Old 12-06-2012, 04:28 AM   #71791
macrae85
Oddometer: 375
Originally Posted by dogjaw View Post
Tis a Galfer from Kientech; stops the DR like a champ...
Ta much!
macrae85 is offline   Reply With Quote
Old 12-06-2012, 08:31 AM   #71792
acesandeights
Asperger
acesandeights's Avatar
Oddometer: 2,052
Replacing bars - grips?
I am replacing my bars. Will I need to replace grips, or will the left one come off?
http://breakingbooks.wordpress.com
http://www.kenmarshallmetalworks.com/
2011 DR650, Fly Aero tapered bars, Race Tech front springs/emulators, RT rear spring/shock shaft assy, BarkBusters, MT21s, 14/43T, etc
I may not be Rainman, but I'm not stupid eighter. Like Bartek on a taco.
acesandeights is offline   Reply With Quote
Old 12-06-2012, 08:46 AM   #71793
mrprez
KJ4WMZ
Oddometer: 1,260
Send a message via Skype™ to mrprez
I had to cut mine off.
Sent via morse code
mrprez is offline   Reply With Quote
Old 12-06-2012, 08:51 AM   #71794
procycle
procycle's Avatar
Oddometer: 1,607
Originally Posted by Emmbeedee View Post
So, just for the record, if my 96 needs a starter, can I use the newer short shaft version?
Dunno. I don't see why not but the long shaft with bearing support looks like a much more robust design. If I had to replace a starter I would seriously consider getting the old style and adding the support bearing.
Clarke's second law of Egodynamics: "For every expert, there is an equal and opposite expert." - Jasper Fforde
www.procycle.us - Everything for your DR650 and lots of other great stuff!
DR900 Big Bore Stroker buildup
procycle is offline   Reply With Quote
Old 12-06-2012, 09:42 AM   #71795
sunthechip
Oddometer: 39
I installed a new horn yesterday ( I haven't had a working one for at least 6 months), then I turned the power on and pressed the horn switch, but there was no sound, so I checked the electrical connectivity.
When I bypassed the switch with a screwdriver the multimeter would read 13V where the horn plugs in, so the switch was the problem.....
I dissembled the entire left hand control and cleaned the inside of the horn switch with a pipe cleaner, turned the power on, pressed the horn switch, and the multimeter read 13V.
I thought it was all fixed, so I reassembled the control unit to the handle bar, turned the power on and pressed the switch to see if it was working properly ........NOPE.
So then I disassembled the entire control unit AGAIN to figure out why the switch wasn’t making contact.
It turns out the horn switch was not flush with the plastic exterior of the control unit, so I wedged a piece of a zip-tie in the crevice and brought the crooked end of the horn switch forward and flush.
I reassembled the unit (halfway this time) and tested the switch... BINGO, 13V on the multimeter.
2 hours later everything works and the horn fires up nicely...
sunthechip is offline   Reply With Quote
Old 12-06-2012, 09:45 AM   #71796
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 5,813
Good point - newer is not necessarily better.
"Don't play a lute to a cow" (Old Chinese Idiom)
Old 12-06-2012, 01:09 PM   #71797
Rusty Rocket
Life behind "Bars"
Rusty Rocket's Avatar
Oddometer: 6,263
It's a superceded part #
http://www.ronayers.com/Fiche/TypeID...STARTING_MOTOR
and the shorty is the only one avail. Sell you a collector's item outta my '96.
1996 DR 650 (a big girl that likes it dirty)
1973 Penton Six-Days (mint)
1971 Suzuki TS185 (needs restoration)
2005 KTM 400exc w/ BajaDesigns D/S light kit
Rusty Rocket is offline   Reply With Quote
Old 12-06-2012, 01:43 PM   #71798
procycle
procycle's Avatar
Oddometer: 1,607
The long shaft starter is still used in their ATVs. It's available from several aftermarket suppliers.
Old 12-06-2012, 01:55 PM   #71799
huguesfrederic
HF
huguesfrederic's Avatar
Oddometer: 25
Clymer Manuals Suzuki Dr650 1993-2013
I have just ordered my copy of the Clymer Manual.
Gift wrapped
From me to me...
I know you are Gurus, but I am a new-be and this will reassure me, when I will upgrade my suspension next spring, just saying.
Remember – there is NO perfect travel bike, only what suits YOU for YOUR chosen trip, which is why nobody makes one. Adam
We do these things not to escape life, but to prevent life from escaping us!
huguesfrederic is offline   Reply With Quote
Old 12-06-2012, 02:16 PM   #71800
procycle
procycle's Avatar
Oddometer: 1,607
The Clymer people finally got tired of listening to me carp on about the lack of an aftermarket manual for the DR650. I've been asking for this for YEARS.
I have one sample copy. It looks pretty good. I haven't had time yet to make sure they didn't replicate the errors in the factory manual.
ProCycle should have the first shipment of Clymer books in about 2 weeks.
Old 12-06-2012, 04:37 PM   #71801
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 5,813
Topic hijack - is it possible to buy a gasket for the locking gas cap found on the IMS tank? I think my tank and cap are about 12 years old and the gasket doesn't seal well.
Must remember to install those two countershaft seal retainers we bought from you - they look great.
Old 12-06-2012, 04:50 PM   #71802
procycle
procycle's Avatar
Oddometer: 1,607
We haven't been able to get gaskets separately.
Old 12-06-2012, 05:42 PM   #71803
sandwash
sandwash's Avatar
Oddometer: 837
Try here:
http://www.imsproducts.com/Products/...=true&tyd=true
Another place
https://www.denniskirk.com/gas-cap-for-ims-gas-tanks.p180255.prd
97dr650 bad ass FCR-MX pumper,plus other goodies
sandwash screwed with this post 12-06-2012 at 05:47 PM
sandwash is offline   Reply With Quote
Old 12-06-2012, 05:46 PM   #71804
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 5,813
Originally Posted by sandwash View Post
I don't see any separate gaskets but I'll ask them if they can sell me a couple. Seems a shame to have to buy a whole new cap just for that, though a Billet one might be nice. Of course, what would be the point of a nice durable Billet cap if its gasket went and I couldn't get a replacement?
Old 12-06-2012, 06:31 PM   #71805
opium89
opium89's Avatar
Oddometer: 1,134
You folks just let me know if you need a bearing and clip to go with that starter.
Tea parties are for little girls with imaginary friends.
opium89 is offline   Reply With Quote
Times are GMT -7.   It's 10:29 PM.
