Old 11-06-2012, 08:28 AM   #70741
JagLite
JagLite's Avatar
Oddometer: 1,330
Eh? Monday goofup is SOP
Originally Posted by TRAVELGUY View Post
I think you have the backwards? Shorter links should raise the seat height, longer links will lower the seat height.
TravelGuy
If the lowering link holes are closer together than the ones you removed, the bike is now lower in the rear.
Period.
UNLESS, you increased the preload on the shock and raised the back end up.
Did you change anything else when you installed the links?
[/QUOTE]
Hah!
That should teach me to reply from work....
My brain doesn't work very well when I am not looking at the problem.
I should have said that if the link holes are closer or farther apart the ride height WILL change up or down.
Or something like that maybe.
I should know that, having taken mine off and on several times and have raised and lowered my bike.
Thanks for being kind and tactful Travelguy!
Hey! it was a Monday after all....
Attitude ~
The difference between
Ordeal and Adventure
James
JagLite is online now   Reply With Quote
Old 11-06-2012, 08:57 AM   #70742
Mongle
Knuckle dragger
Mongle's Avatar
Oddometer: 3,035
Originally Posted by sandwash View Post
I just use a small screw driver and a length of tubing to break the junk up and than blow the crap out of the well(s).Loosen the plug couple of turns and and repeat.
I must be retentive in nature.
I do all of it. First blow with the air hose. Scrape around with a little pick and break the plugs loose. Blow again with the air hose. Then take plugs all the way out and hit it with the shop vac.
Sand is really hard- a piece between the piston and cylinder does bad stuff!
Mongle is offline   Reply With Quote
Old 11-06-2012, 09:01 AM   #70743
JagLite
JagLite's Avatar
Oddometer: 1,330
Thumb Jet kit options
Originally Posted by Skidmarkart View Post
I am going to pull my BST40 carb and clean it, and hopefully do some mild mods to make it work a little better. Is the Procycle kit the way to go? I think I have seen a couple of others (like Moose) but they seem to be more tilted toward a stock rebuild or freshen-up.
TIA for any info.
I vote for ProCycle (PC).
I have their kit in both of my DR's.
You do need to modify the airbox by cutting the top open as their instructions tell you to do.
If you do NOT want to cut the airbox, use the Factory Pro (?) kit that is designed for the stock airbox.
I believe the ProCycle kit uses the Dynojet needle but not the Dynojet jets as they have their own sizing.
From their site:
Our own jet kit for the DR650 stock Mikuni BST40 carburetor. Includes the extended fuel mixture screw and stainless steel allen screws for the float bowl and top cap. Comes with easy to understand detailed instructions and diagrams - even a template for modifying the airbox.
The major advantage of using PC parts is that they actually ride DR's and have first hand experience.
If you have any problems or questions you can just call them and they will know what you are talking about and can offer useful help.
Try calling Moose or Dynojet ...
Derek at Motolab is also very helpful and although he disagrees with PC on how to tune our carb, if you want to call him, you can have him set you up with the parts and tuning guidelines. He sells all the stock carb parts, needles, jets, etc. I don't think he has (yet?) a special "jet kit" to wake the DR engine up, but he has a strong background in engine tuning.
Bottom line is that many of us are very happy with how our DR's run using the PC "jet kit" and their tuning instructions.
Attitude ~
James
Old 11-06-2012, 09:12 AM   #70744
FatChance
Road Captain
FatChance's Avatar
Oddometer: 10,402
Originally Posted by victor441 View Post
I like the LED type, it gives plenty of info, am running this one and especially like that it dims to half brightness when it is in a steady state for a minute or so but goes to full brightness if there is a change...$28
I've been using one of those on my '05 DR650 for about six years and have been happy with the way it works and the information it gives.
Pain in the Butte Ranch
Durango, Colorado
- Calculated risk or forbidden fruit?
