Old 01-04-2013, 04:14 PM   #72481
eakins
Butler Maps
eakins's Avatar
Oddometer: 18,648
Just wondering, has any done a HIR bulb (w/ the notch mod to fit H4) and used it an the DR housing? or something like this http://www.lightbulbs4cars.com/product/HIRH4 with an H4 base but with low only? you of course are the 40w the opposite direction of the 35w HID kit.
Alaska
Butler Maps website:
http://www.butlermaps.com
Old 01-04-2013, 04:22 PM   #72482
eakins
Butler Maps
eakins's Avatar
Oddometer: 18,648
Originally Posted by ER70S-2 View Post
Eakins, this might answer your question:
thanks.
i did read that and should have taken that as him saying it's a single bulb housing so when it fails it the whole thing fails.
it's easy enough to bring or find an H4 bulb when on the road, so if something fails with HID, you can always pop back in a H4 and plug back in the wiring harness plug and you're back to stock.
Alaska
Old 01-04-2013, 09:39 PM   #72483
BergDonk
BergDonk's Avatar
Oddometer: 3,489
Originally Posted by eakins View Post
thanks.
That's the bottom line. How you wire it up is your choice. I still ahve the extra relays in mine from the stock bulb and no longer needed, but if I revert, its just a bulb swap.
http://www.advrider.com/forums/showp...&postcount=379
shed time IS quality time
BergDonk's DR650 BergDonk's XT1200Z
BergDonk is offline   Reply With Quote
Old 01-04-2013, 09:59 PM   #72484
shu
Oddometer: 999
cold running
I frequently ride in cold temps (as long as the roads are dry). Recently I set a new record for myself.
When it's in the 30's and 40's *F, I find it takes the DR (w/ stock BST carb) about 3-4 minutes warming up in the driveway and another 6-8 minutes of easy running on the road to fully warm up and run smoothly.
In the 20's it takes a bit longer and really runs pretty rough at lower rpms for 10-15 minutes. In the low 20's I usually velcro a piece of cardboard in front of the oil cooler screen guard to block some of the direct air flow.
A few days ago, I rode out at midday when the temps were in the 30's and stayed out longer than I expected. When I started home from Denver in the dark it was about 20* and by the time I got to my house in the mountains it was just 3*. Brrrrrrrrr.
I found the DR with the cardboard wind blocker in place would run ok at mid rpms but it never really warmed up at all and when I pulled away from stop signs, etc. I really had to give it a lot of gas and slip the clutch to keep it running.
Questions:
1.How bad was that ride for my motor? (Synthetic 10 W 40)
2. Is this cold running problem typical for a carbureted motor?
3. Should I velcro the cardboard directly touching the oil radiator itself instead of leaving the air space between the guard and the radiator open?
4. As the day warms up, at what temp do you think I should be wary of using anything to block the cooler?
5. How would I know if the bike was overheating due to blocking off the cooler?
All opinions welcome.
Thanks......................shu
shu is offline   Reply With Quote
Old 01-04-2013, 10:55 PM   #72485
VooDooDaddy
VooDooDaddy's Avatar
Oddometer: 163
Originally Posted by GSF1200S View Post
"...if I were going to South America, Id buy new and get the 5 year unlimited mileage warranty..." "Say something freak happens (is 3rd gear really a freak?)- that could be the difference between the end of your trip or simply a (possibly long) delay..."
..."I sometimes wish I had bought new just for that warranty- thats a big slice of piece of mind..."
..."you could even get a spare motor from a wrecked DR and keep it on the side. Thats piece of mind and costs about the same as a warranty.
Not to burst your pretend bubble, but just exactly how/where would a person find "warranty" service in the Bolivian Altoplano? Or just about anywhere in Central America or South America.
Not to mention the thousands of dollars saved in not buying new will fund months of actual riding for me in South America. To each his own, and I realize not everyone has mechanical abilities, experience, tools, or a place to work on their bikes, but I would never buy a new Japanese bike simply for a warranty.
VooDooDaddy is offline   Reply With Quote
Old 01-04-2013, 11:01 PM   #72486
acesandeights
Asperger
acesandeights's Avatar
Oddometer: 3,925
I bought new, but it wasn't for the warranty. It was because they are scarce (reasonably priced) around here. Typically they have farkles I don't want, so I'd be spending farkle money anyway. Also, mileage is time owned, for me. The mileage on most used bikes is a couple or more years of ownership, sometimes it's more than several years of ownership.
http://breakingbooks.wordpress.com
Amazballs Indi-music at https://soundcloud.com/sprunty2000/
I may not be Rainman, but I'm not stupid eighter. Like Bartek on a taco.
