Old 11-11-2012, 07:16 AM   #70876
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,364
Originally Posted by poppawheelie View Post
When is "Tubliss" going to nake a system for 17 inch wheels!?!? *^%^*$#@&!
You can still go ahead and get the front Tubliss set up, Myself, most of my flats have been pinch flats up front with tubes. Since switching over to the Tubliss set up on my KTM 450 I've only had one flat in 3.5 years and I actually rode 70 miles at 60 MPH back home to fix it. Got a front setup I plan on putting on my DR when I change the tire.
Old 11-11-2012, 08:17 AM   #70877
Rusty Rocket
Life behind "Bars"
Rusty Rocket's Avatar
Oddometer: 9,002
A friend bought a used KTM 400 with a Tubliss set up, front and rear. The problem with it, is that you have to air up every time you go riding. The 100 psi sealing ring leaks down after a day or so. Try finding a 100psi hose on an adventure camping ride. It's really for offroad competition IMO, to prevent tubes getting pinch flats in a race.
He took them off the bike in less than a month.
on one side the sign it said "Private Road", but on the other side it didn't say nothin'
2009 DR650
..1972 Penton Six-Days ..1971 Suzuki TS185.. 2005 KTM 400exc
Member of: AMA, NETRA, Blue Ribbon Coalition, CCCofVT, Berkshire TR, CT Ramblers
Rusty Rocket is offline   Reply With Quote
Old 11-11-2012, 09:32 AM   #70878
Rob.G
Mostly Harmless
Rob.G's Avatar
Oddometer: 2,156
Thanks for the info on the Cogent vs PC shock. I'll go with Cogent. I'm going to send him my fork tubes too and have him do the work to them as well. Figure if the bike is gonna be down for a few weeks, might as well have both ends done.
Rob
'12 Suzuki V-Strom DL650
'10 Kawasaki KLX351S #320
'96 Suzuki DR650
'92 TW200
Rob.G is offline   Reply With Quote
Old 11-11-2012, 09:39 AM   #70879
JagLite
JagLite's Avatar
Oddometer: 1,125
Thumb Shocking!
Originally Posted by mrprez View Post
I just finished doing one of these and mine came with a new bottoming cushion. It wasn't all that much work either. Remove the shock which you will have to do either way. DIscharge the bladder, remove the spring, remove two clips, drain the oil and remove all the old parts. Clean it up, fill with oil and reinstall new parts. All together took me about 2 hours to do including removing the shock from the bike. I still have to get it charged but will get that done tomorrow.
That is good news.
Interesting that PC doesn't list the new cushion rubber as part of the "solution".
You reused your seal head I am guessing.
I certainly like the price.
Attitude ~
The difference between
Ordeal and Adventure
James
JagLite is online now   Reply With Quote
Old 11-11-2012, 09:51 AM   #70880
JagLite
JagLite's Avatar
Oddometer: 1,125
More shocking news
Rob
I am sure you will be glad you did.
I am always trying to save money but sometimes (too often) I end up paying twice.
Once for my cheap fix and then again for the correct fix.
Which reminds me, I am searching for a BSA B50 rear wheel if anyone has one....
Attitude ~
James
Old 11-11-2012, 10:22 AM   #70881
procycle
procycle's Avatar
Oddometer: 2,252
Originally Posted by JagLite View Post
That is good news.
We don't include it because not everyone will need one. If the shock is only a couple years old or less the bumper and seal head are probably perfectly fine. Riders with older shocks can add the seal head and bumper if they need them.
The photo above is the shaft assembly. You can see the rebound adjustment knob at the bottom. It does come with a new bumper.
Clarke's second law of Egodynamics: "For every expert, there is an equal and opposite expert." - Jasper Fforde
www.procycle.us - Everything for your DR650 and lots of other great stuff!
DR900 Big Bore Stroker buildup
TurboDiesel Corvette - go to the end to start at the beginning
procycle screwed with this post 11-11-2012 at 10:32 AM
procycle is offline   Reply With Quote
Old 11-11-2012, 10:46 AM   #70882
acesandeights
Asperger
acesandeights's Avatar
Oddometer: 3,847
To compare with Cogent's shock you should be looking at the ProCycle "Shock Shaft Assembly" for $498.
That is very similar to a Cogent shock with all new parts, but YOU still get to do the rebuild.