FatChance is offline   Reply With Quote
Old 11-06-2012, 09:21 AM   #70745
Rusty Rocket
Life behind "Bars"
Rusty Rocket's Avatar
Oddometer: 9,394
Mount it up right next to:
on one side the sign it said "Private Road", but on the other side it didn't say nothin'
2009 DR650
..1972 Penton Six-Days ..1971 Suzuki TS185.. 2005 KTM 400exc
Member of: AMA, NETRA, Blue Ribbon Coalition, CCCofVT, Berkshire TR, CT Ramblers
Rusty Rocket is offline   Reply With Quote
Old 11-06-2012, 09:36 AM   #70746
motolab
motolab's Avatar
Oddometer: 2,737
TIA for any info.
As can be seen here,
the DynoJet/ProCycle needle shape leaves much to be desired. The Factory Pro needle has a more reasonable shape, however stainless steel and titanium needles are both hard on emulsion tubes. I would therefore recommend the non-USA adjustable OEM needle. I do not recommend increasing the slide lift hole area, as doing so causes increased slide guide, emulsion tube and slide wear.
Regards,
Derek
motolab is online now   Reply With Quote
Old 11-06-2012, 09:48 AM   #70747
procycle
procycle's Avatar
Oddometer: 2,377
-- snipped for brevity --
Is that a chart you produced yourself with your equipment?
Clarke's second law of Egodynamics: "For every expert, there is an equal and opposite expert." - Jasper Fforde
www.procycle.us - Everything for your DR650 and lots of other great stuff!
DR900 Big Bore Stroker buildup
TurboDiesel Corvette - go to the end to start at the beginning
procycle is offline   Reply With Quote
Old 11-06-2012, 09:53 AM   #70748
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 6,128
I bought a Klein on line for about $38. It's a full function VOM, so also good for household elec. work. It has a nice big LED screen, beeper and lots of other functions you may never use.
On line there are hundreds of VOM meters starting around $10 up to over $100. The Klein is OK, just don't leave the screen exposed to SUN. Not good for a week!
I used to have a very tiny Triplett professional VOM. Great to take on the road. But after 20 years it died. The Klein is too big to carry with ... I'll buy another small one for travel. A must have tool .... IMHO. (If you don't use it, one of your buddies might!)
Old 11-06-2012, 09:53 AM   #70749
motolab
motolab's Avatar
Oddometer: 2,737
No Sir.
Regards,
Derek
Old 11-06-2012, 10:54 AM   #70750
procycle
procycle's Avatar
Oddometer: 2,377
No Sir.
Regards,
Derek
Well, then I've gotta ask:
Who did the tuning and what are their qualifications?
Was the airbox opened up?
Was there an aftermarket exhaust?
What other mods were done the the bike?
What condition was the carb in?
Did the bike run well and was the owner happy with the result?
After tuning did the bike still return good fuel economy (high 40s/low 50s)?
Here's another result:
I don't have the details but I believe this is from NordieBoy.
Maybe he can fill us in?
procycle screwed with this post 11-06-2012 at 11:33 AM
Old 11-06-2012, 11:02 AM   #70751
Skidmarkart
Dirty Middle Age Man
Skidmarkart's Avatar
Oddometer: 215
“Gentlemen, You Can’t Fight In Here! This Is The War Room!”
Dr. Strangelove
Derek,
Would you do anything besides a non-usa adjustable needle? I just want my stock carb sorted, I am not really trying to do anything besides get rid of the bogging down, backfiring, and poor mileage. I am agnostic about how it is done. I like the idea of the Procycle kit, as a one stop option, and one that several people here have used.
I do not like the fact that there are many changes done at once, and apparently some sorting that may need to be done afterwards (this may be the case with any change to the carb). My biggest fear is getting into a situation where my bike is out of commission for a long time while I sort issues out.
Just about anyone here would know more about tuning that I do. I just like to ride it to work everyday and the one thing I do not have is time to chase gremlins out of the system.
Skidmarkart screwed with this post 11-06-2012 at 06:16 PM Reason: word spellin' and ghrammar was teribull
Skidmarkart is offline   Reply With Quote
Old 11-06-2012, 11:48 AM   #70752
Adv Grifter
Oddometer: 6,128
D+ for reading comprehension bud.
