Old 01-01-2013, 08:45 PM   #72541
Cobain
night owl
Cobain's Avatar
Oddometer: 129
wow thats the exact tire i was mounting yesterday. haha
Cobain is offline   Reply With Quote
Old 01-01-2013, 09:24 PM   #72542
JTB488
Oddometer: 40
Gippyphil, Man you have a tiny garage!
JTB488 is offline   Reply With Quote
Old 01-01-2013, 09:39 PM   #72543
shu
Oddometer: 757
Originally Posted by GSF1200S View Post
**EDIT** Anyone have any hints for getting sand out from around the spark plugs before I pull the plugs? I blasted out the holes as best I could with carb cleaner, but i dont have compressed air since I have no power (bikes at a storage place). They look clean now, but im mostly worried about sand/dirt that might be hiding under the thermistor for the vapor tach (on outside spark plug). Any tips would be cool :)
Blowing it out with a drinking straw works fairly well.
I take a inflation needle for a basketball, cut off the very end to open it up and use it with my little tire pump that I run off the bike's battery. This works surprisingly well as an air hose.
...........shu
shu is offline   Reply With Quote
Old 01-02-2013, 02:08 AM   #72544
1Waipukbiker
Oddometer: 13
Just to change the subject, I want to upgrade the front fork springs and not sure between stiffer stock springs or progressive rate springs, any comments from experiance?
1Waipukbiker is offline   Reply With Quote
Old 01-02-2013, 05:58 AM   #72545
Mongle
Knuckle dragger
Mongle's Avatar
Oddometer: 1,302
Buy a can of compressed air they sell for cleaning computer keyboards and such. Dig around in there with something, blow with the air. Break the plugs loose a turn or two; blow with more air. If you think you are done do it again just to be sure!
DO NOT do what Emm said and crank the engine with the spark plug hanging on by only a few threads! Not only is the piston going to push air out..it sucks air in. Also, a DR cranks with about 100-130 PSI of cranking compression and only having 2-3 threads on a plug and cranking can lead to damaged threads.
Mongle is offline   Reply With Quote
Old 01-02-2013, 06:08 AM   #72546
neo1piv014
ADV in training
Oddometer: 610
Originally Posted by Emmbeedee View Post
A lot of people think just keeping the tire in the rim recess right across from where your levers are is enough. They are the ones struggling with the job. You have to keep as much of the bead in the recess as possible.
Alright, so I don't exactly know what everyone means when they're referring to this. Assuming the side of the tire facing up is "Side A," and the side facing the floor is "Side B," and I'm trying to spoon the tire on at the 12 o'clock position, am I using my knees to push side A into the dish, or am I reaching down with my hand to compress sides A and B into the dish?
_________________________
Ride videos
'01 DR650
"The impossible often has a kind of integrity which the merely improbable lacks."
neo1piv014 is offline   Reply With Quote
Old 01-02-2013, 06:14 AM   #72547
blk-betty
bam-a-lam
blk-betty's Avatar
Oddometer: 1,834
Originally Posted by JagLite View Post
I believe you are thinking the exhaust CLAMP BOLT is the same as the header bolts.
The clamp bolt is torqued to 26nm (19 ft/lb), yes.
Thanks for checking
EDIT;
I had to check what the official Suzi manual says and after a long search I found it in the "periodic maintenance" section.
Page 2-14
You are correct Sir!
Suzi says that ALL the exhaust bolts are the same at 26nm (19 ft/lb)
So Clymer doesn't put the bolts in the same group in their new manual
Thanks for the tq spec...I'm pretty certain I had them tightened to more than 19 ft lbs..that really isn't a lot. Got to see if my local True Value has a replecment bolt otherwise will check with the dealer to see if they have any in stock.
Will reinstall with the anit-sieze.
'12 H-D Road Glide Custom
'09 Suzuki DR650
'09 H-D XR1200
blk-betty is offline   Reply With Quote
Old 01-02-2013, 06:25 AM   #72548
Rusty Rocket
Life behind "Bars"
Rusty Rocket's Avatar
Oddometer: 6,242
Originally Posted by Cobain View Post
Thanks for the input. I need to get some spoons, i was using (2) 7in. bars that came with the tusk fender pack.
I used to use tire irons like these and pinched alot of tubes.
Then I bought a set of these and it's been easy since.
Keeping the tire down in the rim is paramount. It also helps to put some air in the tube. just enough to make it round and that helps it stay outta the way of the irons. be sure to use soapy water as a lubricant.
1996 DR 650 (a big girl that likes it dirty)
1973 Penton Six-Days (mint)
1971 Suzuki TS185 (needs restoration)
2005 KTM 400exc w/ BajaDesigns D/S light kit
Rusty Rocket is offline   Reply With Quote
Old 01-02-2013, 07:08 AM   #72549
Mambo Dave
Mambo Dave's Avatar
Oddometer: 2,472
...........shu
Likewise, get a shop-vac, or any vacuum with a hose, a plastic bag or baggie (or a piece of pastic) and that same straw. Stick the straw through the plastic, then hold it and the plastic up to block the vacuum hose so it makes the vacuum suck through the straw.
I have two long tire irons that have curves in them, and while they won't fit in a fender bag, those and perhaps one spoon would be ideal I'd think.
Mambo Dave is offline   Reply With Quote
Old 01-02-2013, 07:48 AM   #72550
procycle
procycle's Avatar
Oddometer: 1,597
The point is not to only push the tire into the dish at 6 o'clock but to push it in from say 3 o'clock to 9 o'clock or as much of the circumference as possible.
