Old 10-21-2012, 02:50 PM   #70441
Slideways#96
scooter trash
Slideways#96's Avatar
Oddometer: 280
Originally Posted by acesandeights View Post
I'd buy a different bike, or I'd buy the Racetech rear shock assy and Racetech emulators and springs.
Thanks for the reply! I'll do some research on the racetech mods.
Slideways#96 is offline   Reply With Quote
Old 10-21-2012, 02:53 PM   #70442
acesandeights
Asperger
acesandeights's Avatar
Oddometer: 2,047
It can all be purchased through Racetech, http://www.racetech.com or through one of their distributors.
http://breakingbooks.wordpress.com
http://www.kenmarshallmetalworks.com/
2011 DR650, Fly Aero tapered bars, Race Tech front springs/emulators, RT rear spring/shock shaft assy, BarkBusters, MT21s, 14/43T, etc
I may not be Rainman, but I'm not stupid eighter. Like Bartek on a taco.
acesandeights is offline   Reply With Quote
Old 10-21-2012, 02:58 PM   #70443
Slideways#96
scooter trash
Oddometer: 280
Great, thanks again!
Old 10-21-2012, 03:48 PM   #70444
FlowBee
Just me.
Oddometer: 3,385
My DR fully loaded pushes the limits of the OEM sidestand. I adjusted the rear preload but still feel it's too tall and ready to flop over on the right.
How much shorter is the DR650 OEM short sidestand compared to the OEM normal standstand? Would it work for heavily loaded DR650s ?
Thanks.
FB
This space for rent.
FlowBee is offline   Reply With Quote
Old 10-21-2012, 03:56 PM   #70445
Sierra Thumper
Oddometer: 641
Originally Posted by DockingPilot View Post
Wont matter, the engine is plenty big enough.
A 610. Carbed I rode
On a carbed 250, maybe you'd feel it , but not on the big bore DR and its not like your living up there, its up and over. Like I said youll never notice, The DR is the perfect weapon for the TAT. If your jetting is dialed in now, it will be fine for the trip Bri.
Yep if your jetting's currently dialed in, you'll be fine...you'll just lose some (or more ) power at the higher elevations.
"Don't get so concerned with the slab that you choose a turd for the dirt"- The Gospel as spoken by itrack
Sierra Thumper is offline   Reply With Quote
Old 10-21-2012, 04:05 PM   #70446
Fire Escape
Fire Escape's Avatar
Oddometer: 1,125
Sagging springs
Thanks.
FB
I went through that as well. I already had the short stand but had lowered the rear and dropped the front clamps about an inch on the tubes. No amount of preload adjustment (at least up to the manual prescribed minimum) would help the bike stand up (at least not for long, I tightened up on the rear pre-load a couple of times, it would seem better for a short time but the oem spring kept on sagging). I finally gave in and bought springs appropriate to my weight (for me that meant two up with luggage....even though I ride solo). The aftermarket springs haven't shown the same tendency to 'creep', bike height has remained 'normal' and I can be less particular about finding the 'right' spot to try and leave it on the side stand. It probably rides better as well, being as I am now riding in the middle of the shock stroke instead of the bottom. I am not sure that I am qualified to judge that. It certainly isn't all new suspension front and rear but springs are relatively affordable and not too challenging to install.
I know that I have a 'normal' side stand somewhere, if I find it soon, I will get measurements for comparison.
Bruce
No one calls the Fire Department because they did something smart!
06 DR 650, Moose RS Holder, Handguards and Skidplate, ProTaper bars, Garmin 60CSx, Motech racks w/ 20mm Ammo cans, Renazco, TKCs summer/17" SM wheels winter 08 Scrambler, Conti Trail Attacks and BlackTiger Fork mod, 05 FSE 450, 03 KLR 250, 02 FXDX, 72 WR 250 (again), 72 SL 350 K2 (again), 72 TR6R, 06 XT 225
Fire Escape is online now   Reply With Quote
Old 10-21-2012, 07:39 PM   #70447
shu
Oddometer: 757
Thanks.
FB
I had the same problem with not enough lean on my stand.
I'm not sure about the short sidestand- I think it's 1 1/2 inches shorter.
I took my stand to a local welder and had him cut about 1 inch out of my stock sidestand. He welded a pin in for strength and then welded the thing back together. This has worked great for the last 45,000 miles.
