the American made Dekka this time. (the salesperson told me Deka is known to be conservative in rating their batteries) I'd still like to do a side by side comparison of the YTZ battery and see if it spins the DR any better, but I've always had good service from the Dekka, so I'm not sure if I'll switch next time or not.
It sure looks like the YTZ14S might be an interesting replacement for the YTX9. It;s only 3/16" taller (5mm) and with a couple of washers under the battery retainer it apparantly fits under the seat just fine. However, if you are really concerned about weight, it does weigh about 2 pounds more than the stocker.
The only concern I might have is that there are probably more plates in the higher capacity battary in the same (relatively) size package. I've read before that this could cause a problem due to the plates being closer together.
Having said all that, I'm REALLY satisfied with the Deka ETX9. Also made in the U.S. of A. if that matters to you.
I can't take credit for this. Here's the article I found this info in and a big THANK YOU to "Scott", wherever you are!
http://www.cs.clemson.edu/~westall/8...ki-battery.pdf
Dirtly: 2009 Suzuki DR650SE Road Sofa: 2001 Yamaha (ad)Venture 1300
Dirtlier: 1999 Suzuki DR350SE Old Sport: 1979 Suzuki GS1000E
1996 Suzuki Intruder 1400 (for sale) 1987 Yamaha TT600 (for sale)
GaThumper is offline   Reply With Quote
Old 10-18-2012, 11:18 AM   #70178
ER70S-2
ER70S-2's Avatar
Oddometer: 6,457
That's a lot of good information. You could put it in Krusty's DR Index.
http://www.advrider.com/forums/showp...2&postcount=32
While you're doing that, you could include your earlier info about the clear turn signal lenses with amber bulbs. One of the first mods I did to my DR was to replace the turn sigs with some that have clear lenses/amber bulbs. Problem is they're brittle, break easily, and are no longer available.
Thanks for the good stuff.
2004 DR650: 62,605 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is offline   Reply With Quote
Old 10-18-2012, 12:48 PM   #70179
Pike Bishop
Pull Down the Ponzi.
Pike Bishop's Avatar
Oddometer: 10,466
Originally Posted by mud390 View Post
I'm looking at a 2006 DR650. The VIN starts out JS1SP46A followed by 9 additional numbers for a total of 17 digits. I called my insurance company and they were having issues with the "JS1" part of the VIN. I just wanted to verify that this isn't an overseas model and is a US Spec model. Does everyone else have VIN's that start with JS1?
My 2009 DR650SE purchased from a dealer in the U.S. also starts with "JS1" followed by two letters, then 2 digits, then a letter, then nine digits.
Pike Bishop is offline   Reply With Quote
Old 10-18-2012, 01:00 PM   #70180
neoxaero
Oddometer: 13
I'm in the process of having mine rebuilt right now. I was having some issues with it falling out of 2nd gear so I decided to just bite the bullet.
From the reading I did prior to getting the work done, it seems in 06 or 07 suzuki released a new 3rd gear that replaced the old one. I'm assuming it was done in an effort to address the issues with the gear blowing up. I decided to go a head and replace my gear with the newest one instead of buying the billet unit. Hopefully I don't regret it, but I couldn't justify replacing a $50 dollar part with one that costs $500 when the stock one may or may not blow up at some point.
Obviously, If I trash the engine in the bike due to a 3rd gear failure I'll be kicking myself.
I may consider doing the nice 3rd gear when I put the 790 kit in the bike as a little bit of extra insurance
neoxaero is offline   Reply With Quote
Old 10-18-2012, 01:39 PM   #70181
NC Rick
Cogent Dynamics Inc
NC Rick's Avatar
Oddometer: 631
Cogent Dynamics is still looking to purchase or barter for a good set of DR650 forks...
Rick
Cogent Dynamics Inc.
motocd.com
NC Rick is offline   Reply With Quote
Old 10-18-2012, 02:36 PM   #70182
mrprez
KJ4WMZ
Oddometer: 1,265
New to me '04 model
Totally stock '04 DR with just over 6000 miles. A bit rough cosmetically but will be the base for an ADV style bike. Let the farkeling begin!
Sent via morse code
mrprez is offline   Reply With Quote
Old 10-18-2012, 02:47 PM   #70183
neo1piv014
ADV in training
Oddometer: 619
If that's "rough," then my bike is laying beaten in a corner weeping. Nice buy!
Ride videos
'01 DR650
Old 10-18-2012, 02:52 PM   #70184
mrprez
KJ4WMZ
Oddometer: 1,265
Thanks! A camera can make most anyone look good. It should clean up OK though.
Sent via morse code
Old 10-18-2012, 02:54 PM   #70185
neo1piv014
ADV in training
Oddometer: 619
Any mods planned in the near future for it? I didn't see anything looking broken on it, so at least you might not have to make your first farkles repairs.
Ride videos
'01 DR650
Times are GMT -7.   It's 03:17 PM.