I'll die with this hammer in my hand.
acesandeights is offline   Reply With Quote
Old 01-04-2013, 11:31 PM   #72487
eakins
Butler Maps
eakins's Avatar
Oddometer: 18,648
holy hell, my DR is parked in the garage waiting for 50 degree days.
you're a trooper. it was 40 today in FC.
i doubt that oil cooler being blocked off would make any difference until you hit alot warmer temps. i think i've read guys riding DR with the oil eliminated.
i think the cold would make your bike run real rich anyway and that is what you're experiencing. i'd leave that card board on till it goes above 50 and ride away.
Questions:
Alaska
Old 01-04-2013, 11:44 PM   #72488
eakins
Butler Maps
eakins's Avatar
Oddometer: 18,648
DR is not even sold in many CA countries (not sure about SA) and in ones that it is, such as Costa Rica, very rare and probably no parts being stocked anyway. In fact most any bike over 125cc is gonna be an anomaly in much of Latin America.
I wonder if US Suzuki warranties are even honored outside of the US. Having lived in Mexico for a year, I meet a few DR through riders and i'd always ask why a DR650? The answer was always, it's the most reliable 650 on the market, has no radiator and is easy to maintain. Overlanding is about proper vehicle prep, bring spare parts and having some mechanical aptitude not warranties.
I'd say a low mileage, 2004+ would be an ideal used candidate if one can be found.
Alaska
Old 01-04-2013, 11:59 PM   #72489
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 6,128
Questions:
That's some serious Butt Tough Cold riding! I wimp out in the 40's!
By the 20's I beg for mercy! My biggest worry is black ice. I've only hit it once ... made it through ... barely.
Would going richer on jetting help here? Maybe go rich on needle clip and turn out fuel-air screw? Or leave enricher (choke) on?
Don't know much regards covering the oil cooler but I doubt any damage would be done if you left it covered ... even into the 60's. The engine is still AIR COOLED and the fins do a lot of cooling regardless of the cooler.
I like you're idea of a good warm up when it's super cold. Let those parts warm up before putting a load on them. Syn oil is the way. Perfect for the cold. 10-40 should be OK.
Coldest I've ever ridden in (on motorcycles) is 10F. Nearly died! I had to get from N. Utah down through North rim of Grand Canyon, then South from there were it finally warmed up a bit. I was FROZEN solid.
Of course I rode snow mobiles in the Antarctic at minus 40F! Hardest part?
getting the fricken thing started! That was our record cold for the Winter in that part of the Banana belt of the Antarctic.
Old 01-05-2013, 12:03 AM   #72490
ER70S-2
ER70S-2's Avatar
Oddometer: 6,296
205'b Grifter
Alrighty then, here's mine.......................
Disclaimer: my career was sitting at a desk.
i frequently ride in cold temps (as long as the roads are dry). Recently i set a new record for myself.
Records are awesome, I chased and hit my all time summer high: 15,000 miles (start 28,400 - end 43,400).
when it's in the 30's and 40's *f, i find it takes the dr (w/ stock bst carb) about 3-4 minutes warming up in the driveway and another 6-8 minutes of easy running on the road to fully warm up and run smoothly.
In the 20's it takes a bit longer and really runs pretty rough at lower rpms for 10-15 minutes. In the low 20's i usually velcro a piece of cardboard in front of the oil cooler screen guard to block some of the direct air flow.
A few days ago, i rode out at midday when the temps were in the 30's and stayed out longer than i expected. When i started home from denver in the dark it was about 20* and by the time i got to my house in the mountains it was just 3*. Brrrrrrrrr.
I found the dr with the cardboard wind blocker in place would run ok at mid rpms but it never really warmed up at all and when i pulled away from stop signs, etc. I really had to give it a lot of gas and slip the clutch to keep it running.
When you're experiencing these colder temps (<50*), I'm home watching TV, where I belong. However; if I were knutz like you, I'd get a good oil temp gauge and block airflow until I got the temp up, at least 200*. This would include fastening something to the frame down-tube (like a wide reverse fender blocking the cylinder). Yep, that's what I'd do.
Another note, once inna while I forget to turn off my choke. I'll end up 20 miles from the house and wonder why the bike runs like crap at a light or stop sign. Hmmmmmm About that time the light will go on; I'll look down and sure enough I left the choke on. My point is, the bike will run fine with the choke on, it's only noticeable at idle; when the bike is giving you cold temperature fits, put the choke on.
Questions:
1.how bad was that ride for my motor? (synthetic 10 w 40)
Your motor didn't even notice.
Short hot oil opinion: I run full synthetic too. After a few thousand miles (20,000?), I quit thinking about my oil temps. Currently, I feel that my ankles will melt before the DR is compromised by heat. And that's the reason that I run full synthetic. If the Zuki engineers are ok with dino oil (in the manual), I'm ok with anything + full synthetic.
Oops, back to the question:
Cold oil comment: The recent spat of CSS seals unseating themselves has me wondering. The reports say that it's most likely that they'll pop loose right at start-up, so it may be an oil pressure issue; I run 15w-50 so this could affect me directly. Procycle has recently marketed a CSS seal retainer, cheap insurance. www.Procycle.US
Yes. Once FI is perfected for each motorcycle application, like today's cars, this issue won't exist. IMO But at this time I prefer carbs. If my bike quits somewhere, there would be a 5% chance that I could fix/figure out FI.