..............shu
shu is offline   Reply With Quote
Old 10-21-2012, 08:34 PM   #70448
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 6,769
I'd go Ricor front and rear.
Intiminators in the front and an IAS shock in the back.
At the moment the Intiminators are $180 (down from $300) and the shock is $550 (down from $890).
NordieBoy is offline   Reply With Quote
Old 10-21-2012, 09:15 PM   #70449
Kommando
Grumpy Young Man
Kommando's Avatar
Oddometer: 3,754
For those of you who've tinkered with dr650 suspension mods I've got a question:
If you could have ANYTHING done on yours what would it be; forks from a donor bike, different swingarm and/or shock or would the ultimate fix be too cost prohibitive wherein a prudent person would save the cash and apply towards a different bike altogether?
Forks from a donor bike (re-sprung and valved for the weight) and a fully-adjustable shock with appropriate spring. Cogent is usually highly recommended for DR shocks. I'd like to have a remote preload adjuster too.
Note: I'm not riding a 350-400lb adv-thumper like a MX/XC racebike. I'm riding at an exploratory/fun pace when offroad. If I wanted to skim whoops and clear triples, I'd be on a 300lb-or-lighter bike.The DR's thin-wall frame isn't designed to take that kind of abuse with a load of luggage anyway. If I can get 3-4' of air and hit 6-12" ruts without bottoming/wallowing, I call it good enough.
Kommando is offline   Reply With Quote
Old 10-21-2012, 09:37 PM   #70450
victor441
victor441's Avatar
Oddometer: 460
Originally Posted by PPCLI-Jim View Post
https://www.facebook.com/photo.php?f...0&l=bedbb74d41 shows the dash on my DR which I am still working on with the Vapor installed . From the factory it comes with a little clamp/base that connects to your handlebars. Unless you purchase the high speed bar mount made from alum. I like it the light isnt over poweringat night and its always easy to see unless you are at a realy odd angle from it.
the PO of my bike made a clever Vapor mount from aluminum angle and rivets, works great and is light...
victor441 is offline   Reply With Quote
Old 10-22-2012, 12:12 AM   #70451
PPCLI-Jim
PPCLI-Jim's Avatar
Oddometer: 143
My only issue with the current design like the DR Vapor setup is the difficulty getting to the key, if you have a set of gloves on. I wish they could of raised it or had a side accessed key which is something i am trying to wrap my brain around and design for myself
I'm not saying to kill all the stupid people . .. Just remove the warning labels and let nature run it's course
http://www.youtube.com/user/spudhead/videos?view=0 my youtube channel
PPCLI-Jim is offline   Reply With Quote
Old 10-22-2012, 12:56 AM   #70452
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 6,769
I got an Acewell but it has the same bolts out the back for mounting...
I just drilled a couple of holes in the existing speedo mount...
http://sports.nelson.geek.nz/motorsp...ing/index.html
Ran the pickup cable down inside the fork boot.
Old 10-22-2012, 01:51 AM   #70453
kezzajohnson
kezza
kezzajohnson's Avatar
Oddometer: 731
Not if you make a bracket to keep it at a similar height to the stock speedo.
KezzaJohnson Blue 06 DR650se,Yellow 06 DRZ250
Website: http://www.territoryon2wheels.com
"May the Road Never Rise to Defeat you..."
kezzajohnson is offline   Reply With Quote
Old 10-22-2012, 05:10 AM   #70454
Slideways#96
scooter trash
Oddometer: 280
Kommando,
I'm looking for a good set up for rocks. I've got a 300 xcw that will basically glide through rocky sections, ie streambeds and rock strewn roads. The Dr is understandably a different animal altogether however she is a handful in this stuff. Looking to smooth out the ride in these instances. She has eibach springs and is set up for my weight (petite 210 w/gear) but I'm thinking there has to be additional mods I can make to the big girl.
Old 10-22-2012, 06:45 AM   #70455
acesandeights
Asperger
Oddometer: 2,047
Kommando,
The Racetech rear shock assembly is a OEM replacement with significant improvements. It's stronger, has a Gold Valve kit and rebound adjustment. It's also made, same as the OE, so it can be put in the higher or lower height positions. If you already have the correct spring for your weight, it's $399 (or less through other vendors).
The emulators for the front forks "emulate" a more expensive offroad cartridge fork and are roughly ~$169 if you already have the springs you need for your weight.
Times are GMT -7.   It's 07:59 AM.
