Old 10-18-2012, 08:17 PM   #70201
badweatherbiker
badweatherbiker's Avatar
Oddometer: 706
nope, same all the time all temps
1996 Kawasaki KZ1000P (currently being rebuilt)
World class nutritional supplements, weight loss, meal replacement shakes, quality energy drinks, pre and post workout supplements!
Earn extra income, become a distributor or just purchase:
Advocare products-www.advocare.com/12084065
badweatherbiker is offline   Reply With Quote
Old 10-18-2012, 08:25 PM   #70202
Davis53
Oddometer: 574
Originally Posted by mrprez View Post
OK, so just realized that my neutral light isn't working. How much trouble am I in and what's the best route to take at this point. I don't want to assume that the unknown to me PO did anything about fixing the screws or removing the NSU altogether. If it was removed would it be obvious somewhere where the cable exits the motor somewhere????
Don't run the engine anymore till you take the right sidecase off. You may find one or two screws loose in the bottom of the case. They are for the neutral light switch, it is a common problem. If you run the engine they may get caught in the gears.
Davis53 is online now   Reply With Quote
Old 10-18-2012, 08:56 PM   #70203
ER70S-2
ER70S-2's Avatar
Oddometer: 6,960
What year, how many miles, just curious?
Don't let the length of this post scare you, there are several solutions for the same issue. Get a new gasket before you start, some break, some don't. Mine broke into several pieces.
http://www.advrider.com/forums/showp...7&postcount=15
2004 DR650: 62,605 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is offline   Reply With Quote
Old 10-18-2012, 09:03 PM   #70204
motolab
motolab's Avatar
Oddometer: 2,777
OK. Does whether or not the cold start enrichment circuit is active make any difference to the severity of the surging?
Is the cold start enrichment circuit required to be active for it to start from cold?
Regards,
Derek
motolab is offline   Reply With Quote
Old 10-18-2012, 09:51 PM   #70205
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 6,128
I agree. Shut her down and pull the sidecase off and check those NSU bolts.
If missing, try to fish them out. Good luck!
DO NOT start engine until you've verified all is OK. As many know, the neutral light going away has been a common symptom when NSU bolts are missing.
A cheap and easy fix, best catch it before you have a problem.
Old 10-19-2012, 12:45 AM   #70206
sharpblade
Oddometer: 73
Could someone tell me the size of the rear axle nut and the size of the oil plug nut. Thank you.
sharpblade is offline   Reply With Quote
Old 10-19-2012, 12:48 AM   #70207
BergDonk
BergDonk's Avatar
Oddometer: 3,820
OTTOMH, 24 and 14 mm
shed time IS quality time
BergDonk's DR650 BergDonk's XT1200Z
BergDonk is offline   Reply With Quote
Old 10-19-2012, 12:52 AM   #70208
sharpblade
Oddometer: 73
Thank you so much. I was also trying to find a free download for the dr manual. I had a 2006 dr and had the manual but sold the bike about 3 years ago and gave the manual away. Just bought a new 2012 dr and am in need again.
Old 10-19-2012, 02:34 AM   #70209
Sierra Thumper
Oddometer: 641
I just want it to work, its a long way home everyday and that surging is awful!
When you get your bike running properly with those mods, then get back on a stock bike, you'll realize just how much more fun and useful your bike is modded over a stocker. A properly modded DR/XRL/KLR etc is a whole nother beast from the super restricted EPA versions. Once you get used to a properly running modded machine, stock will never thrill you again
"Don't get so concerned with the slab that you choose a turd for the dirt"- The Gospel as spoken by itrack
Sierra Thumper is offline   Reply With Quote
Old 10-19-2012, 03:19 AM   #70210
badweatherbiker
Oddometer: 706
Regards,
Derek
the enricher on the left handlebar? it makes no difference at speed. I turned it on while on the highway at nearly 70mph and noticed no difference.
Old 10-19-2012, 03:57 AM   #70211
mrprez
KJ4WMZ
Oddometer: 1,265
2004, 6281 miles. I'm gonna check the bulb first and then order up a new gasket. Another thing I noticed that it won't start with the side stand down.
Edit: Checked the bulb, it is fine. On to plan B.
Sent via morse code
mrprez screwed with this post 10-19-2012 at 05:15 AM
mrprez is offline   Reply With Quote
Old 10-19-2012, 04:30 AM   #70212
RichBeBe
All Hail Seitan!!!