Random thought: moisture in the oil (condensation is present most of the time, physics); water turns to steam at 212*, at which time the water is cooked out of the oil. Temps below 212* implies that there is still moisture in the oil/crankase. So just because the moisture turns to steam, how does it get out of the crankcase? The answer: when your bike is running, remove the oil fill cap; you'll feel each time the piston travels down in the cylinder; it displaces a lot of air each time. With the oil cap in place, that same pulse is traveling thru the crankcase vent, displacing most of the crankcase volume within a few minutes. When my oil temps are under 200*, I'm starting to get uncomfortable. No, I don't quit and go home, but I don't care to do that on a regular basis. My oil temp is in the oil pressure port, bottom center of the motor.
3. Should i velcro the cardboard directly touching the oil radiator itself instead of leaving the air space between the guard and the radiator open?
The only way to know this accurately, is to have an oil temp gauge. Looking at mine, there is about 5/8" behind the radiator shield. I'd tie the cardboard to the shield, behind it.
This is what I have because it's what was available 'back then' (but pricey)..
4. As the day warms up, at what temp do you think i should be wary of using anything to block the cooler?
For me, the oil temp would decide this. I've seen 275* oil temp on a slow, hot summer ride (up Mt. Herman Rd). 275* is a long way under a full synthetic's 'comfort zone'. Watch NASCAR, they're using a full syn, so I'm ok with 'whatever'.
5. How would i know if the bike was overheating due to blocking off the cooler?
Yer boots will melt................... synthetics rock.
I lost a little continuity in my reply, it's midnight.
2004 DR650: 62,605 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is online now   Reply With Quote
Old 01-05-2013, 12:12 AM   #72491
Adv Grifter
Oddometer: 6,128
Well there are Suzuki dealers throughout Latin America ... but they are not that common and mostly only ever in capital cities ... and I'm not even sure if a USA American Suzuki warranty would even be valid out of USA or Canada. Anyone know for sure?
If the warranty IS valid ... and you could find a Suzuki dealer that sells DR650's, then you might be OK.
But generally speaking that ain't happening. Although there are Police forces now using the DR in Ecuador and I think Colombia. Suzuki do well with their Outboard motors down there, so one may find Suzuki Marine dealer. No idea if any could help out.
If Suzuki DID cover but the dealer did not carry DR650's ... well you may be in for quite a wait on parts ... like weeks. But things are looking up as Suzuki, and the DR650, make more inroads into S. America.
Suzuki Freewind in Ecuador (based on DR650)
Old 01-05-2013, 12:36 AM   #72492
canoli
human
canoli's Avatar
Oddometer: 1,692
FWIW I was told flat out by my authorized dealer that when the bike left the USA ( I was heading to SE Asia) , an extended warranty from Suzuki would no longer be valid. Found out that there are no authorized Suzuki DR 650 mechanics in Thailand. Was able to track down factory trained/ authorized techs for a Hayabusa..but not a DR650.
Canoli
canoli screwed with this post 01-05-2013 at 12:42 AM
canoli is offline   Reply With Quote
Old 01-05-2013, 07:52 AM   #72493
bross
Where we riding to?
bross's Avatar
Oddometer: 4,530
Questions:
If you're regularly running those temps I'd switch to a 0W40 weight oil. That's what I run in my quad that I use for a snow plow in the winter. I use Amsoil full synthetic and it looks just like a 10W40 even in minus 20 temps. Good cold flow properties and quad starts easily.
Old 01-05-2013, 08:13 AM   #72494
Rusty Rocket
Life behind "Bars"
Rusty Rocket's Avatar
Oddometer: 9,155
You mean -40C also
on one side the sign it said "Private Road", but on the other side it didn't say nothin'
2009 DR650
..1972 Penton Six-Days ..1971 Suzuki TS185.. 2005 KTM 400exc
Member of: AMA, NETRA, Blue Ribbon Coalition, CCCofVT, Berkshire TR, CT Ramblers
Rusty Rocket is offline   Reply With Quote
Old 01-05-2013, 08:23 AM   #72495
Sierra Thumper
Oddometer: 641
When I was a youngster my bikes were my only form of transportation.....I once literally got hypothermia on a long night ride in sub-freezing weather. I couldn't make it home, had to stop at a friends house to try and warm up, ended up staying there for a day till I was good enough to hit the road again. The bike was one of my 2 stroke street bikes, I think it was my Suzuki GT185 twin....it ran awesome in the cold.......me, not so much I got my first car soon after that........
I haven't been much of a real cold weather rider since
"Don't get so concerned with the slab that you choose a turd for the dirt"- The Gospel as spoken by itrack
Sierra Thumper is offline   Reply With Quote
Times are GMT -7.   It's 09:24 AM.
