Old 12-21-2012, 12:30 PM   #72076
UberKul
UberNoob
UberKul's Avatar
Oddometer: 114
Originally Posted by VooDooDaddy View Post
And here's what I had to resort to after the PO must have used an impact gun to tighten the inspection/crank cover:
This crank access cover has some kind of physics defying adhesive qualities built into it!
Destroyed a second one even after using anti-seize and a low torque install. Problem is if you use a hammer-driver you punch through the cover before the thing comes loose. Finally bought the Yosh plug with the male hex but they do not seem to be available through their site any longer.
My Smugmug, it's how I roll.
UberKul is offline   Reply With Quote
Old 12-21-2012, 01:21 PM   #72077
Rusty Rocket
Life behind "Bars"
Rusty Rocket's Avatar
Oddometer: 9,737
Originally Posted by blackcap View Post
anyone got their original carb vent breather laying around that they would like to exchange for some dollars?
you mean like one of these?
http://www.procycle.us/bikepages/dr650.html
on one side the sign it said "Private Road", but on the other side it didn't say nothin'
2009 DR650
..1972 Penton Six-Days ..1971 Suzuki TS185.. 2005 KTM 400exc
Member of: AMA, NETRA, Blue Ribbon Coalition, CCCofVT, Berkshire TR, CT Ramblers
Rusty Rocket is offline   Reply With Quote
Old 12-21-2012, 01:49 PM   #72078
JagLite
JagLite's Avatar
Oddometer: 1,434
Question Lost messages?
Originally Posted by Adv Grifter View Post
Of course you could have bought the WHOLE DR650 bike I posted here a while back from a San Francisco Craig's list add; $300, (IIRC) for the WHOLE BIKE. No one even so much as made a peep or thanked me for the tip. Guess I'll keep these finds to myself from now on. Believe me, they pop up more frequently than you would imagine. Early bird and all that .... .
What?
What??
How'd we miss your post?
I check the site several times each day and read all the new posts but I sure missed the $300 DR650!
How many others missed seeing that post?
I know I post things in answer to questions and sometimes it seems nobody saw it.
I wonder if when I hit "unread posts" it jumps past some?
Anyone else notice that?
A $300 DR650. Wow.
Attitude ~
The difference between
Ordeal and Adventure
James
JagLite is online now   Reply With Quote
Old 12-21-2012, 02:18 PM   #72079
procycle
procycle's Avatar
Oddometer: 2,463
Originally Posted by JagLite View Post
What??
You didn't miss anything. That "whole bike" did not have a motor in it. As I recall it was just a frame, suspension and wheels. Kinda rusty and ugly. I checked it out closely, If there was $300 worth of value there I would have picked it up for spares.
Clarke's second law of Egodynamics: "For every expert, there is an equal and opposite expert." - Jasper Fforde
www.procycle.us - Everything for your DR650 and lots of other great stuff!
DR900 Big Bore Stroker buildup
TurboDiesel Corvette - go to the end to start at the beginning
procycle is offline   Reply With Quote
Old 12-21-2012, 02:26 PM   #72080
VooDooDaddy
VooDooDaddy's Avatar
Oddometer: 163
Have you tried it on oxidized Aluminum ...
Yes, I completely stripped the front and rear brake calipers and brackets, washed them in hot soapy water, then let them sit in a bowl of Metal Rescue for a couple of days. They were covered in furry, grey oxidation. I imagine the PO often rode the bike in wet conditions, then just let is sit. Anyway, the MR does a good job of removing oxidation from alumium as well, but not nearly as quickly as from ferrous metals. I did find that also using a small, brass bristled brush, scrubbing on the parts immediately after removing them from the MR also helps bring back the original finish/look.
Good stuff. The jug cost me $25, but I have used less than 1/4 of it with excellent results. Some of the parts were so heavily oxidized, I was considering trying to find replacement parts before I discovered the MR. Check out their website.
VooDooDaddy is offline   Reply With Quote
Old 12-21-2012, 03:01 PM   #72081
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 6,128
I think you're right, sorry, I should have mentioned lack of motor. There were two DR's for sale around the same time, both cheap, I mixed them up.
The San Fran one did not look all that bad to my dim memory however ... had both wheels, frame, bars, controls, electronics (CDI), Reg. Rectifier, swing arm, shock, forks. I think the wiring harness may have been there, but not sure.
