Old 11-07-2012, 06:41 PM   #70786
ER70S-2
ER70S-2's Avatar
Oddometer: 6,127
Originally Posted by Magnum Noel View Post
"Tape a piece of tubing to your vacuum and suck it out."
Hey what a brillient idea
Originally Posted by Chill View Post
Good info. Nice post. My carb is actually running fine but I DO like the sound of drinking beer and inhaling carb cleaner fumes and seeing things.
2004 DR650: 62,402 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is offline   Reply With Quote
Old 11-07-2012, 06:55 PM   #70787
ER70S-2
ER70S-2's Avatar
Oddometer: 6,127
Originally Posted by heirhead View Post
Hello,
Back to the lowering links. Used to be 5'9" but now must be shorter as I want bike lower still. Am on the right track, will have it dialed in soon.
Thanks again for your help,
Heirhead
Do you have a stock Suzuki shock on the rear and have you done the factory lowering option? It's good for 1-1/2".
Found a pic. If your shock has two lower bolt positions and the bolt is in the lower hole like this, you're at the stock height. If you put the bolt in the upper hole, the rear suspension will be 1-1/2" lower. Let us know, as there's another step, your spring seat mounting position.
2013 WR250R
ER70S-2 screwed with this post 11-07-2012 at 07:22 PM
Old 11-07-2012, 07:46 PM   #70788
ER70S-2
ER70S-2's Avatar
Oddometer: 6,127
Originally Posted by Adv Grifter View Post
5L liters of reserve on a tank that size is just about right, IMHO. I'd go with it, be happy!
The important thing is how much of your reserve can you use. I would strap on a 5 liter fuel jug and run out your reserve ... just so you know your TRUE range.
Don't worry about rotating the Elbow. Leave it. No drilling. Main thing is to know just how far you can go on your reserve. With the IMS, about 2 liters are left once reserve runs out. You can only use that last bit of fuel if you tip the bike over. Good luck! Enjoy!
If you can use all the gas on reserve, you're good. If there's much fuel left when the bike quits, then you might have to decide if you want to 'force' the carb elbow to turn or not.
2013 WR250R
Old 11-07-2012, 09:26 PM   #70789
heirhead
Oddometer: 527
Lowering links
Hello,
Thanks for all who responded. The shock is stock but have stiffer spring on it due to my fat ass!!
The shock has been lowered already. The RED CIRCLE is fine.
ProCycle, understood OK, just will have to lower forks more to see if that is enough.
Now what about that shock spring seat height???
I must be really short!!
Thanks again,
Heirhead
heirhead is offline   Reply With Quote
Old 11-07-2012, 09:28 PM   #70790
Sierra Thumper
Oddometer: 641
Hello,
Thanks again,
Heirhead
lol...yep you must be a shorty You're gonna have a flat-tracker when you get done lowering
"Don't get so concerned with the slab that you choose a turd for the dirt"- The Gospel as spoken by itrack
Sierra Thumper is offline   Reply With Quote
Old 11-07-2012, 09:44 PM   #70791
ER70S-2
ER70S-2's Avatar
Oddometer: 6,127
Hello,
Thanks again,
Heirhead
Did you lower the shock bolt or was it done by someone else? Maybe the shock spring seat height has already been taken care of. Ride the bike, if the tire isn't hitting the fender, you should be fine. I don't have a way to show or explain how it's done. It's in the service manual if you have access to one.
Edit: I found a photo, posted it and an explanation on 11-9-2012.
2013 WR250R
ER70S-2 screwed with this post 11-09-2012 at 07:08 PM
Old 11-07-2012, 09:46 PM   #70792
Phreaky Phil
Oddometer: 1,759
Originally Posted by Paddle007 View Post
Wow. Post 71,001 Great thread. Thanks for all the info and inspiration. My commuter and weekend warrior.
Nice setup.
Is that the giant loop Buck n roll tank bag? Does it work ok, ie stay up on the sides of the tank above your knees ?
I have looked at pics of these but never seen one on a DR. I have a Safari tank and it looked like the bars would hit it on full lock. That headlight looks awesome, although ive read comments on it causing buffeting/turbulence ?>
Cheers Phil
Phreaky Phil is offline   Reply With Quote
Old 11-07-2012, 10:06 PM   #70793
heirhead
Oddometer: 527
links, not golf
Hello,
Shock lowered by PO. Riding out to desert this weekend, will test it out.
