Old 12-08-2012, 11:04 PM   #71701
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 7,144
Originally Posted by blk-betty View Post
Know nothing about machining. Are those welds "cleaned up" by hand or is it all mechanized?
By hand.
Before...
After...
Over 60% more surface area.
May be more prone to cracking on the edge of the weld, but I'm willing to risk it.
Oh, and that was 5 1/2 years ago.
NordieBoy is offline   Reply With Quote
Old 12-09-2012, 12:12 AM   #71702
eakins
Butler Maps
eakins's Avatar
Oddometer: 19,247
so what ever happened to the rally fairing Safari was building?
Alaska
Butler Maps website:
http://www.butlermaps.com
Old 12-09-2012, 12:34 AM   #71703
Phreaky Phil
Oddometer: 1,883
Have you seen this update
http://www.advrider.com/forums/showthread.php?t=822511
Phreaky Phil is offline   Reply With Quote
Old 12-09-2012, 01:01 AM   #71704
Mambo Dave
Backyard Adventurer
Mambo Dave's Avatar
Oddometer: 5,787
Originally Posted by Ren20 View Post
guys, go check your NSU screws if you haven't. I just checked. one of them is so loose. I could turn it with one finger.
I did it without taking the clutch out. it was pain in the ass. they are now tighten and safety wired. I still consider myself lucky
bike has 7800 miles. 2001
What type of screwdriver did you use to get in there?
I have about the same mileage and really need to do mine.
Mambo Dave is offline   Reply With Quote
Old 12-09-2012, 02:39 AM   #71705
greer
Oddometer: 3,835
Some folks use a screwdriver bit and a wrench. We used one of these with the back side of the "neck" filed down to give a bit more clearance. It's a little fiddley but works just fine, we've used it on three bikes now. Remove, degrease, and loctite one screw at a time or the whole assembly will want to pop out as it's got a spring under there.
Sarah
'08 DR650
greer is offline   Reply With Quote
Old 12-09-2012, 05:33 AM   #71706
victor441
victor441's Avatar
Oddometer: 990
Sarah
good to know, need to do mine ASAP....BTW there is oil resistant threadlocker available, plan to use it when I do the job, especially if I don't remove the clutch basket
victor441 is offline   Reply With Quote
Old 12-09-2012, 08:29 AM   #71707
Mambo Dave
Backyard Adventurer
Mambo Dave's Avatar
Oddometer: 5,787
Sarah
Thanks man,
any chance there is enough room to get one of these in there?
http://www.sears.com/shc/s/p_10153_1...=31-59333379-2
Old 12-09-2012, 09:20 AM   #71708
SkunkWizard
recycle crime scene tape
SkunkWizard's Avatar
Oddometer: 756
I'm looking at getting a cover for the DR. I've been sharing the carport with Skunkwife and don't want her cooties to get on the bike.
so the question is, what size cover to get? XL/ XXL any body have a recomendation on brand?
needs to fit over soft panniers, no windscreen
thanks
~DR 650~
Upgrades:
1. dented tank
SkunkWizard is offline   Reply With Quote
Old 12-09-2012, 09:47 AM   #71709
Fire Escape
Fire Escape's Avatar
Oddometer: 1,622
Didn't work for me
Originally Posted by Mambo Dave View Post
Thanks man,
I tried that and also one that had an angled handle, neither fit in there well enough to tighten anything. I only used it to take the old screws out though, got Allen heads and drilled them for safety wire to put in. I know that a lot of people have had great luck with Locktite but ... I was too lazy to remove the clutch and didn't figure that I could degrease the holes very well without better access, also I have seen plastic have a bad reaction to Locktite and disintegrate. I didn't want to have to be fishing pieces of the NSU out of the sump. So old fashioned wire was my choice, it is a real pia to do it underneath the clutch but I got it done. When all was said and done, it probably would have been quicker and easier to remove the clutch (doah, not like that hasn't been already said but sometimes you just have to try...)! The worst part of the job for me was the hours that I spent getting the old gasket off. Mine was in pretty good shape and I could probably put a bit of sealer on and been fine but I had a new gasket so ....
