01-04-2013, 01:00 PM
#72631 | |
Butler Maps
Oddometer: 14,458
modern FI components can work dead reliably and be found on "simple" bikes like the XT250 and the TU250. a properly tuned FI on a bike can be a mostly set it and forget thing and provide proper fueling at every elevation. except for the occasional FI body sync (you'd do this with carbs too) 650 Vstroms run day in day out on FI. we've all been driving FI cars forever and not worrying about if the FI will crap out. that being said I think there are plenty to would love to have all the FI advantages and still have that same reliable base-stock DR bike under them. MXRob has proven FI can work extremely well on a DR. If there was a 5 to 6 bill true PnP bolt on kit people would buy it. read the reports. everyone with a TR650 or a WR250R or a CRF250L or a 500EXC is never looking to go backwards to a carb...nor are the MX guys racing on the track. They've fully embraced it because yes it works. If Suzuki re-released the DR with FI (like Yamaha did with XT250) i'd upgrade.
Butler Maps - motorcycle maps for riders by riders - Ozarks , Nor Cal , COBDR shipping, AZBDR scouting http://www.advrider.com/forums/showthread.php?t=598717 Facebook: http://www.facebook.com/butlermaps |
01-04-2013, 01:04 PM
#72632 | |
Butler Maps
Oddometer: 14,458
where we can tag any motorcycle and have no bike inspections what so ever.
01-04-2013, 01:05 PM
#72633 | |
Butler Maps
Oddometer: 14,458
there are plenty of carb bikes not running right from the factory too.
01-04-2013, 01:16 PM
#72634 | |
Butler Maps
Oddometer: 14,458
if he can tag a dirt bike, the new FI Yamaha WR450F is one hell of an off-road machine if he wants to stay in the Japan INC. fold.
this tank will be in the US soon plus there are smaller options. http://justgastanks.com/product_info...oducts_id=3554 Quote:
01-04-2013, 01:17 PM
#72635 |
Life behind "Bars"
Oddometer: 6,267
But with a carb, I but a couple $4 jets, not $300 software pkg.
1996 DR 650 (a big girl that likes it dirty) 1973 Penton Six-Days (mint) 1971 Suzuki TS185 (needs restoration) 2005 KTM 400exc w/ BajaDesigns D/S light kit |
01-04-2013, 01:38 PM
#72636 | |
on the road o'dreams
Oddometer: 5,397
The Ballast and Ignitor plug together, both derive power from the headlight plug. ... that's it, No relay required. But if you have one already wired in ... leave it. But to me, just one more thing to worry about and have to check to see if a solder joint cracked or plug broke. I'm no fan of wires running all over my bike. Been there, done that with a former BMW R100RS I owned that had every accessory known to man on it. ... and guess who had to trouble shoot it many times at night crossing from New York to California? I made it work but with some difficulty. Wires were run from tail light to headlight, fuse blocks, Relays ... they all had issues after 75,000 hard miles. Luckily, for the most part the elec work was done by Pros so color coding and method were correct and not impossible to diagnose. |
01-04-2013, 02:52 PM
#72637 | |
Butler Maps
Oddometer: 14,458
the Ecotrons ECU, i believe, has the ability to connect to a computer and adjust the fuel metering like other bikes. a pnp DR kit would of course have all the fueling fined tuned and perfected before it goes out the door. those that have tuned fueling with a computer via simply plugging in a usb (and changing up to new maps or fine-tuning existing ones) say it's a huge revelation compared pulling carbs and trying different jet combos and working on getting it right. i'm sure people lamented points going away but no one would say nowadays they'd love toss their electronics to go back to points. i'd say FI is the future, but it's not really new by any stretch, and is here to stay.
