Old 01-07-2013, 07:43 PM   #72571
barko1
barko1
barko1's Avatar
Oddometer: 3,406
Originally Posted by gofast1320 View Post
Went out and eyeballed the sight glass in the sunshine a few minutes ago. No visible bubble in sight glass. SOOOOooooo looks like some fuel may have made it in there. Took spark plugs out and turned motor over and gas shot out of spark plug holes. Off to get some oil as soon as I figure out what oil to get so I can change it and will take petcock off of extra tank that came with bike and see if it works.
You need to order this
Float Assembly - Stock BST
DR650 '90-Current
$69.95
A genuine factory replacement float assembly for your stock Mikuni BST40 carburetor.
FCR-MX Carb Conversion Parts
Back to Top
DR650, 98 Bimota SB6R, Kawasaki 14, 67 X-6 Scrambler (apart), SL350K1 (apart), 77 Goldwing 1000, Triumph Thunderbird Sport, Triumph Daytona Super III, DR650, MZ Skorpian Sport Cup, 71 Triumph Daytona 500, KDX220
barko1 is offline   Reply With Quote
Old 01-07-2013, 08:06 PM   #72572
neo1piv014
ADV in training
Oddometer: 621
Originally Posted by 808650se View Post
Will a carb rebuild help overflow of fuel into engine
Just so long as you put it back together right. After talking to a couple different people, I still don't exactly understand how to set the float height.
_________________________
Ride videos
'01 DR650
"The impossible often has a kind of integrity which the merely improbable lacks."
neo1piv014 is offline   Reply With Quote
Old 01-07-2013, 08:21 PM   #72573
motolab
motolab's Avatar
Oddometer: 2,777
DR650 '90-Current
$69.95
Generally not needed, as the float needle and needle seat o-ring are usually the culprits and can be replaced separately.
Regards,
Derek
motolab is online now   Reply With Quote
Old 01-07-2013, 08:24 PM   #72574
motolab
motolab's Avatar
Oddometer: 2,777
A misadjusted float height will not by itself cause the carb to overflow. See http://www.advrider.com/forums/showpost.php?p=19920266&postcount=7068.
Regards,
Derek
Old 01-07-2013, 08:26 PM   #72575
808650se
Oddometer: 4
Thanks d
Thanks d
helpful info
thinkin that i need to replace all gaskets since its been sittin
808650se is offline   Reply With Quote
Old 01-07-2013, 08:50 PM   #72576
motolab
motolab's Avatar
Oddometer: 2,777
Thanks d
helpful info
See http://www.advrider.com/forums/showthread.php?t=528038.
Regards,
Derek
Old 01-07-2013, 10:35 PM   #72577
GSF1200S
Oddometer: 976
Originally Posted by Adv Grifter View Post
This is all pretty normal for a BIG single in cold weather. The white vapor is 100% normal. The weird smell is the fuel treatment product. No worries.
This is what I would do:
1. Adjust Fuel/Air Pilot screw OUT (rich) about 1 turn
2. Turn up Idle (one full turn on idle adjuster) Lower idle once fully warm.
3. Try to store bike indoors if possible.
4. Use 0-40 synthetic oil if possible.
5. Shorai batts need to "warm up" ... so turn on headlight for two minutes before attempting to start bike. Seems counter intuitive but supposedly works.
6. You could take a 1500 Watt hair dryer and run it onto the Carb for 5 minutes before start up. (if that's practical). Carbs like HEAT!
7. If not already done ... cover your bike!
I have noticed that with my TM40, just like the BST, I do have to mess with the idle speed adjustment a bit. Ill start on full choke, runs fine. Starts to stumble, half choke. Starts to stumble, off choke. Then, the RPMs want to drop to 1-1.2k which is too slow, so I turn the idle speed up to about 1500. Once the engine gets thoroughly warmed up, it ends up idling at 1.8k rpms, so I back it off down to 1.5k again. The BST and my new TM40 do this, but I havent had a chance to properly set the idle yet (mixture screws). When is it best for me to try and get the mix set absolutely right? Its further complicated by the fact its now in the 50s here, so im pretty sure the DR never really warms up. I have been changing the oil very frequently as its been in a bunch of dirt (and because im in a humid climate so I want to be very careful about condensation building up in the oil), but I think I need to get some kind of oil cooler block setup for the cold temperatures.
