Old 12-22-2012, 09:32 PM   #72286
Phreaky Phil
Oddometer: 1,172
Originally Posted by procycle View Post
I have a Moto-Master 320 on mine (RM hub). It's never been too much brake even in slippery stuff or gravel. It takes a lighter pull but I find it easier to modulate a light pull. I wouldn't want to go back the the stock rotor and certainly not a stock DRZ or RM rotor.
Hi Jeff, Will you be doing a Galfer 320 one to suit the DRZ front end.
Cheers Phil
Phreaky Phil is online now   Reply With Quote
Old 12-22-2012, 09:37 PM   #72287
rpet
Awesometown
rpet's Avatar
Oddometer: 316
dang but PB Blaster has possibly the best graphic design / typography known to man!
'76 Xl250 '04 XR250R '09 DR650 '10 TR450
rpet is offline   Reply With Quote
Old 12-22-2012, 11:01 PM   #72288
procycle
procycle's Avatar
Oddometer: 1,597
Cheers Phil
They should already be available. I'll look into it.
Clarke's second law of Egodynamics: "For every expert, there is an equal and opposite expert." - Jasper Fforde
www.procycle.us - Everything for your DR650 and lots of other great stuff!
DR900 Big Bore Stroker buildup
procycle is offline   Reply With Quote
Old 12-23-2012, 07:37 AM   #72289
bradrh
Oddometer: 142
Originally Posted by JagLite View Post
Read this on the TW200 forum and it is very interesting:
Penetrating Oils
Machinist's Workshop MagT recently published some information on various penetrating oils that I found very interesting. Some of you might appreciate this. The magazine reports they tested penetrates for break out torque on rusted nuts.
They are below, as forwarded by an ex-student and professional machinist. They arranged a subjective test of all the popular penetrates with the control being the torque required to remove the nut from a "scientifically rusted" environment.
*Penetrating oils ........... Average torque load to loosen*
No Oil used ................... 516 pounds
WD-40 ..................... ... 238 pounds
PB Blaster .................... 214 pounds
Liquid Wrench ...............127 pounds
Kano Kroil .................... 106 pounds
ATF*-Acetone mix............53 pounds
The ATF-Acetone mix is a "home brew" mix of 50 - 50 automatic transmission fluid and acetone. Note this "home brew" released bolts better than any commercial product in this one particular test.
Our local machinist group mixed up a batch and we all now use it with equally good results.
Note also that "Liquid Wrench" is almost as good as "Kroil" for about 20% of the price.
Steve from Godwin-Singer says that ATF-Acetone mix is best, but you can also use ATF and lacquer thinner in a 50-50 mix. *ATF=Automatic Transmission Fluid
Thats good. I've always been amazed at how well liquid wrench works. I wonder if they would have tried some light oil if that would have been almost as good as wd-40. I think the Acetone would evaporate quickly unless you kept it really tightly sealed.
- DR650
- WR250R times 2
bradrh is online now   Reply With Quote
Old 12-23-2012, 08:35 AM   #72290
DockingPilot
Hooked Up and Hard Over
DockingPilot's Avatar
Oddometer: 7,440
Forgive my ignorance for moto electrics
I do have other ignorances too but ............
In an effort to quickly and easily reduce wattage demand I'm going to install a LED 1157 tail light bulb.
What about the headlight ? Can a LED bulb, if there is in fact one, be simply plugged in and thats that ?
Thanks,
Frank
Frank Reinbold
"Every bike I ever had, was the best bike I ever had, when I had it"
*2010 FOREVER WEST*
NEW ENGLAND AND CANADA OFFROAD F800GS
14 DAY IDAHO ADVENTURE KTM 950
TRANS AM TRAIL WEST
TRANS AM TRAIL VID CLIP
THE DEAN OF WESTERN ADVENTURE ROUTES
DockingPilot is online now   Reply With Quote
Old 12-23-2012, 09:05 AM   #72291
Ackme
talented fool
Ackme's Avatar
Oddometer: 212
electrically speaking, the answer is yes. The issue is the headlight is trying to do more than the brake light. Every light is a unit made up of source, reflector and lens. Unlike the glowing filament of an incandescent lamp the LED only emits light in a limited direction. So you need a unit that collects and focus' that output in a useful way. Just dropping an LED source, if one is even manufactured to the stock socket, is unlikely to be very successful.
The brake light just needs to be bright and visible off axis. So you see a lot of these funky arrays on a 1157 compatible base. You may have already looked into how these work. http://www.webbikeworld.com/lights/l...r-motorcycles/
Bottom line: not as bright as incandescent but OK and saves the watts.
The headlight needs to put a great deal more intensity out in a specific pattern where it is usable to you. The likelier solution is to put a LED unit designed to throw enough light to use as a headlight in place of the stock housing.
http://www.aimhi-enduro.com/LED-High...-Lighting.html
ack
"nothing is foolproof to a sufficiently talented fool"
Ackme is offline   Reply With Quote
Old 12-23-2012, 09:15 AM   #72292
DockingPilot
Oddometer: 7,440
ok, that makes sense Ack, thanks!