Thanks,
Heirhead
Old 11-07-2012, 10:23 PM   #70794
eakins
Butler Maps
eakins's Avatar
Oddometer: 18,261
i have an IMS tank w/ their petcock and stock carb. i did not rotate my inlet tube and thus have a loop in my fuel line. i've run my bike bone dry in the tank. i wondered if the loop would affect things at the end of fuel and it did not.
Alaska
Butler Maps website:
http://www.butlermaps.com
Old 11-07-2012, 10:26 PM   #70795
JagLite
JagLite's Avatar
Oddometer: 1,122
Thumb Stock carb rebuild KIT
Originally Posted by Rusty Rocket View Post
I had a set of the float o-rings go bad after 18 months. They cost quite a bit of $$ from Suzuki. Any other sources? How about from KTM or anothe manufacturer that uses that carb?
Jeff at ProCycle is modest and didn't mention that they carry a stock BST carb rebuild kit in addition to their jet kit.
http://www.procycle.us/bikepages/dr650.html#fuelsystems
They are very helpful and will probably sell you parts if you don't need the full rebuild kit.
I like to check with PC before I start searching for bits here and there.
Attitude ~
The difference between
Ordeal and Adventure
James
JagLite is offline   Reply With Quote
Old 11-07-2012, 10:49 PM   #70796
Aerocycle
Aerocycle's Avatar
Oddometer: 233
Hey guys, Anyone have experience with Shinko 244s? im confused about the sizes. They offer a 5.10-17 rated at 94mph but the front is offered in a 2.75-21 at 94 mph or a 3.00-21 at 75 mph.
What are the right sizes? I rarely go over 94 mph but 75 is occasional. The 244s have mostly good reviews and I think im going to try them. Its ether those or the 700s. The sizing and speed rating is screwing with me
2006 DR650
Oregon Tag-O-Rama
http://www.advrider.com/forums/showt...=752387&page=3
Aerocycle is offline   Reply With Quote
Old 11-07-2012, 11:32 PM   #70797
ER70S-2
ER70S-2's Avatar
Oddometer: 6,127
I agree, until he tries to ride the tank dry, he won't know. It seems some aftermarket tanks, like yours, work fine. Others get the air bubble in the uphill loop and can't use all the fuel in the tank.
I'm running the 244s right now: a 3:00-21 on the front and a 5:10-17 on the rear. Since the DR is 'portly' and I occassionaly ride a little sand, I want the extra floatation (if it even matters). I'm thinking the 2:75 would knife in easier and I don't like that concept.
Unless I buy another FJR, I'm not going to worry about speed. Tires are rated at some 'big' safety factor and I'm ok with that. The wind buffeting at those speeds will slow ME down a long time before the tire is a problem. IMO
2013 WR250R
ER70S-2 screwed with this post 11-07-2012 at 11:42 PM
Old 11-08-2012, 12:34 AM   #70798
Sierra Thumper
Oddometer: 641
I run full off-road knobbies on the road at 70mph for extended periods and have never had an issue. Just remember to run the recommended factory pressure in them......NOT low off-road pressures. I run 22psi on and off road with no traction or handling issues whatsoever
The speed ratings are VERY extreme......unless you run way beyond the max for literally hours upon hours (which is how they test them) you'll be fine with any decent tire.......especially on a low power dual sport. I'm MUCH more careful of tire choices on my turbo zx14 or hayabusa running in the upper triple digits tho. THATS when you take your tire pressures, wear, and ratings seriously
Old 11-08-2012, 06:03 AM   #70799
TrophyHunter
Oddometer: 2,167
Ditto.
2005 DR650 '07 WR450
2013 HD Road King '73 Hodaka Wombat
"It's a small amount of gas, but it represents a long walk" My Dad...
TrophyHunter is offline   Reply With Quote
Old 11-08-2012, 06:27 AM   #70800
Skidmarkart
Dirty Middle Age Man
Skidmarkart's Avatar
Oddometer: 209
Dang - I actually checked on Procycle's site first, but I didn't see a stock rebuild kit.
Next time...
Skidmarkart is offline   Reply With Quote
Times are GMT -7.   It's 02:16 AM.
