Old 01-03-2013, 06:30 PM   #72436
procycle
procycle's Avatar
Oddometer: 2,388
Originally Posted by doug s. View Post
...reducing the woltage...
I think you mean vattage...
Clarke's second law of Egodynamics: "For every expert, there is an equal and opposite expert." - Jasper Fforde
www.procycle.us - Everything for your DR650 and lots of other great stuff!
DR900 Big Bore Stroker buildup
TurboDiesel Corvette - go to the end to start at the beginning
procycle is offline   Reply With Quote
Old 01-03-2013, 06:52 PM   #72437
smilin jack
Grandpa Adventurer
smilin jack's Avatar
Oddometer: 1,228
Tire mounting
Originally Posted by neo1piv014 View Post
Alright, so I don't exactly know what everyone means when they're referring to this. Assuming the side of the tire facing up is "Side A," and the side facing the floor is "Side B," and I'm trying to spoon the tire on at the 12 o'clock position, am I using my knees to push side A into the dish, or am I reaching down with my hand to compress sides A and B into the dish?
I put my Motion Pro blue tire clip on the bottom side of the rim (holds the B side bead in the groove), put two small blocks of 2X4 lumber outboard of the blue clip to also help hold side B bead in the groove, then put my knees on the side A of the tire so that bead also is in the groove. The tire almost falls on the rim... with spoons of course. Quick and easy after reading and learning from advrider.
The Motion Pro bead breaker (big plastic chisel) works so well that it's used at home in the shop as well as the trail.
Dave
smilin jack is offline   Reply With Quote
Old 01-03-2013, 06:52 PM   #72438
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 7,144
You've just had coffee haven't you
DR650 Wiki
NordieBoy is offline   Reply With Quote
Old 01-03-2013, 07:20 PM   #72439
eakins
Butler Maps
eakins's Avatar
Oddometer: 19,110
vattage & woltages...you guy are too technical for me.
thnx on the 35w vr 55w input.
Alaska
Butler Maps website:
http://www.butlermaps.com
Old 01-03-2013, 07:27 PM   #72440
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,769
Originally Posted by eakins View Post
vattage & woltages...you guy are too technical for me. .
You're velcome.
Old 01-03-2013, 07:34 PM   #72441
gippyphil
gippyphil's Avatar
Oddometer: 50
Took the DR for a quick run up my (gravel) road with the new bars - feels great, and the extra height makes it way more comfortable to ride standing.
It's about 40C here today (105F) so time to hunker down in the house again!
gippyphil is offline   Reply With Quote
Old 01-03-2013, 07:36 PM   #72442
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 6,128
i've read their FAQ so why the 35W DDM kit vrs the 55w?
just to save 20W? obviously the 35w kit puts out a ton of light but will the 55w put out even more (if saving those 20w are not an issue) and not damage the DR housing? anyone here run the 55w kit?
Won't damage housing ... HID run cool! ... but might damage the eyeballs of on coming traffic!
so you used only the low beam kit on the DR and that is more than enough light have the low option only?
http://www.thumpertalk.com/topic/817...0#entry9193868
I installed the DDM Tuning HID on my Tiger over two years ago. I went 35 watt based on what others had recommended. Some claimed with the 55 watt (SUPER BRIGHT) that too many people flashed him on the highway, even with the beam adjusted down. The Tiger guys used the 55 Watt for the Hi beam bulb. (Tiger has TWO headlights)
When I got the 35 Watt for the Tiger I was pleased. But I DO plan to install
the 55 Watt for the High Beam light.
I think you could go with a single 55 watt on your DR but just make sure you aim the beam angle with you (and gear) on the bike. Also, some say it's SO BRIGHT, cops will U turn and come after you. It you get the DUAL filament HID then you can switch back and forth ... but you'll have more wires to run back and forth from battery.
Your choice. The plain old 35 Watt is roughly (to my eye) 3 times brighter than the standard 55 Watt H-4 bulb on the DR650. So big step up there.
55 Watt would be AWESOME on a dark, lonely road ... or riding the Desert at night.
And YES ... I was also thinking about saving juice on the DR when I picked the 35 Watt version. (my Tiger puts out about 450 Watts ... so no issues there) I have run my DR Battery dead on several occasions from running my Gerbing and grips on HI for too long at night. The 20 Watt saving does make a little difference ... no big deal.
Good luck!
Adv Grifter screwed with this post 01-03-2013 at 07:43 PM
Old 01-03-2013, 08:11 PM   #72443
BergDonk
BergDonk's Avatar
Oddometer: 3,721
Originally Posted by Adv Grifter View Post
................ It you get the DUAL filament HID then you can switch back and forth ... but you'll have more wires to run back and forth from battery.
They're not a dual filament bulb like we are used to. They are not a filament bulb at all in fact, but a bulb of gas that gets excited and glows brightly when it does. They dip by having a solenoid move the bulb along a rail so the focal point moves inside the lense of the light. If you look at an H4 bulb closely you'll see the 2 filaments in different places, so the dipping H4 HID attempts to mimick that.
