Old 11-21-2012, 07:30 AM   #71341
procycle
procycle's Avatar
Oddometer: 2,466
Death Valley ride report
Still in progress. 3 more days ahead of us.
--> http://drriders.com/topic6350.html
Clarke's second law of Egodynamics: "For every expert, there is an equal and opposite expert." - Jasper Fforde
www.procycle.us - Everything for your DR650 and lots of other great stuff!
DR900 Big Bore Stroker buildup
TurboDiesel Corvette - go to the end to start at the beginning
procycle is offline   Reply With Quote
Old 11-21-2012, 07:45 AM   #71342
O'B
O'B's Avatar
Oddometer: 1,281
Originally Posted by greer View Post
Jammin's Troubles
Please bear in mind I know diddleysquat about anything mechanical. But is there any way that new-fangled battery could be causing something funky in the electrical system? Seems like I read some such about that early on in the development of these batteries.
Sarah
I agree you should not proceed without getting another good battery to test with. Be sure to check all the associated ground points. A little patience I am sure you are almost there. It will certaianly be a WTF moment when you identify the problem.
O'B is offline   Reply With Quote
Old 11-21-2012, 09:10 AM   #71343
Jammin
Living on a DR
Jammin's Avatar
Oddometer: 1,563
@BergDonk: As far as I know, the TM38 does not have a built-in fuel filter. I have the Aqualine tank with two petcocks and there are screens on the inside of them. I then have an inline fuel filter (paper core) where the two fuel lines meet and before it goes into the carb inlet. Good idea on viewing the float level. Will try that when I get back to civilization.
Here's an exploded view of my carb: http://www.sudco.com/Diagrams123/exptm.gif
Anything you see in there that I can fiddle with?
@Nullarbor63: thank you, my friend. You are right that I am getting hung up on it being an electrical issue but I'm open to it being related to something else. It's just that I can't diagnose that here but once I'm back to a city, I'll do a full tear down and investigate. Thanks for bringing up the cylinder head crack issue. Didn't know about that.
@greer: you have a valid point and yes, it could be the Shorai lithium-iron battery. I'll test with a regular one once I'm back to Nairobi.
@nsrrider: yeah, I dont think it's the resistor. thanks.
@Randomroad: I can't wait for that WTF moment!
___________________
sanDRina in the middle of a field repair in southwestern Tanzania, just before a thunderstorm rolled through:
In trying times like this, I tell myself to look for the positives and put things in perspective. I'm healthy, dry and online :)
J A Y on a 98 Suzuki DR650SE (sanDRina)
Trip Website: JamminGlobal.com
Current Ride Report: Global South | Past Trips: CDR '09, Alaska '08, Mexico '07 | YouTube Videos
Jammin is offline   Reply With Quote
Old 11-21-2012, 09:47 AM   #71344
DockingPilot
Hooked Up and Hard Over
DockingPilot's Avatar
Oddometer: 9,933
Originally Posted by FlowBee View Post
OK, thanks. S0..... we should expect a 18" conversion. $$$
Well no Flow, we should expect one to call ahead after the long ride to Texas to make sure one had a tire waiting. Like I did in Battle Mountain Nevada while riding the TAT. It was pretty easy, I called a bike shop out there before we left NJ and had him order us tires. He did, they were there.
We continued on..........
Pretty easy
Loose the edge there friend.
Frank Reinbold
"Every bike I ever had, was the best bike I ever had, when I had it"
DockingPilot is offline   Reply With Quote
Old 11-21-2012, 11:37 AM   #71345
MADurstewitz
MADMark
Oddometer: 159
Originally Posted by Hasanito View Post
Just curious, how many people did the full procycle upgrade on their DRs to 790cc.
I couldn't find much info on this thru search...
How much difference was there and in terms of weight/power ratio, any drawbacks?
I did it. The mother moves. Tons of smooth power. I recommend it.
MAD
(yes, those are my real initials)
MADurstewitz is offline   Reply With Quote
Old 11-21-2012, 11:58 AM   #71346
Fred Garvin
Fred Garvin's Avatar
Oddometer: 243
790 kit
You might check out DRRIDERS.com. I think there were some reports of it posted there. I plan on doing the kit this spring.
Fred Garvin is online now   Reply With Quote
Old 11-21-2012, 12:07 PM   #71347
neo1piv014
ADV in training
Oddometer: 627
Have you done any other mods to the bike, or just given it truckloads of awesome power?