Derek has posted that dyno graph about 50 times here. If you R E A D at the bottom of the graph, details are there and basic state of the bike and set up listed. Condition of carb not stated, but most all on your list IS.
Funny, I've got nearly the exact same set up and my bike dyno's at 39 HP! No, don't have the chart. It was a freebee, off the books.
I'm running a Twin-Air, 3rd clip and NO header weld grind. Go figure? Dyno run done at around 25,000 miles. 3 years ago.
Adv Grifter screwed with this post 11-06-2012 at 11:55 AM
Old 11-06-2012, 12:36 PM   #70753
motolab
motolab's Avatar
Oddometer: 2,737
I don't know, however the question is mostly irrelevant, as the shape of the CO trace we see here is a result of needle shape. All that a tuner can do without a change in needle shape is to:
1) Raise or lower entire CO trace via a change in main jet size. Unfortunately, smaller will not help as the lowest CO is already below 3%, and richer will not help because the highest CO is already (way) above 5%.
2) Raise or lower the fuel level. The general trend for raising is to increase CO toward the lower rpm and for lowering to decrease the CO toward the lower rpm. Depending on the bike, there are two trends within this one. One is for the effect to be much like a see-saw (that is linear), the other is for the effect to be more parabolic, that is with the effects being very strong at the lowest rpm and tapering off exponentially as the rpm climb (done by 3-4K rpm). Unfortunately lowering the fuel level will not solve this problem no matter which of the two ways the result may manifest in.
3) Increase or decrease main air correction. The general trend is for the effect to be very strong at the highest rpm and nonexistent below the horsepower peak. The rise in CO from 6 to 7K rpm could be flattened in this way, however that could easily cause the mixture to be as lean at 6 and 7K as it is at 5K and 5K is already too lean, so there is little point in such a change.
If I had a bike here that I was tuning, the CO trace looked like this, and the customer would not allow me to change the needle, what we see here would probably be more or less the best I could do. In other words, the tuner is cornered by this needle. His skill level is irrelevant, because no one, regardless of their level of skill, could do much better.
The description says it was.
The description says there wasn't.
The description says the weld inside the header was ground.
I don't know, but the question is mostly irrelevant, as the primary actor in a worn out carb will be the emulsion tube. A worn emulsion tube manifests itself in the same way as a change in fuel level.
It depends on the definition of the term "well". By my definition, the drastic deviations in CO show that it did not. I don't know the owner so I cannot speak to what he thinks of it.
I don't know.
This shows us some out of context O2 derived "A/F ratio" traces, which I consider to be mostly useless (even in context), as the relationship between O2 content an "A/F ratio" is tenuous at best.
I'd love to see another DynoJet needle equipped DR650 chart with a CO trace...
Regards,
Derek
Old 11-06-2012, 12:43 PM   #70754
motolab
motolab's Avatar
Oddometer: 2,737
Has the engine always exhibited these symptoms?
Regards,
Derek
Old 11-06-2012, 01:09 PM   #70755
Skidmarkart
Oddometer: 215
Somewhat - the bike is fairly new to me. It wasn't running 100% when I got it, but it was running much better than it is now. In the past couple of weeks, it has gone downhill. There's more low-end bog (taking off from idle), and there is more popping when the throttle is released. Seems to run great with the choke on.
I got it about 4 weeks ago a 2005 with 800 miles... So, it has done a fair bit of sitting. The guy who had it before me got it as a present from his wife (cool wife right?), and put a total of 100 miles on it in the last year. I did that in the first day.
I don't know if the change in weather (it is much cooler here now) or simply riding a bike that hasn't been ridden that has loosened thing up a bit.
It is bone stock, never been off road, never had any service (to my knowledge) besides oil changes. I did one of those as soon as I got it, and it had very clean oil and a newer filter on it (someone had obviously done an oil change).
I have fiddled with the external adjustment screw, but I can't seem to find a happy spot.
Also, I have rotten mileage from what folks here seem to get. Maybe 30mpg?
Thanks for any info...
Times are GMT -7.   It's 09:36 PM.
