Old 01-10-2013, 06:44 PM   #72721
Chill
Chill's Avatar
Oddometer: 321
Originally Posted by stoney4vida View Post
What would be the best adhesive for mounting case armor to my DR ?
Originally Posted by blackcap View Post
silicon
Red silicone. There's a how to HERE
Chill is offline   Reply With Quote
Old 01-10-2013, 06:50 PM   #72722
BergDonk
BergDonk's Avatar
Oddometer: 3,679
Originally Posted by BergDonk View Post
Remove the seat and muffler. Now support the wheel, drop the dogbones and undo the bolt from the bottom of the shock. Now remove the top shock bolt and the shock will come out the right hand side through the frame. On some bikes, I have had to loosen the header, but it doesn't need to be removed. You may also need to raise and lower the swingarm a bit to make some space, for which a second pair of hands is useful. 10 mins max.
Originally Posted by procycle View Post
Huh...! I have always removed the airbox. Never considered that the shock might come out the side...
Originally Posted by poppawheelie View Post
BergDonk, thanks. Good to know. Just took mine off via the airbox removal route. It's now at Cogent. Good to know there's another way to do it. May be usefull if a field repair is ever needed.
Recollecting further, it might also require the removal of the link from the frame. If I'm pulling the shock I always service the bearings and it comes off anyway, so not absolutely sure if it needs to come off, but its only one extra bolt if it does.
shed time IS quality time
BergDonk's DR650 BergDonk's XT1200Z
BergDonk is offline   Reply With Quote
Old 01-10-2013, 07:00 PM   #72723
procycle
procycle's Avatar
Oddometer: 2,366
That's the hardest bolt. If you're going to remove the link from the frame it's easier to take the shock out the bottom.
Clarke's second law of Egodynamics: "For every expert, there is an equal and opposite expert." - Jasper Fforde
www.procycle.us - Everything for your DR650 and lots of other great stuff!
DR900 Big Bore Stroker buildup
TurboDiesel Corvette - go to the end to start at the beginning
procycle is offline   Reply With Quote
Old 01-10-2013, 07:08 PM   #72724
TRAVELGUY
Old Traveler
Oddometer: 663
+1 Have done that several times.
TravelGuy
TRAVELGUY
DL1000 '05 black
DL 650 '06 Red
DR650 '07
TRAVELGUY is offline   Reply With Quote
Old 01-10-2013, 08:12 PM   #72725
pzs
pzs's Avatar
Oddometer: 208
Mixture screw, pilot jet question advice needed
If bike runs best with mixture screw all the way in, is the pilot jet too lean??......powerbomb header, gsx can, opened airbox, Dyno jet kit fitted.
Bike runs well, but it has a very slight hesitation just off idle, and possible very slight surging at very light throttle position.
pzs is offline   Reply With Quote
Old 01-10-2013, 08:24 PM   #72726
13.1
Shaken not Stirred
13.1's Avatar
Oddometer: 389
turning in the mixture screw leans it out at the idle and lower rpms
so, this means the bike is too rich in this area
pull the pilot jet and slip the next size smaller in.
then try adjusting the mixture screw again.
of course, you may even have to go down another size if needed
......of course, with the air spinning the other way as it does down under where you are, I may just have all of this BACKWARDS.
When you have eliminated the impossible
whatever remains however improbable
must be the truth..
13.1 is offline   Reply With Quote
Old 01-10-2013, 08:27 PM   #72727
ER70S-2
ER70S-2's Avatar
Oddometer: 6,659
Originally Posted by shu View Post
Ok, since I'm cheap......... how about if we use your oil temp gauge? Maybe next time you go out you could note the air temp. and tell us how long it takes your oil to get to 200*? That would give me a ball park idea about my warm up time and blocking the oil cooler off as well.
Thanks........shu
A few days ago the conversation was about getting the DR up to operating temps in cooler weather. I got a break in the schedule and a 50* plus day and got these numbers.
Air temp was 52-54*, digital thermo on the handlebars.
For the first 65 miles I had the oil cooler closed off with a piece of cardboard, that thin 2 ply cereal box stuff. Who cares? It was the perfect thickness for sliding behind the mounting screws, no zip ties needed. In answer to an earlier question: This put the cardboard snug to the fins and pretty much stopped all airflow thru the cooler. I'd be completely comfortable with the air flow completely blocked up to 60* ambient, especially running full synthetic. Kommando has said the oil cooler is redundant in any sane riding temps.
Oil temp ran between 205-215 degrees with the usual 10-20* increase when hitting consecutive stop lights. But almost all of the mileage was non-stop county roads 20-55mph.
At 65 miles it occurred to me that without removing the cardboard, I'd have no useful information. So I rode the last 40 miles, cardboard out. Same roads, temps 175-195* and the same 10-20* increase when forced to stop repeatedly.
