Old 01-15-2013, 09:19 AM   #72856
motolab
motolab's Avatar
Oddometer: 2,626
Originally Posted by Anklyne View Post
Previously the bike seemed to labour when giving it throttle while cruising, which I had just put down to the BST carb.
It is likely to either be dirty, have worn out/damaged parts, or was/is just not jetted correctly.
Regards,
Derek
motolab is offline   Reply With Quote
Old 01-15-2013, 09:21 AM   #72857
motolab
motolab's Avatar
Oddometer: 2,626
Originally Posted by Rusty Rocket View Post
Try laying the bike on it's side for 10 seconds, pick it up and see if it starts. If so, I suspect it is the float assy o-rings. That was my trouble twice in 7 years of owning mine. (so far)
parts 15 & 16:
http://www.ronayers.com/Fiche/TypeID...oup/CARBURETOR
Do you still have the vacuum operated petcock in place?
Regards,
Derek
Old 01-15-2013, 09:40 AM   #72858
Rusty Rocket
Life behind "Bars"
Rusty Rocket's Avatar
Oddometer: 9,274
Regards,
Derek
Raptor Petcock on my bike
on one side the sign it said "Private Road", but on the other side it didn't say nothin'
2009 DR650
..1972 Penton Six-Days ..1971 Suzuki TS185.. 2005 KTM 400exc
Member of: AMA, NETRA, Blue Ribbon Coalition, CCCofVT, Berkshire TR, CT Ramblers
Rusty Rocket is offline   Reply With Quote
Old 01-15-2013, 10:02 AM   #72859
motolab
motolab's Avatar
Oddometer: 2,626
During the laying the bike on its side procedure, do you turn the petcock off?
Regards,
Derek
Old 01-15-2013, 10:59 AM   #72860
neo1piv014
ADV in training
Oddometer: 619
Searching this thread for "clip position" didn't seem to yield anything on the first several pages, so I thought I'd ask.
I just got the non-USA OEM needle and clip for my carb after having a bent needle from the PO, and I'm not sure what clip position to use. So here's the basic run down of my bike:
- Lives around 5000 ft above sea level
- Airbox mod
- Stock exhaust
- K&N air filter
- 12000 miles (for whatever that matters).
Anyone else running a similar setup that can tell me what clip position and possibly jet size that I should be using? I'm not a tuner in any way, and I don't have access to a professionally setup DR650, so I'm not sure what all I should be looking for.
_________________________
Ride videos
'01 DR650
"The impossible often has a kind of integrity which the merely improbable lacks."
neo1piv014 is offline   Reply With Quote
Old 01-15-2013, 11:22 AM   #72861
motolab
motolab's Avatar
Oddometer: 2,626
- Airbox mod
- Stock exhaust
- K&N air filter
The standard clip position is in the 3rd groove.
Correspondences on CV carbs:
Low rpm all throttle positions: float height, needle base diameter, emulsion tube outlet size
WOT operation overall: main jet
WOT operation between HP peak and red line: main air corrector
WOT operation below red line: jet needle shape
1/4 throttle opening: jet needle clip position
1/8 throttle opening: pilot jet size
1/16 throttle opening: pilot jet size
idle: mixture screw adjustment
Put some tape on the throttle housing and the edge of the grip. Mark zero throttle with a sharpie. This is best done with the engine idling, so you can tell when the slack in the cable has just been taken up. Turn off the engine and mark wide open. Now take a tape measure (metric works best in my opinion) and measure the length of the arc. Put a mark at the mid point. Duplicate this procedure to mark the mid-point between here and zero throttle opening to get 1/4 open. Repeat for 1/8 and 1/16 openings. Don't have an accident trying to look at the marks while riding. If you do, I'm not responsible!
Tune from the top down, i.e. get the right main jet in it for proper wide open throttle operation, then set the needle clip position for correct operation at 1/4 opening, then install the correct pilot jet for proper operation at 1/16-1/8 opening. Readjust the idle mixture after every jetting change. Without the ability to dyno with 5-gas analysis, I would go progressively leaner until there was just the very beginning of a discernible misbehavior. On the main jet, I would then go 2-3 sizes richer. On the needle clip, I would then adjust 1-2 positions richer. On the pilot jet, I would install 1-2 sizes larger. Please do bear in mind that if you have high compression, poor exhaust flow, low octane fuel, and/or ignition timing that is either correct or overadvanced for the correct mixture, tuning via this method could cause detonation and therefore engine damage.
