Old 10-31-2012, 01:52 PM   #70606
neo1piv014
ADV in training
Oddometer: 619
Originally Posted by Sammalamma View Post
Thanks for you opinion and the good idea to use PS. I mostly wish I had the racks that compensated for the muffler so I could fit a spare fuel jug or tool case in the gap in between.
This is a bit...ghetto, but you might be able to use some study spacers to push the other pannier out by an inch or so. I'm not sure if that'd put too much stress on the rack, but if you're just looking to even it out, that might be a better [cheaper] option than buying a second case.
_________________________
Ride videos
'01 DR650
"The impossible often has a kind of integrity which the merely improbable lacks."
neo1piv014 is offline   Reply With Quote
Old 10-31-2012, 01:55 PM   #70607
Rob.G
Mostly Harmless
Rob.G's Avatar
Oddometer: 2,167
Originally Posted by PPCLI-Jim View Post
sounds like the bearings have given up the ghost. Dried up or theres a rusted one. the bearings are supposed to roll freely if they are dried out , or the grease is corrupted it would cause those issues. the reason you dont see it with the wheel in the air is there is no load on it. put a load on it and then the bearings really cominto play. sounds like you know what the issue is but just need a little hand holding. trouble shooting and being able to explain it to someone else goes along way to resolving issues and saving money. caause you have explained it happens under load , changed tires still happens remove load and the issue goes away . check the bearings replace or grease them . Jimbo
Thanks! I'm glad to know this is the likely culprit.
I found the page in the service manual (5-20), but it makes no mention about the bearings needing to be pressed. I suppose if they do, I'll run the stem over to the local cycle shop and let them do it. I'll get the bike ready to be disassembled tonight after I straighten up the garage a bit. The bearings are due here tomorrow.
Rob
'12 Suzuki V-Strom DL650
'96 Suzuki DR650
'92 Yamaha TW200
Rob.G is offline   Reply With Quote
Old 10-31-2012, 02:07 PM   #70608
sandwash
sandwash's Avatar
Oddometer: 1,350
The bearing itself is not pressed,but 3 of 4 races are.If I remember right.
97dr650
sandwash is offline   Reply With Quote
Old 10-31-2012, 02:15 PM   #70609
victor441
victor441's Avatar
Oddometer: 931
Originally Posted by Rob.G View Post
I just ordered new steering bearings from ProCycle. Is there a link to a HOWTO on changing these out? I have the service manual, but wanted to ask here first. I'm not sure if I have the tools needed to do this, especially if it requires them to be pressed on or off.
Something weird is going on with my steering. I've posted about it here before but never figured it out. But it feels like there's an on-center "detent" that makes it very hard to actually turn the bars ever so slightly (whether countersteering at speed, or regular steering at low speeds) that makes it necessary to exaggerate. I've used four different sets of tires on the bike and it does it with all of them, so it's not the tires. So it comes down to either the steering bearings or maybe something in the forks. The detent, or "notch," is undetectable with the front wheel off the ground, but with weight on the front wheel, even at a standstill, it's easy to feel. My KLX250S doesn't do this and neither does my FZ1.
Rob
That problem is common on BMW airheads FWIW, the tapered rollers make small dents in the races (brinelling) and the steering becomes indexed like you said, happened to me. There are probably some writeups here or elsewhere on the web on replacing the bearings on a BMW that might be helpful, there are some tricks for removing and installing the races.
http://en.wikipedia.org/wiki/Brinelling
victor441 screwed with this post 10-31-2012 at 02:27 PM
victor441 is offline   Reply With Quote
Old 10-31-2012, 07:20 PM   #70610
procycle
procycle's Avatar
Oddometer: 2,280
...it feels like there's an on-center "detent" that makes it very hard to actually turn the bars ever so slightly (whether countersteering at speed, or regular steering at low speeds) that makes it necessary to exaggerate...
Classic symptoms of worn steering bearings. When you haven't experienced detented bearings before it feels like tire problems. It can make it very difficult to ride in a straight line at medium speeds.
Clarke's second law of Egodynamics: "For every expert, there is an equal and opposite expert." - Jasper Fforde
www.procycle.us - Everything for your DR650 and lots of other great stuff!
DR900 Big Bore Stroker buildup
TurboDiesel Corvette - go to the end to start at the beginning
procycle is offline   Reply With Quote
Old 10-31-2012, 07:48 PM   #70611
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,602
Often you feel it as you come to a stop. The bike weaves around really badly then.
Old 10-31-2012, 08:22 PM   #70612
Rex Nemo
horizon calling
Rex Nemo's Avatar
Oddometer: 321
Originally Posted by Feelers View Post
Is that the Coyote bag or the Great Basin?
Great Basin. I also have a Coyote for shorter trips.
Another note--it's possible to pack a bit lighter on trips with a group, as you can share tent, stove, and such. Solo, your load is necessarily heavier.
Wandering re-establishes the original harmony which once existed between man and the universe. --Anatole France
Rex Nemo is offline   Reply With Quote
Old 10-31-2012, 09:03 PM   #70613
P-P
P-P's Avatar
Oddometer: 97
I agree wholeheartedly Travelguy! Not that I can do half of what that man could do, I give him (and all the other brave souls here)credit for DOING IT! Lifes an adventure and we need to ride OUR adventure... yours may be 4wd with a bike in the back... his was a bike with a 4wd and a bunch more in back!! Keep on truckin!
