Old 11-27-2012, 09:11 PM   #71446
rpet
Awesometown
rpet's Avatar
Oddometer: 820
I'm very close to owning a DR.
I have 2 questions:
At 6', and used to riding an XR250R (and DH mountain bike) and hoping to take this bike on either the TAT or CDT plus extra offroad touring credit next year, I am looking at RC High bars, Rox risers and high seat foam, plus an 18" rear wheel. Not looking to lower the pegs and reduce any ground clearance. Should that be an OK starting point for ergos?
2nd question: is a Q4 muffler fine or do I need to consider a header upgrade if the maximum performance mod I plan to do would be a carb, but probably sticking with just opening the airbox and replacing the filter. I'm generally skeptical on spending bones on headers if not overboring with cams, etc. I weigh 155lbs and pack light.
Great thread, but too much info to digest in a week (or a year).
thanks guys!
'76 Xl250 '04 XR250R '09 DR650 '10 TR450
Ride The West - OBDR, CDR & western TAT - July 2013
Instagram with plenty of bike pics.
Read my homie's underway Africa trip RR - Round Africa with a Surfboard
WTB: Clarke tank for DR650 for cheap - any color but blue.
rpet is offline   Reply With Quote
Old 11-27-2012, 09:16 PM   #71447
BergDonk
BergDonk's Avatar
Oddometer: 3,715
I have 2 questions:
thanks guys!
You can progressively refine the ergos and find out. Lowering and rearsetting the pegs part way won't compromise ground clearance significantly, unless you use lowering plates. Cutting and welding the stock hangers is straightforward enough, or just making your own. The stock hangers are very tall. I can't comment on your exhaust proposal.
shed time IS quality time
BergDonk's DR650 BergDonk's XT1200Z
BergDonk is offline   Reply With Quote
Old 11-27-2012, 10:32 PM   #71448
Rex Nemo
horizon calling
Rex Nemo's Avatar
Oddometer: 321
I didn't like the loudness of the FMF Q2 pipe my new DR came with, so I did a little research on the innertubes, and got a cheap pair of 1st generation Hayabusa pipes in fine shape. I considered trying to fabricate a 3-hole flange and midpipe, but didn't have several of the tools I'd need.
So, I got the left-side 'busa adapter kit from Jesse at Kientech.
Closeup of the flange
I removed the FMF, loosened everything up, from the header bolts on back, loctited the bolts, attached everything loosely, lined everything up, and then tightened it down into place.
Mid-pipe mounting point
All back together, with Dirtbagz rack
The 'Busa pipe is longer and probably a pound/pound and a half heavier than the FMF, but the fact that it never needs repacking, as well as the quieter (though still raw and fierce, esp at higher rpms) exhaust note made me decide to make the change. Now I just need to find a way to get a spark arrestor in there...
Next, it was time for a dyno run.
I'd already dyno'ed the bike with the FMF, and here was the result. The green line is the new 'Busa pipe; the red line is the old FMF.
When I ran my stock-exhaust, mildly-jetted old DR, it got a whopping 32 hp at the rear wheel. With the FMF, it topped out at 35.15; the 'Busa pipe was ever so slightly less at the top end, with 34.82 hp. The surprise, for me, was the rather improved low-end torque with the 'Busa pipe. It's slightly less torquey than the FMF at 6-7k rpm, but has notably more oomph pulling away from lights, up hills, and is, ahem, easier to wheelie.
Bike has a stage 2 Dynojet kit with a stock 40 pilot jet, 150 DJ main jet, needle on 4th clip, Twinair filter, and Jesse's cut airbox. Header is stock.
Wandering re-establishes the original harmony which once existed between man and the universe. --Anatole France
Rex Nemo is offline   Reply With Quote
Old 11-27-2012, 10:48 PM   #71449
motolab
motolab's Avatar
Oddometer: 2,730
There's something wrong with the data in the chart, as the O2 can't really be 20-22.5% (ambient is roughly 20.95%). CO2 is also way too low. A good running engine should have upwards of 10%.
Regards,
Derek
motolab is offline   Reply With Quote
Old 11-27-2012, 11:08 PM   #71450
kristofer
Motonaut.se
kristofer's Avatar
Oddometer: 69
I have 2 questions:
thanks guys!
1. I am 6' and ride my DR650 with bar risers (1,5"?) and stock seat. I think that it suits me just fine that way. I have the 18" rear wheel and it is probably 1,5" taller in the forks and 2" in the rear. I can still get my feet down good enough, but I can't flat foot both at the same time.
2. I have the stock header and airfilter in an open airbox combined with a MXRob 39 mm FCR-MX (mated to a Lazer home-made slip-on). I have ground down the lug in the header a little, but have not gone crazy with it. So I would say no, there is no need. I'm 175 lbs and haul 30-40 lbs of gear with a 23 ltr fuel tank. The DR becomes pretty quick with that carb :)
All the best,
Kristofer
Kristofer
motonaut.eu - Super light and tough soft luggage systems for daytrips, weektrips and RTW
www.facebook.com/motonautsweden
Motonaut vendor's thread
kristofer is offline   Reply With Quote
Old 11-27-2012, 11:18 PM   #71451
Rex Nemo
horizon calling
Rex Nemo's Avatar
Oddometer: 321
Regards,
Derek
Yep, the dyno is old and crotchety, and the 02 and C02 numbers are highly suspect (in-pipe sensor may be at fault). Would that affect the hp or torque ratings? If so, back to the drawing board.
Old 11-28-2012, 05:08 AM   #71452
rpet
Awesometown
rpet's Avatar
Oddometer: 820
Thank you! I will do bars and wheel first, and decide on the seat based on whether I get knee pain. I'm more concerned about that than flat-footing (my legs are pretty long).