Regards,
Derek
Old 01-15-2013, 12:11 PM   #72862
dopra
dopra's Avatar
Oddometer: 197
Hello DR riders, I bought DR650SE, and I will do some changes, if You like You can see what I do :)
http://www.advrider.com/forums/showthread.php?t=855584
dopra is offline   Reply With Quote
Old 01-15-2013, 01:37 PM   #72863
ER70S-2
ER70S-2's Avatar
Oddometer: 6,464
Hi Dopra:
Welcome from USA and I'll be following along on your rebuild thread.
2004 DR650: 62,605 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is online now   Reply With Quote
Old 01-15-2013, 01:58 PM   #72864
Rusty Rocket
Life behind "Bars"
Oddometer: 9,274
Regards,
Derek
Yes
2009 DR650
Old 01-15-2013, 02:18 PM   #72865
motolab
motolab's Avatar
Oddometer: 2,626
Yes
Good to point out. Otherwise, if the petcock is in the pri position (for a stock petcock), or in the on position (for the Raptor petcock), laying the bike on its side will simply mean a bunch of fuel on the ground (the float valve won't close very well with the bike on its side).
Regards,
Derek
Old 01-15-2013, 04:45 PM   #72866
procycle
procycle's Avatar
Oddometer: 2,308
I just got the non-USA OEM needle and clip for my carb...
- Airbox mod...
I don't think anyone has successfully used an OEM needle (USA or otherwise) with a fully modified airbox (top cut out).
A de-snorkeled airbox - yes, an airbox with the top cut out - no.
Clarke's second law of Egodynamics: "For every expert, there is an equal and opposite expert." - Jasper Fforde
www.procycle.us - Everything for your DR650 and lots of other great stuff!
DR900 Big Bore Stroker buildup
TurboDiesel Corvette - go to the end to start at the beginning
procycle is offline   Reply With Quote
Old 01-16-2013, 03:14 AM   #72867
Anklyne
Anklyne's Avatar
Oddometer: 87
Regards,
Derek
Thanks for the tip.
It has a Procycle extended idle mixture screw, but apart from that, I don't believe the carby has been messed with (as I said, the airbox is unmodifed). That said, I'll pull it apart and give it a clean, inspect all the bits for wear and take note of the jetting.
Cheers.
Anklyne is offline   Reply With Quote
Old 01-16-2013, 07:25 AM   #72868
sin3kal
lurker
sin3kal's Avatar
Oddometer: 2
Not sure if this is the right place for this question but wasn't getting too much love on the DDR site since my bike is a pre 96. Anywho, I have a 93 dr650 that broke the knuckle that attaches to the kickstart shaft (yup it's one of those bikes). Not much in the way of kickstart levers for this bike specifically related to the dr650 that don't cost an arm, a leg, and a wallet. Was wondering if anyone knew if any of the kickstart levers from a dr250 or 200 have the same spline count and diameter on their mounting knuckles.
fix it till it's broken
sin3kal is offline   Reply With Quote
Old 01-16-2013, 07:27 AM   #72869
Rob.G
Mostly Harmless
Rob.G's Avatar
Oddometer: 2,185
Go here: http://www.advrider.com/forums/showthread.php?t=61568
It's the pre-96 DR650S thread.
Rob
'12 Suzuki V-Strom DL650
'96 Suzuki DR650
'92 Yamaha TW200
Rob.G is offline   Reply With Quote
Old 01-16-2013, 07:28 AM   #72870
jessepitt
Ride More
jessepitt's Avatar
Oddometer: 993
There is a thread devoted to to the pre-96 DR's. Just look through the first couple pages of the thumper menu and you should be able to find it. You will have better luck asking your question in that thread.
Damn! 205 Oh well, I tried.
jessepitt is offline   Reply With Quote
Times are GMT -7.   It's 06:00 PM.
