Old 11-20-2012, 08:22 AM   #71296
Escaped
Escaped's Avatar
Oddometer: 488
Hi Jay,
You have considered the side-stand "Safety" switch and related diode? You cant just override the switch but must remove the diode relay. There is discussion somewhere on this site regarding that.
Originally Posted by Jammin View Post
Need your advice, fellow DR riders:
As you may know, I was having electrical problems with my bike in western Tanzania (she's a 1998 with 74,000+ miles). She was dying after a few minutes of running and a reworked carb, a newer CDI, rectifier and ignition coil didn't solve the problem, so I figured it was the stator. I got a new stator shipped in, the 250W uprated one and installed that along with slightly-newer parts from parted DRs: a CDI from a 2006 and a rectifier from a 2001. After those parts, she fired up and sounded really good. I did 50 kms of test rides and was confident the problem was solved, so got back on the trail heading south.
But now, after 400 kms (250 miles), the problem is back. She died on me today in the middle of muddy roads. It felt like a loss of power. I let her cool, we rode a bit more and then she died again. I figured since I didn't replace the original ignition coil, maybe it was acting up now. I put in the coil from the 2001 bike and she died again in a few kms. Then I unplugged the generator and we ran for a while before same failure. Then I unplugged the rectifier and we ran fine for a few kms before she died again. The longer I let her cool down before trying again, the longer she lasts before dying again. To me, this sounds like something is heating up and causing the loss of power. It doesn't feel like a fuel (carb) issue. It feels like something is cutting power to the spark plugs. I limped her back to a small town.
I'm running on the Shorai battery and have a voltage monitor and after unplugging both stator and rectifier, battery was holding charge at 13.45 and after two starts with no stator, it dropped to 13.35 V.
I have a replacement wiring harness from the 2006 bike. Is mounting that on going to help? That's all I can think of now. I'm close to throwing in the towel and putting her on a truck and heading back to a good mechanic in Nairobi. Argghhh!!!!
2006 DR650 54,407 miles
DR650 - Eyes open all of the time
Escaped is offline   Reply With Quote
Old 11-20-2012, 08:32 AM   #71297
JagLite
JagLite's Avatar
Oddometer: 1,382
Pissed Hair pullin'
That is terrible!
It does certainly seem to indicate a heat soak problem.
Do you remember reading the electrical problems the rider on the KTM had going from South Africa to the Arctic Circle?
He replaced just about everything electrical on his bike as he slowly made his way north but it wasn't until he got to England where he replaced the wiring harness only to find, finally, that the problem was the voltage regulator.
His bike had FI and the voltage spike was throwing the computer into a fail mode.
Now, the DR is simple in comparison but you are suffering an extremely rare problem too.
Could it be something as simple as the voltage regulator on your bike?
Bad spark plugs?
Bad plug wires? (I had brand new OEM plug wires installed in my car that went bad in one week, replaced free)
Bad voltage reg?
Bad insulation on a wire that is shorting out on the frame when the wire gets hot?
Your location makes it very difficult to diagnose and replacement parts are not available to experiment with.
I wish I could offer a solution that will solve the problem but I can't.
Only to offer more possibilities to check.
I would certainly replace the harness if you have an alternate one to try.
Could possibly solve the problem...
Attitude ~
The difference between
Ordeal and Adventure
James
JagLite is offline   Reply With Quote
Old 11-20-2012, 09:08 AM   #71298
Lil' Steve
PussyWagon™ Chauffer
Lil' Steve's Avatar
Oddometer: 4,042
Originally Posted by RichBeBe View Post
Yeah I never saw it in person, but the guy from here who bought it was an ideal match for it. He could actually touch the ground
At least that bike had no frame flex.
Steve
13 PCX150, 07 KLX250S w/300 kit, 05 DR650SE, 01 FZ-1
99 VFR800 w/870 kit, 96 GPz1100, 87 CH250
Lil' Steve is offline   Reply With Quote
Old 11-20-2012, 09:15 AM   #71299
RichBeBe
All Hail Seitan!!!
RichBeBe's Avatar
Oddometer: 6,279
I thought it was Julio's but if the bike fits
"Remember that an enduro tests the endurance of three things: your machine, your body, and your wits. Only one has to fail to keep you from reaching the finish line." Cycle World March 1966
RichBeBe is online now   Reply With Quote
Old 11-20-2012, 09:28 AM   #71300
Jammin
Living on a DR
Jammin's Avatar
Oddometer: 1,556
Originally Posted by barko1 View Post
Love the rear suspension. Maybe Jay should pick this one up to continue his journey.
Ha! If it runs, I'll take it
Originally Posted by Escaped View Post
Hi Jay,
Hi, yup, I think I removed the relay when I did this mod, way back before the trip started.
Originally Posted by JagLite View Post
That is terrible!
Bad spark plugs?
Bad voltage reg?
Hey James, yeah, so frustrating that I can't pinpoint the problem, after throwing so much at it. I feel replacing the harness is going to be a bigger job than I can manage where I'm at now. Looking into trucking her out of here.
I replaced my original regulator with a take-off from a 2001 bike from South Africa. The owner couldn't say how good the part was, and it was all I had to go with. It ran fine for the last 250 miles. I unplugged the regulator (and the stator) and the bike was running better, but still cut out again after 10 miles.
