Old 10-19-2012, 06:08 AM   #70216
thetable
thetable's Avatar
Oddometer: 1,446
Originally Posted by GaThumper View Post
Like this...
http://www.motorcycle.com/manufactur...iew-90964.html
[IMG]http://www.adventurebikerider.com/images/stories/altius-scimitar-670-diesel-motorcycle-2.jpg[/ IMG]
Last I heard, HDT was well on their way to going tits up.
I'd also love to know how adding a diesel to a KLR makes it 50lbs lighter.
thetable is offline   Reply With Quote
Old 10-19-2012, 06:09 AM   #70217
Foot dragger
singletracker
Foot dragger's Avatar
Oddometer: 12,856
Originally Posted by eakins View Post
Interesting comment about the Deka being actually higher CCA than the rated @ 120. i've always had nothing to top service and life out of Deka and will continue to keep buy $60 http://www.tristatebattery.com/produ...roducts_id=973 for my DR.
After 4 yrs i just pay another $60 and have peace of mind for another 4yrs. Easy as pie.
Saving a few lbs on a Shorai when used in a heavy DR seemed more like a waste of $ IMO, but i know alot of guys love em. Sure on a light dirtbike where every lbs counts it makes sense, but the DR is heavy and not a dirtbike.
Crazy how Yuasa is getting those larger batteries in the same size and still using AGM. If you look at Deka sizing is does go up and what i'd expect.
http://www.etx9.com/
http://www.etx12.com/
http://www.etx14.com/
In the end, my $ is on a new Deka and 60 bones too.
There are some more powerful batteries that will fit our battery box. I haven't tried one yet, but when my Deka battery needs replacing again (in a few years!) I might try one of the "bigger" batterys. Here's some info I picked up when I was looking at replacing the battery on my '09.
I'm using a Deka battery made by East Penn Mfg. Their replacement for the standard Yuasa YTX9-BS is the ETX9.
I haven't tried it myself but I have found out that there are three Yuasa Batteries that are almost exactly the same physical size, but more Amp Hours/Cold Cranking Amps. I was really tempted to try one in my '09 when I replaced the battery this spring, but ended up going with the Deka.
The stock YTX9-BS-BS is 150x87x105 mm and 8AH/120CCA
The YTX-12A-BS is an AGM battery with the same dimensions and 9.5AH/175CCA
The YTZ 12S is an AGM battery that is 150x87x110 (5mm taller) and 11AH/210CCA
The YTZ 14S is an AGM battery that is also 150x87x110 and packs 11.2AH and 230CCA
I went to pick up 2 of the YTZ14S for me and my riding buddy and when tested one of the only two in stock had a bad cell. That made me uneasy, so I had him bring out a Deka ETX9 and test it and it exceeded the CCA of the YTZ14S so I bought the American made Dekka this time. (the salesperson told me Deka is known to be conservative in rating their batteries) I'd still like to do a side by side comparison of the YTZ battery and see if it spins the DR any better, but I've always had good service from the Dekka, so I'm not sure if I'll switch next time or not.
It sure looks like the YTZ14S might be an interesting replacement for the YTX9. It;s only 3/16" taller (5mm) and with a couple of washers under the battery retainer it apparantly fits under the seat just fine. However, if you are really concerned about weight, it does weigh about 2 pounds more than the stocker.
The only concern I might have is that there are probably more plates in the higher capacity battary in the same (relatively) size package. I've read before that this could cause a problem due to the plates being closer together.
Having said all that, I'm REALLY satisfied with the Deka ETX9. Also made in the U.S. of A. if that matters to you.
I can't take credit for this. Here's the article I found this info in and a big THANK YOU to "Scott", wherever you are!
http://www.cs.clemson.edu/~westall/8...ki-battery.pdf
Yup,worrying about weight on a DR is a little silly.
Like putting a 400.00 FMF muffler on,listening to all that noise,the bike still approaches 400 lbs with gas.
Ive used all manner of 60.00 batteries,most last 3 years. None have melted of their own accord like some Shorai's I have seen pics of.
Some bikes around at times
Foot dragger is offline   Reply With Quote
Old 10-19-2012, 06:13 AM   #70218
mrprez
KJ4WMZ
Oddometer: 1,265
Originally Posted by neo1piv014 View Post
If you don't want to create an account or anything, IMGUR.com is pretty solid. Just feed it pictures and it spits out a link.
I like that! Pretty easy to upload and get the link for the image.
Sent via morse code
mrprez is offline   Reply With Quote
Old 10-19-2012, 06:17 AM   #70219
Foot dragger
singletracker
Oddometer: 12,856
Originally Posted by Zapp22 View Post
If one were to pro-actively rebuild the Transmission, and wanted to make sure its as bulletproof as possible, would you use aftermarket parts or not?
I realize our friends at Procycle [and maybe others?] have a super high-quality 3rd gear kit, but I'm wondering if the collective really KNOW FOR SURE what causes the 3rd gear to detonate the trans??? Its just really hard for me to fathom that Suzi would manufacture all the parts for the trans, and keep on manufacturing just one defective component... it does not pass sniff test.
So if rebuilding with Race-proven Baja-capable parts is the ticket - is there any science on how many of them blowup for one reason or other? how many units have been tested, in-service, for long periods of time as have the Suzuki parts? its a rhetorical question....
you who have done the job, what did you use?
The "evidence" on 3rd gear blowups is sketchy at best,less then 1% of all DR's scatter their engines for one reason or another,people look inside and think about all the 3rd gear explosions they have read about on the internet and decide that must be what happened.
Once the insides are fragmented,its hard to tell what really happened.
Some guys on the internet have picked up the 3rd gear blowup as a cause and have run with it as far as they can,to me,rebuilding a DR trans because it might blow up is a pricey thing to do,for a problem that most likely will never happen.
