11-17-2012, 05:12 PM
#71386 | |
Kool Aid poisoner
Oddometer: 4,830
Good. Bad. I'm the guy with the gun. Guess what doofus, nobody reads your lame blog. |
11-17-2012, 05:13 PM
#71387 | |
Armature speller
Oddometer: 6,774
11-17-2012, 05:17 PM
#71388 |
Harris's hawker
Oddometer: 168
One pretty simple way to install a low fender is to use the RSW Racing supermoto fork brace and bolt a generic sm front (e.g., Acerbis) to the brace.
2008 DR650SE supermoto 2009 CRF230M |
11-17-2012, 06:06 PM
#71389 | |
Oddometer: 641
"Don't get so concerned with the slab that you choose a turd for the dirt"- The Gospel as spoken by itrack |
11-17-2012, 06:38 PM
#71390 | |
Oddometer: 1,126
Almost!
It did remind me how valuable that "Ignore List" can be! Bruce
No one calls the Fire Department because they did something smart! 06 DR 650, Moose RS Holder, Handguards and Skidplate, ProTaper bars, Garmin 60CSx, Motech racks w/ 20mm Ammo cans, Renazco, TKCs summer/17" SM wheels winter 08 Scrambler, Conti Trail Attacks and BlackTiger Fork mod, 05 FSE 450, 03 KLR 250, 02 FXDX, 72 WR 250 (again), 72 SL 350 K2 (again), 72 TR6R, 06 XT 225 |
11-17-2012, 08:04 PM
#71391 | |
Oddometer: 116
Unfortunately, I already checked for this, but still, thanks! |
11-17-2012, 09:18 PM
#71392 | |
Oddometer: 1,169
doug s. |
11-17-2012, 09:26 PM
#71393 | ||
Oddometer: 1,169
i wouldn't recommend a sm fender, but another more conwentional fender bolted to a brace instead - the sm fenders typically don't prowide much coverage at the back. or get this, if you don't wanna do a brace; it needs a little cleaning up, but it should be plug-n-play w/the stock non-inwerted forks: http://www.ebay.com/itm/280930223405 on my bike, i had to adapt a yamaha r6 fender to attach to the fork guards, due to the usd forks... doug s. |
11-18-2012, 12:21 AM
#71394 |
Oddometer: 263
[QUOTE=Albie;20066082]Might get close to the power, but no way you're gonna be able to shed that much weight to get a DR comparable to the XRR.[/QUOTE
Really?? I thought the DR was 10kg heavier than the XR. Should'nt be to hard to shed 10 kg off the DR should it?? |
11-18-2012, 12:55 AM
#71395 |
Oddometer: 696
XRR vs. DR
Not quite. The XR650R has a dry weight of 277 lbs. and a wet weight ready to ride of 320 lbs. This was when mfgs quoted dry weight without lots and lots of "stuff".
The DR650 (post 1995) is 324 lbs. dry and 366 lbs. wet, ready to ride with the stock tank full of gas. So, the difference between the two is 46 lbs. or just shy of 21 kg. Getting the DR down to XRR weight can be done, but it is a little more expensive than just dropping the stock exhaust. Of course, you can lighten up the XRR a bit, too.
1990 Honda NT-650 Hawk-GT Never doubt that a small group of thoughtful, committed citizens can change the world; indeed, it's the only thing that ever has. - Margaret Mead
11-18-2012, 06:18 AM
#71396 |
Kool Aid poisoner
Oddometer: 4,830
[QUOTE=jack82;20068392]You thought wrong.
11-18-2012, 07:15 AM
#71397 |
Dual Sport Addict
Oddometer: 988
I just road a nice low mile XRR the other day. Whata sweet engine! I would love to have one but there is no way it would replace my DR due to its lack of streetability. I would rate the XRR as being slightly less comfortable on the road than my wifes XT225 and I'm talking about the bikes comfort not the riders. It has a pretty tight trans ratio and the seat was narrow. Of pave however, it was a beast.
2011 DirtRoad650 http://i838.photobucket.com/albums/z...mping12182.jpg '98 DR 350 http://i838.photobucket.com/albums/z...t/Photo280.jpg '99 DR 650. Sold. |
11-18-2012, 08:43 AM
#71398 | |
Oddometer: 20
) with stock fork oil (5w). Sounds to me like yours has heavier fork oil or too much oil. Have you ever checked/changed it?If you're riding bumps so fast you're getting airborne stalls and you don't think you can benefit from/appreciate the bike more with suspension improvements no one here will be able to help you. If your bike is older and you've never serviced the suspension, as in right after buying it, then do it now before anything else. 5w to correct level in the forks and 10w shock oil should be a good start point. With all the frame flex analysis I assumed you're a mechanical engineer and you have a new bike. If you haven't thoroughly examined the steering head bearings and races, wheel bearings and axles, and the swing arm bearings and shaft, your analysis is without foundation. Finally, or firstly, what tire pressure do you run and have you ever run different tires on the same bike? |
11-18-2012, 09:45 AM
#71399 | |
Grumpy Young Man
Oddometer: 3,760
11-18-2012, 10:00 AM
#71400 | |
What? Me hurry?
. If he had posted his in, say, Orange Crush, for instance, he would likely have seen dozens of replies commiserating his misfortune. The fact he did so here gives me the idea that he just wants to stir the shit ...