Works fine and there isn't much extra wiring, and what there is is all at the headlight. It plugs into the standard H4 socket instead of the original bulb, and has a feed from the battery.
I got a car setup that is pretty much the same price as single bike ones and got some as yet unsued spares.
I just found this site that may assist:
http://www.yourcustomcar.com/hid-lights.html
shed time IS quality time
BergDonk's DR650 BergDonk's XT1200Z
BergDonk is offline   Reply With Quote
Old 01-03-2013, 09:27 PM   #72444
Rawley83
Rawley83's Avatar
Oddometer: 2
Thumb Fuel Injected DR650
Fellow DR riders,
This is my first post in this forum. I am part of a DR650 Facebook group and some of the guys in that group recommended I join this forum and post my question here; so here it goes!
I need your input. How many of you would be interested in a fuel injection kit for a DR650 if it were readily available? I know Ecotron has a "kit" but I'm not sure how developed it is. I hear that they kind of gave up on it.
I am a mechanical engineer and design/work on unmanned aircraft for a living and am experienced in integrating fuel injection systems on carbureted engines. The ECU system I have in mind would have altitude compensation and would use O2 feedback for fined tuned mixture quality.
Is this something of interest to proceed on? How much would someone be willing to pay for a complete product like this?
Thanks,
Rawley83
Rawley83 is offline   Reply With Quote
Old 01-03-2013, 10:03 PM   #72445
johnkol
Oddometer: 136
No, they didn't give up on it, the kit is ready and is shipping; the history of it is well documented.
If you think you can provide a better EFI kit (either in quality, ease of installation, or price), then you have a good business opportunity.
johnkol is offline   Reply With Quote
Old 01-03-2013, 10:09 PM   #72446
Rawley83
Rawley83's Avatar
Oddometer: 2
Thanks for the feedback. I was misinformed then.
Old 01-03-2013, 10:12 PM   #72447
eakins
Butler Maps
eakins's Avatar
Oddometer: 19,110
Fellow DR riders,
Thanks,
Rawley83
sure we're all ears.
here's the back story for those who don't know.
http://www.advrider.com/forums/showthread.php?t=725795 >>>
http://drriders.com/topic2824.html
http://mxrob.com/mxrob_005.htm
http://www.thumpertalk.com/topic/761...ction-project/
Alaska
Old 01-03-2013, 10:16 PM   #72448
eakins
Butler Maps
eakins's Avatar
Oddometer: 19,110
for some reason, however, the kit was not 100% polished for PnP resale and ProCycle did not pick it up. for the same price as a pumper carb, we're not seeing people jump on that kit so something is up. it seems like it's 99% done and that 1% is the hardest and holding people back. maybe i'm wrong.
if it was my baby, i'd be actively on the boards pushing with 2nd level early adopter discounts (like how Ricor did that with Intiminators) and working the forums for interest and support. seems Ecotrons said here it is figure it out, i'll help some but fine tune my product for me. I think that is giving people pause. guys like Jeff @ Procycle release new products and are there everyday helping out with support online...that's the last 1%. there is a reason i'm ADV most every day...i'd love to say it's for all you fine gents, but it's to move Butler Maps forward.
maybe rawley83 can work with Matt on that last 1% and even be the rep. i'd like to see it at 100% as I started that rabbit hole.
Alaska
eakins screwed with this post 01-03-2013 at 10:25 PM
Old 01-03-2013, 10:35 PM   #72449
eakins
Butler Maps
eakins's Avatar
Oddometer: 19,110
mmm, i'm still on the decision fence as to get the lo 4500K kit or the lo/hi 4500k kit. sounds like 35w is the way to go because of light output and extra juice gained for other items.
currently i'm running those IPF fatboy bulbs and a relay it's better than stock but not ideal at night. adding PC brackets and LED aux lights is an option but more $ than this kit and more crap hanging off the bike waiting to be whacked.
what i find during night riding is i like the low beam light spread most all the time anyway except for maybe faster cornering and seeing around corners with hi beams. if the lo kit has 5x the light as H4 then i'm leaning towards that as ideal unless some is using a lo/hi and gives a compelling reason why having the hi option is essential. i'm not a big night rider to start with and like to ride conservatively anyway when the sun goes down.
Alaska
Old 01-03-2013, 11:52 PM   #72450
BergDonk
BergDonk's Avatar
Oddometer: 3,721
I don't plan to ride at night, but it happens from time to time.
I'd estimate the 35 w HID to double the light output of the previous +80% H4 fitted, with about double the depth and noticably more spread. Remember its somewhere between a square and cube function. Depends a bit on the reflector design. Twice the light output doesn't equal twice the range. The HID works OK in the DR and the low beam cutoff works good so no issues with blinding oncoming traffic.
The LEDs I have don't offer a lot of depth, the HID does that, but they noticably improve the spread. Tucked in and up, mounted to the barkbusters, they are out of the way and not too vulnerable.
Get a dipping HID, you'll wonder why you didn't do it sooner.
Times are GMT -7.   It's 03:10 AM.
