Old 12-22-2012, 08:26 AM   #72106
procycle
procycle's Avatar
Oddometer: 2,412
Originally Posted by blk-betty View Post
What's the likley change it will need carb tuning switching from the oem header to the PowerBomb which is larger diameter than the oem but not as large as the "oversize" FMF pipe?
No jetting change will be necessary.
Clarke's second law of Egodynamics: "For every expert, there is an equal and opposite expert." - Jasper Fforde
www.procycle.us - Everything for your DR650 and lots of other great stuff!
DR900 Big Bore Stroker buildup
TurboDiesel Corvette - go to the end to start at the beginning
procycle is offline   Reply With Quote
Old 12-22-2012, 10:18 AM   #72107
Hesaid
Hesaid's Avatar
Oddometer: 1,422
Soupy's links
I started a thread asking all if they had any experience with Soupy's adjustable lowering links, but I thought I'd ask here for DR650 specific info. So, does anyoneone havce any thoughts? She'd link about another inch, but the idea of being able to go lower for learning, and raise back up again as confidence and skills allow, plus being able to adjust for (future) additions sounds like a great way to go. Let me know what you think.
http://www.soupysperformance.com/cat...00/7531010.htm
MV
Hesaid is online now   Reply With Quote
Old 12-22-2012, 11:13 AM   #72108
ER70S-2
ER70S-2's Avatar
Oddometer: 6,960
Thanks..that's what I assumed.
Weld was not ground, this it what it looked like once removed and "pieced together".
Good photo, thanks for lighting it up so we could actually see the bulge. Mine looks just like that. Yours is the second one I've seen broken in this thread, the other wasn't ground either.
MV
I like adjustability in a situation like this, you don't know what you need or where you'll end up. Don't forget you'll need to do something with the kickstand.
2004 DR650: 62,605 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is online now   Reply With Quote
Old 12-22-2012, 11:48 AM   #72109
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 6,128
Originally Posted by TrophyHunter View Post
blackcap - great pics.
SPOT II's are on promo this weekend. Buy one + service plan with tracking - get the unit free via rebate.
PLUS TWO! Wonderful Photos!
Can you tell us where you were traveling? Bali or Indonesia somewhere ?
Old 12-22-2012, 01:18 PM   #72110
BergDonk
BergDonk's Avatar
Oddometer: 3,820
Originally Posted by DR Steve View Post
Metalgear do one - has to be ordered in though
http://metalgear.com.au/view_model_d...?model_id=8798
Ta
shed time IS quality time
BergDonk's DR650 BergDonk's XT1200Z
BergDonk is offline   Reply With Quote
Old 12-22-2012, 01:21 PM   #72111
BergDonk
BergDonk's Avatar
Oddometer: 3,820
I think I aked this before, but was there any 'force' required when you assembled this all originally? If so, that's likely the cause. It should all fit together without having to use any significant force on any bits one way or the other to get it to line up.
Old 12-22-2012, 01:48 PM   #72112
Phreaky Phil
Oddometer: 1,889
Originally Posted by BergDonk View Post
Just wondering if anyone is aware of an alternate to the EBC floating one. Arguably, its not really suited to ADV type riding. I just want a floating disc and not the calliper adaptor. I've seen references to a Titax one, but can't find a listing.
I have been thinking of using one of Galfers 270mm kits for mine (DRZ front end ) I thought the original DRZ one would be to weak for the DR but its surprisingly ok. Not great though and is showing signs of overheating. Not sure if the 320 would be to much ?
Phreaky Phil is offline   Reply With Quote
Old 12-22-2012, 02:42 PM   #72113
blk-betty
bam-a-lam
blk-betty's Avatar
Oddometer: 2,473
From the source...thanks!
Any day on a dirt road is a great day
blk-betty is offline   Reply With Quote
Old 12-22-2012, 02:48 PM   #72114
blk-betty
bam-a-lam
blk-betty's Avatar
Oddometer: 2,473
No force applied, simply removed the muffler, added the midpipe and mounted the X40F0X with the hardware supplided by Kientech.
