Old 12-31-2012, 10:20 PM   #72511
kezzajohnson
kezza
kezzajohnson's Avatar
Oddometer: 731
Torque
Originally Posted by JagLite View Post
I got my new Clymer manual today from ProCycle (thanks!) and I looked through it quickly and found what it says for the header bolts.
Page 66
6.b. Install a new gasket jnto the cylinder head exhaust port.
6.c. Apply anti-seize compound to the threads.
6.d. Tighten the exhaust pipe retaining bolts securely.
6.f. Retighten the bolts after running the engine and allowing it to cool.
I didn't look at my Suzi factory manual but I expect it to say the same thing.
Anti-seize and retighten.
Not sure what torque value "securely" is though
According to my manual, Exhaust bolts torque to 26NM
KezzaJohnson Blue 06 DR650se,Yellow 06 DRZ250
Website: http://www.territoryon2wheels.com
"May the Road Never Rise to Defeat you..."
kezzajohnson is offline   Reply With Quote
Old 12-31-2012, 11:50 PM   #72512
gippyphil
gippyphil's Avatar
Oddometer: 50
Cry
Help me, DR650 riders, you're my only hope!
I dropped my 2011 DR, and bent the bars. By all accounts, this is not uncommon, and I have been reading threads on bar recommendations. However, it seems that the part the "bottom" part of the left bar clamp is also bent back about 10-15 degrees (see photo). This appears to be bolted on to the top of the forks (I can feel a bolt hole on the underside). If so, what is this replacement part called? If not, what is the whole "top of the forks" part called, and can it be fixed?
gippyphil is offline   Reply With Quote
Old 01-01-2013, 12:12 AM   #72513
trailrider383
867-5309
trailrider383's Avatar
Oddometer: 2,532
Dropped? It looks like you hit a truck at 80 mph. The bar mount is mounted in rubber through the top triple clamp so you might be able to tweak that back in line.
DO WHAT YOU LIKE - LIKE WHAT YOU DO
Explain to me again why enjoying life when I retire is more important than enjoying life now?
trailrider383 is offline   Reply With Quote
Old 01-01-2013, 12:13 AM   #72514
PHILinFRANCE
PHILinFRANCE's Avatar
Oddometer: 760
@ GIPPYPHIL
Get some RENTHAL BARS to replace the bent ones , and by the look of it from your pic the BAR CLAMP does look to bad ................take the bars of and get some better pics please
Phil
I,M HERE FOR A GOOD TIME NOT ALONG TIME
PHILinFRANCE is offline   Reply With Quote
Old 01-01-2013, 12:57 AM   #72515
gippyphil
gippyphil's Avatar
Oddometer: 50
80mph?! I wish - that would at least be a great story to tell. I got into the wrong track on a heavily rutted farming road and lost the front end at about 30-40kph.
gippyphil screwed with this post 01-01-2013 at 01:12 AM
Old 01-01-2013, 05:01 AM   #72516
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 5,817
Originally Posted by Cobain View Post
I mounted, dismounted, and remounted my first rear tire today. Pinched the tube, patched it, then it leaked again, and i tore up the bead of the tire pretty good. That will be the last time i try to do that. I realize why i pay $25 now.
It's really not that difficult. Practice makes it easier.
You likely didn't keep the tire down in the deep part of the rim while trying to lever it on so it was probably a lot harder than it should be. Maybe you should get an old wheel and practice a few times? Knowing how to fix it will get you out of a long walk someday.
"Don't play a lute to a cow" (Old Chinese Idiom)
Old 01-01-2013, 07:10 AM   #72517
TrophyHunter
Oddometer: 922
As PhilinFrance mentioned - better pics needed, It is possible all is okay with the clamp, or you just bent the mounting bolt, The clamp mounting bolt goes thru the mount and the mount reminds me of a rubber dome covered by a metal cup. You can get a lot of movement out of it on a crash before you do real damage, I've loosened everything up and reset it a couple of times with no issues on mine after some minor dirt naps,
Bars are a personal choice but PinF makes a good recommendation. I went with ProCycles big bar kit and risers. I like it,
Do a part by part disassembly with pics at each stage. It'll help with the diagnosis and give ya something to look at on reassembly. Most importantly, you're okay enough to type about it - no major personal body damage.
www.dualsportmoto.com
2005 DR650
2013 HD Road King
"It's a small amount of gas, but it represents a long walk" My Dad...
TrophyHunter is offline   Reply With Quote
Old 01-01-2013, 07:13 AM   #72518
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 4,842
A mans got to know his limitations. It just takes a little practice, patience, and the right tools.
Guess what doofus, nobody reads your lame blog.
Old 01-01-2013, 07:33 AM   #72519
Mambo Dave
Mambo Dave's Avatar
Oddometer: 2,498
Use talc powder (baby powder) all over tubes to allow them to slip & slide around while putting them in there. The last set of tires I did (the DR650's) I used baby powder on the tire beads (instead of soapy water) as well. Hard to believe I didn't screw all of it up, but the Shinkos are still holding air and good to go.
