Old 10-22-2012, 01:51 AM   #70291
kezzajohnson
kezza
kezzajohnson's Avatar
Oddometer: 1,711
Originally Posted by PPCLI-Jim View Post
My only issue with the current design like the DR Vapor setup is the difficulty getting to the key, if you have a set of gloves on. I wish they could of raised it or had a side accessed key which is something i am trying to wrap my brain around and design for myself
Not if you make a bracket to keep it at a similar height to the stock speedo.
KezzaJohnson Blue 06 DR650se,Yellow 06 DRZ250
Website: http://www.territoryon2wheels.com
"May the Road Never Rise to Defeat you..."
kezzajohnson is online now   Reply With Quote
Old 10-22-2012, 05:10 AM   #70292
Slideways#96
scooter trash
Slideways#96's Avatar
Oddometer: 592
Originally Posted by Kommando View Post
Forks from a donor bike (re-sprung and valved for the weight) and a fully-adjustable shock with appropriate spring. Cogent is usually highly recommended for DR shocks. I'd like to have a remote preload adjuster too.
Note: I'm not riding a 350-400lb adv-thumper like a MX/XC racebike. I'm riding at an exploratory/fun pace when offroad. If I wanted to skim whoops and clear triples, I'd be on a 300lb-or-lighter bike.The DR's thin-wall frame isn't designed to take that kind of abuse with a load of luggage anyway. If I can get 3-4' of air and hit 6-12" ruts without bottoming/wallowing, I call it good enough.
Kommando,
I'm looking for a good set up for rocks. I've got a 300 xcw that will basically glide through rocky sections, ie streambeds and rock strewn roads. The Dr is understandably a different animal altogether however she is a handful in this stuff. Looking to smooth out the ride in these instances. She has eibach springs and is set up for my weight (petite 210 w/gear) but I'm thinking there has to be additional mods I can make to the big girl.
Slideways#96 is offline   Reply With Quote
Old 10-22-2012, 06:45 AM   #70293
acesandeights
Asperger
acesandeights's Avatar
Oddometer: 4,095
Originally Posted by Slideways#96 View Post
Kommando,
The Racetech rear shock assembly is a OEM replacement with significant improvements. It's stronger, has a Gold Valve kit and rebound adjustment. It's also made, same as the OE, so it can be put in the higher or lower height positions. If you already have the correct spring for your weight, it's $399 (or less through other vendors).
The emulators for the front forks "emulate" a more expensive offroad cartridge fork and are roughly ~$169 if you already have the springs you need for your weight.
http://breakingbooks.wordpress.com
Amazballs Indi-music at https://soundcloud.com/sprunty2000/
I may not be Rainman, but I'm not stupid eighter. Like Bartek on a taco.
I'll die with this hammer in my hand.
acesandeights is offline   Reply With Quote
Old 10-22-2012, 07:58 AM   #70294
procycle
procycle's Avatar
Oddometer: 2,463
Originally Posted by NordieBoy View Post
I got an Acewell...
Ran the pickup cable down inside the fork boot.
Brilliant!
Clarke's second law of Egodynamics: "For every expert, there is an equal and opposite expert." - Jasper Fforde
www.procycle.us - Everything for your DR650 and lots of other great stuff!
DR900 Big Bore Stroker buildup
TurboDiesel Corvette - go to the end to start at the beginning
procycle is offline   Reply With Quote
Old 10-22-2012, 08:03 AM   #70295
Pike Bishop
Pull Down the Ponzi.
Pike Bishop's Avatar
Oddometer: 11,115
Dr650 batteries ... 50% more power for $8.79
OK, a few days ago in this thread I posted about doing research on replacement batteries for the DR650.
In my last post, I think I mentioned that I had decided, for my next battery, to use a Yuasa YTZ14S which is the same size as the OEM battery, except 3/16" taller (someone said they still fit and after opening up my bike, I bet they do) ... but the YTZ14S stores almost 50% more energy than the stock battery (11.5 Ah versus 8 Ah).
Anyway, I had saved an ebay bookmark where they were selling these batteries, and while cleaning up my bookmarks I looked at the ebay ad again, and THEY'RE NOW SELLING THESE BATTERIES FOR $8.79 WITH FREE SHIPPING!
SCORE!
If you're in the market for a new battery for your DR, take a look! For less than $9 delivered, how can you go wrong?
http://www.ebay.com/itm/New-YTZ14S-B...-/190737356832
Edited to Add: On second look, they appear to be knockoffs, not Yuasa batteries, but still the ebay merchant has almost 82000 points with 99.6% positive feedback...I have no financial relationship with them, and have my fingers crossed...
Pike Bishop screwed with this post 10-22-2012 at 08:08 AM
Pike Bishop is offline   Reply With Quote
Old 10-22-2012, 08:09 AM   #70296
FlowBee
Just me.
