Old 12-10-2012, 10:29 PM   #71746
shaddix
Oddometer: 647
I replaced my brake fluid tonight on the front... didn't realize I needed a socket for the rear so it still has the old stuff.
Anyway, how do I know if I did it correctly? I used a syringe and pumped it up from the caliper to the reservoir instead of using the lever to pump it out. I then did a few pumps with the lever doing it the normal way to make sure no air in the caliper. I can pull on the lever and it activates the brakes early in the available movement of the lever, but if I pull harder I am capable of pulling the lever back to the grip. The pads are brand new...
shaddix is offline   Reply With Quote
Old 12-10-2012, 10:32 PM   #71747
Ren20
Finding Touge
Oddometer: 111
Some one show me how to adjust the clutch properly?
As you recall, I did the NSU screw fix Saturday. Tried to put the clutch release arm back to original position. but the clutch lever has no tension. Does the arm need to be in specific angle before I adjust the cable?
I did a search. Someone mentioned the release arm could be in a wrong position.
teach me please
Ren20 is offline   Reply With Quote
Old 12-10-2012, 10:36 PM   #71748
Fire Escape
Fire Escape's Avatar
Oddometer: 1,572
Originally Posted by neo1piv014 View Post
What kind of rubber did you decide to put on them?
I bought them very slightly used with Dunlop Roadsmart tires installed. 120 on front and 150 rear, the rear has more than adequate clearance but doesn't seem like it will fit when you first try to 'negotiate' it into place. There is probably 'racier' rubber that could be used but these are definitely more than racy enough for my meager skills or courage to challenge.
Bruce
No one calls the Fire Department because they did something smart!
06 DR 650, Moose RS Holder, Handguards and Skidplate, ProTaper bars, Garmin 60CSx, Motech racks w/ 20mm Ammo cans, Renazco 08 Scrambler, Conti Trail Attacks and BlackTiger Fork mod, 05 FSE 450, 03 KLR 250, 02 FXDX, 72 WR 250 (again), 72 SL 350 K2 (again), 72 TR6R, 06 XT 225
Fire Escape is offline   Reply With Quote
Old 12-10-2012, 11:11 PM   #71749
VooDooDaddy
VooDooDaddy's Avatar
Oddometer: 163
teach me please
I just did my NSU screws a few days ago as well. I noticed on the inside of the clutch cover/left side engine cover, where the clutch rod fits into the cover/case, there are serrated 'teeth' on both the inside of the cover and the end of the clutch rod. These teeth need to engage each other. Basically when you installed the engine/clutch cover, the teeth of the clutch rod should have been at about a 3 o'clock position as you look at the bike from the left side while installing the cover.
While I'm not sure I am using the correct terminology for these parts/covers, etc., this is the best way I can explain the process. I would hazard a guess that when you re-installed the clutch/engine cover; these sets of 'teeth' are not engaging each other....?
When I did the NSU fix, I removed and re-installed the entire clutch assembly. It all went back together rather smoothly, and the bike runs/rides perfectly upon the test ride almost immediately after the repair.
VooDooDaddy is offline   Reply With Quote
Old 12-10-2012, 11:21 PM   #71750
Escaped
Escaped's Avatar
Oddometer: 471
Sounds like you have air in the system. You need to pump fluid from the reservoir through the brake line out the caliper until it runs clear. Pump until tight, loosen bleed valve, squirt, hold lever, tighten bleed valve, repeat. You cant short cut it.
Use bleed tube on nipple of course.
Sent from my SAMSUNG-SGH-I317 using Tapatalk 2
2006 DR650 54,407 miles
DR650 - Eyes open all of the time
Escaped is offline   Reply With Quote
Old 12-10-2012, 11:38 PM   #71751
LucasLeader
LucasLeader's Avatar
Oddometer: 292
Originally Posted by Magnum Noel View Post
Just to change the subject for a minute. Has anyone invented or found a way to waterproof their garage door remote whilst leaving it fixed on the bike? I have mine in my jacket pocket and sort of wobble down the the road stearing with my right hand whilst trying to activate the remote button through the jacket outer with my left hand. There must be a better way?
We installed some of these at my old job: http://www.biketronics.com/products/...te-Opener.html
A ziploc bag is a lot cheaper.
LucasLeader is offline   Reply With Quote
Old 12-10-2012, 11:41 PM   #71752
LucasLeader
Oddometer: 292
I used the same method as you with the syringe and it worked fine. To get some of the air out you can hold the wheel and push the caliper out and then pump the lever. This can help firm it out. Also you can tie the lever down overnight and some of the air will work its way out of the line.
Old 12-10-2012, 11:49 PM   #71753
ER70S-2
ER70S-2's Avatar
Oddometer: 6,281
teach me please
It's easy once you understand it. I'm guessing you just need to rotate the arm clock wise, one tooth on the spline. If that isn't enough, try two teeth.
Here are pics and more info.
You're trying to get the arm to rotate freely between pic 4 and 5.
http://www.advrider.com/forums/showp...7&postcount=33
VooDooDaddy mentioned the spline on the clutch itself has to face the front of the bike (first pic in the link). I don't if the cover will go on if the spline is pointing any other direction. It spins freely and is easy enough to bump out of position.
2004 DR650: 62,496 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 screwed with this post 12-10-2012 at 11:57 PM
ER70S-2 is offline   Reply With Quote
Old 12-11-2012, 12:48 AM   #71754
Magnum Noel
Magnum Noel's Avatar
Oddometer: 186
Garage Door Remote Control
Thanks DEVAN8101, ROGOR. BULL600 [hehe], DICKENSHEETS, LUCUSLEADER and MIDNIGHTVENTURE.