Mambo Dave is online now   Reply With Quote
Old 01-01-2013, 08:24 AM   #72520
jessepitt
Dual Sport Addict
jessepitt's Avatar
Oddometer: 988
[QUOTE=Mambo Dave;20370237]Use talc powder (baby powder) all over tubes to allow them to slip & slide around while putting them in there.
These two pieces of advice are the biggest factors in an easy and successful tire change. Keeping the beads of the tire all the way into the rim (deepest part of the \-/ ) opposite where you are working your tire spoons is key. I have recently seen a zip tye used to keep the tire clamped together so that this is easier to accomplish, (I'm sure ERO7-S will be along with pictures shortly, lol). I started off using dish soap and water but have recently also switched to talc, both work great, talc is easier to carry and I've heard it helps keep the tube from chaffing after install too. You should use some kind of lube or something is going to get hurt. Like Emm said, this is a MUST HAVE skill if you ever plan to leave a paved road for any distance and will make you feel more comfortable doing so. I replaced my first tube in the field last summer after eight years of riding and it was a snap. It didn't take me much longer than it usually does in my shop and it was a good feeling to be able to fix it and keep riding. Don't get discouraged, its all in the technique and you can learn that with a little practice.
jessepitt screwed with this post 01-01-2013 at 08:39 AM
jessepitt is offline   Reply With Quote
Old 01-01-2013, 08:56 AM   #72521
sandwash
sandwash's Avatar
Oddometer: 837
Had two new Shinko 230 Tour Masters to put on,the front one went on good and seated/no leaks.The rear one was tough,went to air up and it started spitting air.38-40$ at the shop, 20$ for the tube,16$ for the change out.
And I still have to replace the worn out nobbles with new D606's,front and rear(may just take the rear to the shop,only16$ for change out).
I have been using cable lube(have two buckets of the stuff).
97dr650 bad ass FCR-MX pumper,plus other goodies
sandwash is offline   Reply With Quote
Old 01-01-2013, 09:01 AM   #72522
JagLite
JagLite's Avatar
Oddometer: 606
Thumb Exhaust bolt torque
I believe you are thinking the exhaust CLAMP BOLT is the same as the header bolts.
The clamp bolt is torqued to 26nm (19 ft/lb), yes.
Thanks for checking
EDIT;
I had to check what the official Suzi manual says and after a long search I found it in the "periodic maintenance" section.
Page 2-14
You are correct Sir!
Suzi says that ALL the exhaust bolts are the same at 26nm (19 ft/lb)
So Clymer doesn't put the bolts in the same group in their new manual
Attitude ~
The difference between
Ordeal and Adventure
James
JagLite screwed with this post 01-01-2013 at 01:38 PM Reason: Researhing correct torque
JagLite is offline   Reply With Quote
Old 01-01-2013, 10:09 AM   #72523
Feelers
Oddometer: 181
It's possible that nothing is actually bent. My bars were tweaked a lot after a crash as well. Try this before spending money on new stuff. Roll the bike up so the front wheel is next to something solid (telephone pole, wall, truck bumper, etc). Turn the handlebars in the direction necessary to make them align with the front wheel WITHOUT ALLOWING THE FRONT WHEEL TO TURN (steer, not roll).
The handlebars are rubber mounted and can easily be aligned and misaligned for damage resistance in crashes.
Feelers is offline   Reply With Quote
Old 01-01-2013, 11:00 AM   #72524
Rusty Rocket
Life behind "Bars"
Rusty Rocket's Avatar
Oddometer: 6,266
Loosen the bolts on the bar clamps. There are rubber cones (parts 12 &13 in the attached diagram)that are probably deformed. They will go back to their original shape as soon as you unclamp the bars. Be sure bolt # 11 isn't bent.
http://www.ronayers.com/Fiche/TypeID.../STEERING_STEM
1996 DR 650 (a big girl that likes it dirty)
1973 Penton Six-Days (mint)
1971 Suzuki TS185 (needs restoration)
2005 KTM 400exc w/ BajaDesigns D/S light kit
Rusty Rocket is offline   Reply With Quote
Old 01-01-2013, 11:02 AM   #72525
procycle
procycle's Avatar
Oddometer: 1,607
He's definitely got bent parts. The bars are toast and the bolt that goes through the left clamp is obviously very bent. It's a pretty easy fix. The front end may also be twisted but the place to start is new bars and a new clamp bolt.
Clarke's second law of Egodynamics: "For every expert, there is an equal and opposite expert." - Jasper Fforde
www.procycle.us - Everything for your DR650 and lots of other great stuff!
DR900 Big Bore Stroker buildup
procycle is offline   Reply With Quote
Times are GMT -7.   It's 09:21 PM.
