01-06-2013, 07:08 PM
#72706 |
Dual Sport Addict
Oddometer: 987
An interesting aside on the extended fuel screw in my write up. It is out of a spare TM 33 pumper for my DR350. I looked at it pretty carefully before installing it because I had no idea if it would work or not. It visually matched the stock screws taper and length. Its been in there a couple thousand miles now and I havent had to adjust it after getting it set. I even used my OEM spring and o-ring as they were brand new.
2011 DirtRoad650 http://i838.photobucket.com/albums/z...mping12182.jpg '98 DR 350 http://i838.photobucket.com/albums/z...t/Photo280.jpg '99 DR 650. Sold. |
01-06-2013, 08:28 PM
#72707 |
Oddometer: 487
Davis53 and Procycle- Thanks, I thought I'd previously seen something about that but did not remember the particulars. I'll check it out. Two more tanks came with the bike- One (the OEM) only had one tank of fuel put through it before PO bought a yellow one and put it on it. I just noticed the OEM does have a petcock on it.
Motolab, Where is gas coming from? Have not had an opportunity to "Really" look at it and figure it out- its been bad cold and I haven't wanted to mess with it outside, which is where the leaking fuel is making the bike sit. I've had numerous folks tell me that it may be running into the crankcase but according to the sight glass on the side of the crankcase there has been no rise in the level of oil/fluid in the crankcase. |
01-06-2013, 09:51 PM
#72708 | |
Oddometer: 271
Not a DR yarn but good. In New York City. Few years ago read in Airhead magazine that a guy with a /2 was riding to work and back in freezing weather. Bike would start good in am as was in his garage. Starting, later in the day to go home was a bitch, most times getting a push. One day he was passing by outside of the building and felt warm air. Well he worked on the stage for Julia Childs TV show and that was the vent to the outside. Next day when he got to work he parked in front of the vent and when he went to go home his bike was warm. Started right up. Kept parking there all during taping. A little twist to the story is one day he met some friends and the were all asking what smelled so good? Seems that all of the air and now his bike was loaded with Julias cooking! He said he had the worlds BEST smelling bike. Heirhead |
01-06-2013, 09:56 PM
#72709 |
Oddometer: 2,534
Your oil level NOT rising is a good sign. Although there is room for anything to fail, it's much more llikely that I'll forget to turn the aftermarket petcock off than it is for the stock petcock to fail. if my stocker does fail, I'll buy another stock one.
2004 DR650: 46,358 miles of ![]() ER70S-2 screwed with this post 01-07-2013 at 05:29 PM Reason: #2200 |
01-07-2013, 12:13 AM
#72710 |
Oddometer: 68
I just have to put the new grips on (Renthal dual compound, half waffle), but I have a few n00b questions:
1. I don't use grip glue. I use oil. The grip is made of rubber and the oil means you can slide the grip on and then the rubber absorbs the oil and it's on there solid. Never had to lockwire a grip in my life. 2. Once the grips are on use a rubber mallet on the end of the bar and the bar will punch through the grip like a cookie cutter. 3. I would think the waffle bit lines up with your palm. |
01-07-2013, 02:39 AM
#72711 | |
Oddometer: 3,497
Be sure to check your air box and filter.
Sarah Quote:
'08 DR650 |
01-07-2013, 11:28 AM
#72712 | |
Armature speller
Oddometer: 6,763
01-07-2013, 11:58 AM
#72713 |
Oddometer: 487
DR650 petcock
Went out and eyeballed the sight glass in the sunshine a few minutes ago. No visible bubble in sight glass. SOOOOooooo looks like some fuel may have made it in there. Took spark plugs out and turned motor over and gas shot out of spark plug holes. Off to get some oil as soon as I figure out what oil to get so I can change it and will take petcock off of extra tank that came with bike and see if it works.
01-07-2013, 12:49 PM
#72714 | |
Oddometer: 1,107
Secondarily, the petcock may or may not be at fault as well. The way to check is to disconnect the fuel hose at the petcock and see if fuel exits the hose barb when the lever is in other than the pri position. Regards, Derek motolab screwed with this post 01-07-2013 at 07:36 PM |
01-07-2013, 12:56 PM
#72715 | |
Life behind "Bars"
Oddometer: 6,242
WATCH OUT For SPARKS when turning that motor over.
1996 DR 650 (a big girl that likes it dirty) 1973 Penton Six-Days (mint) 1971 Suzuki TS185 (needs restoration) 2005 KTM 400exc w/ BajaDesigns D/S light kit |
01-07-2013, 03:05 PM
#72716 |
Oddometer: 73
Timing chain wear
Hi everyone,
I recently took the top end and cylinder out of my 1998 DR650 engine, to replace the leaky base gasket and fix oil burning issues. While I have the top end apart, I thought it's a good time to check for wear on other accessible items. The real mileage of the bike is unknown to me - the odo says 35.000km but who can trust the odo of a bike that was purchased from Italy? Up to this point I did not manage to find any information at all on how to check for the timing chain elongation/stretch, also this does not appear to be covered by the service manual. I suspect the real mileage of the bike may be much higher than indicated, maybe well over 100.000kms. So how does one tell if the timing chain is worn beyond service limit? |
01-07-2013, 04:08 PM
#72717 |
Oddometer: 1,620
I am old and could not bring myself to trust the stock petcock. I replaced it soon after I got the bike with a Pingel Petcock.
I have two hands when I turn off the bike my right hits the kill button, the left the petcock,have never forgotten to turn it off. I have forgotten to turn it on, but then it starts to run out during warmup. Yeah, I know, I know, but, then I have never had a watch that didn't have hands either. My 1500 post @ 72722 |
01-07-2013, 05:25 PM
#72718 |
Oddometer: 487
petcock jacked up and gas in crankcase
Yep, me again. I had seen in another thread that Rotella T synthetic in the blue bottle was pretty good for DRs. I went to the auto parts store to pick up a couple of new plugs and the Rotella T in the blue jug was Rotella T6 do any of you know if they are one and the same. Oh yeah and its 5w-40. I just don't want to jack up my clutch.
Thanks |
01-07-2013, 05:28 PM
#72719 | |
Oddometer: 2,534
![]() I don't even remember how to read an analog watch and I'm almost old. ![]()
01-07-2013, 05:34 PM
#72720 |
Oddometer: 1,107