Neither of my NSU screws was 'loose' (as in falling out) but I could not detect ANY 'breaking torque' in turning one of them out, the other required very little effort to start turning.
Bruce
No one calls the Fire Department because they did something smart!
06 DR 650, Moose RS Holder, Handguards and Skidplate, ProTaper bars, Garmin 60CSx, Motech racks w/ 20mm Ammo cans, Renazco 08 Scrambler, Conti Trail Attacks and BlackTiger Fork mod, 05 FSE 450, 03 KLR 250, 02 FXDX, 72 WR 250 (again), 72 SL 350 K2 (again), 72 TR6R, 06 XT 225
Fire Escape is offline   Reply With Quote
Old 12-09-2012, 09:55 AM   #71710
dogjaw
plays well alone
dogjaw's Avatar
Oddometer: 3,208
'09 DR650 just turned 6K miles today and about 20 miles from home exhaust got a little bit louder. About 10 miles got a whole lot louder. Figured it was a crack somewhere on the head pipe as that where the sound was coming from.
Thought about stopping and worried a little about doing engine damage but had no other way to get home so babied it the last 10 miles.
WTF! The head pipe is broken clean off at the flange where it bolts up and there is about 1/2" gap 360 degrees, actually looks like someone cut it off with a rough blade hacksaw.
Is this a common occurence?
Only motor mods are opened up breather box with DT-1 air filter, Pro-Cycle jet kit, and GSXR1000 muffler with Kientech mid-pipe on OEM header.
Anyone have a spare oem header or is there a better option.
I also have a stock header; just went to the FMF... PM me if needed
By God, Woodrow; it's been one hell of a party.
dogjaw is offline   Reply With Quote
Old 12-09-2012, 10:13 AM   #71711
Mambo Dave
Backyard Adventurer
Mambo Dave's Avatar
Oddometer: 5,787
Bruce
Thanks guys.
I wonder if I ground that selector down if it would fit better?
Surely someone has to make an offset driver that would fit well enough... but then I haven't been in there, and it may be more complex than I'm thinking in getting up under the clutch plates.
Old 12-09-2012, 10:42 AM   #71712
blk-betty
bam-a-lam
blk-betty's Avatar
Oddometer: 2,473
Broken Header
Couple of pics.
This is what I found when I got home....
After removal....
Doesn't look like anyone has done any grinding...
Any day on a dirt road is a great day
blk-betty is offline   Reply With Quote
Old 12-09-2012, 10:55 AM   #71713
Fire Escape
Oddometer: 1,622
Thanks guys.
It is 'really interesting' getting anything in there. One of those cases where you can see what you need to do but once you fit something in ... you can't turn the fastener much. I ended up grinding an Allen wrench, way down to where there was barely enough shank to fit into the screw head to replace my screws. Even if you grind everything off the back side of that driver, I am not sure that it will fit but obviously something will. I did get the screws out, I just don't recall what I ended up using as every 'screw turning thing' I had was out at the time. You will get it done but don't plan on it being quick or easy.
Bruce
Old 12-09-2012, 11:03 AM   #71714
ER70S-2
ER70S-2's Avatar
Oddometer: 6,880
TREE used this. There are more photos and info in the link.
http://www.advrider.com/forums/showp...1&postcount=65
2004 DR650: 62,605 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is offline   Reply With Quote
Old 12-09-2012, 11:36 AM   #71715
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 6,128
Couple of pics.
bummer.
My real concern here is for your valves. When the header is broken like that ... the head is open directly to cold air rushing in onto red hot valves.
In some cases the cold air can cause valves to warp a bit.
I know our Auto mechanic guys here know about this. Is this of concern?
Or would one need to run for hours and hours like this to have a bad out come on valves?
I ruined a Go Cart lawnmower motor once, header pipe broke off. 11 year old kids? ... cool! LOUD! We kept riding. Motor didn't run too good after that!
Times are GMT -7.   It's 05:45 AM.