Originally Posted by TRAVELGUY View Post
What a limited "point of view" you have of life.
TraveGuy
Just say NO! to CaliFornication!
P-P is offline   Reply With Quote
Old 10-31-2012, 10:00 PM   #70614
JagLite
JagLite's Avatar
Oddometer: 1,201
Thumb Stem Bearing install
I put the bearing in the oven and the stem in the freezer.
The bearing slid right on the stem, no force needed.
I put the bearing cup in the freezer and was able to press it (them) into the steering head by using a 12" long piece of 5/8" all-thread with a stack of increasing size washers and a nut on each end. The largest washer must be big enough to cover the stem tube so that when you tighten the nuts one end can't move and the other end pulls the bearing cup down into the stem.
You do need to make sure the cup stays straight and pulls in evenly.
I use a hammer to tap the large washer lightly if the cup starts crooked.
Don't force it, let the bolt suck it in.
Do one at a time.
I have a couple pieces of all-thread of different sizes and a bunch of heavy washers of various sizes up to 4" square bolt plates.
The all-thread works good for low pressure pressing and is very handy to have.
Oh, DON'T GREASE THE BEARINGS BEFORE PUTTING THEM IN THE OVEN!
I also put the bearing cups in a baggy in the freezer to keep moisture off.
I put a little grease on the cups before pressing them in.
Attitude ~
The difference between
Ordeal and Adventure
James
JagLite is offline   Reply With Quote
Old 10-31-2012, 11:15 PM   #70615
Chill
Chill's Avatar
Oddometer: 318
I really don't want to start another huge "what oil" debate but I have read oil posts in this thread until I have nearly gone blind and have gone round and round in circles. I have a couple of questions still...
There are three different Castrol varieties here.
Activ 4T (mineral) 15/50
Power 1 GPS (semi synthetic) 10/40
Power 1 Racing (fully Synthetic) 5/40
The price difference is negligible. It's coming up to summer here with night temps about 20c (70f) and days 25-35c (75-95f)
Is there any benefit to me going fully synthetic or do I stick with the mineral, currently I'm using Motul. I'm leaning towards trying the semi-synthetic because it is spot on the recommended 10/40 and seeing if there's any marked improvement in shifting. Or should I go for the mineral because of its higher temp protection?
Chill is offline   Reply With Quote
Old 11-01-2012, 12:22 AM   #70616
Feelers
Oddometer: 187
Oh god. Oil. Again.
I always go full synthetic because it offers longer lasting property retention. It really doesn't matter what you use as long as it is not energy conserving and you change it appropriately. You are over-thinking it. Whatever brand of 10W-40 will do.
Feelers is offline   Reply With Quote
Old 11-01-2012, 12:36 AM   #70617
BergDonk
BergDonk's Avatar
Oddometer: 3,491
You're in Oz. Use Caltex Delo 400. I now have 44,000 kms on my DR using it, changed every 3-4,000 kms. I got it 2nd hand with 11,000 kms. Can't tell the difference in shifting when fresh oil goes in, so it may well go quite a bit further. I've been using it for years in my Bergs and in my old 501 it tripled the service life of the cam roller follower bearings and still going compared to Mobil 1R4T used exclusively previously. The last 20 l drum I got from the depot was $86. and its available at any Caltex servo in Oz so makes for easy changes when travelling. Others I've convinced to use it in their DRs report improved shifting and longetivity too. You had to ask
shed time IS quality time
BergDonk's DR650 BergDonk's XT1200Z
BergDonk is offline   Reply With Quote
Old 11-01-2012, 06:34 AM   #70618
canoli
human
canoli's Avatar
Oddometer: 1,692
Fueling problem?
Just fitted a Safari 30 liter tank and started having some problems. Specifically 2-3 min after I start-up the bike sputters and dies. If I let it warm up things are OK but if I push it and just start it and go, it dies at the side of the road until more gas gets flowing. I am using a Safari tank with dual petcocks and the standard carb (no mods). I've put in a bottle of STP carb cleaner though it but that did nothing except cost me $5. Do I need to disassemble the carb to clean it? Do I make the fuel hose smaller (get rid of that 1/2 loop?) Do I need to crank the carb elbow over 90 degrees? Bike has roughly 14,000 HARD miles on it and the air/oil filters are clean and new.
Thanks,
Canoli
canoli is offline   Reply With Quote
Old 11-01-2012, 07:51 AM   #70619
TRAVELGUY
Old Traveler
Oddometer: 645
I have a Safari on my DR and have no problems but did you rinse the tank out with gas before installing? After a few weeks of using the tank I did rotate the fuel connection on the carb to 3 o'clock just to clean up line routing. My DR does like 20 or so seconds of choke after startup, stock carb adn jetting. I'm totally happy with my Safari tank. I like being able to ride 400+ miles without filling up and the Safari carries the fuel load low so the extra weight is not noticed.
TravelGuy
Thanks,
Canoli
TRAVELGUY
DL1000 '05 black
DL 650 '06 Red
DR650 '07
TRAVELGUY is offline   Reply With Quote
Old 11-01-2012, 08:23 AM   #70620
neo1piv014
ADV in training
Oddometer: 619
Hmm...that sounds very familiar indeed. I guess I'll have to look into doing my steering bearings as well.
Ride videos
'01 DR650
Times are GMT -7.   It's 06:41 PM.
