Old 01-01-2013, 07:16 PM   #72376
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,842
Originally Posted by Carl Childers View Post
Probably my biggest mistake was not getting the tire bead down into the rim recess ..
A lot of people think just keeping the tire in the rim recess right across from where your levers are is enough. They are the ones struggling with the job. You have to keep as much of the bead in the recess as possible.
Old 01-01-2013, 07:46 PM   #72377
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 6,128
Exactly ... and from what I can tell ... that is when those Big 'ol Zip ties really come in handy. I'm going with the HD Zip ties next time!
Old 01-01-2013, 08:08 PM   #72378
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 7,144
Originally Posted by ndthl View Post
Have you done it or know anyone that has?
I just don't have any mechanical knowledge.
Nope, but only the carbs and valves are different...
DR650 Wiki
NordieBoy is offline   Reply With Quote
Old 01-01-2013, 08:17 PM   #72379
Cobain
night owl
Cobain's Avatar
Oddometer: 132
Thanks for the input. I need to get some spoons, i was using (2) 7in. bars that came with the tusk fender pack.
Cobain is offline   Reply With Quote
Old 01-01-2013, 08:41 PM   #72380
ER70S-2
ER70S-2's Avatar
Oddometer: 6,938
A visual for those wondering WTF:
2004 DR650: 62,605 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is online now   Reply With Quote
Old 01-01-2013, 08:45 PM   #72381
Cobain
night owl
Cobain's Avatar
Oddometer: 132
wow thats the exact tire i was mounting yesterday. haha
Old 01-01-2013, 09:24 PM   #72382
JTB488
Oddometer: 152
Gippyphil, Man you have a tiny garage!
JTB488 is offline   Reply With Quote
Old 01-01-2013, 09:39 PM   #72383
shu
Oddometer: 1,053
Originally Posted by GSF1200S View Post
**EDIT** Anyone have any hints for getting sand out from around the spark plugs before I pull the plugs? I blasted out the holes as best I could with carb cleaner, but i dont have compressed air since I have no power (bikes at a storage place). They look clean now, but im mostly worried about sand/dirt that might be hiding under the thermistor for the vapor tach (on outside spark plug). Any tips would be cool :)
Blowing it out with a drinking straw works fairly well.
I take a inflation needle for a basketball, cut off the very end to open it up and use it with my little tire pump that I run off the bike's battery. This works surprisingly well as an air hose.
...........shu
shu is offline   Reply With Quote
Old 01-02-2013, 02:08 AM   #72384
1Waipukbiker
Oddometer: 16
Just to change the subject, I want to upgrade the front fork springs and not sure between stiffer stock springs or progressive rate springs, any comments from experiance?
1Waipukbiker is offline   Reply With Quote
Old 01-02-2013, 05:58 AM   #72385
Mongle
Knuckle dragger
Mongle's Avatar
Oddometer: 3,145
Buy a can of compressed air they sell for cleaning computer keyboards and such. Dig around in there with something, blow with the air. Break the plugs loose a turn or two; blow with more air. If you think you are done do it again just to be sure!
DO NOT do what Emm said and crank the engine with the spark plug hanging on by only a few threads! Not only is the piston going to push air out..it sucks air in. Also, a DR cranks with about 100-130 PSI of cranking compression and only having 2-3 threads on a plug and cranking can lead to damaged threads.
Mongle is offline   Reply With Quote
Old 01-02-2013, 06:08 AM   #72386
neo1piv014
ADV in training
Oddometer: 621
Alright, so I don't exactly know what everyone means when they're referring to this. Assuming the side of the tire facing up is "Side A," and the side facing the floor is "Side B," and I'm trying to spoon the tire on at the 12 o'clock position, am I using my knees to push side A into the dish, or am I reaching down with my hand to compress sides A and B into the dish?
_________________________
Ride videos
'01 DR650
"The impossible often has a kind of integrity which the merely improbable lacks."
neo1piv014 is offline   Reply With Quote
Old 01-02-2013, 06:14 AM   #72387
blk-betty
bam-a-lam
blk-betty's Avatar
Oddometer: 2,473
Originally Posted by JagLite View Post
I believe you are thinking the exhaust CLAMP BOLT is the same as the header bolts.
The clamp bolt is torqued to 26nm (19 ft/lb), yes.
Thanks for checking
EDIT;
I had to check what the official Suzi manual says and after a long search I found it in the "periodic maintenance" section.
Page 2-14
You are correct Sir!
Suzi says that ALL the exhaust bolts are the same at 26nm (19 ft/lb)
So Clymer doesn't put the bolts in the same group in their new manual
Thanks for the tq spec...I'm pretty certain I had them tightened to more than 19 ft lbs..that really isn't a lot. Got to see if my local True Value has a replecment bolt otherwise will check with the dealer to see if they have any in stock.
Will reinstall with the anit-sieze.
Any day on a dirt road is a great day
blk-betty is online now   Reply With Quote
Old 01-02-2013, 06:25 AM   #72388
Rusty Rocket
Life behind "Bars"
Rusty Rocket's Avatar
Oddometer: 9,529
I used to use tire irons like these and pinched alot of tubes.
Then I bought a set of these and it's been easy since.
Keeping the tire down in the rim is paramount. It also helps to put some air in the tube. just enough to make it round and that helps it stay outta the way of the irons. be sure to use soapy water as a lubricant.
on one side the sign it said "Private Road", but on the other side it didn't say nothin'
2009 DR650
..1972 Penton Six-Days ..1971 Suzuki TS185.. 2005 KTM 400exc
Member of: AMA, NETRA, Blue Ribbon Coalition, CCCofVT, Berkshire TR, CT Ramblers
Rusty Rocket is offline   Reply With Quote
Old 01-02-2013, 07:08 AM   #72389
Mambo Dave
Backyard Adventurer
Mambo Dave's Avatar
Oddometer: 5,791
...........shu
Likewise, get a shop-vac, or any vacuum with a hose, a plastic bag or baggie (or a piece of pastic) and that same straw. Stick the straw through the plastic, then hold it and the plastic up to block the vacuum hose so it makes the vacuum suck through the straw.
I have two long tire irons that have curves in them, and while they won't fit in a fender bag, those and perhaps one spoon would be ideal I'd think.
Mambo Dave is offline   Reply With Quote
Old 01-02-2013, 07:48 AM   #72390
procycle
procycle's Avatar
Oddometer: 2,407
The point is not to only push the tire into the dish at 6 o'clock but to push it in from say 3 o'clock to 9 o'clock or as much of the circumference as possible.
Clarke's second law of Egodynamics: "For every expert, there is an equal and opposite expert." - Jasper Fforde
www.procycle.us - Everything for your DR650 and lots of other great stuff!
DR900 Big Bore Stroker buildup
TurboDiesel Corvette - go to the end to start at the beginning
procycle is offline   Reply With Quote
Times are GMT -7.   It's 09:30 PM.