Is there some other electrical component (relay, etc) that would cause a power loss?
I replaced a spark plug, have a different ignition coil with plug wires from a 2001 bike and that didn't solve the problem.
Poor girl, she's really suffering
J A Y on a 98 Suzuki DR650SE (sanDRina)
Trip Website: JamminGlobal.com
Current Ride Report: Global South | Past Trips: CDR '09, Alaska '08, Mexico '07 | YouTube Videos
Jammin is offline   Reply With Quote
Old 11-20-2012, 09:39 AM   #71301
O'B
O'B's Avatar
Oddometer: 1,173
Sounds like an electrical component of some type. How would you know you ask? Years ago I worked in an electronic factory producing pcb boards for use in computer printers. We would trouble shoot down to the component level and my job was testing and repair of the boards before they went into the printers. a common problem was defective chips that would fail after they heated up during the runnin test. These were pretty hard to locate so we would use canned freon on the chips to cool them down as the board was running and almost a 100 percent of the time when the freon was placed on the correct chip the problem was found as the device would start running correctly and when the freon was removed and the chip was let to heat up again the device would start to fail again. I don;t know what it could be but it could even be a defective fuse,spark plug,ect. One thing that was common was the more you ran it the worse it would get. Depending on the degee of defectiveness you start with when a total failure occured it would have a tendancy to take out ajoining components. Start with these simple solutions change all the fuses, Revist all the grounding points on the bike and get a good battery to test with. Also check all the wires for abrasion, Then test. If it still fails move to the component level. Start with what you haven't changed yet. I know you will say I already did this but you should start over step bt step. If you can get a can of freon it may help. Just my two cents.
O'B is offline   Reply With Quote
Old 11-20-2012, 09:45 AM   #71302
opium89
opium89's Avatar
Oddometer: 1,136
I hesitantly and rather expensively ordered it from the dealer. I'll post the specs when it shows up. I found some rather inexpensive options in a 45 and 46mm...Be a shame if they turn out to be a match as they're about 1/12th the price!
Originally Posted by DRT View Post
I am also interested in the dimensions of the ring nut. I believe you can make one by starting with a large socket and doing some machine work. does anybody know what size socket to start with, or what the diameter of the ring nut socket is?
Tea parties are for little girls with imaginary friends.
opium89 is offline   Reply With Quote
Old 11-20-2012, 09:52 AM   #71303
P-P
P-P's Avatar
Oddometer: 97
Okay, okay, so there IS flex! Wrong again, my bad!
Originally Posted by Rusty Rocket View Post
Just say NO! to CaliFornication!
P-P is offline   Reply With Quote
Old 11-20-2012, 11:14 AM   #71304
neo1piv014
ADV in training
Oddometer: 621
That's more like "sag" than flex. Someone ride it hard over a speed bump and put it out of its misery.
_________________________
Ride videos
'01 DR650
"The impossible often has a kind of integrity which the merely improbable lacks."
neo1piv014 is offline   Reply With Quote
Old 11-20-2012, 11:32 AM   #71305
Off Limits
Off Limits's Avatar
Oddometer: 3,481
Originally Posted by Team Longriders View Post
So when I was removing the charcoal canister, I broke the fitting on the bottom of the carb that the hose goes to. Am I screwed? Can I epoxy it tojust plug it or am sol. I fired it up and it doesn't seem to suck any air. But the fitting is brass and has a hole through it.
Any help would be helpful. just need to know if I broke a vent fitting, or a vacuum fitting.
Off Limits is offline   Reply With Quote
Old 11-20-2012, 11:43 AM   #71306
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 7,144
It has no misery left.
It was parted out by a member here...
NordieBoy is offline   Reply With Quote
Old 11-20-2012, 11:45 AM   #71307
neo1piv014
ADV in training
Oddometer: 621
Tell me it was built as a joke, right?
Ride videos
'01 DR650
Old 11-20-2012, 11:46 AM   #71308
Mongle
Knuckle dragger
Mongle's Avatar
Oddometer: 3,145
I'm not sure what you have there- never worked on a Calif. bike.
BUT, looking at the shop manual diagram: If it is the port on the bottom of the carb toward the front I believe that is what they call the "purge port". It takes the charcoal canister vapor and sucks it back through the engine. It may only have vaccum when the engine is picked up off idle (throttle blade is opened). Have somone rev the engine while you put your finger over it. It may be light and hard to feel with your finger.
Mongle is offline   Reply With Quote
Old 11-20-2012, 11:54 AM   #71309
P-P
P-P's Avatar
Oddometer: 97
It is a vacuum fitting. If you're abandoning the system, then at least plug the hole to prevent foriegn matter intrusion.
Old 11-20-2012, 12:08 PM   #71310
ER70S-2
ER70S-2's Avatar
Oddometer: 6,944
Jessepitt took a great pic of his non-Kalifornia BST, it looks like you can just epoxy it shut.
Photo from here:
http://www.advrider.com/forums/showp...5&postcount=71
2004 DR650: 62,605 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is offline   Reply With Quote
Times are GMT -7.   It's 03:45 AM.