01-04-2013, 03:05 PM
#72638 | |
Butler Maps
Oddometer: 14,458
I agree with added electrical parts to bikes. the more you add, the more things can get wonky over time. it's been on my bike for years with no issues and does help providing stronger juice for my regular H4 bulb.
i always knew if i lost lights (both hi & low) i could always plug straight back into the stock harness and get power back that way in a flash after 1st checking the relay fuse to confirm it's not that. of course with a dual filament H4 bulb it's easy to tell if you have a bulb/filament issue, the other filament still burns so it's just a bulb replacement. what about HID lo only kit light failures? I think the bulbs are more robust (the DR is a vibey thumper after all), but do you start with bulb replacement and see what happens? does the ballast/ignitor have any lights on it that says it's still ok? at this price point I know were talking about Chinese components so that's why i'm asking. any know about HID hi/lo bulbs? are they total fail system or can 1 side, hi or lo still work? Quote:
01-04-2013, 03:13 PM
#72639 | ||
Oddometer: 2,565
01-04-2013, 03:14 PM
#72640 |
Butler Maps
Oddometer: 14,458
Just wondering, has any done a HIR bulb (w/ the notch mod to fit H4) and used it an the DR housing? or something like this http://www.lightbulbs4cars.com/product/HIRH4 with an H4 base but with low only? you of course are the 40w the opposite direction of the 35w HID kit.
01-04-2013, 03:22 PM
#72641 |
Butler Maps
Oddometer: 14,458
thanks.
i did read that and should have taken that as him saying it's a single bulb housing so when it fails it the whole thing fails. it's easy enough to bring or find an H4 bulb when on the road, so if something fails with HID, you can always pop back in a H4 and plug back in the wiring harness plug and you're back to stock.
01-04-2013, 08:39 PM
#72642 | |
Oddometer: 1,662
http://www.advrider.com/forums/showp...&postcount=379 |
01-04-2013, 08:59 PM
#72643 |
Oddometer: 756
cold running
I frequently ride in cold temps (as long as the roads are dry). Recently I set a new record for myself.
![]() When it's in the 30's and 40's *F, I find it takes the DR (w/ stock BST carb) about 3-4 minutes warming up in the driveway and another 6-8 minutes of easy running on the road to fully warm up and run smoothly. In the 20's it takes a bit longer and really runs pretty rough at lower rpms for 10-15 minutes. In the low 20's I usually velcro a piece of cardboard in front of the oil cooler screen guard to block some of the direct air flow. A few days ago, I rode out at midday when the temps were in the 30's and stayed out longer than I expected. When I started home from Denver in the dark it was about 20* and by the time I got to my house in the mountains it was just 3*. Brrrrrrrrr. I found the DR with the cardboard wind blocker in place would run ok at mid rpms but it never really warmed up at all and when I pulled away from stop signs, etc. I really had to give it a lot of gas and slip the clutch to keep it running. Questions: 1.How bad was that ride for my motor? (Synthetic 10 W 40) 2. Is this cold running problem typical for a carbureted motor? 3. Should I velcro the cardboard directly touching the oil radiator itself instead of leaving the air space between the guard and the radiator open? 4. As the day warms up, at what temp do you think I should be wary of using anything to block the cooler? 5. How would I know if the bike was overheating due to blocking off the cooler? All opinions welcome. Thanks......................shu |
01-04-2013, 09:55 PM
#72644 | |
Oddometer: 144
Not to mention the thousands of dollars saved in not buying new will fund months of actual riding for me in South America. To each his own, and I realize not everyone has mechanical abilities, experience, tools, or a place to work on their bikes, but I would never buy a new Japanese bike simply for a warranty. |
01-04-2013, 10:01 PM
#72645 |
Asperger
Oddometer: 2,054
I bought new, but it wasn't for the warranty. It was because they are scarce (reasonably priced) around here. Typically they have farkles I don't want, so I'd be spending farkle money anyway. Also, mileage is time owned, for me. The mileage on most used bikes is a couple or more years of ownership, sometimes it's more than several years of ownership.
http://breakingbooks.wordpress.com http://www.kenmarshallmetalworks.com/ 2011 DR650, Fly Aero tapered bars, Race Tech front springs/emulators, RT rear spring/shock shaft assy, BarkBusters, MT21s, 14/43T, etc I may not be Rainman, but I'm not stupid eighter. Like Bartek on a taco. |