Ive read mention of using a cut down welders glove, and ive of course considered metal plates to cover parts of the fins to allow the DR to warm up. What do you think about any/all of the above? It seems to run perfectly jetted straight from ProCycle, while of course I will need to tweak the idle speed- I dont get lean surge, stumble on sudden WOT, or anything- so, im sure my idle woes are all due part to adjustment and part to temperature..
GSF1200S is offline   Reply With Quote
Old 01-08-2013, 12:41 AM   #72578
Chill
Chill's Avatar
Oddometer: 325
I have a pair of DR650 wheels for sale here...
http://advrider.com/forums/showthread.php?t=854035
Please PM if interested, or any ideas what the going $ rate is for this sort of thing, thanks.
Chill is offline   Reply With Quote
Old 01-08-2013, 04:50 AM   #72579
doug s.
Oddometer: 1,348
oil cooler t-stats
from a prewious post:
oil cooler t-stats
thermostats:
http://shop.perma-cool.com/Oil-Thermostats_c10.htm
https://www.denniskirk.com/496595.sk...utm_medium=cse
http://translate.google.com/translat...zubehoer-2.php
http://www.batinc.net/thermos.htm
manual bypass:
http://www.motorcycle-superstore.com...ass-Valve.aspx
doug s.
doug s. is offline   Reply With Quote
Old 01-08-2013, 05:55 AM   #72580
Rusty Rocket
Life behind "Bars"
Rusty Rocket's Avatar
Oddometer: 9,527
Regards,
Derek
Yep, I have had to replace the o-rings twice in 7 years of owning my DR. I think it has something to do with the damn ethanol.
on one side the sign it said "Private Road", but on the other side it didn't say nothin'
2009 DR650
..1972 Penton Six-Days ..1971 Suzuki TS185.. 2005 KTM 400exc
Member of: AMA, NETRA, Blue Ribbon Coalition, CCCofVT, Berkshire TR, CT Ramblers
Rusty Rocket is online now   Reply With Quote
Old 01-08-2013, 06:29 AM   #72581
Mambo Dave
Backyard Adventurer
Mambo Dave's Avatar
Oddometer: 5,791
So I'm now running my Shinko 705's in the low 30's psi range for local commuting (up from high 20's for rear, 30 for front). I'm liking it more, but ... I'm sure there's gonna be a down side. I think, in part, it's to make up for the soft suspension that I have neighther the time or money to address right now.
Maybe I should just buy street tires for it the next time I buy tires... there just aren't many more places to explore down here without loads of trespassing. Still, love the bike and the simplicity of it.
Has anyone had a tire bead pop over the rim or bulges at running tires on the DR650 in the low 30's for street use?
Mambo Dave is offline   Reply With Quote
Old 01-08-2013, 06:47 AM   #72582
gofast1320
gofast1320's Avatar
Oddometer: 735
Barko, motolab, rusty rocket, and others. The bike sat for a while and the PO had the carb rebuilt by the local Suzuki shop that is know for high quality work. I think I started the problem by filling the tank and inadvertantly leaving petcock selector on PRI which allowed fuel to run into carb. I'll know more in a bit. The weather has warmed up and I've set aside the morning to change the oil and get it running. I have another petcock I can put on there so I'll do that while I'm at it.
Thanks for tips
gofast1320 is offline   Reply With Quote
Old 01-08-2013, 07:01 AM   #72583
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,841
Thanks for tips
The leaking tap or you leaving it in the Prime position is only one of at least two faults. For the gas to leak into your engine, the float mechanism or some part of it has to be malfunctioning too.
Old 01-08-2013, 07:09 AM   #72584
barko1
barko1
barko1's Avatar
Oddometer: 3,406
Regards,
Derek
Generally not but my DR got the replacement o-rings and still had problems until I replaced the whole unit and it runs like a champ now
Old 01-08-2013, 09:20 AM   #72585
neo1piv014
ADV in training
Oddometer: 621
I'm currently running Shinko 705's at 30 psi front and rear on my DR650, and they've been perfectly fine so far. I was considering getting some Avon road tires for my stock rims, but for the price, I don't see that the 705's really give up much on the street compared to those cruiser style tires, they're way the hell cheaper, and they're actually not bad on your basic dirt roads.
Ride videos
'01 DR650
Times are GMT -7.   It's 03:27 PM.
