Old 01-09-2013, 08:07 PM   #72676
GSF1200S
Oddometer: 976
Originally Posted by Thumper Dan View Post
I'm slowly upgrading my DR for touring and i'm at the stage of getting a rear duffle bag. But i'm not sure to get a 40 litre or a 60 litre.
I would need to put into this bag: tent, sleeping bag, mattress (small) camping pillow , bike cover and some other odds and ends i'm sure will creep into it as well. I'm feeling a 60 litre bag should be a better size but I don't want it too bulky for the back of the bike.
I already have wolfman expedition bags but one side would be for clothes and the other will be for food and cooking utensils.
I've been looking at these on ebay: http://www.ebay.com.au/itm/OVERBOARD...#ht_3141wt_906
thanks -
I would go with the 60 litre and strap down. That said, you might consider strapping the tent behind the main duffel if your rack is big enough (I have a manracks BBQ rack, so it does for me). I have a thin and basically weightless rolltop bag from academy sporting goods to fit the tent into. That will give you more room in the duffel. Hell, I think I'm going to get a larger duffel and try to get my entire Alaska load in it. I pack very light, and my tools would be in a fender bag. My cameras and phone in my gl tankbag.
GSF1200S is offline   Reply With Quote
Old 01-09-2013, 08:14 PM   #72677
procycle
procycle's Avatar
Oddometer: 2,252
Originally Posted by motolab View Post
The validity of these statements depends upon whether the hesitation is in the 1/16-1/8 or the 1/4 opening range.
No. My statements are valid because this is the experience DR650 owners have when they decide to increase the pilot jet size (which was probably a quick easy fix on their last motorcycle). Instead of solving the hesitation they get a rich bog. My point is that using the pilot jet to try to cure the DR650 off idle leanness is running down the wrong path.
My statement is specific to the DR650 not a general observation about motorcycle carburetion and based on reading forum posts here and elsewhere regarding what actual owners have done to their actual bikes.
Clarke's second law of Egodynamics: "For every expert, there is an equal and opposite expert." - Jasper Fforde
www.procycle.us - Everything for your DR650 and lots of other great stuff!
DR900 Big Bore Stroker buildup
TurboDiesel Corvette - go to the end to start at the beginning
procycle screwed with this post 01-09-2013 at 08:51 PM
procycle is offline   Reply With Quote
Old 01-09-2013, 08:14 PM   #72678
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 7,139
Originally Posted by procycle View Post
Yes, yes, but you may be the only DR owner who has done that. Most expect a bigger pilot jet will cure a lean hesitation which is actually due to the needle. They end up with a rich bog off idle followed by the same lean hesitation they started out with.
It's cause I is smart.
NordieBoy is online now   Reply With Quote
Old 01-09-2013, 08:17 PM   #72679
procycle
procycle's Avatar
Oddometer: 2,252
The galling in the middle (that is where the pin runs in the small end of the rod) indicates an oil film failure, which is usually caused by detonation.
And you can be sure there is matching galling in the small end of the rod. Any repair that does not include replacing the connecting rod is going to have limited life/reliability.
Old 01-09-2013, 08:22 PM   #72680
motolab
motolab's Avatar
Oddometer: 2,529
Originally Posted by opium89 View Post
For the record, I did plug the purge port along with the vacuum port on top normally used for the stock petcock.
Is the vacuum port o-ring in place underneath the diaphragm cover?
The only other hoses coming off the carb now are for the breather and there's one other one right below it that isn't attached to anything and runs up under the seat alongside the breather. I am not really sure of it's function.
The smaller one on the right is a float bowl vent.
I am however aware of the fuel screw and it's function, just wanted to be clear to everyone what I was referring to.
Accurate terminology helps with clarity. Inaccurate, not so much.
I will also take a very close look around the airbox and maybe go as far as to remove it and the air boot and makes sure there are no leaky-leaks anywhere.
Vacuum leaks will generally be on the downstream side of the butterfly, which the airbox and airbox boot don't really have anything to do with. What method have you been using to detect leaks?
My initial guesswork has evolved around the throttle at 1/8 where the hesitation is taking place. This is really why the talk about the pilot jet has been bothering me.
The high idle and rise in rpm when the fuel screw is opened indicate that the pilot jet is not likely to be at fault, or at least not solely.
