Old 10-17-2012, 01:23 PM   #70321
BlueLghtning
Riding is my passion
BlueLghtning's Avatar
Oddometer: 3,864
Send a message via AIM to BlueLghtning Send a message via MSN to BlueLghtning Send a message via Yahoo to BlueLghtning
Originally Posted by Albie View Post
Antigravity batteries are the new hotness. Lot more CCA then the Shorai, better warranty and made in the US instead of China. Of course they're more expensive as well $179 for the 98 + DR's
+1 there is a couple threads on here about Shorai and Antigravity and Antigravity did much better in the tests people were doing.
BlueLghtning - Follow me on my SPOT Messenger
Mine: 09 DL650, 01 FZ1, 08 WR250R, 98 DR650
Hers: 06 F650GS, 12 Duc 696, 13 CRF250L, 06 XT225
Smugmug Pics - Save $5: Y2l43o9LVBERU
BlueLghtning is online now   Reply With Quote
Old 10-17-2012, 02:53 PM   #70322
victor441
victor441's Avatar
Oddometer: 466
Originally Posted by DockingPilot View Post
Any of you fellas know if it is possible to disable the low beam rocker switch thereby making it a headlight shutoff switch ? In other words, high beam position headlight on, low beam position, headlight off.
Thanks,
Frank
That would work if you snipped and capped the low beam wire at the headlight socket, but there is a much better way to add headlight switching and retain both beams by adding a relay and two diodes, under $10, works great...see http://www.advrider.com/forums/showthread.php?t=506789
I wired a Ducati up that way and posted some additional info that might be helpful at http://www.ducatimonsterforum.org/index.php?topic=32045 (the wire colors shown below are for Ducati, Suzuki colors different (HB is yellow IIRC) but otherwise wired the same)
victor441 screwed with this post 10-17-2012 at 03:01 PM
victor441 is offline   Reply With Quote
Old 10-17-2012, 03:07 PM   #70323
barko1
barko1
barko1's Avatar
Oddometer: 2,512
Thanks,
Frank
Yes! I installed a rocker switch so I could turn off the headlight to conserve power when running my electric vest and heated grips. My high beam works as it always does but if my added switch is off then there is no low headlight. If I turn my added switch on the the stock headlight switch and light works as usual, both high and low.
DR650, 98 Bimota SB6R, Kawasaki 14, 67 X-6 Scrambler (apart), SL350K1, 77 Goldwing 1000, V11 Rosso Mondello Guzzi
barko1 screwed with this post 10-17-2012 at 03:43 PM
barko1 is offline   Reply With Quote
Old 10-17-2012, 03:47 PM   #70324
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 5,400
Thanks,
Frank
Yes, that's how my headlight is wired. I found the correct wires up in headlight Nacelle ... leave the HI/LO beam switch alone.
I originally ran the high beam wire through a separate switch I mounted in dash. In high beam position I could turn headlight light ON/OFF using my added switch. In low beam, light operates normally, switch has no affect.
When I added a single filament 35W HID I no longer had a high beam light, so now, high beam position is OFF, low beam is HID light. Wiring did not change other than to by-pass former ON/OFF switch, which is no longer needed with this set up.
Clear as mud, right?
The wires you want I think are yellow and red. (??) Trace them back from bulb and you can figure out where to cut and where to run your switch (if desired). I found this easier than trying to fiddle the delicate HI/LO switch on the handlebar.
Old 10-17-2012, 05:18 PM   #70325
dman
Oddometer: 426
Originally Posted by neo1piv014 View Post
Just cleaning up some of the older parts on this bike, I've noticed that my turn signal switch has been very...sticky...for lack of a better word, and sometimes requires multiple strong presses to actually disengage the signals. At this point, it's mostly just irritating, but getting it moving smoothly again would go a long way towards helping the way this bike feels. Is there a particular kind of lubricant that I should use to grease it up if I took it apart, or is there maybe a relatively inexpensive place to order a brand new set of switch gear for my bike?
Had EXACTLY the same issue, and as another poster said, WD40 solved the problem in seconds.
dman is offline   Reply With Quote
Old 10-17-2012, 05:23 PM   #70326
DockingPilot
Hooked Up and Hard Over
DockingPilot's Avatar
Oddometer: 7,461
Thanks fellas,
did it, easy-peasy.
If I'm riding on roads with cars I always have my hi beam on (modulated), never the low. So the low for me is kinda useless. Even at night because it just don't put out enough on either quite frankly. And I hardy ride at night. So to run my Gerbing jacket and gloves I can now just easily switch it on or off depending on the situation and what my 478c is reading for voltage.
Frank Reinbold
"Every bike I ever had, was the best bike I ever had, when I had it"
*2010 FOREVER WEST*
NEW ENGLAND AND CANADA OFFROAD F800GS
14 DAY IDAHO ADVENTURE KTM 950
TRANS AM TRAIL WEST
TRANS AM TRAIL VID CLIP
THE DEAN OF WESTERN ADVENTURE ROUTES
DockingPilot is online now   Reply With Quote
Old 10-17-2012, 06:33 PM   #70327
eakins
Butler Maps
eakins's Avatar
Oddometer: 14,458
Originally Posted by Pike Bishop View Post
Thanks fellas. After perusing your links and doing a Google search of advrider (way better than the in-house search functionality BTW) I decided that if I need a battery (I'm hoping this one might just need some water and a charge) the 10.5 Ah AGM Motobatt MBTX9U for ~ $67 is the way to go.