Clarke's second law of Egodynamics: "For every expert, there is an equal and opposite expert." - Jasper Fforde
www.procycle.us - Everything for your DR650 and lots of other great stuff!
DR900 Big Bore Stroker buildup
procycle is offline   Reply With Quote
Old 01-02-2013, 07:55 AM   #72551
Foot dragger
beat up ex flat tracker
Foot dragger's Avatar
Oddometer: 6,753
Neduro's big tire change thread is really a good thing to go through if you really want to learn all the tricks about changing tires.
I learned about pulling the tire bead off both sides of the rim and then stuff the wheel inside the tire to get the tire off the rim.
Its so much easier I about kicked myself for all the times Ive done it the hard way.
2003 DR 650.(1976 Montesa 250 Enduro-nice!) - - 1990 MASI TEAM-3V.- 1976 Motobecane, Super-Mirage.- Kona, HumuHumuNukuNukuApua'a. Single Speed ThRaShEr BiKe. 1968 360 Greeves challenger MXer. 1999 Triumph Trophy 1200. 2011 KTM530 EXC. 2012 KONA Hei Hei Deluxe (ongoing bike issues) -2009 KTM 200XC-W.
Foot dragger is offline   Reply With Quote
Old 01-02-2013, 08:54 AM   #72552
victor441
victor441's Avatar
Oddometer: 458
Originally Posted by Adv Grifter View Post
Tires are tough, no question. Experience helps ... but I've been doing it for years and still suffer ... but I'm cheap and don't have all the best and proper tools. Having the right tools and techniques really makes things much easier. Take it from a "right bodger" !
On the DR certain rear road tires can be VERY tough to break the bead on.
A real bead breaker is a must. The Avon Distanzia can be a real BEAR to break the bead on.
For remounting try using the BIG Zip tie method. Documented here somewhere ... but basically using 4 or 5 BIG HD Zip ties to squish the two beads together to get the tire beads deep into the wheel well. This means less chance to pinch a tube and easier to pop it back on. Good smooth nose irons really help too. Once tire is on ... pull Zip ties out!
But in the end ... if you have room and some extra cash ... think about something like the No-Mar tire machine. A God Send!
I've been using six zip ties, works great, and it would be nearly impossible to pinch a tube this way...the tube is inflated just enough to round out and in put in the tire before the zip ties are applied. Little force is needed to get the tire on the rim. Real tire mounting lube helps a lot too, Napa sells a gallon for $12 or so. The original thread where I learned the zip tie trick is at http://www.advrider.com/forums/showthread.php?t=299597 (learned recently, mounted a few tires easily, and have the zeal of the newly converted ;-) FWIW the zip ties can be reused too, the locking tab can be released with a small screwdriver.
victor441 screwed with this post 01-02-2013 at 09:13 AM
victor441 is offline   Reply With Quote
Old 01-02-2013, 09:23 AM   #72553
shu
Oddometer: 757
Everything you do will be on 'side A'.
1.Get some real tire lube from an auto parts store or online.
Brush it on with a small cheap paintbrush around the whole tire bead. In my experience real tire lube will stay wet and slippery longer than a soap mixture which evaporates pretty fast.
2. Get a 'bead buddy' ($10 available almost any shop or on line) and put it on the rim at your 6:00 position. That will hold the tire down at that point in the deepest part of the wheel well. Kneel on the tire at 4:00 and 8:00. Now you are holding almost half the tire bead down in that well.
2. Use 3 tire irons. Start working at the tire just an inch past where your knee is holding the bead down. That would be at 3:00 or 9:00. Once you have levered that little bit on, leave the tire iron in and put your knee on it to keep from losing the bit you have gained. Take another little bite with another tire iron- either on that same side or by the other knee.
3. Keep working around until you are close to 12:00. All the while keep your focus on making sure the tire remains deep in the well. If it starts to take a lot of force to get a little bite of the tire over the rim, that means the other part of the tire is starting to creep up out of the well- put some lube on it and get it back down.
4. Depending on the tire, the last bite can take a little more force or sometimes it will just pop over the rim easily. Put some more lube on and judge your use of force- it is possible to tear the bead of the tire or break the internal wires that make it up.
5. When you're out getting your tire lube and bead buddy also pick up another ten dollar item: a tire valve 'snake' (I forget the real name). It.s a little piece of wire attached to a threaded bit that will thread into the valve of the tube. This little item will save you bruised and battered hands and a lot of cussing getting the valve stem in through the hole in the wheel.
It takes some practice. You'll get it and learn your own tricks on the way.
...............shu
Old 01-02-2013, 10:51 AM   #72554
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 5,769
Relax - I'm not saying he should start the engine - this is an emergency measure where you have to stop sand getting into the hole. A couple of quick starter pushes are not going to damage anything. I've done it many times.
"Don't play a lute to a cow" (Old Chinese Idiom)
Old 01-02-2013, 11:59 AM   #72555
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 5,370
I have the red handle tire irons ... great! Very easy on tubes!
I put air in my tube once the get the TUBE in the tire .... this to straighten it out and make sure there are no "folds" in the tube.
BUT ... after that ... I pull the valve stem OUT and 100% deflate it. Too much air in the tube will make mounting the tire much tougher.
Don't ask me how I know this!!
Some guys use wood or plastic wedges to force and HOLD tire bead/side wall down into wheel well. The Zip Tie method does a similar thing ... but compresses BOTH sides of the tire ... allowing the tire beads to drop in. Makes spooning on the tire easier.
REMEMBER: Small bites! Don't get in a hurry!
Adv Grifter is online now   Reply With Quote
Times are GMT -7.   It's 10:51 AM.