Regards,
Derek
motolab is offline   Reply With Quote
Old 01-09-2013, 08:27 PM   #72681
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,540
What? You can't just change the bushing in the small end?
Old 01-09-2013, 08:48 PM   #72682
procycle
procycle's Avatar
Oddometer: 2,252
No. There is no bushing. That's pretty standard for Japanese motorcycles for at least the last 30-40 years. The pin runs directly in the rod.
Old 01-09-2013, 08:51 PM   #72683
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,540
Too bad. My old BSAs, Triumphs and Ducatis had 'em.
Old 01-09-2013, 08:53 PM   #72684
procycle
procycle's Avatar
Oddometer: 2,252
Yeah, and those bushings were good for 10 maybe 20 thousand miles. There's a reason you don't see modern iron built that way anymore.
Old 01-09-2013, 08:54 PM   #72685
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,540
Now that you mention it... I just remembered why I'm out of Vintage bikes. I prefer riding.
Old 01-09-2013, 08:56 PM   #72686
Mongle
Knuckle dragger
Mongle's Avatar
Oddometer: 2,712
But, the end can be re-honed. Chances are it is on the small size and anyone who actually does rods wouldn't think twice about puting .0002-.0003" more clearance on the pin. And it will not hurt the life of the rod. It is a common and proven practice.
I don't own a $15,000 rod machine because reconditioning rods reduces "life/reliability". Matter of fact every NEW rod we get gets honed to our specifications- We have NEVER had a rod or pin failure in 20 years. I think that should count for something.
And wouldn't say that is from detonation until I actually measured it. Detonation does cause galling, but not normally there. It usually causes the hole to oblong in the up/down area.
Mongle is offline   Reply With Quote
Old 01-09-2013, 08:57 PM   #72687
Mongle
Knuckle dragger
Mongle's Avatar
Oddometer: 2,712
Once again wrong. MOST modern cars have bronze bushing rods now: Chevy LS motors, Ford Modular motors, Honda motors to name a few...
And in motorcycles the gsxrs, and busas.
Try again.
Mongle screwed with this post 01-09-2013 at 09:34 PM
Old 01-09-2013, 09:06 PM   #72688
opium89
opium89's Avatar
Oddometer: 1,136
Yep, and it's new.
Thank you for clarifying.
Vacuum leaks will generally be on the downstream side of the butterfly, which the airbox and airbox boot don't really have anything to do. What method have you been using to detect leaks?
Agreed. In my days as an auto mechanic, I used to spray brake cleaner around the suspect area(s). Temporary idle up generally is indicative of a leak. I will take a closer look at and around the top cap.
Agreed.
Tea parties are for little girls with imaginary friends.
opium89 is offline   Reply With Quote
Old 01-09-2013, 09:10 PM   #72689
gofast1320
gofast1320's Avatar
Oddometer: 713
jacked up petcock
May have been some funk in the carb needle seat. I changed the petcock out for one off of the OEM tank. Filled it with fuel and it did not leak. Hooked up the hoses and cranked it and started it up. Rode it around in the woods 2 miles and then back and forth up and down the driveway getting it up to 50 and backing off, then going again. Its running fine and no gas is running out of it. Thanks for all the tips and advice.Thinking about taking the carb off and rebuilding it makes me sick to my stomach.
As it is not possible for the carb to overflow without fuel getting past the float valve, leaving the petcock in the PRI position cannot be the sole cause.
Regards,
Derek
gofast1320 is offline   Reply With Quote
Old 01-10-2013, 05:00 AM   #72690
deathu
deathu's Avatar
Oddometer: 77
Thanks! Wouldn't detonation leave other visible traces/marks as well? Also I don't know, what could possibly cause detonation in such a low compression engine?
Guys, this sounds very bad. Getting the rod out of the engine to have anything done to it would be major PITA for me, I really wasn't planning on splitting the crankcase (plus I don't have the special tools for this job).
I for sure will check how the small end looks, as soon as I have a chance.
Mongle, you mean even being given brand new stock rod, piston and pin, you would re-hone them to alter the stock clearances between the new items?
deathu is offline   Reply With Quote
Times are GMT -7.   It's 02:41 AM.
