11-09-2012, 05:57 PM
#70981 | ||
Oddometer: 2,610
![]() Quote:
You can't be all that short; your feet reach the ground when you're walking, right? ![]() Quote:
I pirated that photo and I'm looking for the rightful owner right now, to give proper credit.Found and edited my earlier post: Photo thanks to TrophyHunter and findable thanks to Krusty's DR650 Index.
2004 DR650: 47,033 miles of The last 314 miles were done with my super, hot rod, whiz-bang, blue KLIM Dakar gloves. Good thing I lost one of my 10 year old Joe Rocket gloves; I didn't know I could ride so fast. ER70S-2 screwed with this post 11-09-2012 at 07:14 PM |
11-09-2012, 07:10 PM
#70982 | |
Procrastinators
Oddometer: 6,054
Want to know more about the Garmin Montana? See the Wisdom and FAQ Thread. "Don't play a lute to a cow" (Old Chinese Idiom) "The motorcycle, being poorly designed for both flight and marine operation, sustained significant external and internal damage," police noted. Emmbeedee screwed with this post 11-09-2012 at 07:16 PM |
11-09-2012, 07:15 PM
#70983 |
Oddometer: 2,610
2004 DR650: 47,033 miles of The last 314 miles were done with my super, hot rod, whiz-bang, blue KLIM Dakar gloves. Good thing I lost one of my 10 year old Joe Rocket gloves; I didn't know I could ride so fast. |
11-09-2012, 07:32 PM
#70984 | |
Oddometer: 156
The kenda's are tubeless type? You didn't have to do anything seal around the bead? Are you running slime or anything? I've run mtn bikes tubeless for a few years, we just use some tape around the rim to seal around the spokes, then run Stans No-tubes (http://www.notubes.com) to seal up any remaining leaks. One problem that can occur at low pressures is the tire burping off the bead. It will come unsealed for a moment & lose some air, usually when you put a lateral load on it in a corner or a drop. Not too big of a problem at mtn bike speeds, but I wonder if this could occur with a motorcycle rim that isn't designed for tubeless.
- DR650 - WR250R times 2 |
11-09-2012, 08:00 PM
#70985 | |
Oddometer: 882
It's not a big motorcycle, just a groovy little motor bike. |
11-09-2012, 08:02 PM
#70986 | |
Oddometer: 181
11-09-2012, 08:17 PM
#70987 | |
Oddometer: 117
11-09-2012, 08:27 PM
#70988 |
Oddometer: 117
11-09-2012, 08:43 PM
#70989 |
Oddometer: 1,614
For trips out in the bush you still carry a tube for emergency repair.
Clarke's second law of Egodynamics: "For every expert, there is an equal and opposite expert." - Jasper Fforde www.procycle.us - Everything for your DR650 and lots of other great stuff! DR900 Big Bore Stroker buildup |
11-09-2012, 09:55 PM
#70990 |
Oddometer: 181
11-09-2012, 10:14 PM
#70991 |
Oddometer: 1,614
The main advantage is you can repair a simple puncture with a plug. But to be prepared for a damaged rim or tire damage that won't hold a plug you would really want a tube as backup.
11-09-2012, 10:21 PM
#70992 |
Mostly Harmless
Oddometer: 1,772
Rear Shock
So... for the cost-conscious... is the ProCycle Rear Shock Solution kit (basically a gold valve and a spring) going to be that much worse than sending the shock off to Cogent? Seems to me if you get the valving right it oughta be pretty darn good, yes? $279 vs $500-something is a pretty big difference. Especially since I need to do the rear shock on my KLX250S as well.
Rob
'96 Suzuki DR650 '10 Kawasaki KLX351S #320 '01 Yamaha FZ1 The Lane Sharing Works Blog |
11-09-2012, 10:32 PM
#70993 |
Asperger
Oddometer: 2,141
Front/Rear Suspension
Interesting your question came up.
It's my thought that the Race Tech emulators and rear shock assy are the best thing out there. I don't understand the Cogent option. A lot of people are happy with it, but wouldn't they be happier with the Race Tech rear shock assembly? Seems the Race Tech rear shock assembly is better and cheaper, or am I wrong? Anyway, I'd put the Procycle front suspenion kit and the shock assy together as a package and call it race ready. Anyone disagree?
http://breakingbooks.wordpress.com http://www.kenmarshallmetalworks.com/ 2011 DR650, Fly Aero tapered bars, Race Tech front springs/emulators, RT rear spring/shock shaft assy, BarkBusters, MT21s, 14/43T, etc I may not be Rainman, but I'm not stupid eighter. Like Bartek on a taco. |
11-10-2012, 12:34 AM
#70994 |
Oddometer: 641
What I'm wondering is how you can tighten loose spokes as they develop if you seal the nipple? It seems like as soon as you turn the nipple to tighten up the spokes you'll break the seal...then I guess you pull the tire and go back in and reseal?
"Don't get so concerned with the slab that you choose a turd for the dirt"- The Gospel as spoken by itrack |
11-10-2012, 12:59 AM
#70995 |
Oddometer: 117
Do road bike riders carry a tube for their tubeless wheels? Of course not. Why would one carry a tube for a tubeless DR then? I never do. I hardly ever get flats to begin with, so what is the probability that one gets a flat that cannot be repaired with a plug?
