10-14-2012, 01:57 PM
#70231 |
Oddometer: 40
Isn't there like indians behind those rocks
10-14-2012, 03:40 PM
#70232 | |
#395/#111
Oddometer: 863
this is what i am after! i have a fresh set of mt21s mounted with heavy duty tubes. do you have any gps tracks or maps/guides. looking to make the most of my time out there
12 CRF250X - 13 CRF450R |
10-14-2012, 06:53 PM
#70233 | |
Oddometer: 650
Traded my FZ6 for that 03 today with 18,000 miles and a good bit of $$$ too! The guy has not ridden it much in the last couple months and on the ride home (65 miles) it did studder a little bit so I assume it has some trash or gum in the carb, I'll get that cleaned up hopefully next week but I have to say it is way more comfy than the FZ was. Like it so far!
1996 Kawasaki KZ1000P (currently being rebuilt) World class nutritional supplements, weight loss, meal replacement shakes, quality energy drinks, pre and post workout supplements! Earn extra income, become a distributor or just purchase: Advocare products-www.advocare.com/12084065 |
10-14-2012, 06:55 PM
#70234 | |
Motersykle Advntyers
Oddometer: 432
I haven't been everywhere, but it's on my list. 2007 BMW R1200 GSA, 2009 DL1000, 2005 DR650 |
10-14-2012, 07:11 PM
#70235 | |||
Oddometer: 2,538
Use the 1/2" wide zip ties. ![]() Quote:
![]() Quote:
Do not buy the Zuki gel seat, it only delays the pain by 10 minutes. But it is a bit shorter.
10-14-2012, 07:29 PM
#70236 | |
Oddometer: 2,538
Up to this point, it will always start ( ) by holding the throttle wide open until it fires. Worked again today, flat front tire dropped me in a nanosecond, turning into a dirt parking lot.. Lucky for me I was going under 20. Probably on the ground for 15 minutes, I really like the stock vacuum petcock. ![]() If that doesn't work, remove the tank, using air or a hose, blast the area around the spark plugs (always full of debris that you don't want in your cylinder, like sand or gravel), loosen the plugs a bit (half turn?, this will loosen any thing wedged against the plug), blast with air or water again and remove the plugs. If you have air, blow out the cylinder to displace the fuel vapors. If you don't have air, hold the throttle wide open (fuel won't flow at cranking speeds with an open throttle), crank the starter 'for a bit', to purge fuel vapors. Replace plugs, start motor. Maybe. |
10-14-2012, 07:36 PM
#70237 |
ADV in training
Oddometer: 610
Hit up RideFreak on these forums. He does rides up in UT pretty often from what I understand. He might have some tracks you can follow.
_________________________ Ride videos '01 DR650 "The impossible often has a kind of integrity which the merely improbable lacks." |
10-14-2012, 07:41 PM
#70238 |
Finding Touge
Oddometer: 97
Here she is. The virgin!
![]() 2001 with 7700 miles. |
10-14-2012, 07:42 PM
#70239 |
ADV in training
Oddometer: 610
She looks good!
10-14-2012, 07:46 PM
#70240 |
Finding Touge
Oddometer: 97
I have a rm250 1990s Donor bike. Almost complete bike without the cylinder head and seat. Everything else is there. USD forks, bigger rear wheels(19" ??) etc.
I am wondering what kind of parts I could fit onto the dr650. Is it even worth it? Is it a rm250 by the way? :)
Ren20 screwed with this post 10-14-2012 at 08:52 PM |
10-14-2012, 07:53 PM
#70241 |
Harris's hawker
Oddometer: 168
780 for sale in Seattle area
No affiliation, but I might give this one a test ride.
![]() http://seattle.craigslist.org/skc/mcy/3303257537.html
2008 DR650SE supermoto 2009 CRF230M |
10-14-2012, 08:20 PM
#70242 | |
Oddometer: 918
Ck dsm for tracks. Strega and Crawdaddy on ADV have some tracks up there. We did the X-Plane ride http://dualsport-sd.com/forums/index...__1#entry35945 a few years ago and a lot of our local group spends time up there. I missed the Utah trip a week or so ago. http://dualsport-sd.com/forums/index...-of-utah-1012/ Enjoy! Ren20 - that thing looks like it did all 7700 miles in a climate controled garage! Nice.
www.dualsportmoto.com 2005 DR650 2013 HD Road King "It's a small amount of gas, but it represents a long walk" My Dad... |
10-14-2012, 08:36 PM
#70243 | |
ADV in training
Oddometer: 610
10-14-2012, 08:52 PM
#70244 |
Oddometer: 1,637
Presumably the front end is bolt on. Probably pass on the 19" rear. Front brake may be a challenge. Go for it.
10-14-2012, 09:12 PM
#70245 | |
Oddometer: 1,165
![]() doug s. |
