Old 11-12-2012, 09:52 AM   #70906
GaThumper
Road Less Traveled
GaThumper's Avatar
Location: Thumpin' in North GA - headin' for the Smokys
Oddometer: 514
Originally Posted by Rusty Rocket View Post
The people here seem to know more about ADVRider site than most, so I'll ask:
Does anyone remember a post somewhere on ADVRider that compares weights of different dualsport bikes?
This one?
http://advrider.com/forums/showthrea...ghlight=weight
Dirtly: 2009 Suzuki DR650SE Road Sofa: 2001 Yamaha (ad)Venture 1300
Dirtlier: 1999 Suzuki DR350SE Old Sport: 1979 Suzuki GS1000E
1996 Suzuki Intruder 1400 (for sale) 1987 Yamaha TT600 (for sale)
GaThumper is offline   Reply With Quote
Old 11-12-2012, 10:22 AM   #70907
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 6,128
I know I've seen many threads with weights listed. Some are of all ADV bikes (large and small), others just dual sport singles.
You may even find that info right on this thread ... but good luck tracking it down. That info would be good for your DR650 Index thread ... a quick and easy to find comparo! I hope you can include all the 600 class KTM's and Huskies too. They are, in fact, much heavier than most want to admit to. If I run across a good list of weights I'll PM the link to you.
Old 11-12-2012, 10:44 AM   #70908
Adv Grifter
Oddometer: 6,128
Originally Posted by neo1piv014 View Post
I'll look up some how-to's on ditching those safety switches. I don't believe I've yet even tried to take off on a bike with the side stand down, so that's probably okay to ditch at this point. All the lights and everything fire right up with the key, and if it helps, I've also replaced the battery within the last month, and that didn't seem to make any difference.
Honestly, all of the switchgear on my bike needs a thorough cleaning or something. The turn signal switch is...gummy I guess. It sticks a lot and takes a few tries to cancel. The horn works once a week or so, and the kill switch doesn't like to pop back out once pressed in. Some electrical grease and an afternoon might be the cure for what ails me this time.
When your bike won't start ... try turning the handlebars a bit, then try to start again. Move them again, try several positions. If it starts then you know that either the wiring loom is abraded somewhere near the steering stem or the wires to the ignition switch may be coming loose.
WD40 on all the safety switches can solve a lot of problems. Good luck!
Old 11-12-2012, 11:08 AM   #70909
Rusty Rocket
Life behind "Bars"
Rusty Rocket's Avatar
Oddometer: 8,990
Originally Posted by GaThumper View Post
Yes, that's the one. I was trying to find the Montessa VR guy, but couldn't remember his name. closest I got was Meteor...sumpthin'. Thanks.
on one side the sign it said "Private Road", but on the other side it didn't say nothin'
2009 DR650
..1972 Penton Six-Days ..1971 Suzuki TS185.. 2005 KTM 400exc
Member of: AMA, NETRA, Blue Ribbon Coalition, CCCofVT, Berkshire TR, CT Ramblers
Rusty Rocket is online now   Reply With Quote
Old 11-12-2012, 11:09 AM   #70910
Rusty Rocket
Life behind "Bars"
Oddometer: 8,990
Have you seen the weight of the new Husqvarna Terra? 405 lbs.
2009 DR650
Old 11-12-2012, 12:17 PM   #70911
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,348
I wonder if his had a problem. He's the only person that I ever knew who had them.
He got the with a used bike and he figured that was how they were.
This is a good time to ask, what is a good, reasonably priced compact tire pump that can be carried in a tool pack. My old "Double Shot" is. well: Shot.
Don't get me wrong, they do lose air over time, just like tubes do. Not gonna be like cast aluminum street bike tubless setups that hardly lose any air at all.
Old 11-12-2012, 12:29 PM   #70912
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,348
This was posted a little while back: Those were weights that people actually reported that weighed them. The 690 R's weigh 13 lbs more then the older Enduro's
I do know that my DR feels like a tank compared to my 690, a big part of that is the 690 has the fuel tank under the seat which makes a huge difference in handling.
Make Model Curb weight in pounds (engine hp/torque)
Husqvarna TE630 318 (57/41)
KTM 690R 331 (65/49)
BMW G650X 346 (53/44)
Honda XR650L 346 (31/30)
Suzuki DR650 366 (37/34)
BMW G650GS 422 (48/44)
Kawasaki KLR650 432 (34/31)
Old 11-12-2012, 12:54 PM   #70913
Gryphon12
Gryphon12's Avatar
Oddometer: 1,325
You should post those numbers on MontessaVR's thread. Occasionally, he will update the complete list, which is now toward the end of the thread (was on the first page orginally).
1990 Honda NT-650 Hawk-GT
Never doubt that a small group of thoughtful, committed citizens can change the world;
indeed, it's the only thing that ever has. - Margaret Mead
Gryphon12 is offline   Reply With Quote
Old 11-12-2012, 01:28 PM   #70914
BlackBeast
BlackBeast's Avatar
Oddometer: 928
I haven't visited this thread in a while, so the answer may be here already - is there a step by step on replacing the steering head bearings. I have an '08 that needs some TLC this winter and I'm better at following pictorials. Just placed an order with Procycle for some other bits as well. Any help would be appreciated.
BlackBeast is offline   Reply With Quote
Old 11-12-2012, 01:49 PM   #70915
frontiercat
all out of charm
frontiercat's Avatar
Oddometer: 1,172
Wet weight...405 lbs
Dry weight...364 lbs
frontiercat is offline   Reply With Quote
Old 11-12-2012, 01:56 PM   #70916
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 7,139
Originally Posted by dljocky View Post
I thought the front and back wheel off the pre-96's needed a lot of spacer work, rotor pattern work before they could be used on post 96's?
The 350 rear works but not the front.
DR650 Wiki
NordieBoy is offline   Reply With Quote
Old 11-12-2012, 02:43 PM   #70917
sandwash
sandwash's Avatar
Oddometer: 1,333
Try this:
http://www.garagenight.tv/ep-5-repla...head-bearings/
97dr650
sandwash is online now   Reply With Quote
Old 11-12-2012, 05:27 PM   #70918
Garak
Cardassian Spy
Garak's Avatar
Oddometer: 266
Progress!
As some of you may recall, I came to an excessively abrupt stop on my DR at the end of July, bending the fork in the process. Well, LukasM is shipping me the fork tubes from his old bike, I'm getting the cast off my wrist at the end of this month (hopefully) and I'll be crafting a few parts in the machine shop over the next bit. With any luck at all, I'll be back on two wheels by the time the weather improves here. I'm planning to take this opportunity to personalize this machine a bit, as I'm quite taken by the unique ones that show up here from time to time. Once things are underway, if anyone is interested, I may start a photo-thread to keep you up to date on my antics
Across the country on the kindness of strangers and the strangeness of friends (and a DR650).
My LinkedIn Profile
Garak is offline   Reply With Quote
Old 11-12-2012, 05:52 PM   #70919
805gregg
Just Stroming along
Oddometer: 1,541
Older DR's are 324 lbs.
805gregg is offline   Reply With Quote
Old 11-12-2012, 05:54 PM   #70920
BlackBeast
BlackBeast's Avatar
Oddometer: 928
Originally Posted by sandwash View Post
Great, thanks.
Times are GMT -7.   It's 02:02 PM.
