Old 10-23-2012, 01:15 PM   #70351
johnkol
Oddometer: 136
Originally Posted by isaac004 View Post
Anyone ever have any issues with a rough shifting gear box? My 2006 has around 11k-12k miles on the clock. When I shift from N to 1 or N to 2, from a stop at a normal idle speed, I feel the gears grinding quite a bit.
Yes, I have shifting problems too, but not with the first two gears. My main problem is 2 --> 3, and 3 --> 4, where I have to make multiple attempts to engage the next gear, but I also have difficulties downshifting all gears at once (as when you come up on a stoplight). None of this happens when the engine is cold, and there hasn't been any significant change in the time I have had the bike (got it with 5,500 miles, it now has 12,500).
I don't have a solution for it, but oil seems to make a difference: I switched from Shell Rotella to Mobil 1 synthetic and things have improved slightly.
johnkol is offline   Reply With Quote
Old 10-23-2012, 01:15 PM   #70352
procycle
procycle's Avatar
Oddometer: 2,407
Originally Posted by motolab View Post
Are you saying that a stock CV carbureted engine should have mixture strengths that vary this wildly?
I think what Mambo Dave was saying is the bike runs much better and he's happy with the results
Clarke's second law of Egodynamics: "For every expert, there is an equal and opposite expert." - Jasper Fforde
www.procycle.us - Everything for your DR650 and lots of other great stuff!
DR900 Big Bore Stroker buildup
TurboDiesel Corvette - go to the end to start at the beginning
procycle is offline   Reply With Quote
Old 10-23-2012, 01:20 PM   #70353
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 6,128
Anyone ever have any issues with a rough shifting gear box? My 2006 has around 11k-12k miles on the clock. When I shift from N to 1 or N to 2, from a stop at a normal idle speed, I feel the gears grinding quite a bit. I either have to "stomp" it (not actually stomp, but make the shift very fast to reduce the time spent grinding), or deal with a horribly clattering shift lever if I shift slowly. Maybe a few thousand miles ago it ever so slightly grinded, but it seems that it's getting worse.
Any ideas?
Check your shift lever. Make certain it's fitting tight on the shaft, no slop. In my experience they loosen up over time/use and can effect shifting. Also make certain of the position of the shifter. Sometimes it can be sitting TOO CLOSE to the case, which interferes with shifting action. If it can touch the case, not good. Needs a gap.
Old 10-23-2012, 01:24 PM   #70354
TRAVELGUY
Old Traveler
Oddometer: 699
Seems like you need to adjust your clutch!!
TravelGuy
Any ideas?
TRAVELGUY
DL1000 '05 black
DL 650 '06 Red
DR650 '07
TRAVELGUY is offline   Reply With Quote
Old 10-23-2012, 01:26 PM   #70355
TRAVELGUY
Old Traveler
Oddometer: 699
I just installed one of his brackets that relocate the "Dash LIghts". His bracket is a good change.
Travel
Guy
Originally Posted by vfr870 View Post
He meant turn signal/neutral light indicator. His bracket places them in a better location to be seen.
TRAVELGUY
DL1000 '05 black
DL 650 '06 Red
DR650 '07
Old 10-23-2012, 02:03 PM   #70356
Mongle
Knuckle dragger
Mongle's Avatar
Oddometer: 3,145
TravelGuy
+1
If your clutch is dragging it wont let the syncros slow down enough to engage- causing grinding. Higher gears always seem to mesh easier. I often don't even use the clutch when up shifting 3-4-5 just cruising around.
Mongle is offline   Reply With Quote
Old 10-23-2012, 02:18 PM   #70357
NewDR650seOwner
Oddometer: 19
Cry 2007 Dr650 fork width???
I can't seem to find this measurement. Can someone throw me a bone?
NewDR650seOwner is offline   Reply With Quote
Old 10-23-2012, 02:20 PM   #70358
NewDR650seOwner
Oddometer: 19
2007 Dr650Se fork width???
Its an SE, if that makes a difference.
Old 10-23-2012, 02:31 PM   #70359
Rusty Rocket
Life behind "Bars"
Rusty Rocket's Avatar
Oddometer: 9,529
Do you want to know the distance between the forks? Center to center? Or diameter?
on one side the sign it said "Private Road", but on the other side it didn't say nothin'
2009 DR650
..1972 Penton Six-Days ..1971 Suzuki TS185.. 2005 KTM 400exc
Member of: AMA, NETRA, Blue Ribbon Coalition, CCCofVT, Berkshire TR, CT Ramblers
Rusty Rocket is offline   Reply With Quote
Old 10-23-2012, 02:43 PM   #70360
BergDonk
BergDonk's Avatar
Oddometer: 3,809
Originally Posted by Mongle View Post
+1
Synchros, what synchros?
shed time IS quality time
BergDonk's DR650 BergDonk's XT1200Z
BergDonk is offline   Reply With Quote
Old 10-23-2012, 03:16 PM   #70361
motolab
motolab's Avatar
Oddometer: 2,777
Originally Posted by badweatherbiker View Post
By on top I meant freeway speed.
