Old 11-24-2012, 05:45 PM   #71416
procycle
procycle's Avatar
Oddometer: 2,386
Originally Posted by Mambo Dave View Post
Is the 19" front wheel of a width that the rear OEM rim can stay, or does the rear still have to be changed out for balance like with SM wheels?
If you plan on retaining the stock rear rim I would recommend either a 2.15x19 or a 1.85x19 rim on the front.
Clarke's second law of Egodynamics: "For every expert, there is an equal and opposite expert." - Jasper Fforde
www.procycle.us - Everything for your DR650 and lots of other great stuff!
DR900 Big Bore Stroker buildup
TurboDiesel Corvette - go to the end to start at the beginning
procycle is offline   Reply With Quote
Old 11-24-2012, 06:12 PM   #71417
TrophyHunter
Oddometer: 2,251
I borrowed a set from a buddy. Stock rear, 19 front, no issues at all. GoodCat8 ran the combo all the time and never mentioned any problems. The 19 is a blast in the corners and it looks symetrical on the DR.
'07 WR450 2013 HD Road King '73 Hodaka Wombat
TrophyHunter is offline   Reply With Quote
Old 11-24-2012, 08:24 PM   #71418
opium89
opium89's Avatar
Oddometer: 1,136
Engine Swap
Needs some opinions from my fellow DR inmates....
Have a 1999 DR with a grenaded case. Found a replacement bottom end at a salvage yard. Seeing as I am not quite sure how many miles might be on the bottom end I purchased, my original plan was to swap *everything* from the original engine and move it over to the new case. Now that I have it apart, I am not so sure it's worth the bother to split the cases, and simply move everything else over to the replacement. Anything you folks can think of that I should look for in making this decision? I'd really hate to not do it, then find out there's a bad bearing or gear in the replacement bottom end. Anything above the obvious I should be looking for in making this determination? Keep in mind I was an auto mechanic for 11 years of my life, so I am not completely oblivious to signs of normal engine wear. So far, I can't fault the replacement in any way, at least visually, performing some cursory spins, and looking for play in the rod, bearings and output shafts.
Something else has me a little stumped so I have another question. The grenaded case is from a 1999 model bike and did not have this washer behind the flywheel when I took it off.. Parts fiche shows it for 1999, and 2000, but not for 2001...I was told the replacement bottom end was from a 2000 model year bike. What's it doing there?
Tea parties are for little girls with imaginary friends.
opium89 is offline   Reply With Quote
Old 11-24-2012, 09:05 PM   #71419
TRAVELGUY
Old Traveler
Oddometer: 678
Who did the rebuild?
TravelGuy
Originally Posted by LeDakaR! View Post
Rear shock blew thus summer, pro rebuilt and now it's leaking after a hard offroad ride wtf?!?
How many time will I have to rebuild?
TRAVELGUY
DL1000 '05 black
DL 650 '06 Red
DR650 '07
TRAVELGUY is offline   Reply With Quote
Old 11-25-2012, 12:15 AM   #71420
basketcase
lifelong reject fixer
basketcase's Avatar
Oddometer: 1,432
(Rick snipped some stuff...)
1. Can you check the engine # from the replacement and ascertain what year bike it came out of?
2. Is there a way to make certain the parts fiche is correct in displaying/not displaying the washer with respect to the model years?
'00 BMW R1100RT, Gone away: 5 previous BMW's, 3 Honda's, 2 Suzuki's
"The object of life is not to be on the side of the majority, but to escape finding oneself in the ranks of the insane." - Marcus Aurelius
basketcase is offline   Reply With Quote
Old 11-25-2012, 07:39 AM   #71421
opium89
opium89's Avatar
Oddometer: 1,136
Replacement: P409-112575
Grenade: P409-108145
I suppose I could call Bike Bandit and find out, but they've been pretty spot on so far.
By chance, I found an ad on eBay from the exact salvage yard I purchased the bottom end from. They just so happen to have the started idler gear listed from an engine that matched the engine number as mine. The listing states: "The speedometer read 32199 miles before we parted this bike down"
Sometimes you get lucky I guess....at least now I know what I am dealing with! Even at 32k, do you think it's worth a complete tear-down? The busted case only had 6000 on it before the starter-induced implosion.
opium89 screwed with this post 11-25-2012 at 08:17 AM
Old 11-25-2012, 08:19 AM   #71422
gjcarving
Oddometer: 112
14t 41t Gearing. Pros and or Cons. And general Gearing..
Hello. I just switched to a 14t front with stock 42t rear. I REALLY like the low end zip and better off road manners but after 70 it seems to start being a bit buzzy and the motor sounds stressed a bit. Is it? Would love this set up if the DR had a 6th gear!!!! I would like to retain the 525 chain, and there are not many options for gearing. I was wondering if dropping one tooth off the rear to a 41t would give that little extra RPM drop I am looking for or would it be negligible? I ride all kind of styles with this bike and am trying to find optimum gearing as here there is a lot of on road/off road transitions and wish not to keep changing sprockets. Just trying to create my perfect for me Adventure bike. Any info and or recommendations would be appreciated. Thanks!
gjcarving is offline   Reply With Quote
Old 11-25-2012, 09:44 AM   #71423
ChromeSux
Plated and screwed
ChromeSux's Avatar
Oddometer: 1,522
I too like the 14t off road but the bike is buzzy if you have to ride the 4 lane for very long, if i have to ride 4 lane/ interstate for more than an hour or 2, then i put the 15t on, if you put the locking rear axle nut on and make a couple of reference marks on the rear axle cam for the chain adj and leave your counter sprocket cover off, the sprocket change goes pretty quick.
