Old 11-23-2012, 09:19 PM   #71401
dogjaw
plays well alone
dogjaw's Avatar
Oddometer: 3,213
I'm a huge fan of the 19" front wheel as well; rocks the twisties
By God, Woodrow; it's been one hell of a party.
dogjaw is offline   Reply With Quote
Old 11-23-2012, 09:59 PM   #71402
BergDonk
BergDonk's Avatar
Oddometer: 3,818
Originally Posted by procycle View Post
Yeah, Kenda Big Block in back and a Pirelli Scorpion Rally in front. This is my third K784 and I'm happpy enough with them that I'll probably get another after this one is gone. It's not quite as good a tire (for me) as the TKC80 but in the 150/70-17 size I run it is way less expensive. I don't have fun if I feel like I have to ride to baby my tires.
How are yopu finding the Scorpion Rally. I really like the 21" fronts, but I note you are running a 19 which has a blockier tread, I guess better matched to the rear.
shed time IS quality time
BergDonk's DR650 BergDonk's XT1200Z
BergDonk is offline   Reply With Quote
Old 11-24-2012, 01:38 AM   #71403
DR Steve
DR Steve's Avatar
Oddometer: 336
About to pull the trigger on a 19" front too.
Who makes that front brake rotor ?
Assume it's the stock size ?
'13 DR650
DR Steve is offline   Reply With Quote
Old 11-24-2012, 04:33 AM   #71404
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,846
If running on choke makes a big improvement it's almost certain that there is a fuel starvation problem.
Is pulling the enrichener (choke) going to help if the problem is that there's no fuel in the carb?
Old 11-24-2012, 06:02 AM   #71405
dogjaw
plays well alone
dogjaw's Avatar
Oddometer: 3,213
Galfer brake, stock size, definitely improved braking
Old 11-24-2012, 06:07 AM   #71406
procycle
procycle's Avatar
Oddometer: 2,410
When the bike is misfiring there is still fuel in the carb - just not enough for smooth running. The enrichener will suck up enough fuel to stop the misfiring. If pulling the choke temporarily solves the problem then you are pointed in the right direction for finding the source of the problem.
Clarke's second law of Egodynamics: "For every expert, there is an equal and opposite expert." - Jasper Fforde
www.procycle.us - Everything for your DR650 and lots of other great stuff!
DR900 Big Bore Stroker buildup
TurboDiesel Corvette - go to the end to start at the beginning
procycle is offline   Reply With Quote
Old 11-24-2012, 06:13 AM   #71407
Mambo Dave
Backyard Adventurer
Mambo Dave's Avatar
Oddometer: 5,799
Is the 19" front wheel of a width that the rear OEM rim can stay, or does the rear still have to be changed out for balance like with SM wheels?
Mambo Dave is offline   Reply With Quote
Old 11-24-2012, 06:26 AM   #71408
barko1
barko1
barko1's Avatar
Oddometer: 3,407
Originally Posted by Garak View Post
+1. I'm very happy with my Oxfords. The wiring can be delicate in spots so exercise caution when installing, but once they are on they work very well and seem pretty robust.
I usually just buy the cheaper wrap ons and add a relay which works fine for about $35 and sometimes new grips if I have to destroy the existing ones during removal. This time I had just gotten an ad from Aerostitch for Bikemaster heated grips for $59 which seemed decent so I ordered them. Then Aerostitch told me they were back ordered until January so I cancelled and found the same grips for $45 and $5 shipping from Koups Cycle shop. Started to install them on my Moto Guzzi last night. Just need to run one ground wire, one wire to a switch source, runs the wires from the battery to the front of the bike, use a few zip ties, and put the grips on. I just have to do the last part yet but everything is working.
DR650, 98 Bimota SB6R, Kawasaki 14, 67 X-6 Scrambler (apart), SL350K1 (apart), 77 Goldwing 1000, Triumph Thunderbird Sport, Triumph Daytona Super III, DR650, MZ Skorpian Sport Cup, 71 Triumph Daytona 500, KDX220
barko1 is offline   Reply With Quote
Old 11-24-2012, 08:40 AM   #71409
O'B
O'B's Avatar
Oddometer: 1,175
Originally Posted by Jammin View Post
Ha! Found the culprit: clogged fuel filter (paper core). Replaced it with a new spare (copper core) and sanDRina runs like a champ! Went for a 60 km test ride and no issues. I think that was it Continuing south tomorrow
Come on, motorcycle gods, what else you got? Let me have it.
