Old 12-18-2012, 06:19 AM   #71956
TrophyHunter
Oddometer: 2,192
Originally Posted by AeroEngineer View Post
Nicely done. I just put that same front fender on in my change over from blue to all white. Same Gen II Wolfman set up, too.
2005 DR650 '07 WR450
2013 HD Road King '73 Hodaka Wombat
"It's a small amount of gas, but it represents a long walk" My Dad...
TrophyHunter is offline   Reply With Quote
Old 12-18-2012, 07:25 AM   #71957
neo1piv014
ADV in training
Oddometer: 619
It took a few months, but I finally got my ugly stock '06 DR to look less like a giant banana :
Looks amazing! So what headlight are you running on it? It almost looks like you took the light off a KLX250.
_________________________
Ride videos
'01 DR650
"The impossible often has a kind of integrity which the merely improbable lacks."
neo1piv014 is offline   Reply With Quote
Old 12-18-2012, 07:28 AM   #71958
neo1piv014
ADV in training
Oddometer: 619
Originally Posted by ghollaba View Post
Would appreciate some input guys.
Getting back into riding after selling the 1150GS and wanting something used fro under $5,000.
Primary use back roads, 15 miles to work in good weather, dirt/gravel fire roads.
No toll roads, some highway but no long distances.
The DR650SE sits well, going to go ride one this week.
Is there a year to stay away from?
Anything to look for?
Would the dreaded ugly KLR650, "gasp" be a better jeep, ugly ugly bike...?
Appreciate it.
The KLR will be much more like the 1150GS. If all you're doing is commuting with some light dirt and gravel roads, I would recommend the KLR over the DR. The KLR is going to be a much better commuting/highway machine as the wind protection is noticeably better. If you're just doing dirt roads and fire roads, the DR doesn't exactly walk away from the KLR. The guy I used to ride with was on a KLR for a couple years before upgrading to a Tiger 800, and I was never really able to get away from him when I was on the DR. When the trails got tighter and more technical, I had the advantage, but I would gladly have traded bikes as soon as we got back on the pavement.
Ride videos
'01 DR650
Old 12-18-2012, 07:59 AM   #71959
GRinCR
Oppressed Nomad
GRinCR's Avatar
Oddometer: 326
Old School vs New School
Pre vs. Post '96?
Just your 2 cents.
Cheers
Greg Smith
'90 DR650RS
Costa Rica: Trippin' with GR , The Bike Teardown
_ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _
"My father taught me to work; he did not teach me to love it." -Abraham Lincoln
GRinCR screwed with this post 12-18-2012 at 01:07 PM Reason: Self nuke and taken elsewhere...
GRinCR is offline   Reply With Quote
Old 12-18-2012, 08:36 AM   #71960
Mongle
Knuckle dragger
Mongle's Avatar
Oddometer: 2,794
Muffler flow
I just want to add some to the muffler debate.
I think you guys are missing a point: an engine is nothing more than an air pump. The more air you can get in it the more fuel you can add the more HP you get. Simple right?
While everyone is correct that a 650cc pulse of exhaust is harder to quiet then a 250cc pulse- you are missing the most important part of engine dynamics= airflow.
Doing the rough math:
A DR650 with a CFM efficiency of .7 (basic figure for carb 4 cycle engine) flows 56.1 CFM
A GSXR1000 with efficiency of .9 (basic fuel injection 4 cycle engine) flows 190 CFM!
That is about 3.5 times as much air goes through the GSXR as the DR (at max RPM). Even with two mufflers the GSXR mufflers were DESIGNED to flow more air per muffler then the DR engine flows.
How much air per pulse really has nothing to do with HP numbers; only dB.
Also, on a side note. When designing or selecting an air filter they recommend a filter that flows 2 times the air the engine requires.
Mongle is online now   Reply With Quote
Old 12-18-2012, 08:50 AM   #71961
Rusty Rocket
Life behind "Bars"
Rusty Rocket's Avatar
Oddometer: 9,155
Originally Posted by heirhead View Post
There is ALWAYS shrinkage in colder climates!!
Heirhead
I WAS IN THE POOL!!!
on one side the sign it said "Private Road", but on the other side it didn't say nothin'
2009 DR650
..1972 Penton Six-Days ..1971 Suzuki TS185.. 2005 KTM 400exc
Member of: AMA, NETRA, Blue Ribbon Coalition, CCCofVT, Berkshire TR, CT Ramblers
Rusty Rocket is offline   Reply With Quote
Old 12-18-2012, 08:53 AM   #71962
996DL
Buell me
Oddometer: 2,263
Originally Posted by LexTalionis View Post
I like the exhaust tone of the OEM canister...