I have the Motion pro axle wrench/ tire spoon combo,i just grab it and the sprocket out of the tail bag, grab my T handle with 10mm socket and in a matter of moments its changed, a little bit of trouble but worth it.
ChromeSux is offline   Reply With Quote
Old 11-25-2012, 11:19 AM   #71424
LeDakaR!
LeDakaR!'s Avatar
Oddometer: 442
here is my problem, the rebuild was done professionally by a very good suspension shop, dakar provider to Jonah Street
http://www.superplushsuspension.com/
TravelGuy
RIP Benjava, I finally did Alaska, thanks to you
www.route66moto.com
moto rental/sales and tours, location et vente moto, import-export
LeDakaR! is offline   Reply With Quote
Old 11-25-2012, 11:51 AM   #71425
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 6,128
Super Plush are well known among the KTM crowd in the Bay Area. But they deal mostly with racers ... not with bikes that actually get used hard for years and years. (KTM'S never last that long! )
I tried to contact them for fork work. They were never around, never returned my calls. I went to Catalyst Reaction instead. (on the Peninsula)
Fantastic result ... and they do shocks too!
My guess is if you tell SuperPlush the situation they will rebuild your shock again at NO CHARGE. Seems obvious. It's not like it's done 30K miles since their work was done. They owe you ... and if they expect their Rep to be maintained ... they should DO THE RIGHT THING!
Good luck ... and let us know how it goes.
Old 11-25-2012, 12:10 PM   #71426
Adv Grifter
Oddometer: 6,128
I've swapped 14T and 15T sprockets using the stock 42T rear many times. I only notice a slight advantage off road ... but it is there.
On road I could still maintain a good cruising speed with the 14T on, never felt it was over revving or buzzy at indicated 75 mph (actual 70 mph). With stock gearing I maintain indicated 80 mph, pretty smooth.
I rode cross country and for the off road sections (much of Nevada and Utah) I used the 14T front. All good.
There are lots of small things to do to smooth out your DR650 at highway speeds. Little things add up to effect vibes and eliminate a rough "feel" at high speed.
I found the Pro Taper Alu bars helped with vibes from stock. Also, retaining all the stock rubber shock mounting in bars and pegs. Noticeable difference.
Drive line is yet another. New rubber cush drive inserts really help as do fresh chain and sprockets. Check all three bearings while you're in there.
A worn sprocket can make you think your clutch basket is shot or ... bottom end bearings are gone. New sprockets and chain work wonders for this. Bad or worn Hub/Wheel bearings also tranmit a rough feel that may be hard to pin point.
And finally, many diss the heavy Corbin seat. But it's density means it damps out a lot of vibes at higher RPM's. Less rider fatigue.
I can change between a 14T and 15T on the side of the road in about 15 minutes max. NO CHAIN adjustment needed at all on my bike. I never touch the rear axle to do this. If you know how, its a quick swap from one sprocket to the other. (Loc- tite on retainer bolts please)
Old 11-25-2012, 12:13 PM   #71427
LeDakaR!
LeDakaR!'s Avatar
Oddometer: 442
they are super duper goodguys.
so email sent, will keep you posted.
i have a solo DV ride coming up in december, I need to have faith in this bike.
www.route66moto.com
Old 11-25-2012, 05:03 PM   #71428
dogjaw
plays well alone
dogjaw's Avatar
Oddometer: 3,215
Originally Posted by DR Steve View Post
Thanks for that.
Did you notice an improvement over the stock rotor while using the 19" fornt wheel or did you fit the Galfer when you fitted the 19" wheel ?
Did the Galfer at the same time as the 19", so I don't have a valid opinion as to how it would have affected the 21", sorry...
By God, Woodrow; it's been one hell of a party.
dogjaw is offline   Reply With Quote
Old 11-25-2012, 06:51 PM   #71429
MADurstewitz
MADMark
Oddometer: 159
I rebuilt my 2009 last winter from the cases up due to a bearing failure. I got the numbers for all of them and ordered SKF bearings from simplybearings.co.uk. I sized them based on caliper measurements and what I could get from the fiche on sites like bikebandit. Over 9000 miles later is runs fantastic. My point: you have to go in there anyway, might as well do it all. Simplybearings prices are much lower than suzuki and for far better bearings. I think I spent 1/4 of what I would have if I bought OEM (especially the Chinese bearing I found).
You'll kick yourself if you go through all that only to have something fly apart. I know it would make me nuts.
MAD
(yes, those are my real initials)
MADurstewitz screwed with this post 11-25-2012 at 06:54 PM Reason: emoticon in wrong place.
MADurstewitz is offline   Reply With Quote
Old 11-26-2012, 08:54 AM   #71430
buckrut1972
H.R. Nightmare
buckrut1972's Avatar
Oddometer: 112
Front lights needed
I want to add some front lights to my 09 DR but need some help. From what little I know I do know I need low voltage ones. I see ADV Monster and Rigid Industries offer some nice ones but can anyone offer any suggestions on flood lights?
"Never argue with stupid people, they will drag you down to their level and then beat you with experience" Mark Twain
buckrut1972 is offline   Reply With Quote
Times are GMT -7.   It's 07:57 AM.
