Old 12-31-2012, 03:30 PM   #72346
Carl Childers
Ghost in the Machine
Carl Childers's Avatar
Oddometer: 864
Question Couple of fork Questions
I tore down my forks today in anticipation of my new parts showing up soon and a couple of questions came to mind. First on a progressively wound spring do the tight coils go up or down or isn't there much difference? A MC shop had the forks apart before I owned the bike so I can't be sure the way they came out would have been the way the factory put them in.
Secondly what are you guys using for seal drivers on these forks? Is there a size PVC pipe that works?
Carl Childers is offline   Reply With Quote
Old 12-31-2012, 03:41 PM   #72347
Lil' Steve
PussyWagon™ Chauffer
Lil' Steve's Avatar
Oddometer: 4,042
Tight coils up is the way they come from the factory.
2" PVC pipe works, you can use the old seals to drive the new ones in, they fit nicely on top of each other.
Steve
13 PCX150, 07 KLX250S w/300 kit, 05 DR650SE, 01 FZ-1
99 VFR800 w/870 kit, 96 GPz1100, 87 CH250
Lil' Steve is offline   Reply With Quote
Old 12-31-2012, 03:57 PM   #72348
ER70S-2
ER70S-2's Avatar
Oddometer: 6,947
I used the wire brush on my bench grinder around the outside of the old seal to take the rubber coating off; so it wouldn't stick in the fork tube on top of the new seal (someone else's idea, werked fer me).
2004 DR650: 62,605 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is online now   Reply With Quote
Old 12-31-2012, 07:10 PM   #72349
JagLite
JagLite's Avatar
Oddometer: 1,382
Thumb Loc Tite or anti=sieze that is the question
Originally Posted by blk-betty View Post
Thanks for the suggestions.
I tend to use blue loctite regularly but never used it on exhaust header bolts. I did use a new gasket so I think maybe the intital run didtn't get things hot enough for a proper re-torque. Will pick up some new bolts and will add a little blue locktite.
I got my new Clymer manual today from ProCycle (thanks!) and I looked through it quickly and found what it says for the header bolts.
Page 66
6.b. Install a new gasket jnto the cylinder head exhaust port.
6.c. Apply anti-seize compound to the threads.
6.d. Tighten the exhaust pipe retaining bolts securely.
6.f. Retighten the bolts after running the engine and allowing it to cool.
I didn't look at my Suzi factory manual but I expect it to say the same thing.
Anti-seize and retighten.
Not sure what torque value "securely" is though
Attitude ~
The difference between
Ordeal and Adventure
James
JagLite is offline   Reply With Quote
Old 12-31-2012, 09:55 PM   #72350
Cobain
night owl
Cobain's Avatar
Oddometer: 132
I mounted, dismounted, and remounted my first rear tire today. Pinched the tube, patched it, then it leaked again, and i tore up the bead of the tire pretty good. That will be the last time i try to do that. I realize why i pay $25 now.
Cobain is offline   Reply With Quote
Old 12-31-2012, 10:20 PM   #72351
kezzajohnson
kezza
kezzajohnson's Avatar
Oddometer: 1,660
Torque
Page 66
According to my manual, Exhaust bolts torque to 26NM
KezzaJohnson Blue 06 DR650se,Yellow 06 DRZ250
Website: http://www.territoryon2wheels.com
"May the Road Never Rise to Defeat you..."
kezzajohnson is offline   Reply With Quote
Old 12-31-2012, 11:50 PM   #72352
gippyphil
gippyphil's Avatar
Oddometer: 50
Cry
Help me, DR650 riders, you're my only hope!
I dropped my 2011 DR, and bent the bars. By all accounts, this is not uncommon, and I have been reading threads on bar recommendations. However, it seems that the part the "bottom" part of the left bar clamp is also bent back about 10-15 degrees (see photo). This appears to be bolted on to the top of the forks (I can feel a bolt hole on the underside). If so, what is this replacement part called? If not, what is the whole "top of the forks" part called, and can it be fixed?
gippyphil is offline   Reply With Quote
Old 01-01-2013, 12:12 AM   #72353
trailrider383
867-5309
trailrider383's Avatar
Oddometer: 3,336
Dropped? It looks like you hit a truck at 80 mph. The bar mount is mounted in rubber through the top triple clamp so you might be able to tweak that back in line.
