Old 01-08-2013, 02:26 PM   #72601
neo1piv014
ADV in training
Oddometer: 621
Originally Posted by Mambo Dave View Post
Cool. Thanks man.
I ran Shinko fronts on my last bike, and never had a complaint. We all know the horror stories of 705's coming apart, but more and more that's looking like those were underinflated tires.
That must have been the issue. I have been insanely hard on these tires at points, run them on a fully loaded bike for hundreds of miles a day, thrashed them on twisty mountain roads as well as rough dirt roads, and they don't show any indication that they're going to come apart. For $100 a set, I'm not sure I'll ever get different rubber.
_________________________
Ride videos
'01 DR650
"The impossible often has a kind of integrity which the merely improbable lacks."
neo1piv014 is offline   Reply With Quote
Old 01-08-2013, 02:32 PM   #72602
dljocky
Oddometer: 868
Sorry for jumping in on what i guess I should know, but I haven't heard the stories of the Shinko's coming apart. Is this common? I've probably got over 25K miles from several 705's on the rear of my DR with no problems. Were there any recalls or anything?
Cool. Thanks man.
dljocky is offline   Reply With Quote
Old 01-08-2013, 02:34 PM   #72603
shu
Oddometer: 1,050
Thanks for that, Doug.
I like the looks of this one:
But... right now I'm in 'KLR' mode, and these are more like 'BMW' mode, so I'll just keep using my cardboard wind block. Maybe soon, though.....
............shu
shu is offline   Reply With Quote
Old 01-08-2013, 02:50 PM   #72604
garnaro
MotoBlunderer
garnaro's Avatar
Oddometer: 310
Originally Posted by motolab View Post
nope. this would have helped !
bugsonmyboard.org
two wheeled wave hunting dispatches
garnaro is offline   Reply With Quote
Old 01-08-2013, 03:07 PM   #72605
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 6,128
Technically, BST40 carbs use a cold start enrichment circuit instead of a choke. A choke is closed when an engine is cold and opened when it is warm, whereas a fuel enrichment circuit is opened when the engine is cold and closed when it is warm. A choke works by restricting the air flow, whereas an enrichment circuit works by adding extra fuel. A choke requires a fast idle cam or something akin to it (or you have to hold the throttle open manually), whereas an enrichment circuit adds a little extra air simultaneously with the extra fuel, so the fast idle is already built in.
The pilot jet size should be changed in order to tune 1/16 and 1/8 opening. It should not be changed solely in order to alter the idle mixture.
The fuel screw setting should be the only thing that is changed to affect idle mixture, unless it runs out of range. If it does run out of range, it's likely because the pilot jet is clogged, not because a different size needs to be installed.
Regards,
Derek
Thanks for the clarification Derek. I use the term "Choke" to aid communication, I'm aware the DR has an enrichment circuit. I'm only relating my experience tuning DR650's. I had one that needed NO choke (enrichment) to start ... and if you used choke it would begin a stumble at idle almost right away. So I figured something was too rich somewhere.
I asked Mark Salvisburg and the boys ... they suggested a smaller Pilot (leaner). I did this and problem went away. Bike ran well everywhere else.
Go figure. Turns out the Pilot that was in the CARB was oversize, not stock. Went to stock Pilot Jet, all good. Wonders never cease.
Your warnings about clogged Pilot Jets are well taken. I had this problem with a DRZ400E. I thought I'd got the Pilot Jet clean ... not so. The little tiny holes on the side (I guess) were still clogged up. I ended up putting in a NEW Pilot Jet. End of problem. I would have bet money I'd got that jet clean ... but I didn't!
Old 01-08-2013, 03:17 PM   #72606
Adv Grifter
Oddometer: 6,128
I think if you search around on the GSpot forum you may find Shinko stories ... every BMW guy on there now hate Shinko and really believe they are junk.
This is good ... keeps the price down for those of us who know better.
A few did come apart on loaded R1200GS's and the like. I don't believe the tire is rated to hold up under a 700 lbs. R1200GS ADV fully loaded with 100 lbs. of luggage, two up, doing 100 mph in 95F heat for hours and hours.
I'm on my 3rd 705 Shinko now and no such issues. But many OEM's have had bad batches of tires. Metzeler certainly did and so has Avon. Avon gave away LOTS of free tires when the Distanzia first came out ... I was the recipient of one. Metzeler? Not so much! (and one reason I still support Avon today)
Shinko are made in Korea by Yokohama. So these dudes are not new at this. If you ever have a problem with a tire ... go to a dealer. Any dealer. Most times you'll get a new tire out of it if what you have is truly a fault.
That said, our lightweight DR is far easier on tires (and everything really) than a GS, Tenere' or KTM 990. But were 150 lbs. to 200 lbs. lighter, makes sense, right?
Old 01-08-2013, 03:26 PM   #72607
procycle
procycle's Avatar
Oddometer: 2,402
Yes, the early 705s had problems dealing with heavy bikes and high speeds. The tires in the problem sizes have been redesigned and carry different part numbers (and higher prices). The update happened about 2 years ago. Since then Shinkos have been getting rave reviews.
Clarke's second law of Egodynamics: "For every expert, there is an equal and opposite expert." - Jasper Fforde
www.procycle.us - Everything for your DR650 and lots of other great stuff!