For diagnostic purposes, the road speed is mostly irrelevant. The throttle should be open less than 1/4 for steady speed freeway cruising. To be sure, put some tape on the throttle housing and the edge of the grip. Mark zero throttle with a sharpie. This is best done with the engine idling, so you can tell when the slack in the cable has just been taken up. Turn off the engine and mark wide open. Now take a tape measure (metric works best in my opinion) and measure the length of the arc. Put a mark at the mid point. Duplicate this procedure to mark the mid-point between here and zero throttle opening to get 1/4 open. Repeat for 1/8 and 1/16 openings. With the help of the marks, determine precisely during what throttle opening(s) it misbehaves. Don't have an accident trying to look at the marks while riding. If you do, I'm not responsible!
Ideally the fundamentals should be taken care of first. Make sure the slide, emulsion tube, and slide are not worn out. Replace the slide if it has been drilled. The float needle should be replaced if there is evidence of a witness line from seat contact evident on the rubber conical tip of the needle under magnification. Replace any rubber parts that have shrunken, deformed, hardened, cracked or otherwise been damaged. Set the float height to 14.7 mm with a float height setting tool. Replace the pilot jet for good measure. Install an adjustable aluminum jet needle with a reasonable profile. Reinstall the now missing white plastic needle spacer. Adjust the idle mixture and speed.
After that, tuning should be done from the top down, i.e. main jet for wide open throttle first, followed by clip position for 1/4 opening, followed by pilot jet size for 1/8 and 1/16 openings.
Regards,
Derek
motolab is offline   Reply With Quote
Old 10-23-2012, 04:17 PM   #70362
NewDR650seOwner
Oddometer: 19
I would like to know width of a single fork, so I guess diameter. Getting some clip ons.
Old 10-23-2012, 04:22 PM   #70363
JagLite
JagLite's Avatar
Oddometer: 1,380
Cool2 Carb parts and tuning
For diagnostic purposes, the road speed is mostly irrelevant. The throttle should be open less than 1/4 for steady speed freeway cruising. (Depending on your gearing of course as well as the speed of traffic on your freeway... ) To be sure, put some tape on the throttle housing and the edge of the grip. Mark zero throttle with a sharpie. This is best done with the engine idling, so you can tell when the slack in the cable has just been taken up. Turn off the engine and mark wide open. Now take a tape measure (metric works best in my opinion) and measure the length of the arc. Put a mark at the mid point. Duplicate this procedure to mark the mid-point between here and zero throttle opening to get 1/4 open. Repeat for 1/8 and 1/16 openings. With the help of the marks, determine precisely during what throttle opening(s) it misbehaves. Don't have an accident trying to look at the marks while riding. If you do, I'm not responsible!
Ideally the fundamentals should be taken care of first. Make sure the slide, emulsion tube, and slide are not worn out. Replace the slide if it has been drilled. (Or just put a drop of silicone to seal it, or leave the extra hole in it like the rest of us, even though Derek says it will shorten the life of other parts) The float needle should be replaced if there is evidence of a witness line from seat contact evident on the rubber conical tip of the needle under magnification. Replace any rubber parts that have shrunken, deformed, hardened, cracked or otherwise been damaged. Set the float height to 14.7 mm with a float height setting tool. (What!? You don't have one??? Neither do most of us) Replace the pilot jet for good measure. Install an adjustable aluminum jet needle with a reasonable profile. (Make sure it is reasonable. Try asking it political questions) Reinstall the now missing white plastic needle spacer. Adjust the idle mixture and speed. (Derek didn't mention that he stocks and sells all the parts for your carby. He is so modest)
Regards,
Derek
You got all that? Good.
Excellent advice from a tuner who has evidently tuned hundreds of DR's. Well, dozens at least. Ok, maybe a few?
Has anyone on here had Derek tune their bike?
If you live close to his shop it could be fun to have him tune it up.
Or perhaps send him your carb for a rebuild with new parts?
Might be less expensive to just get a new pumper carb though, I don't know.
Most of us are very happy with how our bikes run with a simple jet kit from Procycle.
However, if you carb has problems, like worn parts as Derek mentioned, nothing will work well until those parts are replaced.
I am sure Derek can help you determine what, if any parts are in need of replacement. Give him a call.
It would be very interesting, I mean VERY INTERESTING if someone would take their DR to Derek and dyno it before and after having him tune it.
The best would be if it had a Procycle jet kit in it and the owner believed it to be running very well.
And how it feels to ride afterwards. Hmmmmmm,...
Any takers? Purely in the name of research of course.
A before and after dyno chart would be very nice to see, eh?
Attitude ~
The difference between
Ordeal and Adventure
James
JagLite is offline   Reply With Quote
Old 10-23-2012, 04:26 PM   #70364
motolab
motolab's Avatar
Oddometer: 2,777
I'm all for it!
Regards,
Derek
Old 10-23-2012, 04:30 PM   #70365
JagLite
JagLite's Avatar
Oddometer: 1,380
Pissed USPS fail
On another subject... (please!)
My latest order from Procycle was delivered yesterday.
According to the USPS that is.
Who it was delivered to is the question since the carrier didn't put it in the correct box!
Hopefully whichever one of my neighbors actually got it will turn it in or bring it to me.
The problem of the common ganged lock-box mailboxes.
No way to determine who might have got it.
No street address on the boxes, more than 80 boxes...
The worst part?
My new ProCycle Tee-shirt was in it!!!!!!!
Attitude ~
James
Times are GMT -7.   It's 09:08 PM.