Race Proven DR parts? Who would race one of these tanks in Baja to prove the parts?
Old 10-19-2012, 06:51 AM   #70220
badweatherbiker
badweatherbiker's Avatar
Oddometer: 705
Originally Posted by motolab View Post
OK. Does whether or not the cold start enrichment circuit is active make any difference to the severity of the surging?
Is the cold start enrichment circuit required to be active for it to start from cold?
Regards,
Derek
It Will start without the enricher, at idle i can turn the enricher on and the engine cuts off. At speed it makes no difference.
Thanks for all the help btw!
The tank is good and clean as well as the little filter in the fuel elbow, got that far. Plugs are light colored, kinda white maybe grey
1996 Kawasaki KZ1000P (currently being rebuilt)
World class nutritional supplements, weight loss, meal replacement shakes, quality energy drinks, pre and post workout supplements!
Earn extra income, become a distributor or just purchase:
Advocare products-www.advocare.com/12084065
badweatherbiker is offline   Reply With Quote
Old 10-19-2012, 06:52 AM   #70221
sharpblade
Oddometer: 73
[QUOTE=BergDonk;19851960]OTTOMH, 24 and 14 mm[/Q
Just discovered mine used a 17 mm wrench for the oil plug.
sharpblade is offline   Reply With Quote
Old 10-19-2012, 08:36 AM   #70222
Minsk99
Oddometer: 56
[QUOTE=sharpblade;19853223]
The stock is 17mm. Many of the aftermarket, magnetic plugs are 14mm.
Minsk99 is offline   Reply With Quote
Old 10-19-2012, 08:38 AM   #70223
Mongle
Knuckle dragger
Mongle's Avatar
Oddometer: 2,916
3rd gear takes a beating in my bike. If I am riding hard I often downshift two gears into a corner and clutch it. Depending on how much I want the back to slide around I use the engine breaking a lot in 3rd gear. If a gear is going to go in my bike it is going to be 3rd.
On my bikes with 6 speeds it will be 4th.
Mongle is online now   Reply With Quote
Old 10-19-2012, 08:54 AM   #70224
PPCLI-Jim
PPCLI-Jim's Avatar
Oddometer: 221
Race Proven DR parts? Who would race one of these tanks in Baja to prove the parts? I would if I was a little healthier. (drove over a landmine in Afghanistan) I still have taken mine on race tracks that are modified Trials tracks. they opened them up for bigger bikes(MX ones I found out later.) After the ride guys walked up and asked did I lose a bet or did I just hate myself. Just a dumba$$ if your gonna be dumb you got to be tough
I'm not saying to kill all the stupid people . .. Just remove the warning labels and let nature run it's course
http://www.youtube.com/user/spudhead/videos?view=0 my youtube channel
PPCLI-Jim is offline   Reply With Quote
Old 10-19-2012, 08:56 AM   #70225
motolab
motolab's Avatar
Oddometer: 2,622
Originally Posted by badweatherbiker View Post
the enricher on the left handlebar? it makes no difference at speed. I turned it on while on the highway at nearly 70mph and noticed no difference.
Regards,
Derek
motolab is offline   Reply With Quote
Old 10-19-2012, 09:07 AM   #70226
doug s.
Oddometer: 1,348
Regards,
Derek
per his prior post:
"It Will start without the enricher, at idle i can turn the enricher on and the engine cuts off. At speed it makes no difference."
i suspect it's running a bit rich...
doug s.
doug s. is offline   Reply With Quote
Old 10-19-2012, 09:54 AM   #70227
motolab
motolab's Avatar
Oddometer: 2,622
Originally Posted by doug s. View Post
per his prior post:
It doesn't specifically say cold (unless it says so elsewhere in the referred-to post).
Regards,
Derek
Old 10-19-2012, 10:30 AM   #70228
ER70S-2
ER70S-2's Avatar
Oddometer: 6,461
Originally Posted by mrprez View Post
2004, 6281 miles. I'm gonna check the bulb first and then order up a new gasket. Another thing I noticed that it won't start with the side stand down.
Edit: Checked the bulb, it is fine. On to plan B.
When I R&R'd my rear shock, I forgot to plug in the NSU plug up by the upper shock bolt. My engine wouldn't start with the side stand down either. So you are looking in the right place.
2004 DR650: 62,605 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is offline   Reply With Quote
Old 10-19-2012, 10:31 AM   #70229
JagLite
JagLite's Avatar
Oddometer: 1,247
Question Loud horn?
In case you are tired of reading carb discussions, I just posted this in the "Gear" section but I don't want any of my fellow DR riders to miss it:
I just read about the Screaming Banshee on Jalopnik (car news website) and it sounds (har-har-har!) great.
So I went to their website and see the new plug & play version is ready to ship.
Also a great price break in a group buy deal of 10 units.
Anyone want to put together a group?
I am in Alaska so it is not reasonable for me to organize one but I want to be in on it.
Here is the direct linky
http://www.indiegogo.com/PlugAndPlayScreamer#team
Scroll to the Expanded Club Pack deal for 10 units at $59 each.
Actually I would probably like two or three of them for my bikes.
Hmmmmm, I have 4 street & DS bikes, 3 cars......
I would like to get one for each but that just isn't in the budget.
Anyone?
Attitude ~
The difference between
Ordeal and Adventure
James
JagLite is offline   Reply With Quote
Old 10-19-2012, 10:33 AM   #70230
Gustavo
Motociclista Errante
Gustavo's Avatar
Oddometer: 2,286
You gotta be a bit crazy to try that...
Gustavo
Gustavo is offline   Reply With Quote
Times are GMT -7.   It's 02:32 PM.