MidNight I"m thinking I might go with your idea sounds great and relatively cheap.
cheers everyone
Magnum Noel is offline   Reply With Quote
Old 12-11-2012, 02:34 AM   #71755
Thumper Dan
Oddometer: 325
teach me please
I did exactly the same thing and made the mistake of carefully marking the spline etc with a texture before removing. I put it back on exactly to the mark and low and behold, now clutch.
I thought I botched something up big time but remembered the 'clockwise' technique on this forum and it fixed it. I'm still not sure how the clutch engages, as there seems to be minimal movement in the actual clutch itself. But anyway, it works.
Take your time and you'll work out it .
cya
Currently riding DR650 (2011)
Mods: Manrack, ebay 48 litre top box, grind header pipe; B&B bash plate; bigger/better tool compartment (pvc pipe) - Screens For Bikes Windscreen, TM40 Pumper Carb, Safari Tank, Seat Concepts, Oxford Heater Grips, Highway Pegs, Wolfman Expidition bags and racks, HDB handguards, Cogent Mojave rear shock, intiminators, GSX muffler/mod
Thumper Dan is offline   Reply With Quote
Old 12-11-2012, 02:37 AM   #71756
GSF1200S
Oddometer: 976
cya
I did the same thing- marked it only to find out that didnt help
I basically lined the cover up, started turning the top shaft on the cover clockwise and slipped the cover on. I then made sure all the slack was out as I slipped the clutch arm (connected to the clutch cable) on. I then made sure the lever had a little slack by adjusting the cable at the lever with the adjuster.
GSF1200S is offline   Reply With Quote
Old 12-11-2012, 04:30 AM   #71757
kezzajohnson
kezza
kezzajohnson's Avatar
Oddometer: 1,518
needle wear
Originally Posted by shu View Post
For those running the stock BST carburetor (no jetting or needle changes, no holes drilled) here is a pic of needle wear after 52,000 miles (83,000 Km).
Just a tiny bit of 'stepping'. (not a great pic but if you enlarge it on your screen you can see it a little better.)
I replaced it and the diaphragm anyway with parts from an almost new carb that I bought here for a nice price.
........shu
Here's a pic of my needle wear at around 35000km after having the small washer that came with dyno jet kit placed under the nylon washer to raise the needle slightly. I now run th DJ needle.
KezzaJohnson Blue 06 DR650se,Yellow 06 DRZ250
Website: http://www.territoryon2wheels.com
"May the Road Never Rise to Defeat you..."
kezzajohnson is offline   Reply With Quote
Old 12-11-2012, 07:11 AM   #71758
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,419
Kind of an expensive solution, but works.
http://www.motoadv.com/products/Flas...ge-Opener.html
Albie is offline   Reply With Quote
Old 12-11-2012, 10:47 AM   #71759
motolab
motolab's Avatar
Oddometer: 2,583
........shu
Needle wear as in the picture is the result of slide guide wear in its advanced stages, when the slide becomes constrained by the needle in the emulsion tube rather than by the slide guide. The emulsion tube's outlet will be be enlarged and/or ovaled, and the slide is likely to have an enlarged and/or ovaled needle hole along with exhibiting vertical grooving on the downstream side. I'd be very surprised if the slide guide, emulsion tube, and slide were not in need of replacement. You can verify by having a look at the indentations in the bottom corners adjacent to the bore (not to be confused with the round indentations). If they are less than .010" (0.25mm) deep, the guide should be replaced. Non-nickel plated emulsion tubes are pretty much guaranteed to be worn out when the guide is worn more than .010" (0.25mm). Nickel plated versions are a more wear resistant, but I don't know by how much. Have a look at:
http://www.moto-lab.com/gallery/view?itemid=298, http://www.moto-lab.com/gallery/view?itemid=299, http://www.moto-lab.com/gallery/view?itemid=300, http://www.moto-lab.com/gallery/view?itemid=301, http://www.moto-lab.com/gallery/view?itemid=302, http://www.moto-lab.com/gallery/view?itemid=304, http://www.moto-lab.com/gallery/view?itemid=303 and http://www.moto-lab.com/gallery/view?itemid=305.
Perhaps the slide, slide guide, and emulsion tube out of the carb you got the needle and diaphragm from could be used? Or why not the whole carb?
Regards,
Derek
motolab is online now   Reply With Quote
Old 12-11-2012, 12:04 PM   #71760
thetable
thetable's Avatar
Oddometer: 1,421
Originally Posted by Burnt Toast View Post
Has anyone here experimented with this? It looks pretty interesting and I'm considering taking a shot at it. (After I get my front suspension sorted so it will handle better, or any, braking).
I am running it on my DR-Tard, and it feels incredible, much more linear than any other setup I've run on other bikes. I can't directly compare to the stock setup on the DR, as I bought mine with the Brembo, and big rotor, but I can tell you that the Brembo lever/EBC supermoto rotor/EBC caliper relocation bracket/stock caliper is the most linear brake feeling I've ever experienced, even moreso than the few bikes I've ridden and owned that came stock with radial MCs and calipers.
Now on the same note, I'm not sure that I would have dropped the money on the Brembo unit, but since it came included, I really like it. Maybe one day, I'll even get around to putting a brake light switch on it.
thetable is offline   Reply With Quote
Times are GMT -7.   It's 12:57 AM.