I am a little ham fisted and really tightened up the muffler and "squished" the rubber spacer supplied in the mount kit.
I'll loosen everything up and retighten on the install making sure nothing has any undo force.......waiting on the gaskets on order from the dealer.
Old 12-22-2012, 03:12 PM   #72115
ER70S-2
ER70S-2's Avatar
Oddometer: 6,960
Originally Posted by Phreaky Phil View Post
Not sure if the 320 would be too much ?
I wondered that myself. I have a 20 mile twisty dirt section that I ride quickly with lots of flat, slippery turns. Accelerate, brake hard, turn, accelerate, brake hard, turn, over and over....... But by the end of the 20 miles I started riding slower (coasting into the turns) because my right forearm was starting to pump up.
With the 320 that is no longer an issue, not even a little bit.
The other question I had, am I going to grab too much front brake and drop myself? I wondered if I'd use the same lever pull that I've used forever, which would be too much now. Happily that wasn't a problem either. My muscle memory learned the new, lower pull and adjusted to the traction available, not overbraking. I don't trail brake with the front any more though.
I imagine with your two up riding, the 320 would be sweet. Look into the new Galfer that Procycle is expecting shortly.
2013 WR250R
Old 12-22-2012, 03:36 PM   #72116
BergDonk
BergDonk's Avatar
Oddometer: 3,820
Everything else in my fleet has much more sensitive brakes than my DR, even with the 11 mm Brembo MC. I am always recalibrating my right arm. It was interesting when I first got my FE650, and those who rode it considered the brakes more savage than the throttle
Old 12-22-2012, 04:26 PM   #72117
smilin jack
Grandpa Adventurer
smilin jack's Avatar
Oddometer: 1,229
Rebuilt Forks
Installed the new PC .55 fork springs a few weeks ago and that didn't fix the loose forks so ordered the rebuilt kit (seals and bushings). Also installed the 8.3 shock spring at that time.
Got the fork bushings etc installed today. The forks are much better with no wiggle now. With the heavier springs front and rear the bike felt in complete control doing 40 mph down a gravel street. Dark and rainy now, so will do a longer test ride tomorrow.
edit: photos posted
Left fork done and back on the bike. Right fork is next. 50K on the bike and OEM seals not leaking!
The zip tie shaped like a T is my measuring device (6.5" from top of fork to oil level). The old fork seals and scrap of PVC pipe were the installation tools for the new fork seals. Worked OK.
Dave
smilin jack screwed with this post 12-23-2012 at 12:34 PM
smilin jack is offline   Reply With Quote
Old 12-22-2012, 05:41 PM   #72118
Hesaid
Hesaid's Avatar
Oddometer: 1,422
Yeah, we've got the shorter factory short kickstand on there now, but that means that we also have a brand new stock factory kickstand sitting on a shelf in the garage. So we can play with that. Maybe we can make it adjustable also. If we can get some adjustable levers as well, she might never need to ride, she can just sit and drink coffee and perform motorcycle maintenance. I hear it's a zen-like experience.
MV
Old 12-22-2012, 06:20 PM   #72119
Ren20
Finding Touge
Oddometer: 111
Thumbs down
tried to push start my bike with weak battery. Fail big time.
with a friend's help too.
we gave up and jump from a car battery. (car was off)
Ren20 is offline   Reply With Quote
Old 12-22-2012, 06:27 PM   #72120
Mambo Dave
Backyard Adventurer
Mambo Dave's Avatar
Oddometer: 5,799
Generally a lot of bikes push-start easier in 2nd (maybe some even 3rd?) gear because first gear asks the engine RPM's to be too high - often the rear wheel will just skid if the rear is light.
I was able to push start the new owner of my previous bike, a Vulcan 800, about two weeks ago since he had no idea what to do after leaving it sit for so long, and refusing to buy a battery charger (but, instead, insisting I ride over to help him figure that out, why the carb is getting gunked up, and to show him - after 6 months of having it and I think refusing to even try - how to slide the seat backward to take it off).
Mambo Dave is offline   Reply With Quote
Times are GMT -7.   It's 03:47 PM.