All the best,
Kristofer
Old 11-28-2012, 05:25 AM   #71453
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,691
Originally Posted by Multisurface Rider View Post
My new to me 01 DR650. Had a Corbin seat on it I don't like so I built my own.
Need some risers and then ride.
Looks good!!
Old 11-28-2012, 08:29 AM   #71454
Feelers
Oddometer: 189
Regards,
Derek
Shouldn't we be seeing around 40 or so ft-lbs for the torque as well?
Feelers is offline   Reply With Quote
Old 11-28-2012, 09:54 AM   #71455
JagLite
JagLite's Avatar
Oddometer: 1,325
Thumb Sit down and hang on!
Excellent work sir!
Attitude ~
The difference between
Ordeal and Adventure
James
JagLite is offline   Reply With Quote
Old 11-28-2012, 10:10 AM   #71456
Rusty Rocket
Life behind "Bars"
Rusty Rocket's Avatar
Oddometer: 9,386
Originally Posted by acesandeights View Post
For less than $1k, is there anything better than Racetech emulators and springs up front and Racetech shock shaft assembly and spring in the rear? This is for a Baja trip ~2k miles (mas o menos).
Depending on your weight whether you can still use the stock rear spring.
I sent my rear shock to Cogent and had the upgrade. (Cogent has a damper adjustment) I bought .47 Racetech springs and the Cartridge Emulators. Did the fork work my self. That all cost about $750. Great improvement. (really great) I was able to still use the stock rear spring. If you are over 190lbs, you will want to get a heavier rear spring. That included will put right about $1K.
It is the very next thing you should do after a skid plate, handguards and a DJ kit. Makes it a different bike! Maybe even do it before the DJ kit
on one side the sign it said "Private Road", but on the other side it didn't say nothin'
2009 DR650
..1972 Penton Six-Days ..1971 Suzuki TS185.. 2005 KTM 400exc
Member of: AMA, NETRA, Blue Ribbon Coalition, CCCofVT, Berkshire TR, CT Ramblers
Rusty Rocket screwed with this post 11-28-2012 at 10:50 AM
Rusty Rocket is offline   Reply With Quote
Old 11-28-2012, 10:26 AM   #71457
acesandeights
Asperger
acesandeights's Avatar
Oddometer: 3,980
Yep, I'll need a new rear spring. Doesn't Cogent just rebuild your shock using Racetech components (maybe I'm way off)? I wonder why people use him if they can buy the Racetech shock shaft assy, or do the Gold Valve for even less? Not knocking Cogent, but I just don't understand what he does that Racetech doesn't offer as an assembly, or as a Gold Valve kit? Why would sending it to Cogent be better than the shock shaft assembly? Maybe Cogent isn't using Racetech components/Gold Valve?
http://breakingbooks.wordpress.com
Amazballs Indi-music at https://soundcloud.com/sprunty2000/
I may not be Rainman, but I'm not stupid eighter. Like Bartek on a taco.
I'll die with this hammer in my hand.
acesandeights is offline   Reply With Quote
Old 11-28-2012, 10:54 AM   #71458
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 6,128
I have 2 questions:
Lots of guys run risers and Pro Taper bars. Good set up.
Most custom seat makers can build a "Tall" version, raising you up at least an inch, maybe two? Should help transitioning from seated to standing.
What is your thinking on the 18" wheel? It WILL raise the bike up quite a bit, depending on tire you use. Other than that, what is the advantage? Where will you source the wheel? Will the bearings (Hubb and wheel) hold up with an 18" wheel? Also, fewer 50/50 and street based dual sport tires available in 18". Your choice. If doing "all dirt" then the 18" makes more sense.
In the end, Ergos are quite subjective. Mess around, try different things, go riding, make adjustments as needed!
thanks guys!
If you're a trail rider ... then your first concern should be suspension. But since you're only 155 lbs. (lucky bastard!! ) The stock DR spring rates are not too bad for you ... but still will be a bit "quishy" for aggressive riding. The DR's handling (both ON and OFF road) responds really nicely to suspension upgrades. Just for future thought and upgrades.
FMF
I'm not an FMF fan ... I know them well, have used their products on dirt bikes (and street) since the late 80's. My DR650 came with an FMF pipe ... the rivets started coming out at 4000 miles. I sold it. Also, it was TOO LOUD ... and needed constant repacking. FMF pipes fall apart. IMO? JUNK.
The current hot set up for the DR650 is the Titanium GSXR pipe. It's not as light as the FMF but is super high quality ... will last forever, NOT TOO LOUD. Flows pretty well too.
Old 11-28-2012, 10:56 AM   #71459
Mongle
Knuckle dragger
Mongle's Avatar
Oddometer: 3,035
No
HP and Torque are mathmatical.
HP= Torque x rpm / 5252
Torque= 5252 x HP /rpm
A DR making 40 ft lbs of torque at say 6000 rpm would have almost 47 HP...which would be nice...but probably not possible in stock form.
edit: 5252 is a constant number in the math...if you look at a dyno chart HP and Torque ALWAYS cross at 5252 rpm...if it doesn't something is wrong.
Mongle screwed with this post 11-28-2012 at 11:02 AM
Mongle is offline   Reply With Quote
Old 11-28-2012, 11:14 AM   #71460
Rusty Rocket
Life behind "Bars"
Oddometer: 9,386
Cogent puts his own parts in the shock and you end up with a knob on the bottom of the shaft that has 30 clicks of rebound damping adjustment. Cogent also offers a hard anodize coating for a few bucks more that I believe is a good idea if the shock is of a certain age, if you know what I mean.
see the red knob in the photo: not there with a RaceTech mod. you live with the damping as it comes. Cogent is adjustable.
2009 DR650
Times are GMT -7.   It's 07:39 AM.