_________________________
Ride videos
'01 DR650
"The impossible often has a kind of integrity which the merely improbable lacks."
neo1piv014 is offline   Reply With Quote
Old 11-21-2012, 12:29 PM   #71348
Mongle
Knuckle dragger
Mongle's Avatar
Oddometer: 3,285
Someone might have said this already: Any bike that I have had that would start when cold...run for a bit...then shut off and not re start until time has passed has for me always been a gas tank vent issue. Next time it does it make sure the tank is venting correctly. Take the cap off and try starting again. Also, make sure your fuel lines are not near the cylinder head. I never heard of a bike having fuel vapor lock from heat boiling the gas, but it sounds like you have checked everything else...
I have never been inside of a TM38 so I don't know how the float needle is hung on the float. On some carbs if the float is not hung EXACTLY how the manufacurer reccomends it can hang/stick in its little tube. Most often this results in a lean condition but still runs or will start and quit as soon as the float bowl runs out of gas. Edit: I looked at the carb link you provided...doesn't look like it can go but one way. hmmmm.....
Do we need to send an Old Priest and a Young Priest and have an exorcism? I'm sure you can find someone to swing a dead chicken over that thing! Good luck brother.
Mongle is online now   Reply With Quote
Old 11-21-2012, 12:50 PM   #71349
eakins
Butler Maps
eakins's Avatar
Oddometer: 19,403
Originally Posted by Rusty Rocket View Post
Do mean you stopped buying from SWMotoTire, or PartsUNL?
I just shopped tires (5 mins ago after seeing the name) at SWMT and their prices seemed pretty good. Anywhere better? I love saving munney.
many buy tires from MSS http://www.motorcycle-superstore.com...res-Tires.aspx
buying a pair will almost always be enough for free shipping - $90+
Alaska
Butler Maps website:
http://www.butlermaps.com
Old 11-21-2012, 01:14 PM   #71350
BergDonk
BergDonk's Avatar
Oddometer: 3,931
Nothing jumps out at me and it doesn't appear that you have a drain on the float bowel. I have in the past drilled the float bung and threaded and epoxied a hose fitting into it so I could track down a float level issue. But I also had a spare bung to do it to.
As you have a decent external inline filter, I'd get rid of the screens inside the tank. When they are hidden away, they tend to be ignored.
And as someone else suggested, tank venting?
shed time IS quality time
BergDonk's DR650 BergDonk's XT1200Z
BergDonk is offline   Reply With Quote
Old 11-21-2012, 01:47 PM   #71351
B.E. Coyote
(Super-Genius)
B.E. Coyote's Avatar
Oddometer: 5,610
gsxr muffler ?
Took a chance on a GSXR muffler from ebay.
It is the coveted 40FO.
Description said it sounded like there were loose parts inside.
I received it today and shook it, something sounded loose. Held the 4 bolts on the end, shook it, sounded like maybe a very little loose sand inside but nothing mechanical.
The end cap bolts have very small factory welds on them so I know it hasn't been screwed with.
Am I good to go? Should I try opening it up or leave it alone?
B.E. Coyote is offline   Reply With Quote
Old 11-21-2012, 02:01 PM   #71352
JagLite
JagLite's Avatar
Oddometer: 1,439
Thumb Sandy muffler
You are good to go.
The sound is probably just some of the small pieces from the donor bikes pistons when they disintegrated.
There really is nothing inside there to come loose.
The mid baffle plate and two short tubes welded to it.
All wrapped by a perforated tube with a thin permanent sound deadener between it and the shell.
Attitude ~
The difference between
Ordeal and Adventure
James
JagLite is offline   Reply With Quote
Old 11-21-2012, 02:14 PM   #71353
neo1piv014
ADV in training
Oddometer: 627
How much did you pay for the muffler? I'm looking at swapping too.
Ride videos
'01 DR650
Old 11-21-2012, 02:23 PM   #71354
mrprez
KJ4WMZ
Oddometer: 1,265
I just got one from a Hayabusa for $30 plus shipping. Its the 24F0.
Sent from my A500 using Tapatalk 2
Sent via morse code
mrprez is offline   Reply With Quote
Old 11-21-2012, 02:45 PM   #71355
Sierra Thumper
Oddometer: 641
___________________
First off I have to say I highly respect you for taking on an adventure most folks would never attempt, including me. Kudo's brother
Second I would get a compression and leakdown test if at all possible....if your bike has 74k original miles on the engine this prob could very well be engine related.
Also be sure your vacuum petcock is working right if you're still running it. I always ran my vacuum petcock machines on prime and skipped the vacuum set-up alltogether...they always seemed to give me probs with leaking diaphrams and fuel starvation.....which can often seem like electrical probs.
Good luck and hope you can forge ahead with this awesome adventure
"Don't get so concerned with the slab that you choose a turd for the dirt"- The Gospel as spoken by itrack
Sierra Thumper is offline   Reply With Quote
Times are GMT -7.   It's 09:02 AM.