DO WHAT YOU LIKE - LIKE WHAT YOU DO
Explain to me again why enjoying life when I retire is more important than enjoying life now?
trailrider383 is offline   Reply With Quote
Old 01-01-2013, 12:13 AM   #72354
PHILinFRANCE
PHILinFRANCE's Avatar
Oddometer: 1,187
@ GIPPYPHIL
Get some RENTHAL BARS to replace the bent ones , and by the look of it from your pic the BAR CLAMP does look to bad ................take the bars of and get some better pics please
Phil
I,M HERE FOR A GOOD TIME NOT ALONG TIME
PHILinFRANCE is offline   Reply With Quote
Old 01-01-2013, 12:57 AM   #72355
gippyphil
gippyphil's Avatar
Oddometer: 50
80mph?! I wish - that would at least be a great story to tell. I got into the wrong track on a heavily rutted farming road and lost the front end at about 30-40kph.
gippyphil screwed with this post 01-01-2013 at 01:12 AM
Old 01-01-2013, 05:01 AM   #72356
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,843
It's really not that difficult. Practice makes it easier.
You likely didn't keep the tire down in the deep part of the rim while trying to lever it on so it was probably a lot harder than it should be. Maybe you should get an old wheel and practice a few times? Knowing how to fix it will get you out of a long walk someday.
Old 01-01-2013, 07:10 AM   #72357
TrophyHunter
Oddometer: 2,263
As PhilinFrance mentioned - better pics needed, It is possible all is okay with the clamp, or you just bent the mounting bolt, The clamp mounting bolt goes thru the mount and the mount reminds me of a rubber dome covered by a metal cup. You can get a lot of movement out of it on a crash before you do real damage, I've loosened everything up and reset it a couple of times with no issues on mine after some minor dirt naps,
Bars are a personal choice but PinF makes a good recommendation. I went with ProCycles big bar kit and risers. I like it,
Do a part by part disassembly with pics at each stage. It'll help with the diagnosis and give ya something to look at on reassembly. Most importantly, you're okay enough to type about it - no major personal body damage.
'07 WR450 2013 HD Road King '73 Hodaka Wombat
TrophyHunter is offline   Reply With Quote
Old 01-01-2013, 07:13 AM   #72358
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,817
A mans got to know his limitations. It just takes a little practice, patience, and the right tools.
Old 01-01-2013, 07:33 AM   #72359
Mambo Dave
Backyard Adventurer
Mambo Dave's Avatar
Oddometer: 5,797
Use talc powder (baby powder) all over tubes to allow them to slip & slide around while putting them in there. The last set of tires I did (the DR650's) I used baby powder on the tire beads (instead of soapy water) as well. Hard to believe I didn't screw all of it up, but the Shinkos are still holding air and good to go.
Mambo Dave is offline   Reply With Quote
Old 01-01-2013, 08:24 AM   #72360
jessepitt
Ride More
jessepitt's Avatar
Oddometer: 993
[QUOTE=Mambo Dave;20370237]Use talc powder (baby powder) all over tubes to allow them to slip & slide around while putting them in there.
These two pieces of advice are the biggest factors in an easy and successful tire change. Keeping the beads of the tire all the way into the rim (deepest part of the \-/ ) opposite where you are working your tire spoons is key. I have recently seen a zip tye used to keep the tire clamped together so that this is easier to accomplish, (I'm sure ERO7-S will be along with pictures shortly, lol). I started off using dish soap and water but have recently also switched to talc, both work great, talc is easier to carry and I've heard it helps keep the tube from chaffing after install too. You should use some kind of lube or something is going to get hurt. Like Emm said, this is a MUST HAVE skill if you ever plan to leave a paved road for any distance and will make you feel more comfortable doing so. I replaced my first tube in the field last summer after eight years of riding and it was a snap. It didn't take me much longer than it usually does in my shop and it was a good feeling to be able to fix it and keep riding. Don't get discouraged, its all in the technique and you can learn that with a little practice.
jessepitt screwed with this post 01-01-2013 at 08:39 AM
jessepitt is offline   Reply With Quote
Times are GMT -7.   It's 09:38 AM.