I appreciate your help.
nice catch. $8 more but it's 160cca vrs 120 on the Deka.
bike has to start really strong.
deka is us produced vrs china for the motobatt, but the chinese can produce quality if instructed to. not as many reviews of the motobatt vrs the deka (aka big crank and a bunch of other relabels). i'm on 3yrs with my deka and it still starts strong. at these prices, when the battery gets questionable after 4yrs i just pop for a new one.
Ozarks
, Nor Cal , COBDR shipping, AZBDR scouting
Facebook:
http://www.facebook.com/butlermaps
Old 10-17-2012, 07:06 PM   #70328
badweatherbiker
badweatherbiker's Avatar
Oddometer: 648
Originally Posted by NordieBoy View Post
You want to go back to stock?
What is the jetting it's running at the moment?
Should be a 145 main and 3rd or 4th from top clip on the needle.
I loved my TwinAir, drilled pipe, ProCycle jet kit and cut airbox.
I have to pull the carb this weekend to check it out but it surges from the time I take off all the way through the gears and at highway speed. If it was right it wouldn't be a big deal but I don't have the time to tinker. the jet kit was installed by the p/o around 200 miles ago in August.
1996 Kawasaki KZ1000P (currently being rebuilt)
World class nutritional supplements, weight loss, meal replacement shakes, quality energy drinks, pre and post workout supplements!
Earn extra income, become a distributor or just purchase:
Advocare products-www.advocare.com/12084065
badweatherbiker is offline   Reply With Quote
Old 10-17-2012, 07:57 PM   #70329
barko1
barko1
barko1's Avatar
Oddometer: 2,512
Mine crapped out and no amount of WD40, contact cleaner, etc seemed to help so I picked up a newer one off Ebay. WD is probably good preventive maintenance, thanks for reminding me. Heading to Monticello Canyon in NM Friday, somewhere around 30-40+ water crossings
Old 10-17-2012, 11:33 PM   #70330
motolab
motolab's Avatar
Oddometer: 1,134
Does the problem get worse or better as the engine warms up?
Regards,
Derek
motolab is offline   Reply With Quote
Old 10-18-2012, 05:33 AM   #70331
planemanx15
planemanx15's Avatar
Oddometer: 740
Now that the weather is getting cooler, I have a question about the oil cooler. My commute to work is short, about 10 mins). Today it was around 45*F and the oil temp barely got to 110*F as per my vapor. That includes a 2 minute warm up prior to riding.
Should I cover my oil cooler for these short rides so that the oil can get to a better operating temp?
2000 Suzuki DR650 - 790cc Big bore kit, V-Strom seat, Warp 9 Supermoto rims, TM-40 carb.
1985 Yamaha CA50 - My Hot Rod
2009 Piaggio BV-250 - Escusi, Babba be bo-bee
planemanx15 is online now   Reply With Quote
Old 10-18-2012, 05:45 AM   #70332
Zapp22
ZAPP - Tejas
Zapp22's Avatar
Oddometer: 12,926
Question Transmission Rebuilders: a question
If one were to pro-actively rebuild the Transmission, and wanted to make sure its as bulletproof as possible, would you use aftermarket parts or not?
I realize our friends at Procycle [and maybe others?] have a super high-quality 3rd gear kit, but I'm wondering if the collective really KNOW FOR SURE what causes the 3rd gear to detonate the trans??? Its just really hard for me to fathom that Suzi would manufacture all the parts for the trans, and keep on manufacturing just one defective component... it does not pass sniff test.
So if rebuilding with Race-proven Baja-capable parts is the ticket - is there any science on how many of them blowup for one reason or other? how many units have been tested, in-service, for long periods of time as have the Suzuki parts? its a rhetorical question....
you who have done the job, what did you use?
Zapp
"I will not let the White City fall... nor our people fail.” - Aragorn
K4 WEESTROM Stealthfighter Black - Invisible to Radar
'02 DR650SE SOLD
'97 DR650SE My Fave
Zapp22 is offline   Reply With Quote
Old 10-18-2012, 05:59 AM   #70333
Zapp22
ZAPP - Tejas
Zapp22's Avatar
Oddometer: 12,926
i think you're on the right path. TTalk has a lot more discussion of carb/rebuild/etc for DR and my own personal opinion after reading obsessively on the topic is that its not easy to actually IMPROVE overall perf... there are far more fails than successes.... way, way, way more. those who are really good wrenches can succeed beautifully and have a bike that goes 5mph faster and gets there a good deal quicker, if that's important to you.....
Zapp
'02 DR650SE SOLD
'97 DR650SE My Fave
Old 10-18-2012, 06:04 AM   #70334
neo1piv014
ADV in training
Oddometer: 610
This is why Derek is a life saver.
_________________________
Ride videos
'01 DR650
"The impossible often has a kind of integrity which the merely improbable lacks."
neo1piv014 is offline   Reply With Quote
Old 10-18-2012, 06:05 AM   #70335
P-P
P-P's Avatar
Oddometer: 87
I use Silicone Spray - more dielectric and lasts quite well.
Just say NO! to CaliFornication!
P-P is offline   Reply With Quote
Times are GMT -7.   It's 05:49 PM.