Light rust, yes, but I've seen worse.
I believe it was an early DR as it had the purple frame.
IMO, lots of usable parts ... not pristine, but usable and rebuildable IMO. The forks, wheels, frame and swing arm alone easily surpass $300.
The other DR I saw for sale (cheap) I did not post here. It had a motor, was going for more money ... and it ran. (supposedly) (around $600 IIRC) But actually looked worse. I believe it was down in SoCal ?
Old 12-21-2012, 03:14 PM   #72082
DockingPilot
Hooked Up and Hard Over
DockingPilot's Avatar
Oddometer: 9,927
I smother mine (2012) in Loktite copper based anti seize and also give it a crack open and closed every other oil change (every 2k). So far at 7k miles, it still opens as it should. It is strange why they weld themselves to the cover though.
Frank Reinbold
"Every bike I ever had, was the best bike I ever had, when I had it"
DockingPilot is online now   Reply With Quote
Old 12-21-2012, 03:18 PM   #72083
dman
Oddometer: 645
I have the black plastic part (#20 in ER70S-2's subsequent post) but why would you want it? Not sure shipping from the US is worth it either, but otherwise you can have it.
-dman
dman is offline   Reply With Quote
Old 12-21-2012, 03:25 PM   #72084
Mongle
Knuckle dragger
Mongle's Avatar
Oddometer: 3,278
Seems to work on other non-ferrous metals as well.
Where did you get this stuff?
What were you stripping off the non ferrous metals? Oxidation?
Do you have to dip the stuff or can you coat it on the part?
I'm always looking for something to strip rust from engine blocks...I hate soda blasting!
Mongle is offline   Reply With Quote
Old 12-21-2012, 03:30 PM   #72085
Mongle
Knuckle dragger
Mongle's Avatar
Oddometer: 3,278
Originally Posted by bross View Post
Helps if you try to crack it loose when the motor is good and hot. Then a little anti seize on the threads makes it easier next time.
I 2nd this.
First time I checked the valves I tried that stupid plug with the engine cold I thought I was going to tear the whole side cover off. Never did get it- used the rear wheel.
2nd time and there after- loosened it while the engine was hot (as soon as I pulled into the garage) and it came free with a 3 inch allen. So easy I couldn't believe it!
Old 12-21-2012, 04:45 PM   #72086
Adv Grifter
Oddometer: 6,128
I believe some form of electrolysis may be taking place. Anyone old enough to remember Honda's from the early to mid 60's. I was there and owned several. Honda used those HORRIBLE JIS head (phillips) bolts for the side cased back then ... and for lots of other critical areas. Those bloody bolts would weld themselves to the case ... just about a guarantee the mechanic would strip the soft JIS bolt head.
It was electrolysis at work. Steel bolt, Alu case. All Japanese OEM's moved away from this type of fastener by the 70's but my Honda 305 Superhawk,
Honda 160 and a few smaller bikes all had them. PITA.
Back then we used Impact Drivers to remove ... and greased them up with
copper grease going back in.
Old 12-21-2012, 04:53 PM   #72087
bross
Where we riding to?
bross's Avatar
Oddometer: 4,700
Their website says available at some Home Depot stores.
Old 12-21-2012, 04:56 PM   #72088
BergDonk
BergDonk's Avatar
Oddometer: 3,926
320 mm Rotor
Just wondering if anyone is aware of an alternate to the EBC floating one. Arguably, its not really suited to ADV type riding. I just want a floating disc and not the calliper adaptor. I've seen references to a Titax one, but can't find a listing.
shed time IS quality time
BergDonk's DR650 BergDonk's XT1200Z
BergDonk is offline   Reply With Quote
Old 12-21-2012, 04:59 PM   #72089
procycle
procycle's Avatar
Oddometer: 2,463
We'll have 320mm rotor kits from Galfer soon (couple weeks). Should be a high quality alternative to the EBC brake.
Old 12-21-2012, 05:11 PM   #72090
BergDonk
BergDonk's Avatar
Oddometer: 3,926
Sounds promising, I'll kep and eye out, ta.
And Merry Christmas to all
Times are GMT -7.   It's 07:39 PM.
