Old 12-28-2012, 10:56 AM   #72361
Mambo Dave
Mambo Dave's Avatar
Oddometer: 2,481
Do Acerbis tanks have this much of a problem emptying fuel?
Mambo Dave is offline   Reply With Quote
Old 12-28-2012, 11:02 AM   #72362
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 5,377
Originally Posted by canoli View Post
This is what it looks like now.
Does this look right to you? How bad is that bend in the hose?
Going out for a ride tomorrow and hopefully I can get another 50-60 miles before it goes dry. If not, I might be putting the Safari in the flea market and picking up a Acerbis. I really need the range and don't want to carry external containers if I don't have to.
Canoli
Looks like you have a "L" right angle fitting there, and then your fuel hose has to go UP HILL to the Carb. As long as you have a bit of fuel pressure (head) in your tank, it's likely you can use most ... but maybe not all of remaining fuel in your Safari.
QUESTION: Does the Safari not have a reserve? If not, perhaps you could fit a different Petcock ... one with a reserve intake that is LOWER than the current one in the Safari. This should give extra range.
Question 2 : Does the Safari have TWO petcocks? (right and left side)
I went through similar problems with my IMS tank. I also had to remove an inline aftermarket filter and had to rotate metal Carb intake pipe. All this helped, along with cleaning my dirty Petcock filter. But on your NEW tank should not be an issue ... yet.
I've retained the stock Carb inlet filter in the metal tube ... but I carry TWO
spares when on the road. One load of bad gas will CLOG this tiny filter ... so keep an eye on it. Usually it can be easily cleaned. Sometimes not, hence carrying a spare.
Now ... with my IMS tank ... I can go to about 220 miles before reserve. And what was once just 10 to 15 miles on reserve is now up to 32 miles.
Cleaning the petcock made the BIGGEST improvement. So now up to just over 250 miles until DRY. (although still about a 1.5 liters left unused) Not perfect but better. 220 miles is fine for me and what I do. PLAN AHEAD!
Good luck!
Old 12-28-2012, 11:27 AM   #72363
neo1piv014
ADV in training
Oddometer: 610
Looking at my Acerbis4.9 tank, it appears that the petcock actually sits below the level of the intake on my carb. Anyone else notice this? I can't actually hook up the fuel line without there being a bit of an uphill climb to it or a bend.
_________________________
Ride videos
'01 DR650
"The impossible often has a kind of integrity which the merely improbable lacks."
neo1piv014 is offline   Reply With Quote
Old 12-28-2012, 11:38 AM   #72364
George 99
Oddometer: 384
Don't know if this could help, but... I have pressurized the gas tank on my ST1100 with lung power and piece of hose to get fuel to the carbs when the 'lectric pump failed. Not recommended for a long trip, and do remember to remove the hose from yur mouth before ya inhale.
George
Sometimes in Kingman, Arizona
George 99 is offline   Reply With Quote
Old 12-28-2012, 12:43 PM   #72365
Ren20
Finding Touge
Oddometer: 97
Is this an IMS or Acerbis tank? Seller claimed to be acerbis. But look IMS to me. I think acerbis is more angular, correct?
Ren20 is offline   Reply With Quote
Old 12-28-2012, 12:49 PM   #72366
adventurebound9517
Oddometer: 74
I just purchased the acerbis tank and it looks the same to me. You will know for sure when you fill it up.
adventurebound9517 is offline   Reply With Quote
Old 12-28-2012, 01:25 PM   #72367
Phreaky Phil
Oddometer: 1,169
So the ongoing struggle to get my Safari tank dialed in continues. When I last checked in you guys told me to fill it up and see how far I can get before it craps out. Seemed like the logical thing to do so I filled it with 33 liters (still had some in the tank when I rolled up to the gas station) and rode it for 275 miles. Then 5 miles from town in 108 degree heat, it stopped. It looked like I still had a lot of gas left so the only thing I could do was shake the bike a bit and luckily got some gas into the engine. Once at home I let everything cool down and I sprayed the carb inlet elbow with ALOT of WD40 and proceeded to empty the remaining gas into another container. When the Safari finally ran dry I found that it still had an additional 4 1/4 liters of gas remaining…and I was pissed. So I stripped the tank off grabbed a set of vice grips and cranked the elbow over to the 90 degree position. Was pretty happy that nothing snapped off and after I put the tank back on I re-routed the lines and removed the cheap inline filter I installed.
Stay tuned and thanks again for your help.
Canoli
This seems to be a common problem. When I fitted mine I had it the same as yours and when I hit reserve the bike would die even though I had changed to reserve. I had to blow down the tank vent to get fuel into the carb before it would go again.
What you need is a longer hose between the T piece and the carb and it needs to loop down and back up to the tank. This cures it. Straight in like you have it seems to cause an airlock. With the hose going down hill there is always some fuel in it.
Phreaky Phil is offline   Reply With Quote
Old 12-28-2012, 01:41 PM   #72368
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 4,811
My Acerbis tank is a 5.3 gallon. The petcock is above the intake on my carb, but I have a TM 40.
Guess what doofus, nobody reads your lame blog.
Old 12-28-2012, 01:42 PM   #72369
Cobain
night owl
Cobain's Avatar
Oddometer: 130
Thats the one on craigslist right, in spokane?
Cobain is offline   Reply With Quote
Old 12-28-2012, 01:47 PM   #72370
Ren20
Finding Touge
Oddometer: 97
Yea, Spoken with the seller. He confirmed it's an acerbis. Only wish He posted pictures of different angles.
Old 12-28-2012, 01:52 PM   #72371
acap650
acap650
acap650's Avatar
Oddometer: 354
Originally Posted by ren20 View Post
is this an ims or acerbis tank? Seller claimed to be acerbis. But look ims to me. I think acerbis is more angular, correct?
ims
acap650 is offline   Reply With Quote
Old 12-28-2012, 01:57 PM   #72372
canoli
human
canoli's Avatar
Oddometer: 1,144
Thanks I'll put a "loop" back in it.
Canoli
canoli is offline   Reply With Quote
Old 12-28-2012, 02:00 PM   #72373
doug s.
Oddometer: 1,166
that looks like an ims to me; not an acerbis.
acerbis:
ims:
if it's an acerbis, it's some older type...
doug s.
doug s. is offline   Reply With Quote
Old 12-28-2012, 02:14 PM   #72374
Slideways#96
scooter trash
Slideways#96's Avatar
Oddometer: 280
Originally Posted by trailrider383 View Post
This post makes me appreciate my simple DR all the more. http://www.advrider.com/forums/showp...3&postcount=33
Every time a new thumper comes out I get excited and think it might be something to replace the DR. Then I read posts like this. All that just to change the oil.
And I thought changing the oil on my old 520exc was a PITA. Love my dr though suspension no where near that of the old 520...
Slideways#96 is offline   Reply With Quote
Old 12-28-2012, 02:15 PM   #72375
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 6,765
Def an IMS.
NordieBoy is offline   Reply With Quote
Times are GMT -7.   It's 11:16 PM.