Frank Reinbold
*2010 FOREVER WEST*
TRANS AM TRAIL WEST
Old 12-23-2012, 09:20 AM   #72293
chethro
Oddometer: 18
Be carefull with acetone. It is nasty stuff and you don't want it absorbed into your skin. I rarely
wear gloves with handling most fluids, but I do with acetone. Good to know though, I might have to
try it sometime.
chethro is offline   Reply With Quote
Old 12-23-2012, 09:47 AM   #72294
FlowBee
Just me.
Oddometer: 3,385
Originally Posted by chethro View Post
Be carefull with acetone. It is nasty stuff and you don't want it absorbed into your skin....
+1. The problem with acetone and some of the other solvents isn't that it is absorbed through the skin and into your bloodstream, but that it carries other stuff into your bloodstream with it. ATF has some chemicals in it that do not do your body good. I don't know the specific toxicity, but acetone is a great solvent.
I used to work at an R&D center for a transmission manufacturer. One day over lunch I was looking the chemical structures of various nerve agents used in weapons. I happened to have VX's structure on my computer screen and of our senior chemists walked by my cubicle. He looked at my screen and asked, "Are you looking up friction modifiers?" I said, "No, that's VX." He replied, "Interesting. That organophosphate has a similar structure to some of the friction modifiers used in ATF."
We always wore gloves when working with ATF or ATF-soaked plates until they were de-oiled.
This space for rent.
FlowBee is offline   Reply With Quote
Old 12-23-2012, 11:37 AM   #72295
dljocky
Oddometer: 641
Fork Oil question
I'm looking to change my fork oil in the next week or so. I see in the manual, 563ml oil capacity in each leg. A couple of questions, do I just pour that amount in and I'm done? I remember reading somewhere that after the spring is out, fork compressed, measure from the top and it should be 6.5'' to the oil, but I'm not sure I actually read that or not. I also see that in the manual, it says Oil level: 150ml (5.9'') I'm not sure what this is referring to.
I have after market heavier springs in my forks, and I weigh about 240lbs without gear, should I stick to the 10wt oil or go to the heavier 15wt?
Thank in advance for any input. I'm new to this mechanic stuff, but with the forums help, it's not so hard.
dljocky is online now   Reply With Quote
Old 12-23-2012, 12:17 PM   #72296
smilin jack
Grandpa Adventurer
smilin jack's Avatar
Oddometer: 1,175
Fork oil height
Yes, I just did my forks yesterday with heavy springs. The service manual says 6.5" from the top of the fork to the oil with no spring and the fork fully compressed. Works fine for me, but some people raise the oil level to 5.5" from the top when they are running stock springs and 10 w fork oil.
Some use ATF in the interest of saving $$$, as it's reported to also be 10w. Don't know about the actual viscosity of ATF. Check it out on the web.
Dave
smilin jack is offline   Reply With Quote
Old 12-23-2012, 02:17 PM   #72297
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 5,377
Thanks,
Frank
Hi Frank,
I would go with an HID kit. I use the 35 Watt kit ... single bulb. You lose your "high beam" but the HID is about 3 times brighter than stock bulb and uses 20 watts less power. It's about $22. Reality is ... with this HID you only need the ONE light. Plenty bright and I never get flashed. Great on dark roads at night. Deer tested and passed.
This install is dead simple, you simply plug into stock headlight plug and hook up components in kit. (they only go together ONE WAY ... so hard to mess up)
I did an HID install write up over on Thumper Talk.
Starts at post 29 on page 2. The TT site is a bit Fubar ... pardon all the scummy ads. If you have any questions on install, fire away:
http://www.thumpertalk.com/topic/817...20dr%20%20prep
Here is where I bought my HID kit. I love the HID light. 2 years, all good.
http://www.ddmtuning.com/Product-Cat...-Kits-Lighting
Old 12-23-2012, 02:33 PM   #72298
BergDonk
BergDonk's Avatar
Oddometer: 1,643
+ 1 for the HID. I used a H4 dipping type and it gives you both high and low. Saves 20w and gives much better light too. I also fitted a on/off switch so its only on when I want it on. This may be standard in some markets, but not in Oz.
The only issue I had was when fitting an LED tail light bulb, every time I got on the brakes, my headlight came on too. The LED bulbs I got have some sort of regulator in them and the brightness varies on all LEDs in the array, it doesn't kick more in a like a normal dual filament. This meant I was getting some feedback from the taillight circuit into the HID relay causing to to fire when the brakes came on. I went back to conventional tail light bulb and still saved 20w up front with the HID.
shed time IS quality time
Check my DR650 story:
BergDonks DR650 Build
BergDonk is offline   Reply With Quote
Old 12-23-2012, 05:57 PM   #72299
dljocky
Oddometer: 641
Thanks Smiln Jack.
Old 12-23-2012, 06:12 PM   #72300
DockingPilot
Oddometer: 7,440
Originally Posted by Adv Grifter View Post
Hi Frank,
Thanks! Sounds like the ticket
Sent from my SCH-I800 using Tapatalk 2
Frank Reinbold
*2010 FOREVER WEST*
TRANS AM TRAIL WEST
Times are GMT -7.   It's 02:34 AM.