So, looking at equals you see that a Cogent shock is less expensive, is ready to install, and is a completely new shock.
I thought the shaft shaft assy ($498) was complete and all that was needed was to add nitrogen, nothing to rebuild?
http://breakingbooks.wordpress.com
Amazballs Indi-music at https://soundcloud.com/sprunty2000/
I may not be Rainman, but I'm not stupid eighter. Like Bartek on a taco.
I'll die with this hammer in my hand.
acesandeights is offline   Reply With Quote
Old 11-11-2012, 11:05 AM   #70883
JagLite
JagLite's Avatar
Oddometer: 1,125
Eh? Wrong Again. Shocking, eh?
Ah, my mistake.
I make several each day...
I thought mrprez was saying that he had bought your $279 "Shock Solution Kit".
I wondered why the bottom of his shock looked different. Duh!
He got your "Shock Shaft Assembly" ($498) so it is very similar to a Cogent shock.
Thanks for clarifying that.
Attitude ~
James
Old 11-11-2012, 11:14 AM   #70884
JagLite
JagLite's Avatar
Oddometer: 1,125
Bluhduh Even more shocking!
Direct from ProCycle, our favorite parts supplier:
Shock Shaft Assembly with Rebound Adjustment
Replace the internal components in your shock with a completely updated design with adjustments for both compression and rebound damping.
The new shaft assembly has improved valving for both compressing and rebound, a thicker, stronger shaft, new seal head and bottoming bumper. Comes as a complete assembly ready to go into your shock body and includes your choice of rear spring (required). Other spring rates available by special order - call.
Unless I am wrong (again) you get all new INTERNALS but you have to take your shock apart and put it back together.
That is where mrprez helped out by saying it only took him 2 hours to do the job.
Now, back to juggling apples and oranges and bananas.
Attitude ~
James
Old 11-11-2012, 11:18 AM   #70885
acesandeights
Asperger
Oddometer: 3,847
You're right.
Old 11-11-2012, 11:45 AM   #70886
GaThumper
Road Less Traveled
GaThumper's Avatar
Location: Thumpin' in North GA - headin' for the Smokys
Oddometer: 514
I don't think you will regret having Rick do both ends. He did mine last year and I have been VERY satisfied with it. I could probably still see more improvement from a fork swap, but the resprung front forks with Racetech emulators are fine for me. The Cogent rebuild on the rear is outstanding.
Plus Rick and Joyce are great people!
Rob
Dirtly: 2009 Suzuki DR650SE Road Sofa: 2001 Yamaha (ad)Venture 1300
Dirtlier: 1999 Suzuki DR350SE Old Sport: 1979 Suzuki GS1000E
1996 Suzuki Intruder 1400 (for sale) 1987 Yamaha TT600 (for sale)
GaThumper is offline   Reply With Quote
Old 11-11-2012, 12:06 PM   #70887
nsrrider
Oddometer: 25
i have tubliss on my berg 390 and pretty much agree with your friend.......ive left the front on however cuz i can feel the benefit and just figure i have to pump it up after a few days of riding or if it has sat for a few weeks......i wouldnt use them on my DR650......
nsrrider is offline   Reply With Quote
Old 11-11-2012, 12:35 PM   #70888
Lil' Steve
PussyWagon™ Chauffer
Lil' Steve's Avatar
Oddometer: 3,951
I have the Cogent shock on my bike, and Intiminators up front. Very satisfied for my riding needs. Rick from Cogent also has a cartridge upgrade for the stock forks as another option.
Steve
13 PCX150, 07 KLX250S w/300 kit, 05 DR650SE, 01 FZ-1
99 VFR800 w/870 kit, 96 GPz1100, 87 CH250
Lil' Steve is offline   Reply With Quote
Old 11-11-2012, 12:37 PM   #70889
mrprez
KJ4WMZ
Oddometer: 1,265
Sorry my fault. I did get the entire shaft assembly not the solution kit. I used the solution kit on the front forks.
Sent via morse code
mrprez is offline   Reply With Quote
Old 11-11-2012, 12:40 PM   #70890
lamotovita
Ageing Adventurer
lamotovita's Avatar
Oddometer: 1,495
Any bicycle shop will sell you a small high pressure (low volume) pump for a few bucks.
Beaten paths are for beaten men.
lamotovita is offline   Reply With Quote
Times are GMT -7.   It's 01:06 PM.
