10-20-2012, 11:45 AM
#70411 | |
on the road o'dreams
Oddometer: 5,377
One is to service your calipers, clean/polish pistons well, bleed all fluid & air out of system. Add New fluid. Next, clean up rotors with Steel Wool or light sanding, then wipe off with Brake Clean. Clean rotors every month or so. Next: I had been using less expensive EBC pads on my DR650 for a couple years. Braking force seemed to get worse as they wore down. I swapped in an old pair on OEM Nissin pads ... and WOW! Braking was up by about 20%! I believe EBC pads glaze and bite is reduced over time/use. I've since gone back to Nissin pads. Deals can be found on them if you dig around the net. Way better performance in my experience. Rear brake, EBC seems to work OK. I don't want a really over sensitive rear brake, so the Red EBC pads out back are OK for now ... and they last well. Next option UP is to go with a bigger front Rotor. EBC make one and probably others like: Braking, Galfer and Nissin and various Chinese options on EBay. Most provide an adapter ... so pretty much plug and play. Should make BIG improvement in braking power up front. I would start with the cheap things and work your way up. I know where you're coming from carrying all the weight on a RTW ride. Lots of extra weight really points out the weakness of standard braking. Mongolia on a DR!! How did that go? Good luck with your book! ![]() ![]()
10-20-2012, 11:49 AM
#70412 | |
Oddometer: 650
It starts beautifully, idles smooth too. I taped the airbox 3/4 closed up couple days ago and finally got around to riding it a bit ago (im at work) and that made it worse, twist the throttle a bit fast and it boggs down. I cleaned the little elbow fiter and same thing. again, plugs were a little on the whitish-greyish side s I dunno. exhaust smells like a damn lawn mower. I have a rattle somewhere I cant diagnose when I hit some bumps almost a squeal kinda tin sounding. I had some barkbuster knockoffs but they wouldnt work and one of the threaded stoppers inside the handlebars is missing so need to change them out, they are older purple bars on a yellow bike when it gets a bit colder im gonna need some wind deflectors.stupid kickstand hits the swingarm also, nice little groove there.
1996 Kawasaki KZ1000P (currently being rebuilt) World class nutritional supplements, weight loss, meal replacement shakes, quality energy drinks, pre and post workout supplements! Earn extra income, become a distributor or just purchase: Advocare products-www.advocare.com/12084065 |
10-20-2012, 12:04 PM
#70413 | |
Oddometer: 1,166
doug s. |
10-20-2012, 01:16 PM
#70414 | |
Oddometer: 137
What exactly are your 'decent pads'? The oem Suzuki pads are good, some of the aftermarket stuff is not so good. The best I have run across are EBC MXS. They are not listed for the DR but are the same as 07 Yamaha WR450 which is listed. I bought some for my WR and noticed that both bikes use the same model Nissin caliper. So I tried them, and wow, very noticable difference. Is there any posssibility that the pads you have have been overheated and glazed? If so pull the pads out and deglaze them by rubbing in a figure 8 motion on a piece of #180 sand paper on a flat surface. Give the disc a light sanding also.
Maynard " Youth is fleeting, immaturity is forever" |
10-20-2012, 01:22 PM
#70415 | |
Oddometer: 137
10-20-2012, 01:31 PM
#70416 | |
Oddometer: 1,110
Incorrect needle shape (example: DynoJet needle). Emulsion tube worn out due to worn out slide guide. Fuel level to high due to too little float height, faulty float needle, or faulty needle seat o-ring. Clipped slide spring. Sticking cold start enrichment plunger, due to a missing return spring or a kinked/otherwise binding cable. Jet needle too high (i.e clip too low).. Pilot jet too large. Main jet too large. Regards, Derek |
10-20-2012, 01:39 PM
#70417 | |
Ed
Oddometer: 691
My thoughts originally were that you had a lean surge going on when cruising and accelerating, which is why I suggested taping the opening a little. From your comments about the enricher I would agree with Doug that you are probably rich most everywhere now. Before tearing into the carb (which may be inevitable) I would try turning the pilot screw in a little to lean out the idle circuit a little and removing about half the tape you put on. Then see what it does. Remember the tape is only a quick fix to maybe get you in the ball park and help determine if it's lean or rich-- not a solution. Also did you note the location of the carb VENT filter (not gas) . It should not be hanging down in the airbox, but off to the side a little or the intake pulses in the airbox can mess with the carb slide and cause a surge. Good luck!
Rumlover screwed with this post 10-20-2012 at 01:55 PM |
10-20-2012, 01:56 PM
#70418 | |
Oddometer: 1,110
Regards, Derek |
10-20-2012, 02:13 PM
#70419 | |
Ed
Oddometer: 691
My thoughts were (now that we know it starts without the enricher) that there are possibly two issues going on. 1) pilot screw opened too much (so no enricher needed to start). 2) And what I thought was originally a lean issue on the needle and or main (causing surging), is now a rich condition because of the excess tape. That is why I suggested backing off the tape and turning the pilot screw in. Probably too many opinions now --- I will bow out to avoid confusing the issue.
10-20-2012, 02:20 PM
#70420 |
Oddometer: 1,643
Front Brake
If everything is up to scratch, a bigger disc is what's needed like others said. Its on my to do list. One other thing I did in addtion to a braided line was fit a Brembo master cylinder. Its got a smaller bore, so needs a bit more travel for the same force. With the braided line compensating, its a more progressive and controllable action, but ultimately, no more powerfull.
10-20-2012, 02:28 PM
#70421 | |
Oddometer: 1,110
Regards, Derek |
10-20-2012, 02:39 PM
#70422 | |
Oddometer: 5,377
Both are rated HH ... the Nissin is worlds better in my experience, but do wear quickly if used hard. The red EBC Kevlar ones I use in the rear brake. They are fine for me, don't need a lot of power there ... and can still lock up easy enough. I tend to drag the rear brake, so the hard wearing Red Kevlar ones seem pretty good. YMMV. |
10-20-2012, 03:32 PM
#70423 |
Oddometer: 650
You guys are awesome, thanks so much for the help and all the great info on diagnosing the issue.
I wont have another chance to peel away some tape until Monday when I am back at work (the bike is parked there) but I'll let you know what happens! It was just confusing because the plugs did not indicate a rich condition. so the consensus is remove some tape and turn in the mixture screw?
10-20-2012, 04:58 PM
#70424 | |
Old Traveler
Oddometer: 463
TravelGuy
TRAVELGUY DL1000 '05 black DL 650 '07 ( lives in Costa Rica ) DR 650 "08 .
10-20-2012, 05:16 PM
#70425 | |
Oddometer: 1,110
Start the engine and warm it up. Lower the idle speed below the factory spec. Starting from a setting that is known to be lean (1-1/2 turns is likely but not guaranteed to be), adjust the fuel screw to obtain the highest idle speed. Adjust to 1/8 - 1/4 turn richer than that. Then, adjust the idle speed back to 1500 rpm. Report back with the setting. In order to determine whether, as Rumlover suggested, the mixture was lean before the tape was applied and is only now rich, you could gradually remove more and more tape, testing after each change. If he is right, there will be a sweet spot where it runs better than it does now as well as how it ran un-taped. If the problem gradually gets better as you untape, but never gets better at any stage than before it was taped or now, then you started out too rich and taping only made it richer. Regards, Derek |