205 warning:
It's my belief that condensation doesn't burn out of the oil and crankcase unless the oil temp hits boiling (212* at sea level, closer to 200* here in Denver). Then the water turns to steam and cooks out of the oil. So I would be blocking the oil cooler at temps under 60*. Now that I've thought thru this, I'll try running the blocked cooler at higher temps, just to keep the oil warmed up.
It's 3-7/8" wide, 9-5/8" tall, not including the tab on top. Next time I'll be more cool and turn it around so you guys can't see what I eat for breakfast.
2004 DR650: 62,605 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is offline   Reply With Quote
Old 01-10-2013, 08:29 PM   #72728
stoney4vida
Semper Fidelis
stoney4vida's Avatar
Oddometer: 2,168
Thanks for the link
stoney4vida is offline   Reply With Quote
Old 01-10-2013, 08:34 PM   #72729
ER70S-2
ER70S-2's Avatar
Oddometer: 6,659
Do you have an aftermarket mixture screw?
You have a different idle mixture screw. The one pictured a few posts back is the "Kouba" screw which was originally a Keintech product. It has about 2 or 3 additional screw threads which sometimes have difficulty screwing into the 'unused' internal threads in the carburetor. The screw included in the jet kit is a genuine Mikuni part which has a longer shaft which eliminates the occasional problem with the 'virgin threads'. But it does require the longer spring that comes with it.
2013 WR250R
Old 01-11-2013, 04:49 AM   #72730
pzs
pzs's Avatar
Oddometer: 208
I got the kienetic screw, I have a look ad see if there is anymore adj, I doubt it though, it seems to have seated firmly.
Old 01-11-2013, 06:11 AM   #72731
Mongle
Knuckle dragger
Mongle's Avatar
Oddometer: 3,014
You know...some times it is the simple things that make me think "well, shit-that is way easier!". I would have had the mill and welder going trying to make a metal, closable, finned, oil/air deflector model # 2000... or just use a piece of cardboard.
I enjoyed the write up. Good information! Most people understand that oil can get too hot. Many don't realize that it can be too cold as well to perform as it should.
Mongle is offline   Reply With Quote
Old 01-11-2013, 07:14 AM   #72732
Rusty Rocket
Life behind "Bars"
Rusty Rocket's Avatar
Oddometer: 9,343
I remember getting the shock out was easy, but I haven't done it in a long while and would probably confuse it with the KTM which was out more recently, but I am positive that I did it without having to remove the airbox, just can't remember the steps. Gettin' old.
on one side the sign it said "Private Road", but on the other side it didn't say nothin'
2009 DR650
..1972 Penton Six-Days ..1971 Suzuki TS185.. 2005 KTM 400exc
Member of: AMA, NETRA, Blue Ribbon Coalition, CCCofVT, Berkshire TR, CT Ramblers
Rusty Rocket is offline   Reply With Quote
Old 01-11-2013, 10:41 AM   #72733
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 6,128
Hey Mongle ... I'm sure this has been covered a bunch ... but what are ideal oil temps for a bike like our DR650's? I always thought oil temps up around
180F was about right. My old BMW had an oil temp gauge and in Desert heat (over 100F) oil temps would go to 220 ... which I thought was too hot. In temps between about 65F to 85F oil temp stayed around 180F on that old BMW. (it had an oil cooler ... but very tiny)
What do you think? At what point do you add in a card board piece to warm things up? ... And should it be kept in place even after bike is fully warm or just for the first half hour? Cheers!
Old 01-11-2013, 10:55 AM   #72734
trentster
Oddometer: 158
Originally Posted by trentster View Post
I offered $2,500 cash today... he is stuck at $3,000. Here is the Craigs List link to see pic.
http://indianapolis.craigslist.org/mcy/3489277336.html
I would put a center stand, skid plate and windshield on it right away. How much of an improvement are the performance mods he has listed? Thanks!!!
Thanks guys for the feedback on this DR650 value... he is at $3k bottom dollar. I cant see paying more than $2,500 considering I still have another $700 or so in mods to put into it.
trentster is offline   Reply With Quote
Old 01-11-2013, 11:49 AM   #72735
shu
Oddometer: 1,026
205 warning:
Now this is great info. Thanks for that, ER.
That oil cooler really is pretty effective. If I understand your numbers correctly it can drop the oil temp by 30* F or more. I agree with your judgement and I will be keeping my cardboard block on at all temperatures below the low 50's. I think I'll move the cardboard to directly in front of the cooler as you did, instead of on the outside of the guard where I've had mine.
I'm not sure about having to heat all of the oil to 200* to boil the water out . Since it's getting sprayed and churned against some very hot parts of the motor I think it may evaporate before the oil temperature goes that high.
Thanks again.............shu
(I'll buy you a cup of coffee one of these days.)
shu is offline   Reply With Quote
Times are GMT -7.   It's 04:39 AM.
