10-22-2012, 09:28 PM
#70486 |
Road Less Traveled
Location: Thumpin' in North GA - headin' for the Smokys
Oddometer: 457
If you're considering the Procycle seat, I just posted one in the Flea Market. Thought I'd give a heads up here to the DR650 thread.
http://www.advrider.com/forums/showt...6#post19878796
Dirtly: 2009 Suzuki DR650SE Road Sofa: 2001 Yamaha (ad)Venture 1300 Dirtlier: 1999 Suzuki DR350SE Old Sport: 1979 Suzuki GS1000E 1996 Suzuki Intruder 1400 (for sale) 1987 Yamaha TT600 (for sale) GaThumper screwed with this post 10-23-2012 at 10:18 AM |
10-22-2012, 09:34 PM
#70487 | |
on the road o'dreams
Oddometer: 5,377
How about 50/50 tires like Mefo's or other Euro tires? Are you running a tubeliss rim up front as well or only on the rear? (Woody recommends doing rear only) I must have really screwed up my sealing job. I'll have to read that thread and see if I can salvage what I did. Thanks for the feedback and links. |
10-22-2012, 10:00 PM
#70488 | |
Butler Maps
Oddometer: 14,426
i've noticed i can put my finger into the inner spacer and move it around some. i can push one side up or down a small bit. if it can be pushed back and forth from side of the hub to side of the hub then yes something is not correct, but mine is not locked in there solidly when the wheel is off. assuming there is no damage to the hub (so the bearing sit properly per spec) and there in no dirt and such in the hub cavity (so the bearing would not fully seat properly), i'd say when the full assy is properly torqued everything comes together just as it should. the axel will center spacer upon assy, so it has to sit correct. this spacer of course supports the bearings so they have no lateral forces in play, the inner bearing lips are supported from one end to the other. without this spacer, the bearing would fail inwards. i use 73 ftlbs of torque on the rear axel nut. those with older DRs can upgrade to a new cotter-pinless fuji-nut from Procycle so you torque it and go.
Butler Maps - motorcycle maps for riders by riders - Ozarks , Nor Cal , COBDR shipping, AZBDR scouting http://www.advrider.com/forums/showthread.php?t=598717 Facebook: http://www.facebook.com/butlermaps |
10-22-2012, 10:39 PM
#70489 | |
Armature speller
Oddometer: 6,765
10-22-2012, 11:52 PM
#70490 |
Oddometer: 148
10-23-2012, 12:07 AM
#70491 | |
Oddometer: 116
Tubeless conversion on the front too. Yes, I've read the objections about going tubeless on a wheel without a safety bead, but I do not share these concerns: on one hand, one of the main advantages of tubeless tyres is the fact that they deflate very slowly, so the chance of the tyre suddenly losing all pressure, collapsing on the rim, and you losing control of the bike, is highly improbable; and on the other hand, how is a tube going to prevent the above scenario? In fact, this is far more likely to happen to a tubed tyre. I did the conversion this last spring, so I've only had the chance to use the Shinko 705. But they're almost worn now, so I will be trying the Shinko 700 soon. After that I'll try the Shinko 244. |
10-23-2012, 01:28 AM
#70492 |
GSXR!!!
Oddometer: 45
10-23-2012, 01:34 AM
#70493 |
GSXR!!!
Oddometer: 45
I fitted a FCR to the DR and had a few issues with the throttle cable. Sorted that out and the bike runs like a dream. Fuel economy around 17km/l consistantly regardless of how much throttle I use or terrain I conquer. Only issue is that the bike is still popping when I close the throttle and the beast does not idle when cold. Any advise out there, or should I just ride and enjoy?!?!
10-23-2012, 04:52 AM
#70494 | |
Oddometer: 70
short stand
My bike is stock height with the procycle stiffer springs front and back. One of my riding buddies bought their shortened stand and in a moment of weakness sold it to me (he was in-between DR's at the time). So i have the procycle 1.5" shortened stand and it's perfect for the stock height. I have fully loaded dirtbagz and a top box...all in all, at least 50lbs of junk in addition to my svelte 230lb ass and my stand is rock solid. Only time i worry is if i'm in soft wet dirt...then it'll sink in. I just grab a rock or branch to put under it if it looks like it's going to sink in.
When my buddy bought a new 2012 DR and lowered it using the suzuki stock lowering options, his stand was way too tall and he cut off the foot about 3" up. Once he was sure that the height was ok, i took the stock stand and cut out about 2" from the tube and welded the foot back on. I used the cut out section inside the tubes to give it some additional strength. I cut it lengthwise so that i could roll the tube small enough in diameter so that i could hammer it inside the stand. Once welded, it's probably stronger at that joint than the rest of the tube. So far, he's used it for 1000's of miles and hasn't had any trouble with it. Quote:
10-23-2012, 07:42 AM
#70495 |
ZAPP - Tejas
Oddometer: 12,919
this bike could DEFINITELY benefit from one of my turnsignal relo parts..
Zapp "I will not let the White City fall... nor our people fail.” - Aragorn K4 WEESTROM Stealthfighter Black - Invisible to Radar '02 DR650SE SOLD ![]() '97 DR650SE My Fave
10-23-2012, 08:15 AM
#70496 | |
Oddometer: 739
2000 Suzuki DR650 - 790cc Big bore kit, V-Strom seat, Warp 9 Supermoto rims, TM-40 carb. 1985 Yamaha CA50 - My Hot Rod 2009 Piaggio BV-250 - Escusi, Babba be bo-bee |
10-23-2012, 08:39 AM
#70497 |
Oddometer: 458
The cheaper Garmin Nuvi's are not waterproof but the 500/550 models are and they sell for about $265- and also have a built in battery good for several hours so they can be used for bicycling, walking, geocaching, etc...
victor441 screwed with this post 10-23-2012 at 10:55 AM |
10-23-2012, 09:35 AM
#70498 | |
Oddometer: 650
Grrrrrr!
1996 Kawasaki KZ1000P (currently being rebuilt) World class nutritional supplements, weight loss, meal replacement shakes, quality energy drinks, pre and post workout supplements! Earn extra income, become a distributor or just purchase: Advocare products-www.advocare.com/12084065 |
10-23-2012, 09:42 AM
#70499 | |
Oddometer: 2,482
I've read write-ups of the whole Dyno-jet needle Pro Cycle jet kit thing being wrong for DR650's... but then my bike ran so much better with the changes that I'm just not sure what those people were talking about. It may not be perfect, but it certainly makes the bike run as a stock bike should. |
10-23-2012, 09:54 AM
#70500 | |
Oddometer: 1,110
Regards, Derek motolab screwed with this post 10-23-2012 at 01:36 PM |