Jesse's airbox mod, Dynojet needle with clip 3 NOT 4 down from the top, 155 DJ mainjet for oem exhaust (Jesse's standard recommendation), Kientech's fuel screw aprox. 1 1/4 turns out at 2200' asl, no flat spots (unlike with the DJ's needle's clip placed 4 down from top ) , great mileage and pulls like a bear, with my tall geared roadie usage.
Did I mention smooth as silk, for a large displacement single...
996DL
996DL is offline   Reply With Quote
Old 12-18-2012, 08:56 AM   #71963
Rusty Rocket
Life behind "Bars"
Oddometer: 9,155
Originally Posted by dogjaw View Post
If I was making more money selling a particular exhaust system, I'm sure that I could justify it with charts/pulses/stats; who wouldn't? All I know is that I am fully satisfied with my mediocre, relatively quiet, non packable, stock-appearing though obviously inferior to the aftermarket,GSXR pipe.
I have a SuperTrapp IDS II w/ quiet core,that I was running with 6 discs. I put my stock silencer back on and I'm sooo happy with the quiet that it's staying. (been a bout 2 years now). I really couldn't feel the difference , in a "seat of the pants test". The only real benefit for me with the SuperTrapp was the weight savings up high. ('bout 8 lbs)
2009 DR650
Rusty Rocket screwed with this post 12-18-2012 at 09:01 AM
Old 12-18-2012, 09:02 AM   #71964
procycle
procycle's Avatar
Oddometer: 2,280
Originally Posted by Thumper Dan View Post
thanks Jeff,
While your on the forum, I was curious if you ever bought Jays (jaminglobal) former motor which he blew up but was reconditioned just prior to his misfortune??
It would be good to know if this motor got back up and running and I remember reading you were going to buy it?? Not sure if you did though.
thanks
Yup, I took Jay's old motor and built the first 780 2 years ago which is still in my main bike. It's never been apart since the original build, still runs very strong and doesn't use any oil.
Clarke's second law of Egodynamics: "For every expert, there is an equal and opposite expert." - Jasper Fforde
www.procycle.us - Everything for your DR650 and lots of other great stuff!
DR900 Big Bore Stroker buildup
TurboDiesel Corvette - go to the end to start at the beginning
procycle is offline   Reply With Quote
Old 12-18-2012, 09:09 AM   #71965
Mambo Dave
Backyard Adventurer
Mambo Dave's Avatar
Oddometer: 5,510
I'm thinking of raising the handlebars through handlebars alone, not risers.
Anyone happen to know how much higher the CR high bar style would ride over the stock modern DR650 bars? I've measured based on specs I've seen, but it looks like they wouldn't be enough of a rise to justify those over a higher design if I wanted to avoid risers.
Mambo Dave is offline   Reply With Quote
Old 12-18-2012, 09:15 AM   #71966
procycle
procycle's Avatar
Oddometer: 2,280
Oh I get it. I was trying to explain that HP doesn't have all that much to do with how the exhaust is restricted.
The point is that a bunch of small pulses can slip through a restriction easier than one big pulse.
And of course a big pulse takes more "processing" inside the muffler to get the required 80dB sound level.
This applies to intake through the airbox too which is why the DR responds so well to opening up the airbox.
procycle screwed with this post 12-18-2012 at 09:21 AM
Old 12-18-2012, 09:18 AM   #71967
procycle
procycle's Avatar
Oddometer: 2,280
CR high bars will be about 1/2" to 3/4" taller than stock DR bars. Not much but enough to feel the difference.
Old 12-18-2012, 09:23 AM   #71968
Mambo Dave
Backyard Adventurer
Mambo Dave's Avatar
Oddometer: 5,510
Thank you, I'll probably go higher with some other bar bend then.
Old 12-18-2012, 09:23 AM   #71969
Rusty Rocket
Life behind "Bars"
Oddometer: 9,155
Check here:
http://www.rockymountainatvmc.com/Ha...r-Measurements
2009 DR650
Old 12-18-2012, 09:56 AM   #71970
LucasLeader
LucasLeader's Avatar
Oddometer: 292
Edited: Look into ATV bends. I thought the ATV bends were really narrow but I was wrong. They look to have the most rise.
LucasLeader screwed with this post 12-18-2012 at 10:02 AM
LucasLeader is offline   Reply With Quote
Times are GMT -7.   It's 01:06 PM.