FlowBee's Avatar
Oddometer: 5,754
Anybody here use a short Suzuki sidestand with a standard height suspension bike? Is the shorter sidestand 1.5" shorter like the shortened suspension mod it is meant for? Is it too short? I wasn't able to answer my question by searching this thread.
My loaded up DR is precariously close to vertical, even with the rear preload cranked up a bit. I may just take the sidestand down to the local muffler shop to see if they can take an inch offf the bottom and re-weld a new pad on the bottom. I just thought I'd ask here first in case I just want to throw my credit card at the problem instead...
Thanks in advance.
"And then this one time at banned camp ....."
FlowBee is offline   Reply With Quote
Old 10-22-2012, 08:13 AM   #70297
Mongle
Knuckle dragger
Mongle's Avatar
Oddometer: 3,278
That is how I did mine. Easy to see and function. With the windscreen on it is a little harder to get to due to the screen arms.
I went overkill on my bracket.... 1/4" thick 6061 alumn. Was the thinnest I had at the time and I wanted to get it done. I think I could lift the front of the bike with my vapor mount!
Mongle is offline   Reply With Quote
Old 10-22-2012, 08:15 AM   #70298
B.E. Coyote
(Super-Genius)
B.E. Coyote's Avatar
Oddometer: 5,610
ordered one, hope it works out better than my last ebay battery
B.E. Coyote is offline   Reply With Quote
Old 10-22-2012, 09:24 AM   #70299
Pike Bishop
Oddometer: 11,115
Any decent welder who owns a hacksaw should be able to take an inch out of the middle and reweld it in about 10 minutes flat.
Old 10-22-2012, 09:41 AM   #70300
ER70S-2
ER70S-2's Avatar
Oddometer: 7,261
Cut it off at the bottom, just above the foot gusset. That way there's no length below the weld to 'lever' against the weld. And then there's no need to fit an inner sleeve either.
The stock kick stand has a reinforcement at the top, by the pivot. That's where the force is focused. Think about using a crescent wrench to bend an edge on something. The force is at the jaw, not where your hand is.
2004 DR650: 62,605 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is online now   Reply With Quote
Old 10-22-2012, 10:06 AM   #70301
Kommando
Kommando's Avatar
Oddometer: 7,390
Kommando,
I don't ride that kind of terrain much, but we have ruts around here that seem to deflect lighter bikes with stiff suspension more than the relatively-soft and heavy DR that just kind of plows through crud. Mine feels just a bit stiff at low speeds with Eibachs for similar weight and with heavier fork/shock oil. I'm thinking that slightly-softer springs and lighter oil, with adjustable damping (where the DR lacks), would work better than heavy springs with no damping adjustment, unless you're moving pretty good. When I'm moving faster than the bottom of 2nd, mine feels pretty plush through most ruts and bumps.
Did you try the soft progressive stock springs in this stuff before swapping to the Eibachs? With different preload?They'd probably be a bit too soft with stock damping, but it might give you a better idea of which direction to go with spring-rates.
Kommando is offline   Reply With Quote
Old 10-22-2012, 10:16 AM   #70302
TinkerinWstuff
Take it apart
TinkerinWstuff's Avatar
Oddometer: 1,295
For those of you who've tinkered with dr650 suspension mods I've got a question:
If you could have ANYTHING done on yours what would it be; forks from a donor bike, different swingarm and/or shock or would the ultimate fix be too cost prohibitive wherein a prudent person would save the cash and apply towards a different bike altogether?
Ricor Intiminators (drop in + oil change = job done. no permanent modifications required.)
shimstack and oil change in rear by local suspension guru.
all smiles
1999 Suzuki DR650
1998 Honda VFR800 Interceptor
http://share.findmespot.com/shared/f...KJutW9osVpn3hd
TinkerinWstuff is offline   Reply With Quote
Old 10-22-2012, 11:05 AM   #70303
johnkol
Oddometer: 136
Originally Posted by TRAVELGUY View Post
I have already decided on the rims sealing procedure that I will and have supplies on hand. Just interested in the results that other DR riders have had.
I sealed my rims and they have been working fine for more than 6 months and 5000 miles. They lose air at the rate of about 3psi per week, but compared to the advantages, airing up once a week is a very small price to pay.
johnkol is offline   Reply With Quote
Old 10-22-2012, 11:19 AM   #70304
neo1piv014
ADV in training
Oddometer: 627
What'd you use to seal them up? Pinching tubes is a serious pain in the ass, so if there's something that can be done...
_________________________
Ride videos
'01 DR650
"The impossible often has a kind of integrity which the merely improbable lacks."
neo1piv014 is offline   Reply With Quote
Old 10-22-2012, 11:33 AM   #70305
TinkerinWstuff
Take it apart
Oddometer: 1,295
search around, there are threads all over re tuBliss
http://tubliss.com/
1999 Suzuki DR650
Times are GMT -7.   It's 11:19 PM.