DR900 Big Bore Stroker buildup
TurboDiesel Corvette - go to the end to start at the beginning
procycle is offline   Reply With Quote
Old 01-08-2013, 03:31 PM   #72608
Mambo Dave
Backyard Adventurer
Mambo Dave's Avatar
Oddometer: 5,786
Well stated for dljocky.
Yeah, it's an armchair quarterback, hindsight is 20/20 kinda thing, but the build of 705's maens large areas (the knobs) that won't flex much, and the in-between areas (the sipes) that have to do all the flexing. Now it just makes sense to not allow the flexes to be in that great of a range or it's like working a specific piece of sheet steel back and forth a ton until it heats up and tears/snaps. The sipes can flex enough for the life of a tire if limited to the range they have to flex, and if kept cool enough. Lower pressures on 705's are probably just fine if you find yourself stuck, or about to be stuck, and need sure-traction to get out of where you're at... but don't then run it hard, or fast, or much at all on the highways home with that super-low pressure once you get out of being stuck.
shu, most manufacturers may recommend that for two-up, or because on some bikes more of the rider's weight and load weight goes over the rear?
Anyway, I come from the bicycle world where the taller and skinnier the tire, the higher pressure it gets. Mountain bike tires are typically used from 17 to 35 psi (lower for traction), beach cruiser tires at about 45 to 55, and road bike tires from 90 to 110 psi (fatter tires gets lower pressures for the same sized wheel / rim, but the lightest and skinniest of tires get the most pressure).
With that tall narrow 21" up front, and with all the braking that happens up there, I'm a fan of just a tad more in the front if I were to choose for this bike. But right now I'd bet they're about even.
Mambo Dave screwed with this post 01-08-2013 at 03:39 PM
Mambo Dave is offline   Reply With Quote
Old 01-08-2013, 05:01 PM   #72609
motolab
motolab's Avatar
Oddometer: 2,775
I suppose I should have qualified my statement with, "if the stock pilot jet is installed"...
I am curious though, did you try to adjust the idle mixture via the fuel screw and find it was closed or close to it when adjusted properly before asking Marc for advice?
Regards,
Derek
motolab is offline   Reply With Quote
Old 01-08-2013, 06:16 PM   #72610
Carl Childers
Ghost in the Machine
Carl Childers's Avatar
Oddometer: 852
Question Rear Shock Questions.
I'm done with the front forks and now I'm eyeing up the rear shock and wondering how many of you out there have simply replaced the stock spring and changed the oil weight and said "hey this works great it's all I need"?
If I wen't back in later because I didn't like the performance would I still be able to use the same replacement spring with the valving upgrade? I don't mind several tries at the shock as long as I'm not throwing away $$ on the spring that I couldn't use in round two.
Carl Childers is online now   Reply With Quote
Old 01-08-2013, 06:25 PM   #72611
RED CAT
Bumpy Backroader
RED CAT's Avatar
Oddometer: 3,000
Shinko 705s!
Yea, I'm one of the GS1200 guys that blew the tread right off my rear Shinko. First ones out stated 33psi max on the bias tire side wall. So thats what I ran. Have to admit I did hit 200kph a couple of times on our well maintained gravel roads though. Think if I would have run 38psi they would have held up. Heat must have got to them. Shinko 705s do tent to howl after they get worn a little though. I'm sure on a 35hp DR you won't have any problems.
RED CAT is offline   Reply With Quote
Old 01-08-2013, 06:59 PM   #72612
PPCLI-Jim
PPCLI-Jim's Avatar
Oddometer: 221
I run Shinko's and I agree that the main difference between the DR riders and the GS riders is we tend to go slower with less weight. Either one will make a huge difference in the tires life combining the 2 makes for an extended life. Before i get jumped on by the nay sayers how many times has a DR really been run flat out on a highway the same way a GS has been with or without saddle bags and top box?.
I'm not saying to kill all the stupid people . .. Just remove the warning labels and let nature run it's course
http://www.youtube.com/user/spudhead/videos?view=0 my youtube channel
PPCLI-Jim is offline   Reply With Quote
Old 01-08-2013, 07:09 PM   #72613
Mambo Dave
Backyard Adventurer
Mambo Dave's Avatar
Oddometer: 5,786
Probably put 4,000 or more miles of 75 to 90 MPH (true, not indicated) on my DR650 and the Shinko 705's I have on there now before I resigned from the job that required that commute.
I have a 705 on the rear of my home-built adventure bike (Ninja 500) and that's been to 100 MPH a few times, and did the +1000 trips of highway miles (mostly, with some dirt) just fine.
Now that's not 100 MPH, but I don't think I've ever seen a GS tooling along at 100... ever... either.
Old 01-08-2013, 07:45 PM   #72614
procycle
procycle's Avatar
Oddometer: 2,402
OK, you can't mention that without being ready to throw out some pix...
Old 01-08-2013, 07:59 PM   #72615
Adv Grifter
Oddometer: 6,128
Regards,
Derek
This was a friends bike. But yes, he had an extended fuel screw. I adjusted it IN until it stumbled, then out a half turn ... it was set about one turn out. But the rich stumble with choke on persisted and would start with NO choke when stone cold. Once Pilot jet was changed back to stock I went a tiny bit richer on the fuel screw and all was well.
Times are GMT -7.   It's 05:37 AM.
