Old 11-13-2012, 06:33 PM   #70966
procycle
procycle's Avatar
Oddometer: 2,280
Originally Posted by Emmbeedee View Post
The CCM 644 used the DR650 engine, apparently.
Yep. Actually, it's the Freewind motor which is just like the DR650 except for the dual carbs, 2 intake ports and bigger valves.
Clarke's second law of Egodynamics: "For every expert, there is an equal and opposite expert." - Jasper Fforde
www.procycle.us - Everything for your DR650 and lots of other great stuff!
DR900 Big Bore Stroker buildup
TurboDiesel Corvette - go to the end to start at the beginning
procycle is offline   Reply With Quote
Old 11-13-2012, 06:35 PM   #70967
johnkol
Oddometer: 136
Originally Posted by neo1piv014 View Post
Regarding fuel injection on these bikes, there was a fellow on YouTube that mounted up a FI kit to his DR650. The company he bought it from basically did these pre-made FI kits for bikes based on engine size. The one he got was for 500-800cc engines (if I remember correctly) and was selling for not much more than the pumper carb goes for.
Long thread on DRriders about the Ecotrons EFI module, which was developed with help from members there, and which is now a commercial product.
johnkol is offline   Reply With Quote
Old 11-13-2012, 06:41 PM   #70968
Sierra Thumper
Oddometer: 641
Laugh Battery tenders are a very good thing
Originally Posted by Rusty Rocket View Post
I have been through 2 battery replacements for my '96. about 3 years per.
When the battery goes bad, the bike cranks, but won't start. Then it goes dead. After a charge, it starts and seems fine. Then the next time I went to start it, usually at least a week later, same problem. I think a marginal battery, with just enough juice to turn the motor over, doesn't have enough extra to fire the sparkplugs. Just an opinion. If you can try someone elses battery, even a smaller one, you can probably prove it is the battery. If the battery is over 3 years old, it's probably the culprit.
Keep the bike on a battery tender when parked and you'll get 8+ years of quick dependable starting out of a battery. I have the pigtails installed on all 4 of my bikes, so its super easy to plug them in when parked. I regularly get 8-10 years out of a battery, and the bikes all fire up instantly all the time...cold, hot or anything in between....a fully charged battery makes a BIG difference, my bikes jump to life
"Don't get so concerned with the slab that you choose a turd for the dirt"- The Gospel as spoken by itrack
Sierra Thumper is offline   Reply With Quote
Old 11-13-2012, 08:09 PM   #70969
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 6,128
Originally Posted by procycle View Post
Twin carb?
Yea, looks like you're right. Single carb on pre '96 DR650 too. I've only ever seen ONE pre 1996 DR650 on the road. It was a crazy friends bike from late 80's and it would never start with the kicker. A real PITA. I could have sworn he mentioned twin Carbs? It was fast ... when it ran!
I did see the Freewind when in the EU and can confirm they are twin Carb. Very cool little bike actually.
Someone mentioned CCM. I visited a multi-line dealer carrying CCM while in the UK. Brand new CCM's for sale ... and some really trick used ones too ... Cheap!
I believe some CCM's used a different motor? ... can't recall which? Rotax maybe? Anyway, cool bikes and you can still see them riding around England, but AFAIK, CCM is now closed. Valiant effort lads.
Old 11-13-2012, 08:18 PM   #70970
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,599
http://en.wikipedia.org/wiki/Clews_C...on_Motorcycles
Emmbeedee is online now   Reply With Quote
Old 11-13-2012, 08:25 PM   #70971
drakenstein
Oddometer: 4
balancer chain
New to advrider, Need some opinions on a balancer chain making a whining noise. I just got my 91dr650 out of the shop and the had replaced the cam chain and clutch and a few other odds and ends. When i pick it up they tell me that the balancer chain was making some noise so they went ahead and checked it and said it had some wear and would probably need to be changed in the next 10,000 miles but it was still in spec and that they tightened it up. Now though its whining like it could be too tight or something, Im wondering that if i ride for awhile will just loosen up and be normal or should i look into taking it back or to another shop.
thanks all.
drakenstein is offline   Reply With Quote
Old 11-13-2012, 08:36 PM   #70972
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,599
thanks all.
You should really be asking in the Pre-96 DR thread. 96 and up don't have balancer chains.
Old 11-13-2012, 08:53 PM   #70973
drakenstein
Oddometer: 4
Noted, thanks.
Old 11-13-2012, 09:19 PM   #70974
Kommando
Kommando's Avatar
Oddometer: 7,375
Originally Posted by TRAVELGUY View Post
I have done the Suzuki option lowering and installed a low seat on mine . Still wish it was a inch or more lower. I'm generally traveling heavy loaded and need stable footing.