RichBeBe's Avatar
Oddometer: 6,278
The challenge of transmissions are huge. I worked for a long time at a shop who made custom drag racing transmissions for high-powered bikes and I can tell you there is a LOT that goes into making a transmission. The one thing that fascinated me was the hardening process. Different gears, shafts, and forks were all hardened differently. I can't go into the science of it here, but a gear with dogs on it may be softer than a gear with engagement slots on it, also one gear set me be harder than another.
Not knowing, nor have I seen a blown up third gear i cannot say what the issue it, but I am pretty sure Suzuki as do all manufacturers "play" with the hardening of the parts. They most likely just got it wrong.
"Remember that an enduro tests the endurance of three things: your machine, your body, and your wits. Only one has to fail to keep you from reaching the finish line." Cycle World March 1966
RichBeBe is offline   Reply With Quote
Old 10-19-2012, 05:54 AM   #70213
GaThumper
Road Less Traveled
GaThumper's Avatar
Location: Thumpin' in North GA - headin' for the Smokys
Oddometer: 514
Originally Posted by Kernel View Post
I just posted this over in the no moaning and pissing thread, sorry if there is some rule against making the same post in two threads but I couldn't be bothered reading the site rules.
I just got to thinking.
Everyone refers to the DR650 as the ultimate 'zombie apocalypse' bike.
Sorry, but I tend to disagree.
Why?
The bike is not fuel efficient enough.
Ok ok, the DR650 is quite a fuel efficient bike, especially considering how much forward-lurching torque blast-outta-da-cornerz fun it has, it really is.
But for a zombie apocalypse/post nuclear disaster bike? Sorry, no.
The bikes that will truly shine when shit really hits the motherfucken fan will be bikes such as the TW200, the CT110, the DR250, the XT200.
Bikes which use fuck all of nothing petrol and will get you anywhere and everywhere, and will keep thumping along happily all day. Because lets face it, petrol is going to be damn near unobtainable, and when you can get it, it will be very expensive (think $5 a litre) and people who sell it will be few and far between.
OR.
A multi-fuel motor equipped DR650, a la the HAYES-DT M1030-M2, capable of achieving near 100 MPG. Now THAT would be unstoppable.
Think of the logic behind it. A powerful, high-revving, torque rich, mechanical direct injected, indestructible engine capable of achieving astonishing astonishing fuel mileage mated with the most versatile best go-anywhere any-time bike known to man.
When the zombie apocalypse/post nuclear disaster inevitably hits, there's going to plenty of people scraping a living together making fuel this engine is capable of happily running on. It is going to be the most widely available and cheapest fuel in existence. After all, you can make kerosene/diesel out of used motor oil (providing you run it through an oil cleaner first) very cheap and biodiesel out of vegetable crops, and lets not forget the vast quantities of unused jet fuel that will be looming around in stores. All of which the M1030-M2's engine is capable of running on quite happily.
One of these days either Hayes-DT is going to release their magnificent single cylinder diesel motorcycle engine into the public sector, or someone is going to design and manufacture an equivalent nearly as good (perhaps better?) engine and make it available for sale to the public. I plan on being one of the first to have it adapted it to the DR650 when this happens, so that I will have the edge when petroleum becomes unobtainium.
Like this...
http://www.motorcycle.com/manufactur...iew-90964.html
Maybe this is the final product?
Dirtly: 2009 Suzuki DR650SE Road Sofa: 2001 Yamaha (ad)Venture 1300
Dirtlier: 1999 Suzuki DR350SE Old Sport: 1979 Suzuki GS1000E
1996 Suzuki Intruder 1400 (for sale) 1987 Yamaha TT600 (for sale)
GaThumper screwed with this post 10-19-2012 at 06:05 AM
GaThumper is offline   Reply With Quote
Old 10-19-2012, 06:03 AM   #70214
neo1piv014
ADV in training
Oddometer: 621
That doesn't look rough from here, nice buy! I really like mine as long as I can get the surging to stop.
I need to post a pic but don't have a smugmug or anything.
If you don't want to create an account or anything, IMGUR.com is pretty solid. Just feed it pictures and it spits out a link.
_________________________
Ride videos
'01 DR650
"The impossible often has a kind of integrity which the merely improbable lacks."
neo1piv014 is offline   Reply With Quote
Old 10-19-2012, 06:08 AM   #70215
thetable
thetable's Avatar
Oddometer: 1,468
Originally Posted by GaThumper View Post
Like this...
[IMG]http://www.adventurebikerider.com/images/stories/altius-scimitar-670-diesel-motorcycle-2.jpg[/ IMG]
Last I heard, HDT was well on their way to going tits up.
I'd also love to know how adding a diesel to a KLR makes it 50lbs lighter.
thetable is offline   Reply With Quote
Times are GMT -7.   It's 12:35 PM.