I got jolted last night and told myself that 'give up' isn't in my dictionary. I beat my demons back in their cave and listened to the advice from ADV brethren who directed me to inspect this part.
If I don't make it to the next town tomorrow, I'll figure it out
Thanks!!!
Wierd! Glad it was something simple. If that ain't a real WTF momement I don't know what is!
O'B is offline   Reply With Quote
Old 11-24-2012, 11:23 AM   #71410
DR Steve
DR Steve's Avatar
Oddometer: 336
Thanks for that.
Did you notice an improvement over the stock rotor while using the 19" fornt wheel or did you fit the Galfer when you fitted the 19" wheel ?
'13 DR650
Old 11-24-2012, 12:08 PM   #71411
Jammin
Living on a DR
Jammin's Avatar
Oddometer: 1,556
@Multisurface Rider: I'm on it!
@JagLite: I love the DR Simple rules!
@ADV Grifter: I'm so glad it was fuel related, much easier to solve mechanical problems Yeah, my bad that I repositioned the fuel filter recently so that it was hidden from view. The rectifier and coil were donated by DR riders in South Africa. Hopefully now I'll get there and give them back
@Emmbeedee: (at myself, too)
@procycle: great tip, will remember that
@Randomroad: That's exactly what I yelled out and then a big smile grew on my face
J A Y on a 98 Suzuki DR650SE (sanDRina)
Trip Website: JamminGlobal.com
Current Ride Report: Global South | Past Trips: CDR '09, Alaska '08, Mexico '07 | YouTube Videos
Jammin is offline   Reply With Quote
Old 11-24-2012, 05:00 PM   #71412
smilin jack
Grandpa Adventurer
smilin jack's Avatar
Oddometer: 1,229
New Springs
Got my new springs installed on the 2006 DR this Thanksgiving weekend. NO photos taken. Only broke one 3/8" ratchet handle and a 3/8" extension. Probably needed a 1/2" drive socket set. That is on the shopping list.
8.3 kg/mm rear spring (black)
0.55 kg/mm fork springs
Took it for a 20 mile test ride in the rain and it's much better than stock OEM. Not nearly so much brake dive. The suspension feels slightly stiff, but me being used to the OEM springs, I have some learning to do. The stiffness will be good for hauling adventure camping equipment.
Dave
smilin jack is offline   Reply With Quote
Old 11-24-2012, 05:08 PM   #71413
LeDakaR!
LeDakaR!'s Avatar
Location: route66moto.com San Francisco CA/ Austin, Texas
Oddometer: 448
Rear shock blew thus summer, pro rebuilt and now it's leaking after a hard offroad ride wtf?!?
How many time will I have to rebuild?
RIP Benjava, I finally did Alaska, thanks to you
www.route66moto.com
moto rental/sales and tours, location et vente moto, import-export
LeDakaR! is offline   Reply With Quote
Old 11-24-2012, 05:12 PM   #71414
basketcase
lifelong reject fixer
basketcase's Avatar
Oddometer: 1,439
Dave
Congrats! You'll really realize the value of the springs when you get off road and into something that would tax the stock bouncers.
And there's something about a fully loaded DR that just looks and feels right.
Yours truly -- northern New Mexico, July 2010.
'00 BMW R1100RT, Gone away: 5 previous BMW's, 3 Honda's, 2 Suzuki's
"The object of life is not to be on the side of the majority, but to escape finding oneself in the ranks of the insane." - Marcus Aurelius
basketcase is offline   Reply With Quote
Old 11-24-2012, 05:21 PM   #71415
Sierra Thumper
Oddometer: 641
You got a bad rebuild job.....a properly rebuilt shock should last for years and thousands of miles just like the stocker. Its hard to find good service anymore...........
"Don't get so concerned with the slab that you choose a turd for the dirt"- The Gospel as spoken by itrack
Sierra Thumper is offline   Reply With Quote
Times are GMT -7.   It's 06:22 AM.