TravelGuy
No lowering links and slid forks yet?
Kommando is online now   Reply With Quote
Old 11-13-2012, 11:49 PM   #70975
Tech23
Tech23's Avatar
Oddometer: 476
Originally Posted by Albie View Post
So long as you don't mind paying $8K for it then.
I never buy new anyway. It's no cheaper to add it later. There are many that say to upgrade the suspension first before doing performance upgrades. I'd rather pay for a factory twin clicker than an aftermarket upgraded single clicker without enough adjustment. I'm pretty sure the DRZ 250's 41mm cartridge forks with compression and rebound damping adjusters would slip right into the DR's triple tree's. All Suzuki would have to do is valve and spring the forks for the DR. The same goes for the fully adjustable DRZ 250's rear shock too. Probably wouldn't require a major redesign of the bike to do it either.
Tech23
2004 Suzuki DR 650SM
2000 Harley Davidson FXDWG
2011 Victory Cross Country
Tech23 screwed with this post 11-14-2012 at 12:03 AM
Tech23 is offline   Reply With Quote
Old 11-14-2012, 12:10 AM   #70976
TRAVELGUY
Old Traveler
Oddometer: 645
Have thought about doing that but not for a few months.
TRAVELGUY
DL1000 '05 black
DL 650 '06 Red
DR650 '07
TRAVELGUY is offline   Reply With Quote
Old 11-14-2012, 12:30 AM   #70977
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 7,137
EDIT: here's the youtube page I was talking about:
http://www.youtube.com/user/RCThirty
Apparently, the company is called Ecotrons and it's a 400-800cc kit.
mxrob's video of his homebrew FI...
NordieBoy is offline   Reply With Quote
Old 11-14-2012, 12:32 AM   #70978
heirhead
Oddometer: 580
How low can you go????????
TravelGuy
Hello,
Well a lot of people have given me advice and comments on me being vertically inept! Thanks, read them all!!
I am 5' 8 and 7/8" tall but my weight is PERFECT if I was 6'11'.
2009 dr with the factory lowering done and forks up 3/4". then lower gel seat. Bought Corbin off inmate but to tall-wide,
may or may not sell. Put 8.3 spring on as I am loaded, bike too. Bought 1" lowering links from ProCycle, no difference until lowered forks more at there request. 1-1/8" up now. Can sit flat footed, same as my tw200. Went on a 100 mile ride this weekend 40 dirt and felt great, except,Yes, it is very low for ROCKS. Other than watching out for pointed big rocks it is much better for me as knees are shot and can't stand up on pegs to long. Much, much better in traffic also. Rode down Ortega Hwy, SoCal, twisties and felt like I was on SM flying. Looks a little different as the IMS looks more like a Safari.
Will leave it like this but if going over rocks for long periods will probably raise forks some as it only takes a couple of minutes. Have a 13 tooth on the front and it did nice 2nd gear wheelies but lowered not so good.
Thanks again,
Heirhead
heirhead is online now   Reply With Quote
Old 11-14-2012, 03:10 AM   #70979
eakins
Butler Maps
eakins's Avatar
Oddometer: 18,648
The whole Econtrons FI thing started here
http://www.advrider.com/forums/showthread.php?t=725795
MXrob had his FI microsquirt thing going already but also tried this system.
At this point I had hoped a true plug and play FI system would be available for the DR but alas it is not.
Matt at Ecotrons helped a ton but for some reason he's not heading to the last step and creating true PnP systems from his biz??? He did for the the Ninja 250 but that's it. Not sure 100% why as his kits are only for install/fabricator pros and thus this marginalizes his biz vrs selling a bolt on system and thus much wider acceptance.
The guys at DRriders have done a ton, but the momentum has also stalled their. It's sorta like Matt just said here ya go, this is what I have but figure it all out and then get back to me. Not really the way to bring a product to market...as it's not.
I'm bummed and will eventually buy someone elses FI 650 thumper (i'm convinced of the technology and still have hope for the 660 Tenere or maybe Suzuki will update or possibly Kawi or Honda). For now my BST carb is working well enough.
Alaska
Butler Maps website:
http://www.butlermaps.com
eakins screwed with this post 11-14-2012 at 03:20 AM
Old 11-14-2012, 06:56 AM   #70980
Rumlover
Ed
Oddometer: 707
Suzuki could do it pretty easy in my opinion. They already have been running a big fuel injected single in their King Quad for several years. Unfortunately it is water cooled, so I am not sure that is the motor I would want to see on a DR upgrade.
But the injection system seems pretty rock solid and I would think easily modified and programed for an air cooled engine.
Rumlover is offline   Reply With Quote
Times are GMT -7.   It's 11:30 AM.
